On 05/29/10 01:30, Jean-Francois Moine wrote:
> On Fri, 28 May 2010 13:03:28 -0400
> Amerigo Wang<amwang@redhat.com> wrote:
>> Subject: [PATCH 6/6] Remove obsolete zc0301 v4l driver
>> Duplicate functionality with the gspca_zc3xx driver, zc0301 only
>> supports 2 USB-ID's (because it only supports a limited set of
>> sensors) wich are also supported by the gspca_zc3xx driver
>> (which supports 53 USB-ID's in total).
> You forgot to remove the conditionnal compilation in the gspca_zc3xx
> driver (USB_DEVICE(0x046d, 0x08ae) in gspca/zc3xx.c)
Right, thanks for pointing this out!
Attached is the updated patch, please use this one instead.
Thanks!
Signed-off-by: Amerigo Wang <amwang@redhat.com>
Return an error if the controller is not found.
Now that the video_device registration is tested using
video_is_registered(), drivers don't need to initialize the
video_device::minor field to -1 anymore.
Remove those unneeded assignments.
[mchehab.redhat.com: removed tm6000 changes as tm6000 is not ready yet for submission even on staging]
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Fix all device drivers to use the new video_device_node_name function.
This also strips kernel log messages from the "/dev/" prefix, has the device
node location is a userspace policy decision unknown to the kernel.
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
calculation in some V4L2 drivers
Signed-off-by: Andreas Mohr <andi@lisas.de>
Since internal to v4l2 the ioctl prototype is the same regardless of it
being called through .ioctl or .unlocked_ioctl, we need to convert it all
to the long return type of unlocked_ioctl.
Thanks to Jean-Francois Moine for posting an initial patch for this and
thus bringing it to our attention.
Cc: Jean-Francois Moine <moinejf@free.fr>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Introduce a struct v4l2_file_operations for v4l2 drivers.
Remove the unnecessary inode argument.
Move compat32 handling (and llseek) into the v4l2-dev core: this is now
handled in the v4l2 core and no longer in the drivers themselves.
Note that this changeset reverts an earlier patch that changed the return
type of__video_ioctl2 from int to long. This change will be reinstated
later in a much improved version.
dev_set_name()
This patch is part of a larger patch series which will remove
the "char bus_id[20]" name string from struct device. The device
name is managed in the kobject anyway, and without any size
limitation, and just needlessly copied into "struct device".
To set and read the device name dev_name(dev) and dev_set_name(dev)
must be used. If your code uses static kobjects, which it shouldn't
do, "const char *init_name" can be used to statically provide the
name the registered device should have. At registration time, the
init_name field is cleared, to enforce the use of dev_name(dev) to
access the device name at a later time.
We need to get rid of all occurrences of bus_id in the entire tree
to be able to enable the new interface. Please apply this patch,
and possibly convert any remaining remaining occurrences of bus_id.
We want to submit a patch to -next, which will remove bus_id from
"struct device", to find the remaining pieces to convert, and finally
switch over to the new api, which will remove the 20 bytes array
and does no longer have a size limitation.
Thanks,
Kay
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
The kernel number of a v4l2 node (e.g. videoX, radioX or vbiX) is now
independent of the minor number. So instead of using the minor field
of the video_device struct one has to use the num field: this always
contains the kernel number of the device node.
I forgot about this when I did the v4l2 core change, so this patch
converts all drivers that use it in one go. Luckily the change is
trivial.
Cc: michael@mihu.de
Cc: mchehab@infradead.org
Cc: corbet@lwn.net
Cc: luca.risolia@studio.unibo.it
Cc: isely@pobox.com
Cc: pe1rxq@amsat.org
Cc: royale@zerezo.com
Cc: mkrufky@linuxtv.org
Cc: stoth@linuxtv.org
video_drvdata(filp)
Use the new video_drvdata(filp) function where it is safe to do so.
While doing some testing using Luca Risolia's sonix driver I noticed that
the video device did not get ACL's set to allow access by locally logged in
users, nor does it show up as a video device in lshal, causing cheese to not
see it.
This turns out to be caused by all of Luca Risolia's drivers not setting
the parent member of the video_device struct. This patch fixes this.
Cc: Luca Risolia <luca.risolia@studio.unibo.it>
Signed-off-by: Hans de Goede <j.w.r.degoede@hhs.nl>
The type and type2 fields were unused and so could be removed.
Instead add a vfl_type field that contains the type of the video
device.
Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
According to an old comment this should have been removed in 2.6.15.
Better late than never...
Use asm/byteorder.h instead.
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Added macro CONFIG_COMPAT for v4l_compat_ioctl32.
Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com>
- Static memory is always initialized with 0.
- Replaced in some cases C99 comments for /* */
struct video_device used to define a .hardware field. While
initialized on severl drivers, this field is never used inside V4L.
However, drivers using it need to include the old V4L1 header.
This seems to cause compilation troubles with some random configs.
Better just to remove it from all drivers.
zc0301, remove bad usage of ERESTARTSYS
down_read_trylock can't be interrupted and so ERESTARTSYS would reach
userspace, which is not permitted. Change it to EAGAIN
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Acked-by: Luca Risolia <luca.risolia@studio.unibo.it>
Since at least kernel 2.6.12-rc2, module.h includes moduleparm.h. This
patch removes all occurences of moduleparm.h from drivers/media files.
- Make the driver depend on V4L2 only (KConfig)
- Better and safe locking mechanism of the device structure on open(), close()
and disconnect()
- Use kref for handling device deallocation
- Generic cleanups
Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it>
- Implement audio ioctl's and VIDIOC_ENUM_FRAMESIZES
- Documentation updates
- Generic improvements
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
[akpm@sdl.org: dvb fix]
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
- usb_free_urb() cleanup
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead
of passing regs around manually through all ~1800 interrupt handlers in the
Linux kernel.
The regs pointer is used in few places, but it potentially costs both stack
space and code to pass it around. On the FRV arch, removing the regs parameter
from all the genirq function results in a 20% speed up of the IRQ exit path
(ie: from leaving timer_interrupt() to leaving do_IRQ()).
Where appropriate, an arch may override the generic storage facility and do
something different with the variable. On FRV, for instance, the address is
maintained in GR28 at all times inside the kernel as part of general exception
handling.
Having looked over the code, it appears that the parameter may be handed down
through up to twenty or so layers of functions. Consider a USB character
device attached to a USB hub, attached to a USB controller that posts its
interrupts through a cascaded auxiliary interrupt controller. A character
device driver may want to pass regs to the sysrq handler through the input
layer which adds another few layers of parameter passing.
I've build this code with allyesconfig for x86_64 and i386. I've runtested the
main part of the code on FRV and i386, though I can't test most of the drivers.
I've also done partial conversion for powerpc and MIPS - these at least compile
with minimal configurations.
This will affect all archs. Mostly the changes should be relatively easy.
Take do_IRQ(), store the regs pointer at the beginning, saving the old one:
struct pt_regs *old_regs = set_irq_regs(regs);
And put the old one back at the end:
set_irq_regs(old_regs);
Don't pass regs through to generic_handle_irq() or __do_IRQ().
In timer_interrupt(), this sort of change will be necessary:
- update_process_times(user_mode(regs));
- profile_tick(CPU_PROFILING, regs);
+ update_process_times(user_mode(get_irq_regs()));
+ profile_tick(CPU_PROFILING);
I'd like to move update_process_times()'s use of get_irq_regs() into itself,
except that i386, alone of the archs, uses something other than user_mode().
Some notes on the interrupt handling in the drivers:
(*) input_dev() is now gone entirely. The regs pointer is no longer stored in
the input_dev struct.
(*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does
something different depending on whether it's been supplied with a regs
pointer or not.
(*) Various IRQ handler function pointers have been moved to type
irq_handler_t.
Signed-Off-By: David Howells <dhowells@redhat.com>
(cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
V4L core functions handle VIDIOC_*_OLD older ioctls.
This is a patch fixing a small bug in zc0301_start_transfer()
introduced in the ZC0301 driver v1.04.
ZC0301 driver updates:
- Add support for PB-0330 image sensor
- Generic documentation cleanups and updates
Because of historic reasons, there are two separate directories with
V4L stuff. Most drivers are located at driver/media/video. However, some
code for USB Webcams were inserted under drivers/usb/media.
This makes difficult for module authors to know were things should be.
Also, makes Kconfig menu confusing for normal users.
This patch moves all V4L content under drivers/usb/media to
drivers/media/video, and fixes Kconfig/Makefile entries.
