If vb2_dma_contig_get_userptr() fails on a videobuffer, driver's
.buf_init() method will not be called and the list will not be
initialised. Trying to remove an uninitialised element from a list leads
to a NULL-dereference.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Tested-by: Bastian Hecht <hechtb@gmail.com>
Now that v4l2 subdevices have got their own device objects, having
one more device in soc-camera clients became redundant and confusing.
This patch removes those devices and the soc-camera bus, they used to
reside on.
Acked-by: Paul Mundt <lethal@linux-sh.org>
This moves us one more step closer to eliminating the soc-camera bus
and devices on it. Besides, as a side effect, CSI-2 runtime PM on
sh-mobile secomes finer grained now: we only have to power on the
interface, when the device nodes are open.
soc_camera core now performs the standard .bytesperline and .sizeimage
calculations internally, no need to duplicate in drivers.
Standardize the remaining video drivers to return the API version
for the VIDIOC_QUERYCAP version, instead of a per-driver version.
Those drivers had the version updated more recently or are SoC
drivers. Even so, it doesn't sound a good idea to keep a per-driver
version control, so, let's use the per-subsystem version control
instead.
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
not critical
soc_mbus_get_fmtdesc() returning NULL means only, that no standard
mediabus code -> fourcc conversion is known, this shouldn't be treated
as an error by drivers.
PRELIMINARY: break out spinlock changes; consider multiple completing
feames, causing multiple complete() calles.
Add live crop support to the sh_mobile_ceu driver.
The .stop_streaming() videobuf2 operation has to be implemented to
guarantee, that video buffers are not written to after a STREAMOFF.
With the introduction of CSI2 support on sh-mobile, the host driver
switched to using v4l2_device_call_until_err() with grp_id == 0 to
call subdev operations on the sensor and the CSI2 subdev. However,
this has broken multi-client set ups like the one on migor, because
that way all operations get called on both clients. To fix this add
a grp_id and set it to the client private context.
Use vb2_dma_contig_plane_paddr to retrieve a physical address for a plane
instead of calling an internal mem_ops callback.
Signed-off-by: Pawel Osciak <pawel@osciak.com>
Use the correct scales to calculate cropping offsets.
Convert the sh_mobile_ceu_camera driver to the videobuf2 API.
Use the V4L mutex infrastructure in soc-camera core and drivers and switch to
.unlocked_ioctl.
The test for driver->owner != NULL in sh_mobile_ceu_camera.c is unneeded and it
breaks the static build of sh_mobile_csi2.c. Remove it.
operations
No need to duplicate default .get_parm() and .set_parm() operations.
Missed a few init functions on non-Intel platforms the first time :-(
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Multiple user-space application instances can open the same video device, but
it only makes sense for one of them to manage the videobuffer queue and set
video format of the device. Restrict soc-camera respectively.
videobuf_waiton() must unlock and relock ext_lock if it has to wait.
For that to happen it needs the videobuf_queue pointer.
Don't attempt to unlock/relock q->ext_lock unless it was locked in the
first place.
vb->state has to be protected by a spinlock to be safe.
This patch is based on code from Mauro Carvalho Chehab <mchehab@redhat.com>.
[mchehab@redhat.com: add extra argument to a few missing places]
Using CEU with CSI2 on SH-Mobile requires some special configuration of the
former. We also have to switch from calling only one subdev .s_mbus_fmt and
.try_mbus_fmt to calling all subdevices. Take care to increment CSI2 driver
use count to prevent it from unloading, while in use.
Endianness notation is meaningless for 8 bit YUYV codes. Switch pixel code
names to explicitly state the order of colour components in the data
stream.
With enabled debugging sh_mobile_ceu_camera.c dereferences an invalid or a NULL
pointer. Thanks to James Wang for reporting.
enum_mbus_fmt received an index argument that was defined as an int instead
of an unsigned int. This is now fixed. This had the knock-on effect that the
index argument in the callback get_formats in soc_camera.h also had to be
changed to unsigned int.
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Current version of sh_mobile_ceu_camera.c interprets the V4L2 API specification
of the VIDIOC_S_CROP ioctl as "change input (for capture devices) area,
preserve scaling factors, therefore change output window," whereas a more
intuitive interpretation of the API is "change input area, preserve output
window." Switch sh_mobile_ceu_camera.c to use this interpretation.
Due to obvious copy and paste coding a number of video capture drivers
which implement a limit on the buffer memory decremented the user
supplied buffer count in a while loop until it reaches an acceptable
value.
This is a silly thing to do when the maximum value can be directly
computed.
Signed-off-by: Andreas Bombe <aeb@debian.org>
pointers to struct v4l2_rect elements. They are signed, so adjust the prototype accordingly
This will remove the following sparse warning (see "make C=1"):
* incorrect type in argument 1 (different signedness)
expected unsigned int *start
got signed int *<noident>
as well as a couple more signedness mismatches.
Signed-off-by: Márton Németh <nm127@freemail.hu>
soc_mbus_bytes_per_line() returns -EINVAL on error but we store it in an
unsigned int so the test for less than zero doesn't work. I think it
always returns "small" positive values so we can just cast it to int
here.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
platform_get_irq returns -ENXIO on failure, so !irq was probably
always true. Better use (int)irq <= 0. Note that a return value of
zero is still handled as error even though this could mean irq0.
This is a followup to 305b3228f9ff4d59f49e6d34a7034d44ee8ce2f0 that
changed the return value of platform_get_irq from 0 to -ENXIO on error.
Cc: David Vrabel <dvrabel@arcom.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Cc: Magnus Damm <damm@igel.co.jp>
Cc: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Cc: linux-media@vger.kernel.org
This patch updates the SuperH Mobile CEU driver to
not page align the frame size. Useful in the case of
USERPTR with non-page aligned frame sizes and offsets.
Signed-off-by: Magnus Damm <damm@opensource.se>
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Convert soc-camera core and all soc-camera drivers to the new mediabus
API. This also takes soc-camera client drivers one step closer to also be
usable with generic v4l2-subdev host drivers.
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
adding a client fails
Currently, if resetting the host interface, when adding a new client, fails, a
negative error code is returned, but the host is still marked as occupied. Fix
this bug.
sh_mobile_ceu_remove
The function sh_mobile_ceu_remove is defined using __devexit, so don't
use __exit_p but __devexit_p to wrap it.
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
If CEU driver can not receive data from camera,
CETCR has VBP error state.
Then, CEU is stopped and cure operation is needed.
This patch add VBP error cure operation.
Trivial fix for this compile warning:
v4l/sh_mobile_ceu_camera.c:1789: warning: label 'exit_free_irq' defined but not used
pm_runtime_disable is needed if it failed or removed
Fix a bug in cropping calculation, when the client is also scaling the image.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
(S_CROP)
The initial soc-camera scaling and cropping implementation turned out to be
incompliant with the V4L2 API, e.g., it expected the user to specify cropping
in output window pixels, instead of input window pixels. This patch converts
the soc-camera core and all drivers to comply with the standard.
Use v4l2_subdev_call() instead of v4l2_device_call_until_err() in all host
drivers and in soc-camera core.
Remove set_crop soc-camera device method and switch to s_crop from v4l2-subdev
video operations. Also extend non-i2c drivers to also hold a pointer to their
v4l2-subdev instance in control device driver-data, i.e., in
dev_get_drvdata((struct device *)to_soc_camera_control(icd))
Use host-side image scaling when the client fails to set the requested format.
We also have to take scaling into account when performing host-side cropping.
Similar to cropping we try to use client-side scaling as much as possible to
preserve bus bandwidth and optimise the frame-rate.
Not all video capture devices can configure arbitrary cropping, whereas the
CEU module on SuperH CPUs can crop with pixel precision. However, we want to
use camera cropping if possible to save bandwidth and increase the frame-rate.
This patch verifies whether the camera managed to crop exactly the requested
rectangle, and if not, uses host-side cropping. To be able to crop on CEU we
have to preserve camera rectangle too, for which the host_priv member in
struct soc_camera_device is used. We now allocate memory dynamically, thus we
have to use the .put_formats() method from struct soc_camera_host_ops to free
it.
