commit f83f71fda27650ae43558633be93652577dbc38c upstream.
With 16-bit RGB565 colour format pixels are stored by the device in memory
in the following order:
| b3 | b2 | b1 | b0 |
| R5 G6 B5 | R5 G6 B5 |
This corresponds to V4L2_PIX_FMT_RGB565 fourcc, not V4L2_PIX_FMT_RGB565X.
This change is required to avoid trouble when setting up video pipeline
with the s5p-tv devices, so the colour formats at both devices can be
properly matched.
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
Change-Id: I192b2a0d9c24c2906af52aa69c7c386b9c505a82
Reviewed-on: http://git-master/r/74188
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Tested-by: Varun Wadekar <vwadekar@nvidia.com>
Standardize the remaining video drivers to return the API version
for the VIDIOC_QUERYCAP version, instead of a per-driver version.
Those drivers had the version updated more recently or are SoC
drivers. Even so, it doesn't sound a good idea to keep a per-driver
version control, so, let's use the per-subsystem version control
instead.
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
With multi-planar formats fmt.pix_mp member of struct v4l2_format
should be used rather than fmt.pix. Fix find_fmt() function to do
the right thing.
The buf_init buffer queue operation is optional and
buffer_init() does nothing, remove it.
Avoid dereferencing of NULL f->fmt. Correct size of the allocated
buffer in case the crop rectangle is smaller than the bounds
rectangle (configured with S_FMT). Also remove redundant check
for *num_buffer == 0 as this case is handled in videobuf2.
Correct inconsistencies in data structures' documentation.
Remove meaningless debug traces.
Remove V4L2_MBUS_FMT_RGB565_2X8_BE media code entry as
camera interface supports only packed YUYV formats.
Add missing kfree on the error path.
Reported-by: Tomasz Stanislawski <t.stanislaws@samsung.com>
Add the subdev driver for the MIPI CSIS units available in S5P and
Exynos4 SoC series. This driver supports both CSIS0 and CSIS1
MIPI-CSI2 receivers.
The driver requires Runtime PM to be enabled for proper operation.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (42 commits)
[media] media: vb2: correct queue initialization order
[media] media: vb2: fix incorrect v4l2_buffer->flags handling
[media] s5p-fimc: Add support for the buffer timestamps and sequence
[media] s5p-fimc: Fix bytesperline and plane payload setup
[media] s5p-fimc: Do not allow changing format after REQBUFS
[media] s5p-fimc: Fix FIMC3 pixel limits on Exynos4
[media] tda18271: update tda18271c2_rf_cal as per NXP's rev.04 datasheet
[media] tda18271: update tda18271_rf_band as per NXP's rev.04 datasheet
[media] tda18271: fix bad calculation of main post divider byte
[media] tda18271: prog_cal and prog_tab variables should be s32, not u8
[media] tda18271: fix calculation bug in tda18271_rf_tracking_filters_init
[media] omap3isp: queue: Don't corrupt buf->npages when get_user_pages() fails
[media] v4l: Don't register media entities for subdev device nodes
[media] omap3isp: Don't increment node entity use count when poweron fails
[media] omap3isp: lane shifter support
[media] omap3isp: ccdc: support Y10/12, 8-bit bayer fmts
[media] media: add missing 8-bit bayer formats and Y12
[media] v4l: add V4L2_PIX_FMT_Y12 format
cx23885: Fix stv0367 Kconfig dependency
[media] omap3isp: Use isp xclk defines
Fix up trivial conflict (spelink errurs) in drivers/media/video/omap3isp/isp.c
Add support for buffer timestamps and the sequence number in
the video capture driver.
Make sure the sizeimage for 3-planar color formats is
width * height * 3/2 and the bytesperline is same for each
plane in case of a multi-planar format.
Protecting the color format with vb2_is_streaming() is not sufficient
as this prevents changing the format only after VIDIOC_STREAMON.
To prevent the color format reconfiguration as soon as buffers
are allocated use vb2_is_busy() instead.
Also make the videobuf queue ops structure static.
Correct pixel limits for the fourth FIMC entity on Exynos4 SoCs.
FIMC3 only supports the writeback input from the LCD mixer.
Also rename s5pv310 variant to exynos4 which is needed after
renaming s5pv310 series to Exynos4.
Use pix_mp member of struct v4l2_format to return a format
description rather than pix. Also fill in the plane_fmt array.
This is a missing bit of conversion to the multiplanar API.
Use pr_debug instead of printk so it is possible to control
debug traces at runtime.
E.g. to enable debug trace in file fimc-core.c use command:
echo -n 'file fimc-core.c +p' > /sys/kernel/debug/dynamic_debug/control
or
echo -n 'file fimc-core.c -p' > /sys/kernel/debug/dynamic_debug/control
to disable.
Allow the MIPI-CSI data alignment to be defined in the board setup
as it may be different across various camera sensors.
Add num_clients field to struct s5p_fimc_isp_info to define exactly
size of clients array which simplifies a bit the sensors management.
Rework the locking in m2m driver to assure proper operation on SMP systems.
When job_abort or stop_streaming was called to immediately shutdown
a memory-to-memory transaction video buffers scheduled for processing
were never returned to vb2 and v4l2_m2m_job_finish was not called
which led to hanging.
Correct this and also return the unprocessed buffers to vb2 marking
them as erroneous, in case the end of frame interrupt do not occur.
Reported-by: Sewoon Park <seuni.park@samsung.com>
Prevent invalid pointer dereference on error path.
In some cases fimc H/W did not stop although there were no output
buffers available. So the capture deactivation interrupt routine
is modified and the state of ST_CAPT_RUN is cleared only
in the LAST-IRQ call.
After LAST-IRQ is generated, H/W pointer will be skipped by 1 frame.
(reference by user manual) So, S/W pointer should be increased too.
Reviewed-by Jonghun Han <jonghun.han@samsung.com>
Signed-off-by: Sungchun Kang <sungchun.kang@samsung.com>
When is called fimc_stop_capture, it seems that wait_event_timeout
used improperly. It should be wake up by irq handler.
This patch fixes the value of FIFO_CTRL in MSCTRL.
Main-scaler has the value to specify a basis FIFO control of input DMA.
The description of FIFO_CTRL has been changed as below.
0 = FIFO Empty (Next burst transaction is possible when FIFO is empty)
1 = FIFO Full (Next burst transaction is possible except Full FIFO)
Value '1' is recommended to enhance the FIMC operation performance.
Reviewed-by: Jonghun Han <jonghun.han@samsung.com>
Signed-off-by: Hyunwoong Kim <khw0178.kim@samsung.com>
This patch adds callback functions, stop_streaming and job_abort,
to abort or finish any DMA in progress. stop_streaming is called
by videobuf2 framework and job_abort is called by m2m framework.
ST_M2M_PEND state is added to discard the next job.
Horizontal and vertical scaling range are according to the following equations.
If (SRC_Width >= 64 x DST_Width) { Exit(-1); /* Out of Horizontal scale range}
If (SRC_Height >= 64 x DST_Height) { Exit(-1); /* Out of Vertical scale range}
fimc_check_scaler_ratio() is used to check if horizontal and vertical
scale range are valid or not. To use fimc_check_scaler_ratio,
source and destination format should be set by VIDIOC_S_FMT.
And in case of scaling up, it doesn't have to check the scale range.
The main scaler has four SFRs for main scaler ratio depending on FIMC version.
FIMC 4.x has only two SFRs and FIMC 5.x has four SFRs for main scaler.
Those are MainHorRatio, MainHorRatio_ext, MainVerRatio and MainverRatio_ext.
The FIMC 5.x has 15 bit resolution for scaling ratio as below.
{MainHorRatio,MainHorRatio_ext} = {[14:6],[5:0]}.
{MainVerRatio,MainVerRatio_ext} = {[14:6],[5:0]}.
MainHorRatio = CISCCTRL[24:16], MainHorRatio_ext = CIEXTEN[15:10]
MainVerRatio = CISCCTRL[8:0], MainVerRatio_ext = CIEXTEN[5:0]
This patch supports FIMC 4.x and FIMC 5.x using platform_device_id::driver_data.
Some color formats are mismatched in s5p-fimc driver.
CIOCTRL[1:0], order422_out, should be set 2b'00 not 2b'11
to use V4L2_PIX_FMT_YUYV. Because in V4L2 standard V4L2_PIX_FMT_YUYV means
"start + 0: Y'00 Cb00 Y'01 Cr00 Y'02 Cb01 Y'03 Cr01". According to datasheet
2b'00 is right value for V4L2_PIX_FMT_YUYV.
Manage the camera sensor clock in the host driver rather than
leaving this task for sensor drivers. The clock frequency
must be passed in the sensor's and host driver's platform data.
Map all (0, 90, 180, 270) deg counterclockwise rotation and
horizontal and vertical flip controls to (0, 90) deg rotation,
horizontal and vertical flip transformations available
in the device.
Increase the input DMA "successive burst count" to default
value 4 to improve DMA performance. Minor cleanup.
Prevent VIDIOC_STREAMON failing when s_stream callback is
not implemented by a sensor subdev driver.
Remove bus_width from s5p_fimc_isp_info data structure.
Determine camera data bus width based on mediabus pixel format.
Change s3c_fimc.h header file name to s5p_fimc.h, replace s3c_fimc_*
names with s5p_fimc_*. s3c_fimc need to be reserved for S3C series
and s5p-fimc driver will not cover CAMIF devices in S3C SoC series.
Conversion to multiplanar color formats and minor cleanup.
Porting to videobuf 2 and minor cleanup.
Separate videobuf_queue_ops are are created for m2m
and capture video nodes.
Add missing newlines.
FIMC IP in S5Pv310 series has extended DMA status registers
and some bit fields are marked as reserved comparing to S5PC100/110.
Use correct registers for getting DMA write pointer in each SoC variant
supported by the driver.
Replace V4L2_PIX_FMT_RGB24 code with V4L2_PIX_FMT_RGB32
since the hardware uses 24-bits for actual pixel data but pixels
are 4-byte aligned in memory.
Reported by: Dan Carpenter <error27@gmail.com>
Create separate vidioc_g_crop/vidioc_s_crop handlers for capture
video node and so image cropping parameters are properly queried
at FIMC input (image sensor) and not at FIMC output.
Adapt to recent videobuf_queue_dma_contig_init signature change.
The argument isn't used anymore by the functions, remove it.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
With the v4l2_i2c_new_subdev* functions now supporting loading modules
based on modaliases, replace the hardcoded module name passed to those
functions by NULL in the cafe-ccic, via-camera and s5p-fimc drivers.
All corresponding I2C modules have been checked, and all of them include
a module aliases table with names corresponding to what the drivers
modified here use.
> From: Dan Carpenter [mailto:error27@gmail.com]
> These are signed so instead of being 1 and 0 as intended they are -1 and
> 0. It doesn't cause a bug in the current code but Sparse warns about
> it:
> drivers/media/video/s5p-fimc/fimc-core.h:226:28:
> error: dubious one-bit signed bitfield
> struct fimc_scaler {
> - int scaleup_h:1;
> - int scaleup_v:1;
> - int copy_mode:1;
> - int enabled:1;
> + unsigned int scaleup_h:1;
> + unsigned int caleup_v:1;
> + unsigned int copy_mode:1;
> + unsigned int enabled:1;
In general I agree, however this patch would change scaleup_v:1
to caleup_v, so it cannot be applied in current form.
Here is the corrected patch:
Reported-by: Dan Carpenter <error27@gmail.com<
