path: root/drivers/media/video/saa7110.c
2011-03-21[media] saa7110: use control frameworkHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: saa7110: remove obsolete v4l2-i2c-drv.h headerHans Verkuil
2009-12-05V4L/DVB (13241): Cleanup redundant tests on unsignedRoel Kluin
The variables are unsigned so the test `>= 0' is always true, the `< 0' test always fails. In these cases the other part of the test catches wrapped values. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11380): v4l2-subdev: change s_routing prototypeHans Verkuil
It is no longer needed to use a struct pointer as argument, since v4l2_subdev doesn't require that ioctl-like approach anymore. Instead just pass the input, output and config (new!) arguments directly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11370): v4l2-subdev: move s_std from tuner to core.Hans Verkuil
s_std didn't belong in the tuner ops. Stricly speaking it should be part of the video ops, but it is used by audio and tuner devices as well, so it is more efficient to make it part of the core ops. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10914): v4l2: fix compile warnings when printing u64 value.Hans Verkuil
2009-03-30V4L/DVB (10731): zoran i2c modules: remove i2c autoprobing support.Hans Verkuil
Zoran doesn't do autoprobing anymore, so remove support for this from the i2c modules. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10724): saa7110: convert to v4l2_subdev.Hans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> [mchehab@redhat.com: fix merge conflict with removal of v4l2_ctrl_query_fill_std()] Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10714): zoran et al: convert zoran i2c modules to V4L2.Hans Verkuil
The zoran i2c modules were still using V4L1 internally. Replace this with V4L2. Also deleted saa7111.c and saa7114.c, we use saa7115.c instead. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> [mchehab@redhat.com: fix v4l2_ctrl_query_fill_std merge conflict] Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-11V4L/DVB (9372): Minor fixes to the saa7110 driverJean Delvare
* Apparently the author of the saa7110 driver was confused by the number of outputs returned by DECODER_GET_CAPABILITIES. Of course a decoder chip has no analog ouputs, but it must have at least one digital output. * Fix an off-by-one error when checking the input value of DECODER_SET_INPUT. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-17V4L/DVB (9204): saa7110: convert i2c driver for new i2c APIHans Verkuil
- Convert to use v4l2-i2c-drv-legacy.h to be able to handle the new i2c API - Cleanups - Use v4l_dbg/v4l_info to have uniform kernel messages Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-04-24V4L/DVB (7094): static memoryDouglas Schilling Landgraf
- Static memory is always initialized with 0. - Replaced in some cases C99 comments for /* */ Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-30NULL noise: drivers/mediaAl Viro
Acked-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-20V4L/DVB (5858): Use msecs_to_jiffies instead of HZ on media/video I2C driversMauro Carvalho Chehab
2006-06-25V4L/DVB (4068): Removed all references to kernel stuff from videodev.h and ↵Mauro Carvalho Chehab
videodev2.h The videodev.h and videodev2.h describe the public API for V4L and V4L2. It shouldn't have there any kernel-specific stuff. Those were moved to v4l2-dev.h. This patch removes some uneeded headers and include v4l2-common.h on all V4L driver. This header includes device implementation of V4L2 API provided on v4l2-dev.h as well as V4L2 internal ioctls that provides connections between master driver and its i2c devices. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-25V4L/DVB (3599b): Whitespace cleanups under drivers/mediaMauro Carvalho Chehab
2006-03-23Merge master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: V4L/DVB (3568k): zoran: Use i2c_master_send when possible V4L/DVB (3568j): adv7175: Drop unused encoder dump command V4L/DVB (3568i): adv7175: Drop unused register cache V4L/DVB (3568h): cpia: correct email address V4L/DVB (3568g): sem2mutex: zoran V4L/DVB (3568f): saa7110: Fix array overrun V4L/DVB (3568e): bt856: Spare memory V4L/DVB (3568d): saa7111.c fix V4L/DVB (3568c): zoran: Init cleanups V4L/DVB (3568b): saa7111: Prevent array overrun V4L/DVB (3568a): saa7114: Fix i2c block write
2006-03-23[PATCH] I2C: Drop unneeded i2c-dev.h includesJean Delvare
Several media/video and sound drivers include i2c-dev.h while they don't need it at all. Clean it up. This header file is really only needed by i2c-dev.c and compat_ioctl.c, other drivers should never need it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-23V4L/DVB (3568k): zoran: Use i2c_master_send when possibleJean Delvare
Change all the Zoran (ZR36050/ZR36060) drivers to use i2c_master_send instead of i2c_transfer when possible. This simplifies the code by a few lines in each driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-23V4L/DVB (3568f): saa7110: Fix array overrunJean Delvare
Fix a (probably harmless) array overrun in the DECODER_DUMP command of the saa7110 driver. No big deal as this command is not used anywhere anyway. Also reformat the dump so that it displays nicely. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-05[PATCH] I2C: Remove .owner setting from i2c_driver as it's no longer neededGreg Kroah-Hartman
Now that i2c_add_driver() doesn't need the module owner to be set by hand, we can delete it from the drivers. This patch catches all of the drivers that I found in the current tree (if a driver sets the .owner by hand, it's not a problem, just not needed.) Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Cc: Jean Delvare <khali@linux-fr.org>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 5 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the drivers/media/video and usb/media drivers. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Rework client usage count, 2 of 3Jean Delvare
Make I2C_CLIENT_ALLOW_USE the default for all i2c clients. It doesn't hurt if the usage count is actually never used for any given driver, and allows for nice code simplifications in i2c-core. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-01-05[PATCH] i2c: Drop i2c_driver.flags, 2 of 3Jean Delvare
Just about every i2c chip driver sets the I2C_DF_NOTIFY flag, so we can simply make it the default and drop the flag. If any driver really doesn't want to be notified when i2c adapters are added, that driver can simply omit to set .attach_adapter. This approach is also more robust as it prevents accidental NULL pointer dereferences. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-05[PATCH] hwmon: hwmon vs i2c, second round (01/11)Jean Delvare
Add support for kind-forced addresses to i2c_probe, like i2c_detect has for (essentially) hardware monitoring drivers. Note that this change will slightly increase the size of the drivers using I2C_CLIENT_INSMOD, with no immediate benefit. This is a requirement if we want to merge i2c_probe and i2c_detect though, and seems a reasonable price to pay in comparison with the previous cleanups which saved much more than that (such as the i2c-isa cleanup or the i2c address ranges removal.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-21[PATCH] I2C: Merge unused address lists in some video driversJean Delvare
On top of my previous patch which removes the use of address ranges in video i2c drivers, this one can save an additional few bytes of memory. Most of these drivers which do not use I2C_CLIENT_INSMOD initialize the unused address lists in a less than optimal way. This patch simply optimizes this, by using a single one-element list instead of 3 different lists with two elements each. This saves an average 63 bytes on these drivers. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> diff -ruN linux-2.6.12-rc1-bk5.orig/drivers/media/video/adv7170.c linux-2.6.12-rc1-bk5/drivers/media/video/adv7170.c
2005-06-21[PATCH] I2C: Kill address ranges in non-sensors i2c chip driversJean Delvare
Some months ago, you killed the address ranges mechanism from all sensors i2c chip drivers (both the module parameters and the in-code address lists). I think it was a very good move, as the ranges can easily be replaced by individual addresses, and this allowed for significant cleanups in the i2c core (let alone the impressive size shrink for all these drivers). Unfortunately you did not do the same for non-sensors i2c chip drivers. These need the address ranges even less, so we could get rid of the ranges here as well for another significant i2c core cleanup. Here comes a patch which does just that. Since the process is exactly the same as what you did for the other drivers set already, I did not split this one in parts. A documentation update is included. The change saves 308 bytes in the i2c core, and an average 1382 bytes for chip drivers which use I2C_CLIENT_INSMOD, 126 bytes for those which do not. This change is required if we want to merge the sensors and non-sensors i2c code (and we want to do this). Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Index: gregkh-2.6/Documentation/i2c/writing-clients ===================================================================
