path: root/drivers/media/video/tcm825x.c
2008-05-11i2c: Convert some more new-style drivers to use module aliasingJean Delvare
Update 3 more new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. These video drivers aren't used yet so converting them is trivial. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-04-24V4L/DVB (7518): media/video/ replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7086): driver: tcm825x - fix logical typo errorCyrill Gorcunov
This patch does fix potential NULL pointer dereference due to logical typo error. The issue is pointed out by Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Signed-off-by: Cyrill Gorcunov <gorcunov@gmail.com> CC: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6220): TCM825x: Add support for vidioc_int_g_ifparm call, small ↵Sakari Ailus
cleanups vidioc_int_g_ifparm returns platform-specific information about the interface settings used by the sensor. Support for [gs]_ext_clk has been removed. Fix indentation and remove useless & characters. Remove experiment for typechecking slave callback function arguments. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6111): Fix a warning when compiling on x86_64Mauro Carvalho Chehab
tcm825x.c: In function 'ioctl_try_fmt_cap': tcm825x.c:639: warning: format '%d' expects type 'int', but argument 4 has type 'long unsigned int' Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5863): TCM825x: Add driver.Sakari Ailus
Add a driver for Toshiba TCM825x VGA camera sensor. This sensor is used e.g. in Nokia N800 internet tablet. This driver uses the new V4L2 internal ioctl interface. Signed-off-by: Sakari Ailus <sakari.ailus@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
