Ref-count the AVP open/release requests; if AVP already opened,
just inc the refcount and let the request succeed.
bug 772210
Change-Id: I061e02e4c82fc6915ed5b73a536a7707d5c055db
Reviewed-on: http://git-master/r/13661
Tested-by: Bharat Nihalani <bnihalani@nvidia.com>
arch/arm/mach-tegra/board-ventana-power.c
drivers/mfd/tps6586x.c
Change-Id: Ic8c46d4251d6e71fa2900b7e876f87e256299bc4
Source files should not be with executable permission.
Change-Id: I70b6be4cf88fea4be9b092ca2f5dd08e40ee7cbd
Reviewed-on: http://git-master/r/12081
Reviewed-by: Chao Jiang <chaoj@nvidia.com>
Tested-by: Chao Jiang <chaoj@nvidia.com>
Change-Id: I1312ec33ba8bac38dc395d7d1a2f485b13d74c14
commit 0310871d8f71da4ad8643687fbc40f219a0dac4d upstream.
The switch to the new control framework caused a regression where the audio was
no longer unmuted after the carrier scan finished.
The original code attempted to set the volume control to its current value in
order to have the set-volume control code to be called that handles the volume
and muting. However, the framework will not call that code unless the new volume
value is different from the old.
Instead we now call msp_s_ctrl directly.
It is a bit of a hack: we really need a v4l2_ctrl_refresh_ctrl function for this
(or something along those lines).
Thanks to Andy Walls for bisecting this and to Shane Shrybman for reporting it!
Reported-by: Shane Shrybman <shrybman@teksavvy.com>
Thanks-to: Andy Walls <awalls@md.metrocast.net>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
commit 35bbe587d0959712b69540077c9e0fd27d3e6baf upstream.
The entries for those cards are after the generic entries,
so they don't work, in practice. Moving them to happen before the
generic entres fix the issue.
Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com>
commit abe1def46d84aa27d3f84d729204b162e8c64d76 upstream.
It was missing the `break'.
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=18672
Reported-by: Igor <i2g2r2@gmail.com>
commit 4f5c933abb34532dc962185c999509b97a97fa1b upstream.
Necessary on arm.
Signed-off-by: Janne Grunau <j@jannau.net>
commit 0303a90a744662e934877a5d637a43197229274b upstream.
The bug was introduced by commit 23a98274cc348880ecb6803307c254448084953a
applying values of sensor sp80708 to sensors hv7131r and mi0360.
Signed-off-by: Jean-François Moine <moinejf@free.fr>
commit f43402fa55bf5e7e190c176343015122f694857c upstream.
When audio is present, some alternate settings were skipped.
This prevented some webcams to work, especially when bulk transfer was used.
This patch permits to use the last or only alternate setting.
Reported-by: Antonio Ospite <ospite@studenti.unina.it>
Tested-by: Antonio Ospite <ospite@studenti.unina.it>
Change-Id: I51382f58f296df939f99d60926ba97f0b4e04aed
Signed-off-by: Colin Cross <ccross@android.com>
Change-Id: I7299b3bed83fbf41f5666724e328980cfcda1186
Change-Id: I3f9025285fc5a002dbd436ee76bb6ca757c425ea
Signed-off-by: Dima Zavin <dima@android.com>
Change-Id: Ib5490a7f7d294760d34a3b9da14281ad96c9b26c
Change-Id: I7af31dc4cd1e2d7a4142f6265665a05ca4f41d15
Change-Id: I127ea2a132adf2126c28194e8d778cc46b0a2e63
Reviewed-on: http://git-master/r/10573
Reviewed-by: Chien-Yu Chen <chichen@nvidia.com>
Change-Id: I8f323ecc04e0ccefa31d6533b58b7878675bf8c9
Change-Id: I7dbc97aee0c0912baf4722a8756d228bf7dd1212
Also hold the mutex for longer on cleanup, while deleting
the libs nvmap client. Not strictly necessary...
Change-Id: I4dfdb065211571338053a16bacc2e5412c26ae77
Change-Id: I7ade4469609ecf87663e6a6733842889b27f7ce5
For now just includes the existing ports, the peer owners,
and the port and peer state.
Change-Id: I2c6b603ca02dc48acc1c763380ff0f1cb66f482b
Change-Id: I42bf507b7d644184bd27be6ff53e5974dcfa3797
Change-Id: I824f9a27bfefe86211bc71d5f79ea798052b98b7
Change-Id: Ia72e022ad1217ffe75915465ca0e886b16d1a64a
Change-Id: I9233c5d7c678f6a9ba1c23af686137bf4d6a4291
The tegra_camera device includes all clock and regulator
functionality needed to support camera on tegra.
Change-Id: I281f1cb5f360276af832309e35dbe17c98b62bb3
Change-Id: Idabf0fb5eed1dee0d1329c6588524ab828c278ab
arch/arm/configs/tegra_defconfig
arch/arm/mach-tegra/tegra_i2s_audio.c
Change-Id: Ib0d7fc5c84b21a58f78a4a987c245e0e110ff437
Change-Id: I2b12aaf72ac0303725aa9b419cd7240e1a198fd8
The compat code for the VIDIOCSMICROCODE ioctl is totally buggered.
It's only used by the VIDEO_STRADIS driver, and that one is scheduled to
staging and eventually removed unless somebody steps up to maintain it
(at which point it should use request_firmware() rather than some magic
ioctl). So we'll get rid of it eventually.
But in the meantime, the compatibility ioctl code is broken, and this
tries to get it to at least limp along (even if Mauro suggested just
deleting it entirely, which may be the right thing to do - I don't think
the compatibility translation code has ever worked unless you were very
lucky).
Reported-by: Kees Cook <kees.cook@canonical.com>
Cc: Mauro Carvalho Chehab <mchehab@infradead.org>
Cc: stable@kernel.org
Change-Id: I5e4d4a14f055ea8a19f715f8bf8fb3d7b88b7cda
Signed-off-by: Rebecca Schultz Zavin <rebecca@android.com>
The tegra_camera device has been extended to include all clock and
regulator functionality needed by to support camera on tegra.
Change-Id: Ie1611a79c24f7ebe3ae570d38a9f470683af91dd
Change-Id: I6ff1bf0e72ef69b59d5875bd60c7cd825fa2ca4f
When a driver that uses videobuf-dma-contig is used with the USERPTR
memory access method a kernel oops might happen: a NULL address may be
passed to dma_free_coherent(). This happens when an application calls
REQBUFS and then exits without queuing any buffers. This patch fixes
that bug.
Signed-off-by: Pawel Osciak <p.osciak@samsung.com>
on S5PV210 SoCs
Fix DMA engine pixel offset calculation for 3-planar YUV formats.
On S5PV210 SoCs horizontal offset is applied as number of pixels,
not bytes per line.
[mchehab@redhat.com: CodingStyle cleanup]
Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
On failed create_workqueue() fimc_probe() was returning 0.
At all frame rates except 30fps and 5fps the camera produces very dark
pictures. Auto-exposure is probably disabled by the camera at all frame
rates except 30fps, making them pretty unusable.
Work around the problem by introducing a new RESTRICT_FRAME_RATE quirk
that disables all the frame rates except the default one.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
The camera requires the STREAM_NO_FID quirk. Add a corresponding entry
in the device IDs list.
The FBIOGET_VBLANK device ioctl allows unprivileged users to read 16
bytes of uninitialized stack memory, because the "reserved" member of
the fb_vblank struct declared on the stack is not altered or zeroed
before being copied back to the user. This patch takes care of it.
Signed-off-by: Dan Rosenberg <dan.j.rosenberg@gmail.com>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
The wrong value for the volume control limit, 65335 vs. 65535,
prevents proper cx25840 v4l2_subdevice initialization.
Reported-by: Igor M. liplianin <liplianin@me.by>
Video device was not being released on driver remove.
Output buffer has to be at least the size of input buffer, not the other
way around.
The drivers/media/video/mt9v022.c file, on line 405, tries a "case 0" o a
v4l2_mbus_pixelcode enum which don't have an 0 value element, so I got a compile
warning. That "case" is useless so it can be removed.
Signed-off-by: Ionut Gabriel Popescu <poyo_vl@yahoo.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Signed-off-by: Michael Grzeschik <m.grzeschik@pengutronix.de>
Signed-off-by: Philipp Wiesner <p.wiesner@phytec.de>
The mx25_camera_irq irq handler may get called after the camera has been
deactivated (from mx2_camera_deactivate). Detect this situation, and bail out.
Signed-off-by: Baruch Siach <baruch@tkos.co.il>
As the end of frame marker does not contain any pixel, it must not be
transferred.
Reported-by: Ivo Jager <ivo.jager@siliconfields.net>
This fixes a nasty memory corruption bug when using userptr I/O.
The function videobuf_pages_to_sg() sets up the scatter-gather list for the
DMA transfer to the userspace pages. The first transfer is setup correctly
(the size is set to PAGE_SIZE - offset), but all other transfers have size
PAGE_SIZE. This is wrong for the last transfer which may be less than PAGE_SIZE.
Most, if not all, drivers will program the boards DMA engine correctly, i.e.
even though the size in the last sg element is wrong, they will do their
own size calculations and make sure the right amount is DMA-ed, and so seemingly
prevent memory corruption.
However, behind the scenes the dynamic DMA mapping support (in lib/swiotlb.c)
may create bounce buffers if the memory pages are not in DMA-able memory.
This happens for example on a 64-bit linux with a board that only supports
32-bit DMA.
These bounce buffers DO use the information in the sg list to determine the
size. So while the DMA engine transfers the correct amount of data, when the
data is 'bounced' back too much is copied, causing buffer overwrites.
The fix is simple: calculate and set the correct size for the last sg list
element.
Signed-off-by: Hans Verkuil <hans.verkuil@tandberg.com>
As reported by: Carlos Americo Domiciano <c_domiciano@yahoo.com.br>:
[ 220.033500] cx231xx v4l2 driver loaded.
[ 220.033571] cx231xx #0: New device Conexant Corporation Polaris AV Capturb @ 480 Mbps (1554:5010) with 6 interfaces
[ 220.033577] cx231xx #0: registering interface 0
[ 220.033591] cx231xx #0: registering interface 1
[ 220.033654] cx231xx #0: registering interface 6
[ 220.033910] cx231xx #0: Identified as Unknown CX231xx video grabber (card=0)
[ 220.033946] BUG: unable to handle kernel NULL pointer dereference at (null)
[ 220.033955] IP: [<ffffffffa0d3c8bd>] cx231xx_pre_card_setup+0x5d/0xb0 [cx231xx]
Thanks-to: Carlos Americo Domiciano <c_domiciano@yahoo.com.br>
