path: root/drivers/media/video/v4l2-compat-ioctl32.c
2011-03-21[media] v4l: removal of old, obsolete ioctlsHans Verkuil
Some ioctl's were defined wrong on 2.6.2 and 2.6.6, using the wrong type of R/W arguments. They were fixed, but the old ioctl names are still there, maintained to avoid breaking binary compatibility: There's no sense on preserving those forever, as it is very doubtful that someone would try to use a such old binary with a modern kernel. Removing them will allow us to remove some magic done at the V4L ioctl handler. Note that any application compiled with a videodev2.h from 2.6.7 or later will be using the correct ioctls. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: Add compat functions for the multi-planar APIPawel Osciak
Add multi-planar ioctl handling to the 32bit compatibility layer. [mchehab@redhat.com: Merged with a fixup patch from Pawel] Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-01-04[media] v4l2-compat-ioctl32: fix compile warningHans Verkuil
drivers/media/video/v4l2-compat-ioctl32.c: In function 'get_v4l2_format32': drivers/media/video/v4l2-compat-ioctl32.c:169:2: warning: case value '0' not in enumerated type 'enum v4l2_buf_type' drivers/media/video/v4l2-compat-ioctl32.c: In function 'put_v4l2_format32': drivers/media/video/v4l2-compat-ioctl32.c:200:2: warning: case value '0' not in enumerated type 'enum v4l2_buf_type' Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] V4L1 removal: Remove linux/videodev.hMauro Carvalho Chehab
There's no sense on keeping it on 2.6.38, as nobody is using it anymore, at the kernel tree, and installing it at the userspace API. As two deprecated drivers still need it, move it to their internal directories. Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] V4L: remove V4L1 compatibility modeHans Verkuil
2010-11-17BKL: remove extraneous #include <smp_lock.h>Arnd Bergmann
The big kernel lock has been removed from all these files at some point, leaving only the #include. Remove this too as a cleanup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-10-15v4l1: fix 32-bit compat microcode loading translationLinus Torvalds
The compat code for the VIDIOCSMICROCODE ioctl is totally buggered. It's only used by the VIDEO_STRADIS driver, and that one is scheduled to staging and eventually removed unless somebody steps up to maintain it (at which point it should use request_firmware() rather than some magic ioctl). So we'll get rid of it eventually. But in the meantime, the compatibility ioctl code is broken, and this tries to get it to at least limp along (even if Mauro suggested just deleting it entirely, which may be the right thing to do - I don't think the compatibility translation code has ever worked unless you were very lucky). Reported-by: Kees Cook <kees.cook@canonical.com> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14v4l: Remove reference to bkl ioctl in compat ioctl handlingFrederic Weisbecker
There are no more users of struct file_operations:ioctl. These can be safely removed. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Cc: John Kacur <jkacur@redhat.com> Cc: Hans Verkuil <hverkuil@xs4all.nl>
2010-07-19update email addressPavel Machek
pavel@suse.cz no longer works, replace it with working address. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-19V4L/DVB: V4L: Events: Add new ioctls for eventsSakari Ailus
This patch adds a set of new ioctls to the V4L2 API. The ioctls conform to V4L2 Events RFC version 2.3: <URL:http://www.spinics.net/lists/linux-media/msg12033.html> Signed-off-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: Fix VIDIOC_QBUF compat ioctl32Arnaud Patard
When using VIDIOC_QBUF with memory type set to V4L2_MEMORY_MMAP, the v4l2_buffer buffer gets unmodified on drivers like uvc (well, only bytesused field is modified). Then some apps like gstreamer are reusing the same buffer later to call munmap (eg passing the buffer "length" field as 2nd parameter of munmap). It's working fine on full 32bits but on 32bits systems with 64bit kernel, the get_v4l2_buffer32() doesn't copy length/m.offset values and then copy garbage to userspace in put_v4l2_buffer32(). This has for consequence things like that in the libv4l2 logs: libv4l2: v4l2 unknown munmap 0x2e2b0000, -2145144908 libv4l2: v4l2 unknown munmap 0x2e530000, -2145144908 The buffer are not unmap'ed and then if the application close and open again the device, it won't work and logs will show something like: libv4l2: error setting pixformat: Device or resource busy The easy solution is to read length and m.offset in get_v4l2_buffer32(). Signed-off-by: Arnaud Patard <apatard@mandriva.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-02-26V4L/DVB: use correct size in put_v4l2_window32()Roel Kluin
Although these sizes may be the same it is better to calculate the size of the source, than the destiny. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-12-16V4L/DVB (13571): v4l: Adding Digital Video Timings APIsMuralidharan Karicheri
This adds the above APIs to the v4l2 core. This is based on version v1.2 of the RFC titled "V4L - Support for video timings at the input/output interface" Following new ioctls are added:- - VIDIOC_ENUM_DV_PRESETS - VIDIOC_S_DV_PRESET - VIDIOC_G_DV_PRESET - VIDIOC_QUERY_DV_PRESET - VIDIOC_S_DV_TIMINGS - VIDIOC_G_DV_TIMINGS Please refer to the RFC for the details. This code was tested using vpfe capture driver on TI's DM365. Following is the test configuration used :- Blu-Ray HD DVD source -> TVP7002 -> DM365 (VPFE) ->DDR A draft version of the TVP7002 driver (currently being reviewed in the mailing list) was used that supports V4L2_DV_1080I60 & V4L2_DV_720P60 presets. A loopback video capture application was used for testing these APIs. This calls following IOCTLS :- - verify the new v4l2_input capabilities flag added - Enumerate available presets using VIDIOC_ENUM_DV_PRESETS - Set one of the supported preset using VIDIOC_S_DV_PRESET - Get current preset using VIDIOC_G_DV_PRESET - Detect current preset using VIDIOC_QUERY_DV_PRESET - Using stub functions in tvp7002, verify VIDIOC_S_DV_TIMINGS and VIDIOC_G_DV_TIMINGS ioctls are received at the sub device. - Tested on 64bit platform by Hans Verkuil Signed-off-by: Muralidharan Karicheri <m-karicheri2@ti.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12549): v4l2: video device: Add FM TX controls default configurationsEduardo Valentin
This patch adds basic configurations for FM TX extended controls. That includes controls names, menu strings, pointer identification, type classification and flags configuration. Signed-off-by: Eduardo Valentin <eduardo.valentin@nokia.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-09-12V4L/DVB (12543): v4l: introduce string control support.Hans Verkuil
The upcoming RDS encoder needs support for string controls. This patch implements the core implementation. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-03-30V4L/DVB (10910): videodev2.h: remove deprecated VIDIOC_G_CHIP_IDENT_OLDHans Verkuil
As announced VIDIOC_G_CHIP_IDENT_OLD is now removed for 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10141): v4l2: debugging API changed to match against driver name ↵Hans Verkuil
instead of ID. Since the i2c driver ID will be removed in the near future we have to modify the v4l2 debugging API to use the driver name instead of driver ID. Note that this API is not used in applications other than v4l2-dbg.cpp as it is for debugging and testing only. Should anyone use the old VIDIOC_G_CHIP_IDENT, then this will be logged with a warning that it is deprecated and will be removed in 2.6.30. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10139): v4l: rename v4l_compat_ioctl32 to v4l2_compat_ioctl32Hans Verkuil
This rename prevents conflicts with the older compat_ioctl32 module. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10138): v4l2-ioctl: change to long return type to match unlocked_ioctl.Hans Verkuil
Since internal to v4l2 the ioctl prototype is the same regardless of it being called through .ioctl or .unlocked_ioctl, we need to convert it all to the long return type of unlocked_ioctl. Thanks to Jean-Francois Moine for posting an initial patch for this and thus bringing it to our attention. Cc: Jean-Francois Moine <moinejf@free.fr> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10135): v4l2: introduce v4l2_file_operations.Hans Verkuil
Introduce a struct v4l2_file_operations for v4l2 drivers. Remove the unnecessary inode argument. Move compat32 handling (and llseek) into the v4l2-dev core: this is now handled in the v4l2 core and no longer in the drivers themselves. Note that this changeset reverts an earlier patch that changed the return type of__video_ioctl2 from int to long. This change will be reinstated later in a much improved version. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2009-01-02V4L/DVB (10132): v4l2-compat-ioctl32: remove dependency on videodev.Hans Verkuil
2008-12-30V4L/DVB (9934): v4l2-compat32: add two additional #ifdef __OLD_VIDIOC_ linesHans Verkuil
2008-12-30V4L/DVB (9932): v4l2-compat32: fix 32-64 compatibility moduleHans Verkuil
Added all missing v4l1/2 ioctls and fix several broken conversions. Partially based on work done by Cody Pisto <cpisto@gmail.com>. Tested-by: Brandon Jenkins <bcjenkins@tvwhere.com> Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-12-30V4L/DVB (9905): v4l2-compat32: add missing newline after kernel messageHans Verkuil
2008-12-29V4L/DVB (9484): v4l: rename compat_ioctl32.c to v4l2-compat-ioctl32.cHans Verkuil
All core v4l sources should start with 'v4l2-' This file was the last one for which this was not the case. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
