Reported by, and based on a patch from, Martin Dauskardt.
The AUDIO_AC3_BITRATE control is still missing from this list, but such
optional controls are a bit hard to handle. This will be fixed automatically
when we switch to the control framework.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Reported-by: Martin Dauskardt <martin.dauskardt@gmx.de>
This patch converts the remaining users of flush_scheduled_work() in
media/video.
* bttv-input.c and cx23885-input.c don't use workqueue at all. No
need to flush.
* Make omap24xxcam.c and saa7134-empress.c flush the used work
directly.
* In fd_defio.c, replace cancel_delayed_work() +
flush_scheduled_work() with cancel_delayed_work_sync(). While at
it, replace the deprecated cancel_rearming_delayed_work() with
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
The big kernel lock has been removed from all these files at some point,
leaving only the #include.
Remove this too as a cleanup.
Add an ext_lock argument to the videobuf init functions. This allows
drivers to pass the vdev->lock pointer (or any other externally held lock)
to videobuf. For now all drivers just pass NULL.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
An earlier commit removed the lock_kernel/unlock_kernel pair but forgot
to remove the unlock_kernel call in the cleanup path at the end of the
function.
Now that the video_device registration is tested using
video_is_registered(), drivers don't need to initialize the
video_device::minor field to -1 anymore.
Remove those unneeded assignments.
[mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging]
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Instead of using the minor number in kernel log messages, use the device
node name as returned by the video_device_node_name() function. This
makes debug, informational and error messages easier to understand for
end users.
Fix all device drivers to use the video_drvdata function instead of
maintaining a local list of minor to private data mappings. Call
video_set_drvdata to register the driver private pointer when not
already done.
Where applicable, the local list of mappings is completely removed when
it becomes unused.
Fix all device drivers to use the new video_device_node_name function.
This also strips kernel log messages from the "/dev/" prefix, has the device
node location is a userspace policy decision unknown to the kernel.
* Remove smp_lock.h from files which don't need it (including some headers!)
* Add smp_lock.h to files which do need it
* Make smp_lock.h include conditional in hardirq.h
It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT
This will make hardirq.h inclusion cheaper for every PREEMPT=n config
(which includes allmodconfig/allyesconfig, BTW)
1. Add start/stop TS function.
2. Move setup DMA of TS to DMA function.
3. Write support cupture via MMAP
4. Rework startup and finish process, remove simple FSM.
Tested-by: Hermann Pitton <hermann-pitton@arcor.de>
Tested-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com>
Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com>
Signed-off-by: Alexey Osipov <lion-simba@pridelands.ru>
When we capture signal from composite input offen lost and found syncro
sequence. In this case the MPEG coder hardware reset after each
lost/found event. The image has a lot of artefactes. This patch remove
hardware reset of MPEG encoder.
This is patch from our customer. I checked this.
With my best regards, Dmitry.
This card has the saa6752hs on 7-bit address 0x21 instead of 0x20. Add
support in the card definition struct to select which address to use and
update the definitions accordingly.
The v4l2_ctrl_query_fill_std() function wasn't one the best idea I ever had.
It doesn't add anything valuable that cannot be expressed equally well with
v4l2_ctrl_query_fill and only adds overhead.
Replace it with v4l2_ctrl_query_fill() everywhere it is used and remove it
from v4l2_common.c.
Control arrays as are used with v4l2_ctrl_next must be sorted from
low to high. Add a comment at the top of all such arrays to warn
about this.
Register v4l2_device and switch to v4l2_subdev to access the i2c modules.
instead of ID.
Since the i2c driver ID will be removed in the near future we have to
modify the v4l2 debugging API to use the driver name instead of driver ID.
Note that this API is not used in applications other than v4l2-dbg.cpp
as it is for debugging and testing only.
Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged
with a warning that it is deprecated and will be removed in 2.6.30.
Introduce a struct v4l2_file_operations for v4l2 drivers.
Remove the unnecessary inode argument.
Move compat32 handling (and llseek) into the v4l2-dev core: this is now
handled in the v4l2 core and no longer in the drivers themselves.
Note that this changeset reverts an earlier patch that changed the return
type of__video_ioctl2 from int to long. This change will be reinstated
later in a much improved version.
The kernel number of a v4l2 node (e.g. videoX, radioX or vbiX) is now
independent of the minor number. So instead of using the minor field
of the video_device struct one has to use the num field: this always
contains the kernel number of the device node.
I forgot about this when I did the v4l2 core change, so this patch
converts all drivers that use it in one go. Luckily the change is
trivial.
Cc: michael@mihu.de
Cc: mchehab@infradead.org
Cc: corbet@lwn.net
Cc: luca.risolia@studio.unibo.it
Cc: isely@pobox.com
Cc: pe1rxq@amsat.org
Cc: royale@zerezo.com
Cc: mkrufky@linuxtv.org
Cc: stoth@linuxtv.org
non-tuner inputs
When changing the standard the saa6752hs was not updated unless the input
was the TV tuner. The saa6752hs should be updated regardless of the input.
In addition the S_STD and G_STD ioctls for the mpeg video device didn't do
anything. This is now fixed: they behave just like S_STD and G_STD on the
video0 device.
empress cards
Additional code to improve the init sequence and add board type tests
were done by Hans Verkuil.
Cleaned up the saa6752hs i2c driver.
Add AC-3 support.
Add VIDIOC_CHIP_IDENT support.
The BKL is now moved from the video_open function in v4l2-dev.c to the
various drivers. It seems about a third of the drivers already has a
lock of some sort protecting the open(), another third uses
video_exclusive_open (yuck!) and the last third required adding the
BKL in their open function.
The type and type2 fields were unused and so could be removed.
Instead add a vfl_type field that contains the type of the video
device.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
ts_release() locked a mutex that videobuf_stop() also tried to obtain.
But ts_release() shouldn't hold that mutex at all.
Make empress_users atomic as well to prevent possible race condition.
struct
All ioctl callbacks are now stored in a new v4l2_ioctl_ops struct. Drivers fill in
a const struct v4l2_ioctl_ops and video_device just contains a const pointer to it.
This ensures a clean separation between the const ops struct and the non-const
video_device struct.
The field 'dev' is not the video device, but the parent of the video device.
Rename accordingly.
The MPEG controls could not be enumerated and so could not be read or set
through the v4l2-ctl utility or shown in control panels.
The naming for the callbacks that handle the VIDIOC_ENUM_FMT and
VIDIOC_S/G/TRY_FMT ioctls was very confusing. Renamed it to match
the v4l2_buf_type name.
The saa7134 driver uses a (non-atomic) variable in an attempt to
only allow one opener of the device (how it deals with sending
the fd over unix sockets I don't know).
Unfortunately, the release function first decrements this variable,
and THEN goes on to disable more of the device. This allows for
a race where another opener of the device comes in after the decrement of
the variable, configures the hardware just to then see the hardware
be disabled by the rest of the release function.
This patch makes the release function use the same lock as the open
function to protect the hardware as well as the variable (which now
at least has some locking to protect it).
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
decrementing dev->empress_users should be done as last action of ts_release,
because it sleeps and write access to dev->empress_started is not protected
in any way
(additionally closing thread could mute audio after opening thread unmuted it)
Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com>
If I try v4l2-ctl --all -d /dev/video1 or v4l2-ctl --streamon -d /dev/video1
modules crashed:
*pde = 00000000
Modules linked in: ac battery loop saa7134_empress(F) saa6752hs(F) tuner_simple(F) tuner_types(F) tea5767(F) tda9887(F) tda8290(F) tea5761(F) tuner(F) snd_cmipci snd_pcm snd_page_alloc snd_opl3_lib saa7134(F) snd_mpu401 parport_pc parport snd_timer snd_hwdep snd_mpu401_uart floppy rtc psmouse videodev(F) v4l1_compat(F) compat_ioctl32(F) v4l2_common(F) videobuf_dma_sg(F) videobuf_core(F) snd_rawmidi snd_seq_device via_ircc pcspkr snd ir_kbd_i2c(F) irda soundcore ir_common(F) crc_ccitt tveeprom(F) i2c_viapro i2c_core button via_agp agpgart evdev ext3 jbd mbcache ide_cd_mod cdrom ide_disk 8139cp via82cxxx ide_core 8139too mii ehci_hcd uhci_hcd usbcore thermal processor fan
EIP is at __mutex_lock_slowpath+0x29/0x7b
DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
Process v4l2-ctl (pid: 2742, ti=ced7e000 task=cf325260 task.ti=ced7e000)
d08e5411 00000000 ced7fed4 00000000 d0975acb 40045612 cfa86ee0 ffffffcd
cf2b7000 ced7febc c03858d6 00000019 00000292 d089e4ec cf37b2a0 d089e4a0
Call Trace:
[<c028b52b>] mutex_lock+0xa/0xb
[<d08e5411>] videobuf_streamon+0xf/0x9a [videobuf_core]
[<d0975acb>] __video_do_ioctl+0x136a/0x2d68 [videodev]
[<d088f789>] task_end_request+0x40/0x51 [ide_core]
[<d088c4aa>] ide_intr+0x187/0x192 [ide_core]
[<c016a551>] mntput_no_expire+0x11/0x64
[<c0160b1c>] path_walk+0x90/0x98
[<d0977738>] video_ioctl2+0x173/0x239 [videodev]
[<c0140936>] filemap_fault+0x202/0x370
[<c014930a>] __do_fault+0x2c3/0x2fe
[<c014ab03>] handle_mm_fault+0x22a/0x49f
[<c0162737>] vfs_ioctl+0x47/0x5d
[<c0162992>] do_vfs_ioctl+0x245/0x258
[<c01629e6>] sys_ioctl+0x41/0x5b
[<c01036a6>] sysenter_past_esp+0x5f/0x85
After this fix all of that commands works without problem:
Driver Info:
Driver name : saa7134
Card type : Beholder BeholdTV M6 Extra
Bus info : PCI:0000:00:0d.0
Driver version: 526
Capabilities : 0x05000001
Video Capture
Read/Write
Streaming
Format Video Capture:
Width/Height : 720/576
Pixel Format : MPEG
Field : Any
Bytes per Line: 0
Size Image : 58656
Colorspace : Unknown (00000000)
Video input : 0 (CCIR656)
Video Standard = 0x000000ff
PAL-B/B1/G/H/I/D/D1/K
P.S. data from /dev/video1 is not correct :(( .
This is patch for fix data structure in querycap syscall.
__FUNCTION__ is gcc-specific, use __func__
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Signed-off-by: Michael Krufky <mkrufky@linuxtv.org>
videobuf-dma-sg does not need to depend on PCI. Switch it to using generic
DMA API, convert all affected drivers, relax Kconfig restriction, improve
compile-time type checking, fix some Coding Style violations while at it.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de>
- Static memory is always initialized with 0.
- Replaced in some cases C99 comments for /* */
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
videobuf functions at close() method already locks videobuf. It makes no sense
to keep the locking at empress close() method.
There is also a lock at open() method. I'm not sure if it is safe to remove the
locking there.
This helps to identify where vb_lock is being used, and find missusages of the
locks.
saa7134 were converted to video_ioctl2, but saa7134_empress weren't. This broke
saa7134-empress, since it were dependent of saa7134_common_ioctl.
With the conversion, the module had a size decrease of 436 bytes on x86_64:
5196 4912 4 10112 2780 old/saa7134-empress.ko
4760 4912 4 9676 25cc new/saa7134-empress.ko
Drivers were using cookie cutter code for stopping the read/stream. Use the
new videobuf_stop function which is lock safe.
Signed-off-by: Brandon Philips <bphilips@suse.de>
Remove the obsolete VIDIOC_G_MPEGCOMP and VIDIOC_S_MPEGCOMP ioctls from
the V4L2 API as per the removal schedule (October 2007).
struct video_device used to define a .hardware field. While
initialized on severl drivers, this field is never used inside V4L.
However, drivers using it need to include the old V4L1 header.
This seems to cause compilation troubles with some random configs.
Better just to remove it from all drivers.
list_for_each_entry
A couple loops weren't changed because they expected the loop iterator
to be left as NULL if the list was empty. Maybe the code should just
check for that first, then loop?
Adjust some of the loop logic to be simpler.
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org>
PCI-dependent videobuf_foo methods were renamed as videobuf_pci_foo.
Also, videobuf_dmabuf is now part of videobuf-dma-sg private struct.
So, to access it, a subroutine call is needed.
This patch renames all occurences of those function calls to be
consistent with the video-buf split.
http://thread.gmane.org/gmane.comp.video.video4linux/34978/focus=34981
Reviewed-by: Ricardo Cerqueira <v4l@cerqueira.org>
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This
patch removes all occurences of moduleparm.h from drivers/media files.
TV-Station DVR" card
With previous patch card is generating MPEG audio stream too.
Unfortunatly I2S audio output is muted. Unmute it.
Signed-off-by: Rafal Bilski <rafalbilski@interia.pl>
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
[akpm@sdl.org: dvb fix]
