path: root/drivers/media/video/saa7134/Makefile
2008-04-29V4L/DVB(7767): Move tuners to common/tunersMauro Carvalho Chehab
There were several issues in the past, caused by the hybrid tuner design, since now, the same tuner can be used by drivers/media/dvb and drivers/media/video. Kconfig items were rearranged, to split V4L/DVB core from their drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6623): remove saa7134-ossAdrian Bunk
The saa7134-oss is deprecated for quite some time, it's the only remaining OSS user outside of sound/oss/, and considering how few and what kind of soundcards are left supported by OSS I hardly see any use cases left. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5166): Remove obsolete alias defines of CONFIG_* settingsTrent Piepho
The out of tree v4l-dvb build system didn't always override the kernel's configuration settings with v4l-dvb's settings correctly. To work around this, makefiles would define some new macro based on the setting of a config variable. e.g. the pwc Makefile would define CONFIG_PWC_DEBUG if CONFIG_USB_PWC_DEBUG (which is defined via Kconfig) was set. The v4l-dvb build system should now always override correctly, and this is no longer necessary. This patch gets ride of these extra defines and just uses the CONFIG_* settings directly. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4388): Remove frontend selection from cx88/saa7134 driversAndrew de Quincey
Replaced with dvb_attach() Signed-off-by: Andrew de Quincey <adq_dvb@lidskialf.net> Acked-by: Michael Krufky <mkrufky@linuxtv.org> Acked-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-04-04kbuild: fix unneeded rebuilds in drivers/media/video after moving source treeCarl-Daniel Hailfinger
This fixes some uneeded rebuilds under drivers/media/video after moving the source tree. The makefiles used $(src) and $(srctree) for include paths, which is unnecessary. Changed to use relative paths. Compile tested, produces byte-identical code to the previous makefiles. Signed-off-by: Carl-Daniel Hailfinger <c-d.hailfinger.devel.2006@gmx.net> Signed-off-by: Sam Ravnborg <sam@ravnborg.org>
2005-12-22V4L/DVB (3200): Fix saa7134 ALSA/OSS collisionsRicardo Cerqueira
- When ALSA or OSS are loaded, check if the other is present Fixed hotplug notifiers cleanup on module removal - The saa7134 DMA sound modules now have their own Kconfig entries, and if built statically enforce exclusivity - SND_PCM_OSS isn't necessary for the OSS driver Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2005-11-28[PATCH] fix broken hybrid v4l-dvb frontend selectionMichael Krufky
Repair broken build configuration for hybrid v4l/dvb card frontend selection. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] v4l: (951) Make saa7134-oss as a stand-alone moduleRicardo Cerqueira
- saa7134-oss is now a standalone module as well - remaining DMA sound code has been removed from core the module - Lots of small cleanups and variable renames to get more consistency between the OSS and ALSA drivers - Fixed saa7134-alsa spinlock bug - Added missing #include in saa7134-oss Signed-off-by: Ricardo Cerqueira <v4l@cerqueira.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] V4L: SAA7134 alsa build fixMauro Carvalho Chehab
Fixes saa7134-alsa build inside saa7134 driver. Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 870: added dvb support for avermedia avertvhd mce a180Michael Krufky
- Added DVB support for AVerMedia AVerTVHD MCE A180 Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] v4l: 773: be sure to enable video buf dvb in kernel buildMichael Krufky
- Be sure to enable video-buf-dvb in kernel build. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] v4l: hybrid dvb: rename CFLAGS from CONFIG_DVB_xxxx back to original ↵Michael Krufky
HAVE_xxxx The #define CONFIG_DVB_* are actually CFLAGS set by Makefile. CONFIG_* namespace is reserved for Kconfig. This renames them back to HAVE_* Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] v4l: hybrid dvb: move #defines to MakefileMichael Krufky
This patch moves #define from cx88-dvb.c and saa7134-dvb.c into Makefile as CFLAGS, allowing code compatability with video4linux cvs. Signed-off-by: Michael Krufky <mkrufky@m1k.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
