path: root/drivers/media/video/tvaudio.c
2010-10-21V4L/DVB: tvaudio: remove obsolete tda8425 initializationHans Verkuil
The tda8425 initialization function sets up the inputmap for riva boards. After some digging I discovered that this was for the V4L rivatv driver that is found on sourceforge. This driver hasn't been maintained since the last 5 years and will no longer work with the current v4l framework. So we can safely remove this. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: tvaudio: remove obsolete v4l2-i2c-drv.h headerHans Verkuil
2009-12-05V4L/DVB (13166): remove duplicate structure field initializationJulia Lawall
The definition of tvaudio_tuner_ops initializes the s_tuner field twice. It appears that the second case should initialize the g_tuner field. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r@ identifier I, s, fld; position p0,p; expression E; @@ struct I s =@p0 { ... .fld@p = E, ...}; @s@ identifier I, s, r.fld; position r.p0,p; expression E; @@ struct I s =@p0 { ... .fld@p = E, ...}; @script:python@ p0 << r.p0; fld << r.fld; ps << s.p; pr << r.p; @@ if int(ps[0].line)!=int(pr[0].line) or int(ps[0].column)!=int(pr[0].column): cocci.print_main(fld,p0) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11380): v4l2-subdev: change s_routing prototypeHans Verkuil
It is no longer needed to use a struct pointer as argument, since v4l2_subdev doesn't require that ioctl-like approach anymore. Instead just pass the input, output and config (new!) arguments directly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11372): v4l2: use old-style i2c API for kernels < 2.6.26 instead of ↵Hans Verkuil
< 2.6.22 Originally the intention was to switch to the new style i2c API starting with the introduction of the API in 2.6.22. However, the i2c_new_probed_device() function has a lethal bug that wasn't fixed until 2.6.25. Or more accurately, it was only fixed in the stable series of 2.6.25 and 2.6.26. Given the fact that the new i2c API also changed starting with 2.6.26 (the addition of i2c_device_id), it is easiest to switch APIs starting with 2.6.26. This patch updates all the legacy code accordingly. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11370): v4l2-subdev: move s_std from tuner to core.Hans Verkuil
s_std didn't belong in the tuner ops. Stricly speaking it should be part of the video ops, but it is used by audio and tuner devices as well, so it is more efficient to make it part of the core ops. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-04-06V4L/DVB (11365): tvaudio: remove i2c legacy codeHans Verkuil
All drivers that use tvaudio now use v4l2_subdev, so we can remove the legacy code from tvaudio. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11277): tvaudio: always call init_timer to prevent rmmod crash.Hans Verkuil
In the tvaudio_remove function del_timer_sync(&chip->wt) is called. However, chip->wt isn't always initialized depending on the type of audio chip. Since del_timer_sync hangs when given an uninitialized timer we should always initialize it. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11276): tvaudio: add tda9875 support.Hans Verkuil
This change allows bttv to use tvaudio for this device. Since this device has the same i2c address as the tda9874 we need to support both in the same tvaudio driver. This makes it possible for tvaudio to detect which chip is used. Originally the tda9875 was only available in the dedicated tda9875 driver, but that makes life very hard for bttv since loading tvaudio might misdetect a tda9875 as a tda9874. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (11275): tvaudio: fix mute and s/g_tuner handlingHans Verkuil
The mute control depends on CHIP_HAS_INPUTSEL, so test for that first. The s/g_tuner code should check whether getmode/setmode is set at the beginning instead of filling in the struct and discovering at the end that this chip doesn't implement audiomodes after all (i.e. is a simple muxer chip). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10730): v4l-dvb: cleanup obsolete references to v4l1 headers.Hans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> [mchehab@redhat.com: fix compilation of tea575x-tuner.c] Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10698): v4l2-common: remove v4l2_ctrl_query_fill_stdHans Verkuil
The v4l2_ctrl_query_fill_std() function wasn't one the best idea I ever had. It doesn't add anything valuable that cannot be expressed equally well with v4l2_ctrl_query_fill and only adds overhead. Replace it with v4l2_ctrl_query_fill() everywhere it is used and remove it from v4l2_common.c. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-05V4L/DVB (10832): tvaudio: Avoid breakage with tda9874aVitaly Wool
The 'bytes' array is 64 bytes large but the easy standard programming (TDA9874A_ESP) has a number of 255, outside the shadow array size. This patch increases the size of the shadow array in order to accomodate this register. Signed-off-by: Vitaly Wool <vital@embeddedalley.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9959): tvaudio: convert to v4l2_subdev.Hans Verkuil
2008-11-14V4L/DVB (9624): CVE-2008-5033: fix OOPS on tvaudio when controlling bass/trebleMauro Carvalho Chehab
This bug were supposed to be fixed by 5ba2f67afb02c5302b2898949ed6fc3b3d37dcf1, where a call to NULL happens. Not all tvaudio chips allow controlling bass/treble. So, the driver has a table with a flag to indicate if the chip does support it. Unfortunately, the handling of this logic were broken for a very long time (probably since the first module version). Due to that, an OOPS were generated for devices that don't support bass/treble. This were the resulting OOPS message before the patch, with debug messages enabled: tvaudio' 1-005b: VIDIOC_S_CTRL BUG: unable to handle kernel NULL pointer dereference at 00000000 IP: [<00000000>] *pde = 22fda067 *pte = 00000000 Oops: 0000 [#1] SMP Modules linked in: snd_hda_intel snd_seq_dummy snd_seq_oss snd_seq_midi_event snd_seq snd_seq_device snd_pcm_oss snd_mixer_oss snd_pcm snd_timer snd_hwdep snd soundcore tuner_simple tuner_types tea5767 tuner tvaudio bttv bridgebnep rfcomm l2cap bluetooth it87 hwmon_vid hwmon fuse sunrpc ipt_REJECT nf_conntrack_ipv4 iptable_filter ip_tables ip6t_REJECT xt_tcpudp nf_conntrack_ipv6 xt_state nf_conntrack ip6table_filter ip6_tables x_tables ipv6 dm_mirrordm_multipath dm_mod configfs videodev v4l1_compat ir_common 8139cp compat_ioctl32 v4l2_common 8139too videobuf_dma_sg videobuf_core mii btcx_risc tveeprom i915 button snd_page_alloc serio_raw drm pcspkr i2c_algo_bit i2c_i801 i2c_core iTCO_wdt iTCO_vendor_support sr_mod cdrom sg ata_generic pata_acpi ata_piix libata sd_mod scsi_mod ext3 jbdmbcache uhci_hcd ohci_hcd ehci_hcd [last unloaded: soundcore] Pid: 15413, comm: qv4l2 Not tainted (2.6.25.14-108.fc9.i686 #1) EIP: 0060:[<00000000>] EFLAGS: 00210246 CPU: 0 EIP is at 0x0 EAX: 00008000 EBX: ebd21600 ECX: e2fd9ec4 EDX: 00200046 ESI: f8c0f0c4 EDI: f8c0f0c4 EBP: e2fd9d50 ESP: e2fd9d2c DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process qv4l2 (pid: 15413, ti=e2fd9000 task=ebe44000 task.ti=e2fd9000) Stack: f8c0c6ae e2ff2a00 00000d00 e2fd9ec4 ebc4e000 e2fd9d5c f8c0c448 00000000 f899c12a e2fd9d5c f899c154 e2fd9d68 e2fd9d80 c0560185 e2fd9d88 f8f3e1d8 f8f3e1dc ebc4e034 f8f3e18c e2fd9ec4 00000000 e2fd9d90 f899c286 c008561c Call Trace: [<f8c0c6ae>] ? chip_command+0x266/0x4b6 [tvaudio] [<f8c0c448>] ? chip_command+0x0/0x4b6 [tvaudio] [<f899c12a>] ? i2c_cmd+0x0/0x2f [i2c_core] [<f899c154>] ? i2c_cmd+0x2a/0x2f [i2c_core] [<c0560185>] ? device_for_each_child+0x21/0x49 [<f899c286>] ? i2c_clients_command+0x1c/0x1e [i2c_core] [<f8f283d8>] ? bttv_call_i2c_clients+0x14/0x16 [bttv] [<f8f23601>] ? bttv_s_ctrl+0x1bc/0x313 [bttv] [<f8f23445>] ? bttv_s_ctrl+0x0/0x313 [bttv] [<f8b6096d>] ? __video_do_ioctl+0x1f84/0x3726 [videodev] [<c05abb4e>] ? sock_aio_write+0x100/0x10d [<c041b23e>] ? kmap_atomic_prot+0x1dd/0x1df [<c043a0c9>] ? enqueue_hrtimer+0xc2/0xcd [<c04f4fa4>] ? copy_from_user+0x39/0x121 [<f8b622b9>] ? __video_ioctl2+0x1aa/0x24a [videodev] [<c04054fd>] ? do_notify_resume+0x768/0x795 [<c043c0f7>] ? getnstimeofday+0x34/0xd1 [<c0437b77>] ? autoremove_wake_function+0x0/0x33 [<f8b62368>] ? video_ioctl2+0xf/0x13 [videodev] [<c048c6f0>] ? vfs_ioctl+0x50/0x69 [<c048c942>] ? do_vfs_ioctl+0x239/0x24c [<c048c995>] ? sys_ioctl+0x40/0x5b [<c0405bf2>] ? syscall_call+0x7/0xb [<c0620000>] ? cpuid4_cache_sysfs_exit+0x3d/0x69 ======================= Code: Bad EIP value. EIP: [<00000000>] 0x0 SS:ESP 0068:e2fd9d2c Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-14V4L/DVB (9623): tvaudio: Improve debug msg by printing something more humanMauro Carvalho Chehab
Before the patch, the used ioctl were printed as an hexadecimal code, hard to be understand without consulting the way _IO macros work. Instead, use the V4L default handler for printing such errors into a way that would be easier to understand. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-14V4L/DVB (9622): tvaudio: Improve comments and remove a unneeded prototypeMauro Carvalho Chehab
Some comments are not clear enough. Improve it to allow a better understanding of the driver behavior. While there, remove an unneeded struct prototype. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-14V4L/DVB (9621): Avoid writing outside shadow.bytes[] arrayMauro Carvalho Chehab
There were no check about the limits of shadow.bytes array. This offers a risk of writing values outside the limits, overriding other data areas. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-14V4L/DVB (9620): tvaudio: use a direct reference for chip descriptionMauro Carvalho Chehab
Instead of storing the pointer for the proper entry at chip description table, the driver were storing an indirect reference, by using an index. Better to reference directly the data. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-14V4L/DVB (9619): tvaudio: update initial commentsMauro Carvalho Chehab
A driver used on several bttv boards since 2000 is not experimental anymore ;) Remove it from the comments. While there, update copyrights addind a quick note about the "recent" updates since 2005. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-14V4L/DVB (9618): tvaudio: add additional logic to avoid OOPSMauro Carvalho Chehab
This patch checks for volume, bass, treble, set mode and get mode callbacks before actually enabling the code that would use them. Instead of aborting the driver for load, this patch will allow it to load with a reduced number of functionatities. This prevents OOPS if some board entry is missing a needed callback. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-14V4L/DVB (9617): tvtime: remove generic_checkmode callbackMauro Carvalho Chehab
generic_checkmode() were called, via a callback, for some tvaudio chips. There's just one callback code used on all those boards. So, it makes no sense on keeping this as a callback. Since there were some OOPS reported on tvaudio on kerneloops.org, this patch removes this callback, adding the code at the only place were it is called: inside chip_tread. A flag were added to indicate the need for a kernel thread to set stereo mode on cards that needs it. Using this more direct approach simplifies the code, making it more robust against human errors. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-14V4L/DVB (9616): tvaudio: cleanup - group all callbacks togetherMauro Carvalho Chehab
2008-11-14V4L/DVB (9615): tvaudio: instead of using a magic number, use ARRAY_SIZEMauro Carvalho Chehab
Also, the default standard is the first one. So, fix the comment at the array. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-11-14V4L/DVB (9613): tvaudio: fix a memory leakMauro Carvalho Chehab
2008-10-11security: avoid calling a NULL function pointer in drivers/video/tvaudio.cArjan van de Ven
NULL function pointers are very bad security wise. This one got caught by kerneloops.org quite a few times, so it's happening in the field.... Fix is simple, check the function pointer for NULL, like 6 other places in the same function are already doing. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-20V4L/DVB (8246): tvaudio: Stop I2C driver ID abuseJean Delvare
The tvaudio driver is using "official" I2C device IDs for internal purpose. There must be some historical reason behind this but anyway, it shouldn't do that. As the stored values are never used, the easiest way to fix the problem is simply to remove them altogether. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-11i2c: Convert some more new-style drivers to use module aliasingJean Delvare
Update 3 more new-style i2c drivers to use standard module aliasing instead of the old driver_name/type driver matching scheme. These video drivers aren't used yet so converting them is trivial. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-04-29i2c: Add support for device alias namesJean Delvare
Based on earlier work by Jon Smirl and Jochen Friedrich. This patch allows new-style i2c chip drivers to have alias names using the official kernel aliasing system and MODULE_DEVICE_TABLE(). At this point, the old i2c driver binding scheme (driver_name/type) is still supported. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Jochen Friedrich <jochen@scram.de> Cc: Jon Smirl <jonsmirl@gmail.com> Cc: Kay Sievers <kay.sievers@vrfy.org>
2008-04-24V4L/DVB (7094): static memoryDouglas Schilling Landgraf
- Static memory is always initialized with 0. - Replaced in some cases C99 comments for /* */ Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7139): add parenthesesRoel Kluin
'!' has a higher priority than '&': bitanding has no effect. Signed-off-by: Roel Kluin <12o3l@tiscali.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6461): tvaudio: convert to bus-based I2C APIHans Verkuil
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6418): Converted tvaudio from V4L1 to V4L2Mauro Carvalho Chehab
V4L1 ioctls were replaced to V4L2 were applicable. The older ones already implemented were removed. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (6079): Cleanup: remove linux/moduleparam.h from drivers/media filesMauro Carvalho Chehab
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This patch removes all occurences of moduleparm.h from drivers/media files. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-20V4L/DVB (5858): Use msecs_to_jiffies instead of HZ on media/video I2C driversMauro Carvalho Chehab
2007-07-17Freezer: make kernel threads nonfreezable by defaultRafael J. Wysocki
Currently, the freezer treats all tasks as freezable, except for the kernel threads that explicitly set the PF_NOFREEZE flag for themselves. This approach is problematic, since it requires every kernel thread to either set PF_NOFREEZE explicitly, or call try_to_freeze(), even if it doesn't care for the freezing of tasks at all. It seems better to only require the kernel threads that want to or need to be frozen to use some freezer-related code and to remove any freezer-related code from the other (nonfreezable) kernel threads, which is done in this patch. The patch causes all kernel threads to be nonfreezable by default (ie. to have PF_NOFREEZE set by default) and introduces the set_freezable() function that should be called by the freezable kernel threads in order to unset PF_NOFREEZE. It also makes all of the currently freezable kernel threads call set_freezable(), so it shouldn't cause any (intentional) change of behaviour to appear. Additionally, it updates documentation to describe the freezing of tasks more accurately. [akpm@linux-foundation.org: build fixes] Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Nigel Cunningham <nigel@nigel.suspend2.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Oleg Nesterov <oleg@tv-sign.ru> Cc: Gautham R Shenoy <ego@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27V4L/DVB (5492): Remove useless includes of i2c-algo-bit.hJean Delvare
The tda7432, tda9875 and tvaudio media drivers don't need to include the linux/i2c-algo-bit.h header file. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5355): Add VIDIOC_G_CHIP_IDENT to various i2c modulesHans Verkuil
2006-12-07[PATCH] Add include/linux/freezer.h and move definitions from sched.hNigel Cunningham
Move process freezing functions from include/linux/sched.h to freezer.h, so that modifications to the freezer or the kernel configuration don't require recompiling just about everything. [akpm@osdl.org: fix ueagle driver] Signed-off-by: Nigel Cunningham <nigel@suspend2.net> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-26V4L/DVB (4624): Tvaudio: Replaced kernel_thread() with kthread_run()Cedric Le Goater
Replaced kernel_thread() with kthread_run() since kernel_thread() is deprecated in drivers/modules. Removed the completion and the wait queue which are now useless with kthread. Also removed the allow_signal() call as signals don't apply to kernel threads. Fixed a small race condition when thread is stopped. Please check if the timer vs. thread still works fine without the wait queue. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-04-02V4L/DVB (3609): Remove VIDIOC_S_AUDIO from tvaudio: no longer used.Hans Verkuil
2006-03-24V4L/DVB (3584): Implement V4L2_TUNER_MODE_LANG1_LANG2 audio modeHans Verkuil
Add a new audio mode V4L2_TUNER_MODE_LANG1_LANG2 (used by VIDIOC_G/S_TUNER). This mode allows the user to select both languages of a bilingual transmission, one language on the left, one on the right audio channel. If there is no bilingual transmission, or it is not supported, then this mode should act like V4L2_TUNER_MODE_STEREO. This mode is introduced for PVR-like drivers where it is useful to be able to record both languages of a bilingual broadcast. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3582): Implement correct msp3400 input/output routingHans Verkuil
- implement VIDIOC_INT_S_AUDIO_ROUTING for msp3400 and tvaudio - use the new command in bttv, pvrusb2 and em28xx. - remove the now obsolete MSP_SET_MATRIX from msp3400 (yeah!) - remove the obsolete VIDIOC_S_AUDIO from msp3400. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3577): Cleanup audio input handlingHans Verkuil
Cleanup audio input handling in bttv and tvaudio: - inputs were specified that were never used - mute was handled as a special input which led to confusing code - confusing naming made it difficult to see if the setting was for i2c or gpio. The old audiochip.h input names moved to tvaudio.h. Currently this is used both by tvaudio and msp3400 until the msp3400 implements the new msp3400-specific inputs. Detect in bttv the tvaudio and msp3400 i2c clients and use these client pointers to set the inputs directly instead of broadcasting the command. Removed AUDC_SET_INPUT. Now replaced by VIDIOC_S_AUDIO. This will be replaced again later by the new ROUTING commands. Removed VIDIOC_G_AUDIO implementations in i2c drivers: this command is a user level command and not to be used internally. It wasn't called at all anyway. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3548): Renamed I2C_foo addresses to I2C_ADDR_fooMauro Carvalho Chehab
I2C_foo were used for some i2c addresses. Bad, since those constants could mean other i2c chip things. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-24V4L/DVB (3547): Tvaudio.h are just i2c addresses. Merged into i2c-addr.hMauro Carvalho Chehab
