One saa7111 device is reporting a different ID:
saa7115 0-0024: chip found @ 0x48 (ID 0f7111d0e111111) does not match a known saa711x chip.
As this is for sure a saa7111, change the detection code to also
cover this device.
Autodetect input's standard using field frequency detection
feature (FIDT in status byte at 0x1F) of the chips saa7111/
saa7111a/saa7113/saa7114/saa7118.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Now that s_fmt is no longer used for VBI format setup in subdevs, remove
the VBI support from s_fmt.
Only a relatively small number of video receivers and transmitters actually
support VBI. So start moving the vbi specific ops to an ops struct of their
own.
Add the ability to use the v4l2_ctrl_query_fill() function for the newly
introduced chroma gain control.
Also, make use of the centralized function by the one caller.
This work was sponsored by EyeMagnet Limited.
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
Add support for chroma agc and gain to the saa7115 driver. This allows for
users to do manual adjustment for abnormal signal conditions.
This patch enables the anti-alias filter, which was originally enabled for
the saa7113, but the saa7115_init_misc was trampling the value. Without this
patch, there would be visible vertical bands in the chroma.
Thanks to Andy Walls for helping test this change against other ivtv products.
When the saa7111 driver was merged into saa7115 several bugs were introduced,
in particular with the saa7111a support as is used in the mxb.c driver.
This patch fixes the saa7111a support. This was tested with the mxb driver.
It is no longer needed to use a struct pointer as argument, since v4l2_subdev
doesn't require that ioctl-like approach anymore. Instead just pass the input,
output and config (new!) arguments directly.
v4l2_subdev.
With all the v4l2_subdev changes that were made to these drivers it is a
good idea to increase the version number of each driver.
It's just the patch level that is increased, except for the zoran and saa7146
drivers where the minor number was increased due to the more substantial
changes that were made to those two drivers.
s_std didn't belong in the tuner ops. Stricly speaking it should be part of
the video ops, but it is used by audio and tuner devices as well, so it is
more efficient to make it part of the core ops.
All drivers that use saa7115 now use v4l2_subdev, so we can remove the
legacy code from saa7115.
Replace 'VIDIOC_' references in v4l i2c drivers by their new v4l2_subdev
callback names.
Devices like the saa7111 do not have this register, so check for this
before using it.
The v4l2_ctrl_query_fill_std() function wasn't one the best idea I ever had.
It doesn't add anything valuable that cannot be expressed equally well with
v4l2_ctrl_query_fill and only adds overhead.
Replace it with v4l2_ctrl_query_fill() everywhere it is used and remove it
from v4l2_common.c.
A hue of -128 was rejected due to an incorrect range check, which was
faithfully copy-and-pasted into four drivers...
instead of ID.
Since the i2c driver ID will be removed in the near future we have to
modify the v4l2 debugging API to use the driver name instead of driver ID.
Note that this API is not used in applications other than v4l2-dbg.cpp
as it is for debugging and testing only.
Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged
with a warning that it is deprecated and will be removed in 2.6.30.
The service_set field was used in saa7115 and cx25840 to determine
whether raw or sliced VBI was desired. This is incorrect since it is
perfectly valid to select sliced VBI with a service_set of 0.
Instead these drivers should checked on VIDIOC_S_FMT whether the type
field matches the raw or sliced VBI type.
Updated ivtv accordingly.
The saa7111 support in saa7115.c was missing some features and did not
properly take some of the differences into account. With this patch
saa7115 can be used in the mxb driver instead of saa7111.c.
Not a bug as such, but it looks really strange doing this before
checking whether the state structure could be allocated.
autodetect driver name.
Having an _auto suffix is less ambiguous than a 'saa711x' identifier.
It's also used like this in the saa7127 driver.
Thanks to Jean Delvare for suggesting this.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
Also remove some blank lines that were used to split compat code at -devel
tree.
Update all the remaining new-style i2c drivers to use standard module
aliasing instead of the old driver_name/type driver matching scheme.
Note that the tuner driver is a bit quirky at the moment, as it
overwrites i2c_client.name with arbitrary strings. We write "tuner"
back on remove, to make sure that driver cycling will work properly,
but there may still be troublesome corner cases.
Based on earlier work by Jon Smirl and Jochen Friedrich.
This patch allows new-style i2c chip drivers to have alias names using
the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this
point, the old i2c driver binding scheme (driver_name/type) is still
supported.
Cc: Jochen Friedrich <jochen@scram.de>
Cc: Jon Smirl <jonsmirl@gmail.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Fsc 3.58 refers to Combination PAL-N (aka PAL-Nc), not to plain PAL-N (that
uses Fsc 4.43).
- Static memory is always initialized with 0.
- Replaced in some cases C99 comments for /* */
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
If the chip isn't recognized, then the correct errors should be returned.
The v4l2_i2c_attach() utility function will return 0 for all errors
except -ENOMEM to provide proper compatibility support for the old I2C
probing function.
VIDIOC_G_CHIP_IDENT improves debugging of card problems: it can be
used to detect which chips are on the board and based on that information
selected register dumps can be made, making it easy to debug complicated
media chips containing tens or hundreds of registers.
This ioctl replaces the internal VIDIOC_INT_G_CHIP_IDENT ioctl.
The chip matching in struct v4l2_register for VIDIOC_DBG_G/S_REGISTER
was rather primitive. It could not be extended to other busses besides
i2c and it lacked a way to.
When capturing a 60 Hz input the internal field ID is inverted. The
VIDIOC_INT_G_VBI_DATA didn't take that into account and so returned
XDS instead of CC and vice versa.
Before, root privileges were only needed to set hardware registers, not
to read them. On some hardware, reading from the wrong place at the
wrong time can hang the machine. So, to be consistent, root privileges
are required to read registers on all hardware.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
The direct register access ioctls were defined as kernel internal only,
but they are very useful for debugging hardware from userspace and are
used as such. Officially export them.
VIDIOC_INT_[SG]_REGISTER is renamed to VIDIOC_DBG_[SG]_REGISTER
Definition of ioctl and struct v4l2_register is moved from v4l2-common.h
to videodev2.h.
Types used in struct v4l2_register are changed to the userspace
exportable versions (u32 -> __u32, etc).
Use of VIDIOC_DBG_S_REGISTER requires CAP_SYS_ADMIN permission, so move
the check into the video_ioctl2() dispatcher so it doesn't need to be
duplicated in each driver's call-back function. CAP_SYS_ADMIN check is
added to pvrusb2 (which doesn't use video_ioctl2).
Nexus CA needs to use a different routing on saa7115 module.
Signed-off-by: Marco Schluessler <marco@lordzodiac.de>
Remove coding style inconsistencies.
The old code would accept any device on the same i2c address as the
saa711x chips as an saa711x. However, this fails with saa717x chips,
which use that same address and so are misdetected as a saa7111. Now
check whether the chip is really a saa711x model.
Without the attached trivial patch, the saa7113 is set up for PAL when SECAM
is selected and hence will see only show black and white for SECAM signals.
Tested the patch against the saa7115 module in linux-2.6.17 with a
Pinnacle 50e USB tuner (em28xx).
Signed-off-by: Pádraig Brady <P@draigBrady.com>
Also sends the proper saa71111 init table.
This repairs a problem introduced by a commit earlier applied.
Thanks-to: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Mike Isely <isely@pobox.com>
