path: root/drivers/media/video/v4l2-mem2mem.c
2011-03-22[media] Update Pawel Osciak's e-mail addressPawel Osciak
Signed-off-by: Pawel Osciak <pawel@osciak.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: mem2mem: port to videobuf2Marek Szyprowski
Port memory-to-memory framework to videobuf2 framework. Add support for multi-planar Video for Linux 2 API extensions to the memory-to-memory driver framework. Based on the original patch written by Pawel Osciak. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-21V4L/DVB: videobuf: prepare to make locking optional in videobufHans Verkuil
Currently videobuf uses the vb_lock mutex to lock its data structures. But this locking will (optionally) move into the v4l2 core, which means that in that case vb_lock shouldn't be used since the external lock is already held. Prepare for this by adding a pointer to such an external mutex and don't lock if that pointer is set. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-05-19V4L/DVB: add memory-to-memory device helper framework for videobufPawel Osciak
A mem-to-mem device is a device that uses memory buffers passed by userspace applications for both their source and destination data. This is different from existing drivers, which utilize memory buffers for either input or output, but not both. In terms of V4L2 such a device would be both of OUTPUT and CAPTURE type. Examples of such devices would be: image 'resizers', 'rotators', 'colorspace converters', etc. This patch adds a separate Kconfig sub-menu for mem-to-mem devices as well. Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Vaibhav Hiremath <hvaibhav@ti.com> Tested-by: Vaibhav Hiremath <hvaibhav@ti.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
