Preview is showing as vertically-flipped in some camera apps.
Modified ov7695 orientation
Bug 1316532
Change-Id: I3470131016d637abcf5ea2a5c834272ffd8ee6be
Signed-off-by: Alvin Park <apark@nvidia.com>
Reviewed-on: http://git-master/r/280973
Reviewed-by: Karl Kim <kkim@nvidia.com>
GVS: Gerrit_Virtual_Submit
Reviewed-by: Peter Kim <pekim@nvidia.com>
NVCS can't set the full range because the ad5823 driver is
clipping position value as working range.
This is separated physical and working range
Bug 1340766
Change-Id: I61f4dbdc8572fd6b1725a9e0803656b9d0bc1ec4
Signed-off-by: Karl Kim <kkim@nvidia.com>
Reviewed-on: http://git-master/r/259886
Reviewed-by: Jake Park <jakep@nvidia.com>
Current OV5693 gain mode is sensor gain. sensor gain mode can't
support 16x gain. so gain mode change to real gain mode.
Bug 1310144
Change-Id: Iaf71983273655c93847b79ebd384020f14b75ff4
Reviewed-on: http://git-master/r/258663
Added getting exposure time API into ov7695 yuv sensor driver
Bug 1330342
Change-Id: Icbcacdce5c19515d0f6f6b35f5fc81fa4462f9a4
Reviewed-on: http://git-master/r/253247
This reverts commit 18237e62a732298a922a8ce9db6d0109394b7f00"
This reverts commit 83148877afa7a4d638e709650e66ad3f9857b23f
Change-Id: I382be2eb99a2c79e764ac00e31c8df1c99cfaf75
Reviewed-on: http://git-master/r/251331
Tested-by: Peter Kim <pekim@nvidia.com>
Change-Id: I83148877afa7a4d638e709650e66ad3f9857b23f
Reviewed-on: http://git-master/r/250646
This is the proper fix for reducing the stripe
pattern noise seen on IMX091 and IMX135 HDR
sensors. This fix keeps the backward compatibility
for none-AOHDR code path.
Bug 1299338
Change-Id: I5621b173f42ca506e87ee2a2213b1e2dfdef6d32
Signed-off-by: Frank Chen <frankc@nvidia.com>
Reviewed-on: http://git-master/r/241029
(cherry picked from commit 81128dc9b2f56a658c8f2aad9915fa2b1e42ad1c)
Reviewed-on: http://git-master/r/249762
Apply ov7695 quality tune register changes from OV,
'OV7695 reference setting_MIPI_24MCLK_o70213_nVidia.txt'.
Bug 1278482
Change-Id: If40629b7a4fe7c4c8bd731693f5b8e2cc66bb674
Signed-off-by: Jake Park <jakep@nvidia.com>
Reviewed-on: http://git-master/r/244866
Tested-by: Karl Kim <kkim@nvidia.com>
To reduce initial greenish preivew time,
1. start from manual white balance with pre-defined values
2. discard 2 frame
3. move to auto white balance
Bug 1304101
Change-Id: Iba4520b94614ccaca8d2d0c037928c70e736ecb8
Reviewed-on: http://git-master/r/244570
vde.emc is required to know whether video playback is
going on or not. Display efficiency rate is set to 45%
if both dc.emc and vde.emc is enabled.
vde.emc clock is enabled when non-zero avp.emc clock
rate is requested and is disabled when zero avp.emc clock
is requested.
Bug 1266369
Change-Id: Ic1de7145763a41a8adf11a9e1cd7a1cd723f46e2
Signed-off-by: Kevin Huang <kevinh@nvidia.com>
Reviewed-on: http://git-master/r/232614
(cherry picked from commit 1a7d3d91d7491813b8b335f202504152ab137193)
Signed-off-by: Kenneth Kwak <kkwak@nvidia.com>
Change-Id: I491c6356800309123b9cb3ece9fb32d4dfe00d78
Reviewed-on: http://git-master/r/242227
Reviewed-by: Jinyoung Park <jinyoungp@nvidia.com>
These values are measured on DVT1 or ERS.
Bug 1244384
Change-Id: I0f5f73132c0b00d51ea2713d62aade01110ec1c6
Signed-off-by: Bo Kim <bok@nvidia.com>
Reviewed-on: http://git-master/r/242722
Reviewed-by: Gabby Lee <galee@nvidia.com>
Bug 1244384
Change-Id: Ia44451cd79a5f551f479685d4089e2398a5fc152
Reviewed-on: http://git-master/r/242293
Bug 1244384
Change-Id: Ifb5c71e26c3d2a78c38beeaf20b48b38e6e3cb3c
Reviewed-on: http://git-master/r/242292
AD5823 open time is long due to msleep delay.
It is no need.
Bug 1315484
Change-Id: Ic0527f2868d4d2d6e11dfd7b40ade4cf0373c44c
Reviewed-on: http://git-master/r/243350
Reviewed-by: Ruicheng Dai <rdai@nvidia.com>
settletime / POS_LOW / POS_HIGH value is adjusted by
result of ad5823 charaterization
Bug 1308712
Change-Id: I89c0471f3a49d15e54d0293c6a42f12f2d10edbb
Reviewed-on: http://git-master/r/241635
- Relocate streaming_off to the start of set_mode() and
streaming_on to the end of set_mode().
- Fix some variable name and register address errors.
Bug 1271714
Bug 1270541
Bug 1264961
Change-Id: I6e692c43ad2b6aaa7c58f73a513899bd6440dfa7
Reviewed-on: http://git-master/r/236773
(cherry picked from commit 15d0555e7c0bbd0677e29232e806633016af2651)
Reviewed-on: http://git-master/r/237163
(cherry picked from commit d52bbb8303b5356263582b08f0863363667a097f)
Reviewed-on: http://git-master/r/239561
Changed power off sequence as recommended. CAM1_AF_PWDN shoud ramp
down before VA_CAM1_AF. Because most of devices require power down
signal ramps down before power rails.
Bug 1300199
Change-Id: I44a60dd90fb7a89cbff344f12ef814b247a9c1ea
Reviewed-on: http://git-master/r/239518
Change AD5816 focuser drive mode from switching
to linear in order to reduce the line noises in
sensor frames.
Bug 1299338
Change-Id: I030aab939730a577f5138e44cd24379c66588437
Reviewed-on: http://git-master/r/238242
Reviewed-by: Sean Pieper <spieper@nvidia.com>
Reviewed-by: Katharine Ip <kip@nvidia.com>
Reviewed-by: Jon Mayo <jmayo@nvidia.com>
Adds support to read fuse ID from OTP memory on
ov2710, ov9726, ov9772, ar0832, and imx091 sensors.
Also includes macro-enabled fuse ID programming for
ov2710. Adjusts data structure used by fuse ID ioctl
to include a field for fuse ID size.
Required by nvcamera version 1.8.0
Required by NVCS version 4.10.0
Bug 1198663
Change-Id: Ib3bb0e100e49aea2c6ce13cd069862476d7f4bb6
Signed-off-by: Phil Breczinski <pbreczinski@nvidia.com>
Reviewed-on: http://git-master/r/169187
(cherry picked from commit 0ce57617ee1f735759333a589aa2890559053fe0)
Reviewed-on: http://git-master/r/232254
Reviewed-by: Brian Bamsch <bbamsch@nvidia.com>
Tested-by: Brian Bamsch <bbamsch@nvidia.com>
Apply ov7695 qualiy tune register change from OV,
'OV7695 reference setting_MIPI_24MCLK_060713_nVidia.txt'.
Bug 1278482
Change-Id: If14deae5e49cc766c226e57d91a325b3fb1a8134
Reviewed-on: http://git-master/r/237108
(cherry picked from commit bf6303da0d525e9656e3da04bde609589945a0c6)
Reviewed-on: http://git-master/r/237161
Reviewed-by: Sachin Nikam <snikam@nvidia.com>
Keep power on after probe function.
Also change focus position type from u16 to s32 so garbage bytes
aren't passed to the raw header.
Bug 1283378
Change-Id: I6a045ac93a3045e390cee9bd0a9772c6d7668290
Reviewed-on: http://git-master/r/237032
Reviewed-by: Zhaoyi Wei <zwei@nvidia.com>
Reviewed-by: Gilbert Yeung <gyeung@nvidia.com>
Added the capability to set pos_high/pos_low from
the per unit calibration data for VCM.
Bug 1271714
Bug 1270541
Bug 1264961
Change-Id: If459308459523918be153df809f8890b379a797c
Reviewed-on: http://git-master/r/232852
(cherry picked from commit 2c86c26fd86d913980503bd860de4fcfb9b84c73)
Reviewed-on: http://git-master/r/222636
Reviewed-by: Riham Haidar <rhaidar@nvidia.com>
Tested-by: Riham Haidar <rhaidar@nvidia.com>
settletime / POW_LOW / POS_HIGH / VCM_MODE_TIME value is adjusted
by result of ad5823 characterization.
Bug 1288326
Change-Id: Ibb22927049610d6ea3b5df499b2aa322c2d3e548
Reviewed-on: http://git-master/r/235435
Set MGC register to use sensor gain instead of real gain.
Change-Id: I949637ec50230539bccdb0acfc4e069165fba33d
Reviewed-on: http://git-master/r/234764
Reviewed-on: http://git-master/r/234785
(cherry picked from commit 25bd6126c61fb839411ae9570249f465b005722c)
Reviewed-on: http://git-master/r/236900
Reviewed-by: Yin-Chia Yeh <yyeh@nvidia.com>
1. modified ov5693 power on/off sequence
2. removed unused power rail
3. removed delay code
Bug 1234944
Change-Id: I681088faeb3dd663bae1e3f827270da2270a65f2
Reviewed-on: http://git-master/r/233584
(cherry picked from commit 1a6856f773b4a27d1d1035abea7958c0dc190b56)
Reviewed-on: http://git-master/r/236899
Reviewed-by: Frank Chen <frankc@nvidia.com>
Tested-by: Frank Chen <frankc@nvidia.com>
video: tegra: dw9718: enable auto-detect support
Bug 1250073.
Change-Id: Iabbf3d13e07ce053a74a8b6ff9dca610dfc6e55a
Signed-off-by: Gary Fitzer <gfitzer@nvidia.com>
media: video: tegra: imx135 flash support
enable imx135 on-sensor flash strobe.
bug 1277452
Change-Id: I9fb1bc50567d2f2c2e911420104b8350711022d4
Signed-off-by: Charlie Huang <chahuang@nvidia.com>
media: video: tegra: max77387: add flash device
it is used with imx135 camera sensor.
bug 1277452
Change-Id: I94eb413b0594b1abc70d9c9d62114782708678df
media: tegra: dw9718: Fix dw9718 settle time
Fix focuser settle time
Change-Id: Idab65b6800137d55d04842ff04d721b7847366de
Reviewed-on: http://git-master/r/218461
(cherry picked from commit 10b6451fa99afdcfe947df2366116fccac1591cb)
Signed-off-by: Michael Lin <mlin@nvidia.com>
arm: tegra11: config: enable OV5693 and AD5823
Bug 1250073.
Change-Id: Ic8714f22925ab9e6d76c944c33a8fe0d45c5015e
arm: tegra: add autodetect imaging sensors
Add autodetect check for IMX135, AR0833, and OV5693
Change-Id: I05638424067be1496d0f70e8ee900b721b34bf0e
arm: tegra: Add imx132 sensor support for Dalmore
The new E1812 camera board for Dalmore has IMX135
and IMX132 sensors.
Bug 1250073
Change-Id: Id8691bc219d1bd13b12c4ad49725ed3b706f1f61
ARM: tegra: dalmore: update imx135 on sensor flash
enable imx135 on sensor flash function.
setup max77387 which is used with imx135.
bug 1277452
Change-Id: I4e5fea14defbd84f25fac238001e528d5b24dfca
ARM: dalmore: sensor specific focuser settings
imx091/imx135 modules use the same vcm driver ad5816 but their
actuarator's charactoristics are different.
overwrite focuser setting in the ad5816 focuser detect function
if the sensor detected is imx135.
update dw9718 focuser range.
bug 1272352
Change-Id: I8dd7ccc97533e1dd47c341b1aa8660d86fe52baa
video: tegra: ad5816: enable auto-detect support
Bug 1250073.
Change-Id: I1c30757d0570e9e4d51f3326d2c0fe233f8cf046
(cherry picked from commit c3a21f51fc6c5a9935f8e52aa3149ddb0de66ac6)
media: video: tegra: ad5816: customise setting
different sensor modules have specific focuser settings like
actuator resonance frequency and optimal arc mode.
the settings should be carried in the sensor board file.
bug 1272352
Change-Id: I6bb086faaf3ccfb62ed2a900befe755010dde0d1
(cherry picked from commit 52ac0ee51a8fe80379b4c07d21198c1cfc0c80c9)
ARM: configs: tegra11: defconfig: enable max77387
bug 1277452
Change-Id: I220cddcd7cc856b0906d089a7a5a6e384391ea10
Update focuser calibrated working range.
Bug 1297156
Change-Id: I3203420b1d077a33bf8373b32207a212363e316a
Signed-off-by: Sudhir Vyas <svyas@nvidia.com>
Reviewed-on: http://git-master/r/234970
Fix issue that image is rotated 180 degree.
Bug 1290264
Change-Id: I58cdfceac947f51dfb9f5a7451c7adef9bb93baf
Signed-off-by: Jinyoung Park <jinyoungp@nvidia.com>
Reviewed-on: http://git-master/r/229672
promotion_build
Move sync point increment to CPU side for T11X.
bug 1279729
Change-Id: I3ff5efc2300635411aaa5b71a3455e0b27808460
Signed-off-by: Soumen Kumar Dey <sdey@nvidia.com>
Reviewed-on: http://git-master/r/232770
Reviewed-by: Gajanan Bhat <gbhat@nvidia.com>
Change-Id: Ib8a8426a4bad7d0f305a9f18052acbe83cb65748
Signed-off-by: kkim <kkim@nvidia.com>
Reviewed-on: http://git-master/r/231589
Reviewed-by: Harshada Kale <hkale@nvidia.com>
Tested-by: Harshada Kale <hkale@nvidia.com>
Adding missed regulator_disable() into probe().
While probing ad5823 focuser, regulator vdd should be turned on
before i2c operations and should be turned off after i2c oeprations.
Bug 1293915
Change-Id: Ie9936e699ad3e3b08eb1dad55182e33dc89244a3
Reviewed-on: http://git-master/r/231547
Update ad5816 focuser calibrated working range.
Current settings do not give better results for
macro mode specifically.
Bug 1238213
Change-Id: Ic8b60081bda75ecf3158d98796c979528767dfcd
Reviewed-on: http://git-master/r/229267
Bug 1278482
Change-Id: Ib74a3a8d018a5082f3098fa058609d634bfb2010
Reviewed-on: http://git-master/r/230186
Reviewed-by: John Sasinowski <jsasinowski@nvidia.com>
This change adds the camera supoorted changes to bring AOHDR feature in
to rel-17.
Change-Id: I39929e0644ce0d3e63c8a6960e2a8c3ebd3596ee
Signed-off-by: sivasubramaniam venkataraman <svenkatarama@nvidia.com>
LensShading was shown different result in the both
1296x972 and 2592x1944 due to wrong initial setting
value.
Bug 1237002
Change-Id: Ic4b7fba8639358b1031be47deb21ab0c4a9089bd
Reviewed-on: http://git-master/r/228305
Reviewed-by: Alvin Park <apark@nvidia.com>
Reviewed-by: Philip Breczinski <pbreczinski@nvidia.com>
Reviewed-by: Prayas Mohanty <pmohanty@nvidia.com>
Expose DTV_STATUS register in debugfs which could be read by user land
applications.
Removed read operation over DTV_FIFO registers which may cause data
loss.
Bug 1061456
Bug 1258577
Reviewed-on: http://git-master/r/144430
(cherry picked from commit a7668922b555aca4ca0f5ca0569e4aa45383cb81)
(cherry picked from commit d14000d021e65b34735a167b2f313695b984e54c)
Change-Id: If4b5bd94fe8cc62f8a9695ec114345bd7cdd90a0
Signed-off-by: Adam Jiang <chaoj@nvidia.com>
Reviewed-on: http://git-master/r/224678
Reviewed-by: Varun Wadekar <vwadekar@nvidia.com>
Bug 1269275
Change-Id: I2f7b9dded7ed5e06efd5875bc7990afc338ed3ce
Reviewed-on: http://git-master/r/222047
Tested-by: Jake Park <jakep@nvidia.com>
Change-Id: I9132ac2b464e795413079ad9c50e2fa14249304c
Reduce wait time from 100ms to 1ms per
suggestion from vendor.
Bug 1261782
Change-Id: I294380676ecb0602c2b5d8f633fb41c4673347eb
Signed-off-by: Hu He <hhe@nvidia.com>
Reviewed-on: http://git-master/r/221255
Reviewed-by: Bhushan Rayrikar <brayrikar@nvidia.com>
In some systems with fast memory configuration, sometimes the settle
time is not satisfied between two set positions, especially the first
two after power on.
Implement the time counter between two set positions to maintain the
proper settle time.
bug 1237579
Change-Id: I046cbb2c9d4f55d475fe30114a58b1e2316f4efe
Reviewed-on: http://git-master/r/220019
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
For bug 1236935.
Change-Id: I9cfb94685d47375ad8ef9106980be18bde51156c
Signed-off-by: Lihui Cui <lcui@nvidia.com>
Reviewed-on: http://git-master/r/218626
Add bulk i2c writes.
Bug 1234944
Change-Id: I57fbe31972fc69de2b7b6c4338450b7ade26c597
Reviewed-on: http://git-master/r/218122
On this device the torch level can be set as high as the flash, but
on some platforms the torch level is required to be lower to get
better photo qualities.
Also replace dev_warn with dev_notice and updated debugfs methods.
bug 1242531
Change-Id: I48140cbdaa093b5ffcf41258d0f2fd51cca35eb2
Reviewed-on: http://git-master/r/219100
Bug 1255019
Change-Id: Ie02ca813bcb362d20de2c07aeea62a46866cc723
Reviewed-on: http://git-master/r/217662
Bug 1271714
Change-Id: Ibab4ce7c08150edceb463d4dadd3579d88956654
Reviewed-on: http://git-master/r/219772
For management of the diversity on register definitions of DTV module,
move those definitions into mach/dtv.h.
fix Bug 1258577
Change-Id: I6d5ad063ba3ed44fb7ef6313f33946e261ad7f5b
Reviewed-on: http://git-master/r/217592
We should not update frame length register since
it is done by sensor automatically. Force to update
frame length register will cause image to flash when
HDR ratio is bigger than 1:1.
Bug 1267273
Change-Id: Id134c1e35ec60033a7b684de3c2c3d13d9ba933e
Reviewed-on: http://git-master/r/216991
Bug 1255103
Change-Id: I26acd27ae331343d0c8c8c1d6d5216ff45c07867
Reviewed-on: http://git-master/r/213972
Reviewed-by: Sudhir Vyas <svyas@nvidia.com>
Reviewed-by: Alex Courbot <acourbot@nvidia.com>
Reviewed-by: Nitin Kumbhar <nkumbhar@nvidia.com>
Bug 1255103
Change-Id: Iabc3dd93d71d5be9229393c7706d695ad56a0eb5
Reviewed-on: http://git-master/r/213971
