path: root/drivers/media/video/zoran_driver.c
2008-10-12V4L/DVB (9129): zoran: move zoran sources into a zoran subdirectoryHans Verkuil
Prevent the zoran driver sources from cluttering the video directory. This changeset only moves the drivers and it does not fix any of the checkpatch warnings/errors to keep the changeset clean. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8962): zr36067: VIDIOC_S_FMT returns the colorspace valueJean Delvare
Ioctl VIDIOC_S_FMT is supposed to fill the colorspace value in the returned buffer. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8906): v4l-dvb: fix assorted sparse warningsHans Verkuil
Fix sparse warnings. None are serious, but cutting down on these helps find future serious sparse warnings/errors. Redid the av7710.c patch based on a suggestion by Oliver Endriss. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-12V4L/DVB (8613): v4l: move BKL down to the driver level.Hans Verkuil
The BKL is now moved from the video_open function in v4l2-dev.c to the various drivers. It seems about a third of the drivers already has a lock of some sort protecting the open(), another third uses video_exclusive_open (yuck!) and the last third required adding the BKL in their open function. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-04V4L/DVB (8961): zr36067: Fix RGBR pixel formatJean Delvare
The zr36067 driver is improperly declaring pixel format RGBP twice, once as "16-bit RGB LE" and once as "16-bit RGB BE". The latter is actually RGBR. Fix the code to properly map both pixel formats. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Trent Piepho <xyzzy@speakeasy.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-10-04V4L/DVB (8958): zr36067: Return proper bytes-per-line valueJean Delvare
The zr36067 driver should return the actual bytes-per-line value when queried with ioctl VIDIOC_G_FMT, instead of 0. Otherwise user-space applications can get confused. Likewise, with ioctl VIDIOC_S_FMT, we are supposed to fill the bytes-per-line value. And we shouldn't fail if the caller sets the initial value to something different from 0. This is perfectly valid for applications to pre-fill this field with the value they expect. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2008-07-27V4L/DVB (8523): v4l2-dev: remove unused type and type2 field from video_deviceHans Verkuil
The type and type2 fields were unused and so could be removed. Instead add a vfl_type field that contains the type of the video device. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-26V4L/DVB (8499): zr36067: Rework device memory allocationJean Delvare
Allocate zoran devices dynamically. Currently, the zr36067 driver stores the device structures in a global array, with room for 4 devices. This makes the bss section very large (90 kB!), and given that most users, I suspect, have only one zoran device, this is a waste of kernel memory. Allocating the memory dynamically lets us use only the amount of memory we need. Before: text data bss dec hex filename 64754 9230 90224 164208 28170 drivers/media/video/zr36067.o After: text data bss dec hex filename 64866 9230 112 74208 121e0 drivers/media/video/zr36067.o Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Ronald Bultje <rbultje@ronald.bitfreak.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-23V4L/DVB (8430): videodev: move some functions from v4l2-dev.h to ↵Hans Verkuil
v4l2-common.h or v4l2-ioctl.h The functions in a header should not belong to another module. The prio functions belong to v4l2-common.c, so move them to v4l2-common.h. The ioctl functions belong to v4l2-ioctl.c, so create a new v4l2-ioctl.h header and move those functions to it. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8134): zoran annotations and fixesAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-07-20V4L/DVB (8095): zoran_driver.c: Removed duplicated includeHuang Weiyi
Removed duplicated include file <asm/byteorder.h> in drivers/media/video/zoran_driver.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-06-05V4L/DVB (7968): zoran: endianness annotationsAl Viro
2008-06-05V4L/DVB (7901): zoran: use correct type for CPU flagsAndrew Morton
locking-add-typecheck-on-irqsave-and-friends-for-correct-flags.patch will cause drivers/media/video/zoran_driver.c: In function 'zoran_close_end_session': drivers/media/video/zoran_driver.c:1172: warning: comparison of distinct pointer types lacks a cast Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-05-16byteorder: don't directly include linux/byteorder/generic.hHarvey Harrison
Use asm/byteorder.h instead. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-24V4L/DVB (7584): Fix build that occurs when CONFIG_VIDEO_PMS=y and ↵Mauro Carvalho Chehab
VIDEO_V4L2_COMMON=m This patch removes zoran checks for VIDEO_V4L2, since this API is always present, when V4L is selected. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7518): media/video/ replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7402): add macro validation for v4l_compat_ioctl32Douglas Schilling Landgraf
Added macro CONFIG_COMPAT for v4l_compat_ioctl32. Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-04-24V4L/DVB (7094): static memoryDouglas Schilling Landgraf
- Static memory is always initialized with 0. - Replaced in some cases C99 comments for /* */ Signed-off-by: Douglas Schilling Landgraf <dougsland@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2008-03-30NULL noise: drivers/mediaAl Viro
Acked-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22V4L/DVB (6320): v4l core: remove the unused .hardware V4L1 fieldMauro Carvalho Chehab
struct video_device used to define a .hardware field. While initialized on severl drivers, this field is never used inside V4L. However, drivers using it need to include the old V4L1 header. This seems to cause compilation troubles with some random configs. Better just to remove it from all drivers. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-19Use helpers to obtain task pid in printksPavel Emelyanov
The task_struct->pid member is going to be deprecated, so start using the helpers (task_pid_nr/task_pid_vnr/task_pid_nr_ns) in the kernel. The first thing to start with is the pid, printed to dmesg - in this case we may safely use task_pid_nr(). Besides, printks produce more (much more) than a half of all the explicit pid usage. [akpm@linux-foundation.org: git-drm went and changed lots of stuff] Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Cc: Dave Airlie <airlied@linux.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10V4L/DVB (6285): Remove pointless kmalloc() return value cast in Zoran PCI ↵Jesper Juhl
controller driver No need to cast the void pointer returned by kmalloc() in drivers/media/video/zoran_driver.c::v4l_fbuffer_alloc(). Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5981): Zoran_driver.c: fix memset in ioctlMariusz Kozlowski
Looks like memset() is zeroing wrong nr of bytes. Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5885): zr36067: Fix problems with module parametersTrent Piepho
Add permissions to all the module parameters so they can be queried and set (when possible) via sysfs. Add description for the vidmem parameter. Change the video_nr parameter to an array, so that the video number can be specified when a user has more than one card. The driver would try to give all cards the same number otherwise, which will fail for all cards after the first. The default_input option would only allow values of 0 or 1, contrary to the description. Allow values up to the number of inputs defined for the card. Add description of lock_norm's different behavior for 1 and >1. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Ronald S. Bultje <rbultje@ronald.bitfreak.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-10-09V4L/DVB (5884): zr36067: clean up debug functionJean Delvare
Debugging cleanups to the zr36067 driver: * Use module_param_named() to declare the debug parameter, so we can use a single global variable to handle the debug level. This makes the driver a bit smaller (by 648 bytes on x86_64), thanks to one less level of indirection on every use. * Change the debug parameter sysfs permissions, so that the debug level can be adjusted at runtime, as is done in many other media/video drivers. * The debug level is between 0 and 5, not 0 and 4. * Move the zr_debug export and dprintk macro definition to a header file so that we don't have to define them in each source file. * Simplify a duplicate test on zr_debug. Note that zr_debug was subsequently renamed to debug_zr36067 to avoid possible conflicts with other Zoran device drivers, on a suggestion by Trent Piepho. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Ronald S. Bultje <rbultje@ronald.bitfreak.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-30V4L/DVB (5891): zr36067: Turn off raw capture properlyTrent Piepho
When raw capture was turned off, the current capturing frame (v4l_grab_frame) wasn't reset to NO_GRAB_ACTIVE. If capture was turned back on, the driver would think this frame was currently being captured, and wait for it to complete before starting a new frame. The hardware on the other hand would not be actively capturing a frame. The result was the driver would wait forever for v4l_grab_frame to be captured. Some calls to zr36057_set_memgrab(0) were missing spin-locks, which have been added. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Ronald S. Bultje <rbultje@ronald.bitfreak.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-30V4L/DVB (5890): zr36067: Add UYVY, RGB555X, RGB565X, and RGB32 formatsTrent Piepho
Add support for the UYVY and the other big endian output formats. The driver was naming formats based on the host endianess. This is different that all the other drivers appear to work and not what software appears to expect. Use ARRAY_SIZE() to find the the size of the zoran_formats array. Change the way the driver handles setting the video format register. Rather than use some if and switch statements to set to register by looking at the format id, the format list simply has a field with the proper bits to set. Adds a bit of ifdef to make a driver without V4L1 support more possible. Also create a macro for defining formats that handles vl41 and/or vl42 support to avoid repeated ifdefs in the format list. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Ronald S. Bultje <rbultje@ronald.bitfreak.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-30V4L/DVB (5888): zr36067: Driver was not returning correct image sizeTrent Piepho
The driver was returning the size of the (fixed) buffer it allocated as the sizeimage field in the v4l2 pixel format, rather than the actual size of the image. For example, a 192x128 YUYV image is 49152 bytes but the driver would always return 131072 bytes since if that was the size of the v4l buffer. This violates the v4l2 spec, which says that sizeimage should be the actual size of the image for uncompressed formats. It also caused mplayer to crash. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Ronald S. Bultje <rbultje@ronald.bitfreak.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-30V4L/DVB (5887): zr36067: Fix poll() operationTrent Piepho
During uncompressed capture, the poll() function was looking the wrong frame. It was using the frame the driver was going to capture into next (pend_tail), when it should have been looking at the next frame to be de-queued with DQBUF/SYNC (sync_tail). It also wasn't looking in the right spot. It was looking at the file handle's copy of the buffer status, rather than the driver core copy. The interrupt routine marks frames as done in the driver core copy, the file handle copy isn't updated. So even if poll() looked at the right frame, it would never see it transition to done and return POLLIN. The compressed capture code has this same problem, looking in fh->jpg_buffers when it should have used zr->jpg_buffers. There was some logic to detect when there was no current capture in process nor any frames queued and try to return an error, which ends up being a bad idea. It's possible to call select() from one thread while no capture is in process, or no frames queued, and then start a capture or queue frames from another thread. The buffer state variables are protected by a spin lock, which the code wasn't acquiring. That is fixed too. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Ronald S. Bultje <rbultje@ronald.bitfreak.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-30V4L/DVB (5886): zr36067: Fix problem setting normsTrent Piepho
The zr36067 driver doesn't make a distinction between the different sub-types of NTSC, PAL, or SECAM norms. For example, when the enum std ioctl returns the PAL standard it returns PAL_BG|PAL_DK|PAL_H|PAL_I. When setting the norm, it required the bitmask to match exactly the set of norms used during the enumeration. If just one norm was specified, for example PAL_BG or NTSC_M, it would fail. This violates the V4L2 spec, "VIDIOC_S_STD accepts *one* or more flags..." The key thing to realize is that V4L2_STD_PAL is not one bit, it is multiple bits. It's ok to call S_STD with any *one* of those bits, but the driver was requiring *all* of them. This fixes the S_STD function so that it will accept any set of one or more PAL norms as PAL, and the same for NTSC and SECAM. Signed-off-by: Trent Piepho <xyzzy@speakeasy.org> Acked-by: Ronald S. Bultje <rbultje@ronald.bitfreak.net> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-07-18V4L/DVB (5774a): Remove CONFIG_BIGPHYS_AREA from zoran_driverMauro Carvalho Chehab
CONFIG_BIGPHYS_AREA is an out-of-tree kernel patch. It makes no sense to keep supporting this on mainstream. The out-of-tree compilation with CONFIG_BIGPHYS_AREA will still be preserved at the v4l-dvb development tree at: http://linuxtv.org/hg/v4l-dvb Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2007-05-08Clean up mutex_trylock noiseJean Delvare
Ingo Molnar's semaphore to mutex conversions left some noise on a few trylock calls. Clean it up. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Mauro Carvalho Chehab <mchehab@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct file_operations const 4Arjan van de Ven
Many struct file_operations in the kernel can be "const". Marking them const moves these to the .rodata section, which avoids false sharing with potential dirty data. In addition it'll catch accidental writes at compile time to these shared resources. [akpm@sdl.org: dvb fix] Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] Get rid of "double zeroing" of allocated pagesRobert P. J. Day
Simplify the few instances where a call to "get_zeroed_page()" is closely followed by an unnecessary call to memset() to clear that page. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: chas williams <chas@cmf.nrl.navy.mil> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-09-26V4L/DVB (4632): Zoran: Implement pcipci failure checkAlan Cox
We should be doing this on all devices doing PCI<->PCI DMA. We only set the _FAIL ones when the DMA will fail or may cause crashes. This relies on the PCIAGP_FAIL patch I sent to Andrew already Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-09-10V4L/DVB (4605): Fixes an issue with V4L1 and make headers-installMauro Carvalho Chehab
V4L1 support should be disabled when no CONFIG_VIDEO_V4L1_COMPAT is defined, to allow checking for broken V4L2 ports. This is very important during the migration phase for V4L2 API. However, userspace apps should be capable of using both APIs, since they need to test at runtime, via VIDIOCGCAP ioctl, if V4L1 is supported. So, when __KERNEL__ is not defined, those ioctls and corresponding structs should be visible. This patch also removes the obsolete defines HAVE_V4L1 and HAVE_V4L2, that where causing some confusion, and were replaced by CONFIG_VIDEO_V4L1_COMPAT and CONFIG_VIDEO_V4L2. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4070): Zoran strncpy() fixEric Sesterhenn
The zoran driver uses strncpy() in an unsafe way. This patch uses the proper sizeof()-1 size parameter. Since all strncpy() targets are initialised with memset() the trailing '\0' is already set. Where std->name was the target for the strncpy() we overwrote 8 Bytes of the std structure with zeros. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-06-25V4L/DVB (4068): Removed all references to kernel stuff from videodev.h and ↵Mauro Carvalho Chehab
videodev2.h The videodev.h and videodev2.h describe the public API for V4L and V4L2. It shouldn't have there any kernel-specific stuff. Those were moved to v4l2-dev.h. This patch removes some uneeded headers and include v4l2-common.h on all V4L driver. This header includes device implementation of V4L2 API provided on v4l2-dev.h as well as V4L2 internal ioctls that provides connections between master driver and its i2c devices. Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-25V4L/DVB (3599b): Whitespace cleanups under drivers/mediaMauro Carvalho Chehab
2006-03-23V4L/DVB (3568g): sem2mutex: zoranIngo Molnar
Semaphore to mutexes conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-11V4L/DVB (3344a): Conversions from kmalloc+memset to k(z|c)allocPanagiotis Issaris
Conversions from kmalloc+memset to k(z|c)alloc. Signed-off-by: Panagiotis Issaris <takis@issaris.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-01-09V4L (926_2): Moves compat32 functions from fs to v4l subsystemArnd Bergmann
This moves the 32 bit ioctl compatibility handlers for Video4Linux into a new file and adds explicit calls to them to each v4l device driver. Unfortunately, there does not seem to be any code handling the v4l2 ioctls, so quite often the code goes through two separate conversions, first from 32 bit v4l to 64 bit v4l, and from there to 64 bit v4l2. My patch does not change that, so there is still much room for improvement. Also, some drivers have additional ioctl numbers, for which the conversion should be handled internally to that driver. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@brturbo.com.br>
2006-01-05[PATCH] i2c: Drop i2c_driver.{owner,name}, 5 of 11Laurent Riffard
We should use the i2c_driver.driver's .name and .owner fields instead of the i2c_driver's ones. This patch updates the drivers/media/video and usb/media drivers. Signed-off-by: Laurent Riffard <laurent.riffard@free.fr> Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-11-07[PATCH] prevent dmesg warning in zr36067 driverRonald S. Bultje
Fix the warning "Debug: sleeping function called from invalid context at include/asm/semaphore.h:102" that the zr36067 driver emits every time an application using JPEG capture starts up (e.g. mjpegtools' lavrec). The warning is harmless, but clogs up the dmesg output. This was logged as bugzilla #5403. (Thanks to Christian Casteyde for helping me in fixing this long-standing annoyance.) Signed-off-by: Ronald S. Bultje <rbultje@ronald.bitfreak.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] vfree and kfree cleanup in drivers/Jesper Juhl
This patch does a full cleanup of 'NULL checks before vfree', and a partial cleanup of calls to kfree for all of drivers/ - the kfree bit is partial in that I only did the files that also had vfree calls in them. The patch also gets rid of some redundant (void *) casts of pointers being passed to [vk]free, and a some tiny whitespace corrections also crept in. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
