path: root/drivers/media/video/videobuf2-memops.c
2011-07-30Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (430 commits) [media] ir-mce_kbd-decoder: include module.h for its facilities [media] ov5642: include module.h for its facilities [media] em28xx: Fix DVB-C maxsize for em2884 [media] tda18271c2dd: Fix saw filter configuration for DVB-C @6MHz [media] v4l: mt9v032: Fix Bayer pattern [media] V4L: mt9m111: rewrite set_pixfmt [media] V4L: mt9m111: fix missing return value check mt9m111_reg_clear [media] V4L: initial driver for ov5642 CMOS sensor [media] V4L: sh_mobile_ceu_camera: fix Oops when USERPTR mapping fails [media] V4L: soc-camera: remove soc-camera bus and devices on it [media] V4L: soc-camera: un-export the soc-camera bus [media] V4L: sh_mobile_csi2: switch away from using the soc-camera bus notifier [media] V4L: add media bus configuration subdev operations [media] V4L: soc-camera: group struct field initialisations together [media] V4L: soc-camera: remove now unused soc-camera specific PM hooks [media] V4L: pxa-camera: switch to using standard PM hooks [media] NetUP Dual DVB-T/C CI RF: force card hardware revision by module param [media] Don't OOPS if videobuf_dvb_get_frontend return NULL [media] NetUP Dual DVB-T/C CI RF: load firmware according card revision [media] omap3isp: Support configurable HS/VS polarities ... Fix up conflicts: - arch/arm/mach-omap2/board-rx51-peripherals.c: cleanup regulator supply definitions in mach-omap2 vs OMAP3: RX-51: define vdds_csib regulator supply - drivers/staging/tm6000/tm6000-alsa.c (trivial)
2011-07-27[media] V4L/videobuf2-memops: use pr_debug for debug messagesUwe Kleine-König
Otherwise they clutter the dmesg buffer even on a production kernel. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-06-20treewide: remove duplicate includesVitaliy Ivanov
Many stupid corrections of duplicated includes based on the output of scripts/checkincludes.pl. Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-22[media] Update Pawel Osciak's e-mail addressPawel Osciak
Signed-off-by: Pawel Osciak <pawel@osciak.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] V4L: add missing EXPORT_SYMBOL* statements to vb2Guennadi Liakhovetski
videobuf2-memops and videobuf2-core can be compiled as modules, in which case 3 more symbols from videobuf2-memops.c have to be exported. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-21[media] v4l: videobuf2: add generic memory handling routinesMarek Szyprowski
Add generic memory handling routines for userspace pointer handling, contiguous memory verification and mapping. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Pawel Osciak <p.osciak@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Pawel Osciak <pawel@osciak.com> Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
