something-bility is spelled as something-blity
so a grep for 'blit' would find these lines
this is so trivial that I didn't split it by subsystem / copy
additional maintainers - all changes are to comments
The only purpose is to get fewer false positives when grepping
around the kernel sources.
Signed-off-by: Dirk Hohndel <hohndel@infradead.org>
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
[akpm@linux-foundation.org: fix KVM]
* mark struct vm_area_struct::vm_ops as const
* mark vm_ops in AGP code
But leave TTM code alone, something is fishy there with global vm_ops
being used.
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6:
V4L/DVB (13039): dib0700: not building CONFIG_DVB_TUNER_DIB0070 breaks compilation
V4L/DVB (13038): dvbdev: Remove an anoying/uneeded warning
V4L/DVB (13037): go7007: Revert compatibility code added at the wrong place
media: video: Fix build in saa7164
* remove asm/atomic.h inclusion from linux/utsname.h --
not needed after kref conversion
* remove linux/utsname.h inclusion from files which do not need it
NOTE: it looks like fs/binfmt_elf.c do not need utsname.h, however
due to some personality stuff it _is_ needed -- cowardly leave ELF-related
headers and files alone.
compilation
As reported by Ingo Molnar:
Here's another new build breakage that triggers in -tip testing:
drivers/built-in.o:(.data+0xb1f40): undefined reference to `dib0070_ctrl_agc_filter'
drivers/built-in.o:(.data+0xb1f80): undefined reference to `dib0070_ctrl_agc_filter'
triggers due to:
CONFIG_DVB_USB_DIB0700=y
CONFIG_DVB_TUNER_DIB0070 is not set
While working on a better approach, for now, let's just select tuner
dib0070 anytime we compile dib0700.
Cc: Patrick Boettcher <pboettcher@kernellabs.com>
As pointed by Marcin Slusarz <marcin.slusarz@gmail.com>, the warns happens
because CONFIG_DVB_MAX_ADAPTERS depends on CONFIG_DVB_CORE, and there are
valid configs where DVB_CORE is not selected.
This causes such warnings, for every V4L and common drivers that may or
may not be compiled with DVB support:
drivers/media/dvb/dvb-core/dvbdev.h:36:2: warning: #warning invalid CONFIG_DVB_MAX_ADAPTERS value
We can safely remove the warning.
-tip testing found that the x86 build (64-bit allyesconfig) fails due to:
LD vmlinux.o
drivers/built-in.o:(.bss+0x4b648): multiple definition of `debug'
arch/x86/built-in.o:(.kprobes.text+0x88): first defined here
ld: Warning: size of symbol `debug' changed from 90 in
arch/x86/built-in.o to 4 in drivers/built-in.o
make: *** [vmlinux.o] Error 1
This is because recent saa7164 changes introduced a global symbol
named 'debug'. The x86 platform code already defines a 'debug'
symbol. (which is named in a too generic way as well - but it
can be used nicely to weed out too generic symbols in drivers ;-)
Rename it to saa_debug.
[mchehab@redhat.com: use module_param_named to preserve old name]
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (34 commits)
trivial: fix typo in aic7xxx comment
trivial: fix comment typo in drivers/ata/pata_hpt37x.c
trivial: typo in kernel-parameters.txt
trivial: fix typo in tracing documentation
trivial: add __init/__exit macros in drivers/gpio/bt8xxgpio.c
trivial: add __init macro/ fix of __exit macro location in ipmi_poweroff.c
trivial: remove unnecessary semicolons
trivial: Fix duplicated word "options" in comment
trivial: kbuild: remove extraneous blank line after declaration of usage()
trivial: improve help text for mm debug config options
trivial: doc: hpfall: accept disk device to unload as argument
trivial: doc: hpfall: reduce risk that hpfall can do harm
trivial: SubmittingPatches: Fix reference to renumbered step
trivial: fix typos "man[ae]g?ment" -> "management"
trivial: media/video/cx88: add __init/__exit macros to cx88 drivers
trivial: fix typo in CONFIG_DEBUG_FS in gcov doc
trivial: fix missing printk space in amd_k7_smp_check
trivial: fix typo s/ketymap/keymap/ in comment
trivial: fix typo "to to" in multiple files
trivial: fix typos in comments s/DGBU/DBGU/
alpha:
drivers/media/dvb/pt1/pt1.c: In function 'pt1_cleanup_tables':
drivers/media/dvb/pt1/pt1.c:422: error: implicit declaration of function 'vfree'
drivers/media/dvb/pt1/pt1.c: In function 'pt1_init_tables':
drivers/media/dvb/pt1/pt1.c:431: error: implicit declaration of function 'vmalloc'
drivers/media/dvb/pt1/pt1.c:431: warning: assignment makes pointer from integer without a cast
Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org>
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (222 commits)
V4L/DVB (13033): pt1: Don't use a deprecated DMA_BIT_MASK macro
V4L/DVB (13029): radio-si4713: remove #include <linux/version.h>
V4L/DVB (13027): go7007: convert printks to v4l2_info
V4L/DVB (13026): s2250-board: Implement brightness and contrast controls
V4L/DVB (13025): s2250-board: Fix memory leaks
V4L/DVB (13024): go7007: Implement vidioc_g_std and vidioc_querystd
V4L/DVB (13023): go7007: Merge struct gofh and go declarations
V4L/DVB (13022): go7007: Fix mpeg controls
V4L/DVB (13021): go7007: Fix whitespace and line lengths
V4L/DVB (13020): go7007: Updates to Kconfig and Makefile
V4L/DVB (13019): video: initial support for ADV7180
V4L/DVB (13018): kzalloc failure ignored in au8522_probe()
V4L/DVB (13017): gspca: kmalloc failure ignored in sd_start()
V4L/DVB (13016): kmalloc failure ignored in lgdt3304_attach() and s921_attach()
V4L/DVB (13015): kmalloc failure ignored in m920x_firmware_download()
V4L/DVB (13014): Add support for Compro VideoMate E800 (DVB-T part only)
V4L/DVB (13013): FM TX: si4713: Kconfig: Fixed two typos.
V4L/DVB (13012): uvc: introduce missing kfree
V4L/DVB (13011): Change tuner type of BeholdTV cards
V4L/DVB (13009): gspca - stv06xx-hdcs: Reduce exposure range
The build of the dabusb driver broke:
drivers/media/video/dabusb.c:758: error: unknown field 'nodename' specified in initializer
drivers/media/video/dabusb.c:758: warning: initialization from incompatible pointer type
make[3]: *** wait: No child processes. Stop.
Due to this commit:
e454cea: Driver-Core: extend devnode callbacks to provide permissions
Missing the dabusb driver's dabusb_nodename() callback.
Similar issues with the iio/industrialio driver in staging, pointed out
and patched by Jean Delvare.
Industrialio-parts-by: Jean Delvare <khali@linux-fr.org>
Signed-off-by: Uwe Kleine-Koenig <u.kleine-koenig@pengutronix.de>
Trivial patch which adds the __init and __exit macros to the module_init /
module_exit functions to several files in drivers/media/video/cx88/
Signed-off-by: Peter Huewe <peterhuewe@gmx.de>
Signed-off-by: Anand Gadiyar <gadiyar@ti.com>
This allows subsytems to provide devtmpfs with non-default permissions
for the device node. Instead of the default mode of 0600, null, zero,
random, urandom, full, tty, ptmx now have a mode of 0666, which allows
non-privileged processes to access standard device nodes in case no
other userspace process applies the expected permissions.
This also fixes a wrong assignment in pktcdvd and a checkpatch.pl complain.
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
drivers/media/dvb/pt1/pt1.c: In function ‘pt1_probe’:
drivers/media/dvb/pt1/pt1.c:915: warning: ‘DMA_nnBIT_MASK’ is deprecated
Remove #include <linux/version.h>
Cc: Eduardo Valentin <eduardo.valentin@nokia.com>
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
This is an initial driver for Analog Devices ADV7180 Video Decoder.
So far it only supports query standard.
[akpm@linux-foundation.org: remove unneeded cast]
Cc: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Richard Röjfors <richard.rojfors.ext@mocean-labs.com>
Prevent NULL dereference if kzalloc() fails.
Cc: Devin Heitmueller <dheitmueller@linuxtv.org>
Signed-off-by: Roel Kluin <roel.kluin@gmail.com>
Prevent NULL dereference if kmalloc() fails.
Cc: Jean-Francois Moine <moinejf@free.fr>
Cc: Markus Rechberger <mrechberger@sundtek.de>
Adding Compro VideoMate E800 (DVB-T part only)
Cc: Steven Toth <stoth@linuxtv.org>
Signed-off-by: Vladimir Geroy <geroin22@yandex.ru>
Fixed two typos.
Signed-off-by: Matti J. Aaltonen <matti.j.aaltonen@nokia.com>
Acked-by: Eduardo Valentin <eduardo.valentin@nokia.com>
Move the kzalloc and associated test after the stream/query test, to avoid
the need to free the allocated if the stream/query test fails.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
// <smpl>
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,f1,l;
position p1,p2;
expression *ptr != NULL;
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
when != if (...) { <+...x...+> }
x->f1 = E
(x->f1 == NULL || ...)
f(...,x->f1,...)
return \(0\|<+...x...+>\|ptr\);
return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
// </smpl>
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Change tuner type to correct for BeholdTV cards with FM1216MK5.
Cc: Hermann Pitton <hermann-pitton@arcor.de>
Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com>
Due to rounding and clipping, exposure and gain settings do not map to
unique register values. Rather than read the registers and report gain
and exposure that may be different than the values that were set, just
cache the latest values that were set and report them. Reduce exposure
range from 0-65535 to 0-255 so libv4l's autogain doesn't take forever.
Remove vestiges of driver signal processing that is now handled by
libv4l.
Signed-off-by: James Blanford <jhblanford@gmail.com>
Signed-off-by: Erik Andrén <erik.andren@gmail.com>
Initialize image size before it's used to initialize exposure.
Work around lack of exposure set hardware latch with a sequence of
register writes in a single I2C command packet.
writes and reads
calculation in some V4L2 drivers
Signed-off-by: Andreas Mohr <andi@lisas.de>
http://linuxtv.org/wiki/index.php/Zolid_Hybrid_TV_Tuner
test status analog (PAL-B):
- Sometimes picture is noisy, but it becomes crystal clear after
switching between channels. (happens for example at 687.25 Mhz)
- On a lower frequency (511.25 Mhz) the picture is always sharp, but
lacks colour.
- No sound problems.
- radio untested.
Digital:
- DVB-T/H stream reception works.
- Would expect to see some more channels in the higher frequency region.
Overall is the impression that sensitivity still needs improvement
both in analog and digital modes.
Signed-off-by: Henk Vergonet <Henk.Vergonet@gmail.com>
When fast push-pull button of remote control we can received incorrect
key code 0x00. Key information from IR decoder has ID of remote control 2 bytes,
byte of key code and byte of mirror key code.
Correct data
0x86 0x6B 0x00 0xFF
Wrong data
0x86 0x6B 0x00 0x00
This patch added additional test of mirror byte for filtering.
This patch adds driver for 774 Friio White, ISDB-T USB receiver
Friio White is an USB 2.0 ISDB-T receiver. (http://www.friio.com/)
The device has a GL861 chip and a Comtech JDVBT90502 canned tuner module.
This driver ignores all the frontend_parameters except frequency,
as ISDB-T shares the same parameter configuration across the country
and thus the device can work like an intelligent one.
As this device does not include a CAM nor hardware descrambling feature,
the driver passes through scrambled TS streams.
There is Friio Black, a variant for ISDB-S, which shares the same USB
Vendor/Product ID with White, but it is not supported in this driver.
They should be identified in the initialization sequence,
but this feature is not tested.
Signed-off-by: Akihiro Tsukada <tskd2@yahoo.co.jp>
Add a driver for Earthsoft PT1
Eearthsoft PT1 is a PCI card for Japanese broadcasting with two ISDB-S
and ISDB-T demodulators.
This card has neither MPEG decoder nor conditional access module
onboard. It transmits only compressed and possibly encrypted MPEG data
over the PCI bus, so you need an external software decoder and a
decrypter to watch TV on your computer.
This driver is originally developed by Tomoaki Ishikawa
<tomy@users.sourceforge.jp> by reverse engineering.
[mchehab@redhat.com: renamed isdb_ts to isdbs_ts to use the current standard]
Signed-off-by: HIRANO Takahito <hiranotaka@zng.info>
In ISDB-S, time-devision duplex is used to multiplexing several waves
in the same frequency. Each wave is identified by its own transport
stream ID, or TS ID. We need to provide some way to specify this ID
from user applications to handle ISDB-S frontends.
This code has been tested with the Earthsoft PT1 driver.
[mchehab@infradead.org: Fix merge conflicts with isdbt and rename the new parameter to DTV_ISDBS_TS_ID]
drivers/media/video/gspca/gl860/gl860.c: In function ‘gl860_build_control_table’:
drivers/media/video/gspca/gl860/gl860.c:119: warning: ‘sd_ctrls’ may be used uninitialized in this function
drivers/media/video/saa7164/saa7164-buffer.c: In function ‘saa7164_buffer_alloc’:
drivers/media/video/saa7164/saa7164-buffer.c:110: warning: cast to pointer from integer of different size
drivers/media/video/saa7164/saa7164-buffer.c:112: warning: cast to pointer from integer of different size
Following changes done for vpif driver to support vpif capture:-
1) Current version of display driver defined vpif register
space as part for vpif display platform driver resource
This is not correct since vpif is common across capture
and display drivers. So the resource iomap function is
moved to this module
2) Since there are common registers, a spinlock is added for
mutual exclusion.
This has incorporated comments against version v0 of the patch series
Resending to merge to V4L linux-next
Reviewed-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Muralidharan Karicheri <m-karicheri2@ti.com>
This is the vpif capture bridge driver for DM6467. This video
supports two video channels each having a tvp5147 device at
the input. This allows simultaneous capture of NTSC/PAL video
in each of this channel. Both MMAP and USERPTR io mechanism
are supported. Currently buffer allocation happens at REQBUF
ioctl request. Since USERPTR IO is supported, this is not an
issue since user applications can allocate buffers and pass
the user space address to the driver. Following are TODOs :-
1) Adding support for allocation of buffers at init
2) VBI/HBI data service
This has incorporated comments received against version v0
of the patch series.
Resending to merge V4l linux-next
create mode 100644 drivers/media/video/davinci/vpif_capture.c
create mode 100644 drivers/media/video/davinci/vpif_capture.h
Adds Kconfig and Makefile changes required for vpif capture driver
The structure name for vpif display driver changed since it was not unique. So this
update is done to reflect the same. Also removed the code related to register
address space iomap. Uses v4l2_i2c_new_subdev_board() instead of
v4l2_i2c_new_probed_subdev() so that platform data can be added for subdevice
configuration for polarities.
This has incorporated comments against version v0 of the patch series.
Resending the original patch for merge to V4L linux-next
function
Warn when the desired device node number is already in use, except when
the new video_register_device_no_warn function is called since in some
use-cases that warning is not relevant.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
numbers
There are some subtle differences in the way the devnode numbers are
handled depending on whether the FIXED_MINOR_RANGES config option is
set. Add some simple wrapper functions to handle that correctly.
