path: root/drivers/media/video/videodev.c
2008-04-24V4L/DVB (7665): videodev: Add default vidioc handlerDouglas Schilling Landgraf
Added default vidioc handler for other private ioctls Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7560): videodev: Some printk fixesMauro Carvalho Chehab
2008-04-24V4L/DVB (7558): videobuf: Improve command output for debug purposesMauro Carvalho Chehab
2008-04-24V4L/DVB (7518): media/video/ replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-02-18V4L/DVB (7133): Fix Kconfig dependenciesMauro Carvalho Chehab
As pointed by Adrian Bunk, with I2C=m and VIDEO_DEV=y, videodev brokes. This patch moves the functions that videodev needs from v4l2-common. It also fixes some Kconfig changes. After this patch, I2C=m / VIDEO_DEV=y will make v4l2 core statically linked into kernel. v4l2-common will be m, and all V4L drivers will also be m. This approach is very conservative, since it is possible to have V4L drivers that don't need I2C or v4l2-common. The better is to map what drivers really need v4l2-common, making them to select v4l2-common, and allowing the others to be 'y', 'm' and 'n'. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-01-25V4L/DVB (6805): video std is a bitmask. Better to print in hexaMauro Carvalho Chehab
2007-10-22V4L/DVB (6321): Remove obsolete VIDIOC_S/G_MPEGCOMP ioctlsHans Verkuil
Remove the obsolete VIDIOC_G_MPEGCOMP and VIDIOC_S_MPEGCOMP ioctls from the V4L2 API as per the removal schedule (October 2007). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-10V4L/DVB (6300): CodingStyle cleanupTrent Piepho
Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-10V4L/DVB (6293): V4L: convert struct class_device to struct deviceKay Sievers
The currently used "struct class_device" will be removed from the kernel. Here is a patch that converts all users in drivers/media/video/ to struct device. Reviewed-by: Thierry Merle <thierry.merle@free.fr> Reviewed-by: Mike Isely <isely@pobox.com> Reviewed-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5982): Dev.c: memset fixMariusz Kozlowski
Looks like memset() is zeroing wrong nr of bytes. Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5617): V4L2: videodev, allow debuggingJiri Slaby
videodev, allow debugging fix typo? in videodev.c to allow debugging Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5569): Fix: v4l1_compat should be called only if V4L1_COMPATMauro Carvalho Chehab
Added also some explanations about V4L1 handling Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-09V4L/DVB (5568): VIDIOCGMBUF handling in video_ioctl2()Sam Revitch
Correct handling of VIDIOCGMBUF in video_ioctl2(). Signed-off-by: Sam Revitch <samr7@cs.washington.edu> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5554): Fix: vidioc_g_parm were not zeroing the memoryMauro Carvalho Chehab
2007-04-27V4L/DVB (5306): Add support for VIDIOC_G_CHIP_IDENTHans Verkuil
VIDIOC_G_CHIP_IDENT improves debugging of card problems: it can be used to detect which chips are on the board and based on that information selected register dumps can be made, making it easy to debug complicated media chips containing tens or hundreds of registers. This ioctl replaces the internal VIDIOC_INT_G_CHIP_IDENT ioctl. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-04-27V4L/DVB (5289): Add support for video output overlays.Hans Verkuil
Add V4L2_BUF_TYPE_VIDEO_OUTPUT_OVERLAY support. Also add support for local and global alpha overlays. Add new field enums V4L2_FIELD_INTERLACED_TB and V4L2_FIELD_INTERLACED_BT. These changes are needed to support the ivtv On Screen Display features. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5271): Add VIDIOC_TRY_ENCODER_CMD and VIDIOC_ENCODER_CMD ioctls.Hans Verkuil
Add support for starting, stopping, pausing and resuming an MPEG (or similar compressed stream) encoder. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-03-01V4L/DVB (5270): Add VIDIOC_G_ENC_INDEX ioctlHans Verkuil
The VIDIOC_G_ENC_INDEX ioctl can obtain the MPEG index from an MPEG encoder. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5163): Add checks for CAP_SYS_ADMIN to VIDIOC_DBG_G_REGISTERTrent Piepho
Before, root privileges were only needed to set hardware registers, not to read them. On some hardware, reading from the wrong place at the wrong time can hang the machine. So, to be consistent, root privileges are required to read registers on all hardware. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5146): Make VIDIOC_INT_[SG]_REGISTER ioctls no longer internal onlyTrent Piepho
The direct register access ioctls were defined as kernel internal only, but they are very useful for debugging hardware from userspace and are used as such. Officially export them. VIDIOC_INT_[SG]_REGISTER is renamed to VIDIOC_DBG_[SG]_REGISTER Definition of ioctl and struct v4l2_register is moved from v4l2-common.h to videodev2.h. Types used in struct v4l2_register are changed to the userspace exportable versions (u32 -> __u32, etc). Use of VIDIOC_DBG_S_REGISTER requires CAP_SYS_ADMIN permission, so move the check into the video_ioctl2() dispatcher so it doesn't need to be duplicated in each driver's call-back function. CAP_SYS_ADMIN check is added to pvrusb2 (which doesn't use video_ioctl2). Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-21V4L/DVB (5144): Restore VIDIOC_INT_[SG]_REGISTER callsTrent Piepho
Add support for these ioctls to the video_ioctl2 system and the cx88 driver. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-02-12[PATCH] mark struct file_operations const 4Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@sdl.org: dvb fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-10V4L/DVB (4901): Improve debug msgs to show fourcc and buffer length on ↵Mauro Carvalho Chehab
video_ioctl2 Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4861): Remove the need of a STD array for drivers using video_ioctl2Mauro Carvalho Chehab
video_ioctl2 will auto-generate standard entries at ENUM_FMT. Also, now, a driver may return a subset of the video array at the return, to be stored as the current_norm. For example, a driver may ask for V4L2_STD_PAL. At return, driver may change it to V4L2_STD_PAL_B. This way, a futher call to G_STD will return the exact detected video std. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-12-10V4L/DVB (4860): Optimization of v4l1 handlingMauro Carvalho Chehab
2006-12-10V4L/DVB (4859): Fix initializations on some video_ioctl2 handlersMauro Carvalho Chehab
2006-12-08[PATCH] struct path: convert v4lJosef Sipek
2006-10-14V4L/DVB (4743): Fix oops in VIDIOC_G_PARMJonathan Corbet
The call to v4l2_std_construct() in the VIDIOC_G_PARM handler treats vfd->current_norm as if it were an index - but it's not. The result is an oops if the driver has no vidioc_g_parm() method defined. Here's the fix. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-10-14V4L/DVB (4740): Fixed an if-block to avoid floating with debug-messagesEnrico Scholz
The dbgarg() macro in videodev.c contains some printk() statements where only the first one is influenced by an if-statement. This causes floating with debug-messages which is fixed by this patch by adding a '{ ... }' pair. Signed-off-by: Enrico Scholz <enrico.scholz@informatik.tu-chemnitz.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4637): Add a default method for VIDIOC_G_PARMMauro Carvalho Chehab
For most drivers, VIDIOC_G_PARM will just return the current standard fps. So, instead of failing, drivers based on video_ioctl2 will implement the default method. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4628): Fix VIDIOC_ENUMSTD ioctl in videodev.cSascha Hauer
Do not return -EINVAL for index=0 in VIDIOC_ENUMSTD, because it is a valid index Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-26V4L/DVB (4622): Copy-paste bug in videodev.cSascha Hauer
This patch fixes a copy-paste bug in videodev.c where the vidioc_qbuf() function gets called for the dqbuf ioctl. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-25[PATCH] VIDIOC_ENUMSTD bugJonathan Corbet
The v4l2 API documentation for VIDIOC_ENUMSTD says: To enumerate all standards applications shall begin at index zero, incrementing by one until the driver returns EINVAL. The actual code, however, tests the index this way: if (index<=0 || index >= vfd->tvnormsize) { ret=-EINVAL; So any application which passes in index=0 gets EINVAL right off the bat - and, in fact, this is what happens to mplayer. So I think the following patch is called for, and maybe even appropriate for a 2.6.18.x stable release. Signed-off-by: Jonathan Corbet <corbet@lwn.net> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-08V4L/DVB (4399): Fix a typo that caused some compat stuff to not workMauro Carvalho Chehab
Config option typo: -#ifdef CONFIG_V4L1_COMPAT +#ifdef CONFIG_VIDEO_V4L1_COMPAT Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-07-29V4L/DVB (4379): Videodev: Check return value of class_device_register() ↵Trent Piepho
correctly Errors are return values < 0, not != 0. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-07-29V4L/DVB (4368): Bttv: use class_device_create_file and handle errorsTrent Piepho
Revert bttv-driver.c from video_device_create_file() to use class_device_create_file() again. video_device_create_file() is only available when V4L1 is on. Proper error checking is added for failure of class_device_create_file(). Will print error message and unroll partially created sysfs entries. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-07-29V4L/DVB (4367): Videodev: Handle class_device related errorsTrent Piepho
Add proper error checking and roll-back for failure of class_device_create_file() in videodev.c. Print error messages and unroll partially created sysfs entries. Also, failure of class_device_register() in video_register_device() is handled correctly. It was failing to de-allocate the minor number. This must be done in video_register_device(), since the caller has no way of knowing if failure occurred before or after the class device was registered. Also added an error message if video_register_device() is called with an unknown type, which should never happen. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-07-29V4L/DVB (4343): Fix for compilation without V4L1 or V4L1_COMPATMauro Carvalho Chehab
Removed usage of HAVE_V4L1 Including videodev.h will just include videodev2.h if V4L1 is not supported V4L1 code at core drivers will honor CONFIG_V4L1_COMPAT stuff Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-07-29V4L/DVB (4316): Check __must_check warningsMichael Krufky
Check __must_check warnings for class_device_register and class_device_create_file video_device_create_file was declared as a void, but instead should return the int value of class_device_create_file. Move the check from bttv-driver.c into v4l2-dev.h, because all other callers of video_device_create_file must also be checked. Replace the call to class_device_create_file in videodev.c with video_device_create_file, as defined in v4l2-dev.h, so that the return value of class_device_create_file will be checked. Check the return value of class_device_register in videodev.c and pvrusb2-sysfs.c Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-26[PATCH] devfs: Remove the videodevice devfs_name field as it's no longer neededGreg Kroah-Hartman
Also fixes all drivers that set this field. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove the devfs_fs_kernel.h file from the treeGreg Kroah-Hartman
Also fixes up all files that #include it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_remove() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_remove() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-26[PATCH] devfs: Remove devfs_mk_cdev() function from the kernel treeGreg Kroah-Hartman
Removes the devfs_mk_cdev() function and all callers of it. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-25V4L/DVB (4198): Avoid newer usages of obsoleted experimental MPEGCOMP APIHans Verkuil
Put old MPEGCOMP API under #if __KERNEL__ and issue warnings when used. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4189): Add videodev support for VIDIOC_S/G/TRY_EXT_CTRLS.Hans Verkuil
videodev.c copies the control list specified in struct v4l2_ext_controls to kernel space. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4148): Fix userbits debug printsMauro Carvalho Chehab
Previously, it were showing the pointer value, instead of the setted bits. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4112): Fix: videodev.c were cleaning the pointer, not the valuesMauro Carvalho Chehab
2006-06-25V4L/DVB (4065): Several improvements at videodev.cMauro Carvalho Chehab
Videodev now is capable of better handling V4L2 api, by processing V4L2 ioctls and using callbacks to the driver. The drivers should be migrated to the newer way and the older one will be obsoleted soon. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
