path: root/drivers/media/video/sn9c102/sn9c102_tas5110c1b.c
2007-05-09V4L/DVB (5585): SN9C1xx driver updatesLuca Risolia
* Default color improvements to the OV7660 @ Fix sn9c102_write_reg() @ Fix sn9c102_i2c_try_raw_read() @ Fix MI-0343 + Add support for pair MI0360+SN9C120 + Add more USB ids Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5502): Sn9c102: more efficient register writing codeTrent Piepho
There were many places in the driver which had long sequences of constant register initializations. These were done with one function call per register. The register address and value were immediate values in the function calls. This is very inefficient, as each register and value take twice the space when they are code, as each includes a push instruction to put it on the stack. There there is the overhead, both size and time, for a function call for each register. It's also quite a few lines of C code to do this. The patch creates a function that writes multiple registers from a list, and a macro that makes it easy to construct a such a list as a const static local to send to the function. This gets rid of quite a bit of C code, and shrinks the driver by around 8k, while at the same time being more efficient. Acked-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5474): SN9C1xx driver updatesLuca Risolia
@ Don't assume that SOF headers can't cross packets boundaries @ Fix compression quality selection + Add support for MI-0360 image sensor * Documentation updates @ Fix sysfs @ MI0343 rewritten * HV7131R color fixes and add new ABLC control * Rename the archive from "sn9c102" to "sn9c1xx" * fix typos * better support for TAS5110D @ fix OV7630 wrong colors @ Don't return an error if no input buffers are enqueued yet on VIDIOC_STREAMON * Add informations about colorspaces * More appropriate error codes in case of failure of some system calls * More precise hardware detection * Add more informations about supported hardware in the documentation + More supported devices + Add support for HV7131R image sensor Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5062): SN9C102 driver updatesLuca Risolia
- Add support for SN9C105 and SN9C120 - Add some more USB device identifiers - Add support for OV7660 - Implement audio ioctl's and VIDIOC_ENUM_FRAMESIZES - Add preliminary support for 0x0c45/0x6007 - Documentation updates - Generic improvements Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-25V4L/DVB (3599b): Whitespace cleanups under drivers/mediaMauro Carvalho Chehab
2006-03-25V4L/DVB (3599a): Move drivers/usb/media to drivers/media/videoMauro Carvalho Chehab
Because of historic reasons, there are two separate directories with V4L stuff. Most drivers are located at driver/media/video. However, some code for USB Webcams were inserted under drivers/usb/media. This makes difficult for module authors to know were things should be. Also, makes Kconfig menu confusing for normal users. This patch moves all V4L content under drivers/usb/media to drivers/media/video, and fixes Kconfig/Makefile entries. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
