path: root/drivers/media/video/tcm825x.c
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-06-23V4L/DVB (12111): tcm825x: remove incorrect __exit_p wrapperHans Verkuil
tcm825x_remove is not necessarily called on module exit, it can also be called when the i2c_adapter is removed. While the i2c adapter might never be removed on an embedded system, in practice this sensor driver can also be used in e.g. a USB webcam where this is a perfectly acceptable thing to do. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10628): V4L: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Cc: Jean-Francois Moine <moinejf@free.fr> Cc: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-20V4L/DVB (7897): TCM825x: Include invertation of image mirroring in configurationSakari Ailus
Add invertation of image mirroring register bits to default configuration. This is useful when the camera module is e.g. mounted upside down. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-11i2c: Convert some more new-style drivers to use module aliasingJean Delvare
Update 3 more new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. These video drivers aren't used yet so converting them is trivial. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-04-24V4L/DVB (7518): media/video/ replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7086): driver: tcm825x - fix logical typo errorCyrill Gorcunov
This patch does fix potential NULL pointer dereference due to logical typo error. The issue is pointed out by Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> CC: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6220): TCM825x: Add support for vidioc_int_g_ifparm call, small ↵Sakari Ailus
cleanups vidioc_int_g_ifparm returns platform-specific information about the interface settings used by the sensor. Support for [gs]_ext_clk has been removed. Fix indentation and remove useless & characters. Remove experiment for typechecking slave callback function arguments. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6111): Fix a warning when compiling on x86_64Mauro Carvalho Chehab
tcm825x.c: In function 'ioctl_try_fmt_cap': tcm825x.c:639: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int' Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5863): TCM825x: Add driver.Sakari Ailus
Add a driver for Toshiba TCM825x VGA camera sensor. This sensor is used e.g. in Nokia N800 internet tablet. This driver uses the new V4L2 internal ioctl interface. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
