The problem is that dprintk() dereferences "dev" which is null here.
The i2cdprintk() uses "ir" so that's OK.
Also Jean Delvare pointed out a typo in the comment so we may as well
fix that.
Acked-by: Jean Delvare <khali@linux-fr.org>
The original code had two break statements in a row.
This change adds support for one more remote control type for Avermedia
M135A (model RM-K6), shipped with Positivo machines.
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
This change adds support for Avermedia M733A. The original version for
linux 2.6.31 was sent to me from Avermedia, original author is unknown.
I ported it to current kernels, expanded and fixed key code handling for
RM-K6 remote control, and added an additional pci id also supported.
[mchehab@redhat.com: make checkpatch.pl happier]
[dougsland@redhat.com: Fixed cards numbers reject due changes in saa7134.h]
Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
drivers/media/IR/ir-raw-event.c is currently written with the assumption
that all "raw" hardware will generate events only on state change (i.e.
when a pulse or space starts).
However, some hardware (like mceusb, probably the most popular IR receiver
out there) only generates duration data (and that data is buffered so using
any kind of timing on the data is futile).
Furthermore, using signed int's to represent pulse/space durations is a
well-known approach when writing ir decoders.
With this patch:
- s64 int's are used to represent pulse/space durations in ns
- a workqueue is used to decode the ir protocols outside of interrupt context
- #defines are added to make decoders clearer
- decoder reset is implemented by passing a zero duration to the kfifo queue
and decoders are updated accordingly
Signed-off-by: David Härdeman <david@hardeman.nu>
Some devices have in-hardware Remote Controller decoder, while others
need a software decoder to get the IR code. As each software decoder
can be enabled/disabled individually, allowing multiple protocol
decoding capability.
On the other hand, hardware decoders have a limited protocol
support, often being able of decoding just one protocol each time.
So, each type needs a different set of capabilities to control the
supported protocol(s).
Thanks to Andy Walls <awalls@md.metrocast.net> for pointing me his
code, that gave me some ideas to better implement it.
After some work with saa7134 bits, I found a way to catch both IRQ
edge pulses. By enabling it, the NEC decoder can now take both
pulse and spaces into account, making it more precise.
Instead of the old strategy of handling the events all at once,
this code implements a state machine. Due to that, it handles
individual pulse or space events, validating them against the
protocol, producing a much more reliable decoding.
With the new implementation, the protocol trailer bits are properly
handled, making possible for the repeat key to work.
Also, the code is now capable of handling both NEC and NEC extended
IR devices. With NEC, it produces a 16 bits code, while with NEC
extended, a 24 bits code is returned.
There's an error at the IRQ2 bit map registers. Also, it doesn't
show what bits are needed for positive and for negative edge.
In the case of IR raw decoding, for some protocols, it is important
to detect both positive and negative edges. So, a latter patch
will need to use the other values.
Also, the code that detects problems on IRQ handling is incomplete,
as it disables only one of the IRQ bits for GPIO16 and GPIO18.
Instead of using the ugly keymap sequences, use the new rc-*.ko keymap
files. For now, it is still needed to have one keymap loaded, for the
RC code to work. Later patches will remove this depenency.
A latter patch will reuse the ir_input_register with a different meaning.
Before it, change all occurrences to a temporary name.
Replaces most of the occurences of IR keytables on V4L drivers by a macro
that evaluates to provide the name of the exported symbol.
Signed-off-by: Vladimir Ermakov <vooon341@gmail.com>
Reviewed-by: hermann pitton <hermann-pitton@arcor.de>
Especially when IR needs to do polling, it generates lots of wakeups per
second. This makes no sense, if the input event device is closed.
Adds a callback handler to the IR hardware driver, to allow registering
an open/close ops.
drivers/media/video/saa7134/saa7134-input.c: In function ‘saa7134_raw_decode_irq’:
drivers/media/video/saa7134/saa7134-input.c:957: warning: unused variable ‘oldpulse’
drivers/media/video/saa7134/saa7134-input.c:957: warning: unused variable ‘count’
Some decoders and a lirc_dev interface may need some other operations to work.
For example: IR device register/unregister and ir_keydown events may need to
be tracked.
As some operations can occur in interrupt time, and a lock is needed to prevent
un-registering a decode while decoding a key, the lock needed to be convert
into a spin lock.
At raw_decode mode, the key is processed after the end of a timer. The
previous code resets the timer every time something is received at the IR
port. While this works fine with IR's that don't implement repeat, like
Avermedia RM-JX IR, it keeps waiting until keydown, on IR's that implement
NEC repeat command, like the Terratec yellow.
The solution is to change the behaviour to do the timeout after the first
received data.
The timeout is currently set to 15 ms, as it works fine with NEC protcocol.
It may need some adjustments to support other protocols and to better handle
spurious detections that may happen with some IR sensors.
Adds a method to pass IR raw pulse/code events into ir-core. This is
needed in order to support LIRC. It also helps to move common code
from the drivers into the core.
In order to allow testing, it implements a simple NEC protocol decoder
at ir-nec-decoder.c file. The logic is about the same used at saa7134
driver that handles Avermedia M135A and Encore FM53 boards.
Adds new capture boards Hawell HW-404M7 and HW-808M7. Those cards have 4
or 8 SAA7130 chips and for the work it only needs initialize registers.
The value of those registers were dumped under Windows using flytest.
But board haven't EEPROM.
For the first chip:
SAA7130 (0x7130, SubVenID:1131, SubDevID:0000, Rev: 01)
I2C slave devices found:
No devices
GPIO pins:
Mode : 0x00389C00
Value: 0x00016C00
Video input: 3
Audio input: Analog Line1
For other chips:
No devices
GPIO pins:
Mode : 0x00389200
Value: 0x00010000
Video input: 3
Now, both driver and keytable names are exported to userspace. This
will help userspace to decide when a table need to be replaced
by another one.
Fix broken I2C IR for TV cards of Beholder.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Add lost configuration for our TV card.
When preparing the linux-next patches, I got those errors:
include/media/ir-core.h:29: warning: left shift count >= width of type
In file included from include/media/ir-common.h:29,
from drivers/media/video/ir-kbd-i2c.c:50:
drivers/media/video/ir-kbd-i2c.c: In function ‘ir_probe’:
drivers/media/video/ir-kbd-i2c.c:324: warning: left shift count >= width of type
Unfortunately, enum is 32 bits on i386. As we define IR_TYPE_OTHER as 1<<63,
it won't work on non 64 bits arch.
Adds an structure to ir_input_register to contain IR device characteristics,
like supported protocols and a callback to handle protocol event changes.
ir_input_register()
We'll need to register a sysfs class for the IR devices. As such, the better
is to have the input_register_device()/input_unregister_device() inside
the ir register/unregister functions.
Also, solves a naming problem with V4L ir_input_init() function, that were,
in fact, registering a device.
While here, do a few cleanups at budget-ci IR logic.
Now, ir_input_free does more than just freeing the keytab. Better to
rename it as ir_input_unregister.
saa7134: Add support for IR reciever on card LifeView FlyDVB Trio
To unsubscribe from this list: send the line "unsubscribe linux-media" in
the body of a message to majordomo@vger.kernel.org
More majordomo info at http://vger.kernel.org/majordomo-info.html
[mchehab@redhat.com: CodingStyle fixes and ported upstream]
Tested-by: Petr Fiala <petr.fiala@gmail.com>
Signed-off-by: Lukas Karas <lukas.karas@centrum.cz>
Currently, the IR table is initialized by calling ir_input_init(). However,
this function doesn't return any error code, nor has a function to be called
when de-initializing the IR's.
Change the return argment to integer and make sure that each driver will
handle the error code. Also adds a function to free any resources that may
be allocating there: ir_input_free().
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
control
Signed-off-by: Michael Obst <mike.obst@gmail.com>
Google is pretty clear that the HVR 1110 IR chip is always at address
0x71 and the BeholdTV IR chip is always at address 0x2d. This
completes the list of IR device addresses for the SAA7134-based
adapters, and we no longer need to probe any of them.
The i2c core prevents us from probing I2C address 0x7a because it's
not a valid 7-bit address (reserved for 10-bit addressing.) So we must
stop probing this address, and explicitly list all adapters which use
it. Under the assumption that only the Upmost Purple TV adapter uses
this invalid address, this fix should do the trick.
Acked-by: hermann pitton <hermann-pitton@arcor.de>
Acked-by: Jarod Wilson <jarod@redhat.com>
Recent fixes to the em28xx and saa7134 drivers have been overzealous.
While the ir-kbd-i2c platform data indeed needs to be persistent, the
struct i2c_board_info doesn't, as it is only used by i2c_new_device().
So revert a part of the original fixes, to save some memory.
When fast push-pull button of remote control we can received incorrect
key code 0x00. Key information from IR decoder has ID of remote control 2 bytes,
byte of key code and byte of mirror key code.
Correct data
0x86 0x6B 0x00 0xFF
Wrong data
0x86 0x6B 0x00 0x00
This patch added additional test of mirror byte for filtering.
ir-kbd-i2c's ir_probe() function can be called much later (i.e. at
ir-kbd-i2c module load), than the lifetime of a struct IR_i2c_init_data
allocated off of the stack in cx18_i2c_new_ir() at registration time.
Make sure we pass a pointer to a persistent IR_i2c_init_data object at
i2c registration time.
Thanks to Brian Rogers, Dustin Mitchell, Andy Walls and Jean Delvare to
rise this question.
Before this patch, if ir-kbd-i2c were probed after SAA7134, trash data
were used.
Compile tested only, but the patch is identical to em28xx one. So, it
should work properly.
Currently, V4L uses a scancode table whose index is the scancode and
the value is the keycode. While this works, it has some drawbacks:
1) It requires that the scancode to be at the range 00-7f;
2) keycodes should be masked on 7 bits in order for it to work;
3) due to the 7 bits approach, sometimes it is not possible to replace
the default keyboard to another one with a different encoding rule;
4) it is different than what is done with dvb-usb approach;
5) it requires a typedef for it to work. This is not a recommended
Linux CodingStyle.
This patch is part of a larger series of IR changes. It basically
replaces the IR_KEYTAB_TYPE tables by a structured table:
struct ir_scancode {
u16 scancode;
u32 keycode;
This is very close to what dvb does. So, a further integration with DVB
code will be easy.
While we've changed the tables, for now, the IR keycode handling is still
based on the old approach.
The only notable effect is the redution of about 35% of the ir-common
module size:
6721 29208 4 35933 8c5d old/ir-common.ko
5756 18040 4 23800 5cf8 new/ir-common.ko
In thesis, we could be using above u8 for scancode, reducing even more the size
of the module, but defining it as u16 is more convenient, since, on dvb, each
scancode has up to 16 bits, and we currently have a few troubles with rc5, as their
scancodes are defined with more than 8 bits.
This patch itself shouldn't be doing any functional changes.
This patch add support for RoverMedia TV Link Pro FM (LR138 REV:I) card
based on saa7134.
Signed-off-by: Eugene Yudin <Eugene.Yudin@gmail.com>
Add support our new TV card based on xc5000 and saa7134.
Analog TV works well.
Added support to AverMedia Studio 505
[dougsland@redhat.com: fixed rejects and removed the change to add dk as default secam variant]
[mchehab@redhat.com: fix a few CodingStyle issues]
Signed-off-by: Vasiliy Temnikov <vaka@newmail.ru>
With the recent improvements we don't need to probe anymore, if we know
the i2c address of the receiver.
The address of the receiver for the remote with the gray buttons is not
confirmed anywhere, but it is very unlikely to see it on something else.
We want to have that information anyway.
BTW, those remaining still probing, please join.
Signed-off-by: hermann pitton <hermann-pitton@arcor.de>
The changeset 0b17d0ed that aded ASUSTeK P7131 Analog were using
7 spaces instead of tab, probably due to some bad cut-and-paste.
Add Compro VideoMate S350 DVB-S driver.
The card uses zl10313, zl10039, saa7130 integrated circuits.
Signed-off-by: Igor M. Liplianin <liplianin@me.by>
Now that we instantiate I2C IR devices explicitly, we can skip probing
altogether on boards where the I2C IR device address is known. The
AVerMedia Cardbus E506R is one of these boards.
Tested-by: Oldrich Jedlicka <oldium.pro@seznam.cz>
altogether on boards where the I2C IR device address is known. The MSI
TV@nywhere Plus is one of these boards.
For specific boards, pass initialization data to ir-kbd-i2c instead
of modifying the settings after the device is initialized. This is
more efficient and easier to read.
