commit 68f194e027ecfbbc8d5515bc40787e542eed59e9 upstream.
For some unknown reason, on a MacBookPro5,3 the iSight sometimes report
a different video format GUID. This patch add the other (wrong) GUID to
the format table, making the iSight work always w/o other problems.
What it should report: 32595559-0000-0010-8000-00aa00389b71
What it often reports: 32595559-0000-0010-8000-000000389b71
Signed-off-by: Daniel Ritz <daniel.ritz@gmx.ch>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Cc: Leann Ogasawara <leann.ogasawara@canonical.com>
commit 61421206833a4085d9bdf35b2b84cd9a67dfdfac upstream.
The Miricle 307K (17dc:0202) camera reports a 16-bit greyscale format,
support it in the driver.
commit f129b03ba272c86c42ad476684caa0d6109cb383 upstream.
The camera requires the STREAM_NO_FID quirk. Add a corresponding entry
in the device IDs list.
commit 1e4d05bc95a0fe2972c5c91ed45466587d07cd2c upstream.
The camera requires the PROBE_DEF quirk. Add a corresponding entry in
commit 806b07c29b711aaf90c81d2a19711607769f8246 upstream.
IR support on FusionHDTV cards is broken since kernel 2.6.31. One side
effect of the switch to the standard binding model for IR I2C devices
was to let i2c-core do the probing instead of the ir-kbd-i2c driver.
There is a slight difference between the two probe methods: i2c-core
uses 0-byte writes, while the ir-kbd-i2c was using 0-byte reads. As
some IR I2C devices only support reads, the new probe method fails to
detect them.
For now, revert to letting the driver do the probe, using 0-byte
reads. In the future, i2c-core will be extended to let callers of
i2c_new_probed_device() provide a custom probing function.
Tested-by: "Timothy D. Lenz" <tlenz@vorgon.com>
commit 55e0b489a39bb635a44f769d620e44c70d9c065b upstream.
The 046d:08da usb id shouldn't be associated with the stv06xx driver as they're
not compatible with each other.
This fixes a bug where Quickcam Messenger cams fail to use its proper driver
(gspca-zc3xx), rendering the camera inoperable.
Signed-off-by: Erik Andrén <erik.andren@gmail.com>
Tested-by: Gabriel Craciunescu <nix.or.die@googlemail.com>
Signed-off-by: Jean-François Moine <moinejf@free.fr>
commit 19f48cb105b7fa18d0dcab435919a3a29b7a7c4c upstream.
this patch fixes a memory leak which occurs when an em28xx card with DVB
extension is unplugged or its DVB extension driver is unloaded. In
dvb_fini(), dev->dvb must be freed before being set to NULL, as is done
in dvb_init() in case of error.
Note that this bug is also present in the latest stable kernel release.
Signed-off-by: Francesco Lavra <francescolavra@interfree.it>
VIDIOC_QUERYCTRL
commit f4eabafeb3ea41801260fba624cbf2da971d19f8 upstream.
Return minimum, maximum and step set to 0 without querying the hardware.
Cc: maximilian attems <max@stro.at>
UHCI controllers
commit 70136081fc67ea77d849f86fa323e5773c8e40ea upstream.
If you read the mail to Oliver Neukum on the linux-usb list, then you know
that I found a cure for the mysterious problem that the MR97310a CIF "type
1" cameras have been freezing up and refusing to stream if hooked up to a
machine with a UHCI controller.
Namely, the cure is that if the camera is an mr97310a CIF type 1 camera, you
have to send it 0xa0, 0x00. Somehow, this is a timing reset command, or
such. It un-blocks whatever was previously stopping the CIF type 1 cameras
from working on the UHCI-based machines.
Signed-off-by: Theodore Kilgore <kilgota@auburn.edu>
commit 2434466432464110b5307757e0285dd41f15512e upstream.
Move I2C IR initialization from just after I2C bus setup to right
before non-I2C IR initialization. This avoids the case where an I2C IR
device is blocking audio support (at least the PV951 suffers from
this). It is also more logical to group IR support together,
regardless of the connectivity.
This fixes bug #15184:
http://bugzilla.kernel.org/show_bug.cgi?id=15184
constant => sizeof conversion.
commit 53f68607caba85db9a73846ccd289e4b7fa96295 upstream.
Regression was caused by my commit 6b35ca0d3d586b8ecb8396821af21186e20afaf0
which determined message size using sizeof rather than hardcoded constants.
Unfortunately pwc_set_shutter_speed reuses a 2 byte buffer for a one byte
message too so the sizeof was bogus in this case.
All other uses of sizeof checked and are ok.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Martin Fuzzey <mfuzzey@gmail.com>
commit 385097e08b9c24655626ed760bc67eb7e50115a0 upstream.
The control blacklisting code erroneously used usb_match_id() by passing
a pointer to a usb_device_id structure instead of an array of such
structures.
Replace the usb_match_id() call by usb_match_id_one().
Thanks to Paulo Assis for diagnosing the bug and providing an initial
fix.
SubVendor ID: 0x1043 Device ID: 0x4847)
commit e3c6e1aaa5db7822524f5b1355960fd732910068 upstream.
Adds the device IDs and driver linking to allow the Asus Europa DVB-T
card to operate with these drivers.
The device has a SAA7134 chipset with a TD1316 Hybrid Tuner.
All inputs work on the card including switching between DVB-T and
Analogue TV, there is also no IR with this card.
[mchehab@redhat.com: CodingStyle fixes]
Signed-off-by: Danny Wood <danwood76@gmail.com>
Cc: Ben Hutchings <ben@decadent.org.uk>
commit 07d1c69b2dcfdd1b21e36af0ff8b9506234908ee upstream.
A previous code optimization inverted bridge registers and values,
doing a regression in kernel 2.6.32.
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
commit c60503c1db76bd46577cc7ff4fafa033b675e0e5 upstream.
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
commit 50e9d31183ed61c787b870cb3ee8f6c3db8c8a1e upstream.
This was found with a static checker and has not been tested, but it seems
pretty clear that the mutex_lock() was supposed to be mutex_unlock()
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
Cc: Brandon Philips <brandon@ifup.org>
commit 518c8df77c21b7d1690dd8b96eb0e54c4ec1c9c1 upstream.
Signed-off-by: Rafal Milecki <zajec5@gmail.com>
Cc: Surbhi Palande <surbhi.palande@canonical.com>
Trivial fix for this compile warning:
v4l/sh_mobile_ceu_camera.c:1789: warning: label 'exit_free_irq' defined but not used
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
The vpif_config struct was renamed to vpif_display_config, but there
is still a stray vpif_config *config pointer in vpif_display.c, preventing
it from compiling.
Remove this old duplicate pointer.
Set device GPIOs only once. There is no need for .dvb_gpio to select
between analog and digital because device is digital only.
Signed-off-by: Antti Palosaari <crope@iki.fi>
pm_runtime_disable is needed if it failed or removed
Signed-off-by: Kuninori Morimoto <morimoto.kuninori@renesas.com>
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Commit ef373189f62413803b7b816c972fc154c488cdc0 "fix use-after-free Oops,
resulting from a driver-core API change" fixed the Oops, but didn't correct
missing device object initialisation. This patch makes unloading and reloading
of soc-camera host- and client-drivers possible again.
The Hauppauge WinTV HVR-1150 retail boards require the FORCE_TS_VALID bit
to be set in order to function properly. This change will work on the early
revisions on the board as well, but the final revision will not function
without this change.
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
When FORCE_TS_VALID mode is enabled, the saa713x will accept MPEG TS input
without requiring TS_VALID set high. This is required for some new boards
to function properly, due to the hardware design implementation.
The configuration is toggled within the board setup configuration. Boards
that do not have this bit set will function as before with no change.
mismatch with abs()
The abs() macro has changed in 2.6.32 and returns a long instead of an
int. Fix the driver to avoid compilation warnings.
The FIX_BANDWIDTH quirk tries to work around cameras requesting the
maximum bandwidth regardless of the image size by computing a bandwidth
estimate. This works only for uncompressed frames.
Which is why I have always preferred sizeof(struct foo) over
sizeof(var).
Cc: Antti Palosaari <crope@iki.fi>
Acked-by: Steven Toth <stoth@kernellabs.com>
Required for wakeup call.
Signed-off-by: Jonathan Cameron <jic23@cam.ac.uk>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
gspca_mr97310a: Change vstart for CIF sensor type 1 cams
This fixes the distortion at the end of the frame, and avoids the bad frame
dropping done because of this distortion, trippling the framerate!
Signed-off-by: Theodore Kilgore <kilgota@banach.math.auburn.edu>
Adds a vflip quirk for the Fujitsu Amilo Xi 2528. Thanks to Evgeny for the report.
Adds another vflip quirk for the MSI GX700.
Thanks to John Katzmaier for reporting.
Adds a vflip quirk for the Bruneinit laptop. Thanks to Jörg for the report
waiting processes
The s2255 driver had logic which aborted processing of a video frame
if there was no process waiting on the video buffer in question. That
simply doesn't work when the application is doing things in an
asynchronous manner. If the application went to the trouble to queue
the buffer in the first place, then the driver should always attempt
to complete it - even if the application at that moment has its
attention turned elsewhere. Applications which always blocked waiting
for I/O on the capture device would not have been affected by this.
Applications which *mostly* blocked waiting for I/O on the capture
device probably only would have been somewhat affected (frame lossage,
at a rate which goes up as the application blocks less). Applications
which never blocked on the capture device (e.g. polling only) however
would never have been able to receive any video frames, since in that
case this "is anyone waiting on this?" check on the buffer never would
have evalutated true. This patch just deletes that harmful check
against the buffer's wait queue.
Signed-off-by: Mike Isely <isely@pobox.com>
CC: stable@kernel.org
Because the counters were not reset when starting up streaming, they would
be reused from the previous run. This can result in cases such that when the
second instance of streaming starts up, the "cnt" variable in
em28xx_audio_isocirq() can end up being negative, resulting in attempting to
write to memory before the start of runtime->dma_area (as well as having a
negative number of bytes to copy).
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
The bttv driver function which handles switching of the video standard
(set_tvnorm() in bttv-driver.c) includes a check which can optionally
also reset the cropping configuration to a default value. It is
"optional" based on a comparison of the cropcap parameters of the
previous vs the newly requested video standard. The comparison is
being done with a memcmp(), a function which only returns a true value
if the comparison actually fails.
This if-statement appears to have been written to assume wrong
memcmp() semantics. That is, it was re-initializing the cropping
configuration only if the new video standard did NOT have different
cropcap values. That doesn't make any sense. One definitely should
reset things if the cropcap parameters are different - if there's any
comparison to made at all.
The effect of this problem was that a transition from, say, PAL to
NTSC would leave in place old cropping setup that made sense for the
PAL geometry but not for NTSC. If the application doesn't care about
cropping it also won't try to reset the cropping configuration,
resulting in an improperly cropped video frame. In the case I was
testing this actually caused black video frames to be displayed.
Another interesting effect of this bug is that if one does something
which does NOT change the video standard and this function is run,
then the cropping setup gets reset anyway - again because of the
backwards comparison. It turns out that just running anything which
merely opens and closes the video device node (e.g. v4l-info) will
cause this to happen. One can argue that simply opening the device
node and not doing anything to it should not mess with any of its
state - but because of this behavior, any TV app which does such
things (e.g. xawtv) probably therefore doesn't see the problem.
The solution is to fix the sense of the if-statement. It's easy to
see how this mistake could have been made given how memcmp() works.
The patch is therefore removal of a single "!" character from the
if-statement in set_tvnorm in bttv-driver.c.
There is a subtle interaction in the bttv driver which can result in
fields being repeatedly processed out of order. This is a problem
specifically when running in V4L2_FIELD_ALTERNATE mode (probably the
most common case).
1. The determination of which fields are associated with which buffers
happens in videobuf, before the bttv driver gets a chance to queue the
corresponding DMA. Thus by the point when the DMA is queued for a
given buffer, the algorithm has to do the queuing based on the
buffer's already assigned field type - not based on which field is
"next" in the video stream.
2. The driver normally tries to queue both the top and bottom fields
at the same time (see bttv_irq_next_video()). It tries to sort out
top vs bottom by looking at the field type for the next 2 available
buffers and assigning them appropriately.
3. However the bttv driver *always* actually processes the top field
first. There's even an interrupt set aside for specifically
recognizing when the top field has been processed so that it can be
marked done even while the bottom field is still being DMAed.
Given all of the above, if one gets into a situation where
bttv_irq_next_video() gets entered when the first available buffer has
been pre-associated as a bottom field, then the function is going to
process the buffers out of order. That first available buffer will be
put into the bottom field slot and the buffer after that will be put
into the top field slot. Problem is, since the top field is always
processed first by the driver, then that second buffer (the one after
the first available buffer) will be the first one to be finished.
Because of the strict fifo handling of all video buffers, then that
top field won't be seen by the app until after the bottom field is
also processed. Worse still, the app will get back the
chronologically later bottom field first, *before* the top field is
received. The buffer's timestamps will even be backwards.
While not fatal to most TV apps, this behavior can subtlely degrade
userspace deinterlacing (probably will cause jitter). That's probably
why it has gone unnoticed. But it will also cause serious problems if
the app in question discards all but the latest received buffer (a
latency minimizing tactic) - causing one field to only ever be
displayed since the other is now always late. Unfortunately once you
get into this state, you're stuck this way - because having consumed
two buffers, now the next time around the "first" available buffer
will again be a bottom field and the same thing happens.
How can we get into this state? In a perfect world, where there's
always a few free buffers queued to the driver, it should be
impossible. However if something disrupts streaming, e.g. if the
userspace app can't queue free buffers fast enough for a moment due
perhaps to a CPU scheduling glitch, then the driver can get
momentarily starved and some number of fields will be dropped. That's
OK. But if an odd number of fields get dropped, then that "first"
available buffer might be the bottom field and now we're stuck...
This patch fixes that problem by deliberately only setting up a single
field for one frame if we don't get a top field as the first available
buffer. By purposely skipping the other field, then we only handle a
single buffer thus bringing things back into proper sync (i.e. top
field first) for the next frame. To do this we just drop the few
lines in bttv_irq_next_video() that attempt to set up the second
buffer when that second buffer isn't for the bottom field.
This is definitely a problem in when in V4L2_FIELD_ALTERNATE mode. In
the other modes this change either has no effect or doesn't harm
things any further anyway.
change
Commit b4028437876866aba4747a655ede00f892089e14 has broken again re-use of
device objects across device_register() / device_unregister() cycles. Fix
soc-camera by nullifying the struct after device_unregister().
A missed conversion prevents correct pixel format negotiation with client
drivers.
Reported-by: Antonio Ospite <ospite@studenti.unina.it>
Fix a bug in cropping calculation, when the client is also scaling the image.
When we call gspca_frame_add, it returns a pointer to the frame passed in,
unless we call it with LAST_PACKET, when it will return a pointer to a
new frame in which to store the frame data for the next frame.
The frame pointer was not updated in stv06xx and ov518.
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
V4L/DVB (13039): dib0700: not building CONFIG_DVB_TUNER_DIB0070 breaks compilation
V4L/DVB (13038): dvbdev: Remove an anoying/uneeded warning
V4L/DVB (13037): go7007: Revert compatibility code added at the wrong place
media: video: Fix build in saa7164
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
-tip testing found that the x86 build (64-bit allyesconfig) fails due to:
LD vmlinux.o
drivers/built-in.o:(.bss+0x4b648): multiple definition of `debug'
arch/x86/built-in.o:(.kprobes.text+0x88): first defined here
ld: Warning: size of symbol `debug' changed from 90 in
arch/x86/built-in.o to 4 in drivers/built-in.o
make: *** [vmlinux.o] Error 1
This is because recent saa7164 changes introduced a global symbol
named 'debug'. The x86 platform code already defines a 'debug'
symbol. (which is named in a too generic way as well - but it
can be used nicely to weed out too generic symbols in drivers ;-)
Rename it to saa_debug.
[mchehab@redhat.com: use module_param_named to preserve old name]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
trivial: fix typo in aic7xxx comment
trivial: fix comment typo in drivers/ata/pata_hpt37x.c
trivial: typo in kernel-parameters.txt
trivial: fix typo in tracing documentation
trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c
trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c
trivial: remove unnecessary semicolons
trivial: Fix duplicated word "options" in comment
trivial: kbuild: remove extraneous blank line after declaration of usage()
trivial: improve help text for mm debug config options
trivial: doc: hpfall: accept disk device to unload as argument
trivial: doc: hpfall: reduce risk that hpfall can do harm
trivial: SubmittingPatches: Fix reference to renumbered step
trivial: fix typos "man[ae]g?ment" -> "management"
trivial: media/video/cx88: add __init/__exit macros to cx88 drivers
trivial: fix typo in CONFIG_DEBUG_FS in gcov doc
trivial: fix missing printk space in amd_k7_smp_check
trivial: fix typo s/ketymap/keymap/ in comment
trivial: fix typo "to to" in multiple files
trivial: fix typos in comments s/DGBU/DBGU/
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (222 commits)
V4L/DVB (13033): pt1: Don't use a deprecated DMA_BIT_MASK macro
V4L/DVB (13029): radio-si4713: remove #include <linux/version.h>
V4L/DVB (13027): go7007: convert printks to v4l2_info
V4L/DVB (13026): s2250-board: Implement brightness and contrast controls
V4L/DVB (13025): s2250-board: Fix memory leaks
V4L/DVB (13024): go7007: Implement vidioc_g_std and vidioc_querystd
V4L/DVB (13023): go7007: Merge struct gofh and go declarations
V4L/DVB (13022): go7007: Fix mpeg controls
V4L/DVB (13021): go7007: Fix whitespace and line lengths
V4L/DVB (13020): go7007: Updates to Kconfig and Makefile
V4L/DVB (13019): video: initial support for ADV7180
V4L/DVB (13018): kzalloc failure ignored in au8522_probe()
V4L/DVB (13017): gspca: kmalloc failure ignored in sd_start()
V4L/DVB (13016): kmalloc failure ignored in lgdt3304_attach() and s921_attach()
V4L/DVB (13015): kmalloc failure ignored in m920x_firmware_download()
V4L/DVB (13014): Add support for Compro VideoMate E800 (DVB-T part only)
V4L/DVB (13013): FM TX: si4713: Kconfig: Fixed two typos.
V4L/DVB (13012): uvc: introduce missing kfree
V4L/DVB (13011): Change tuner type of BeholdTV cards
V4L/DVB (13009): gspca - stv06xx-hdcs: Reduce exposure range
