path: root/drivers/media
2011-05-23Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits) b43: fix comment typo reqest -> request Haavard Skinnemoen has left Atmel cris: typo in mach-fs Makefile Kconfig: fix copy/paste-ism for dell-wmi-aio driver doc: timers-howto: fix a typo ("unsgined") perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course'). treewide: fix a few typos in comments regulator: change debug statement be consistent with the style of the rest Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations" audit: acquire creds selectively to reduce atomic op overhead rtlwifi: don't touch with treewide double semicolon removal treewide: cleanup continuations and remove logging message whitespace ath9k_hw: don't touch with treewide double semicolon removal include/linux/leds-regulator.h: fix syntax in example code tty: fix typo in descripton of tty_termios_encode_baud_rate xtensa: remove obsolete BKL kernel option from defconfig m68k: fix comment typo 'occcured' arch:Kconfig.locks Remove unused config option. treewide: remove extra semicolons ...
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (346 commits) ASoC: core: Don't set "(null)" as a driver name ALSA: hda - Use LPIB for ATI/AMD chipsets as default Revert "ALSA: hda - Use position_fix=3 as default for AMD chipsets" ASoC: Tegra: Fix compile when debugfs not enabled ASoC: spdif-dit: Add missing MODULE_* SOUND: OSS: Remove Au1550 driver. ALSA: hda - add Intel Panther Point HDMI codec id ALSA: emu10k1 - Add dB range to Bass and Treble for SB Live! ALSA: hda - Remove PCM mixer elements from Virtual Master of realtek ALSA: hda - Fix input-src parse in patch_analog.c ASoC: davinci-mcasp: enable ping-pong SRAM buffers ASoC: add iPAQ hx4700 machine driver ASoC: Asahi Kasei AK4641 codec driver ALSA: hda - Enable Realtek ALC269 codec input layer beep ALSA: intel8x0m: enable AMD8111 modem ALSA: HDA: Add jack detection for HDMI ALSA: sound, core, pcm_lib: fix xrun_log ASoC: Max98095: Move existing NULL check before pointer dereference. ALSA: sound, core, pcm_lib: xrun_log: log also in_interrupt ALSA: usb-audio - Add support for USB X-Fi S51 Pro ...
2011-05-22Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-05-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: firewire: sbp2: parallelize login, reconnect, logout firewire: sbp2: octlet AT payloads can be stack-allocated firewire: sbp2: omit Scsi_Host lock from queuecommand firewire: core: use non-reentrant workqueue with rescuer firewire: optimize iso queueing by setting wake only after the last packet firewire: octlet AT payloads can be stack-allocated firewire: ohci: optimize find_branch_descriptor() firewire: ohci: avoid separate DMA mapping for small AT payloads firewire: ohci: do not start DMA contexts before link is enabled
2011-05-18Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: [media] V4L: soc-camera: regression fix: calculate .sizeimage in soc_camera.c [media] v4l2-subdev: fix broken subdev control enumeration [media] Fix cx88 remote control input [media] v4l: Release module if subdev registration fails
2011-05-10firewire: optimize iso queueing by setting wake only after the last packetClemens Ladisch
When queueing iso packets, the run time is dominated by the two MMIO accesses that set the DMA context's wake bit. Because most drivers submit packets in batches, we can save much time by removing all but the last wakeup. The internal kernel API is changed to require a call to fw_iso_context_queue_flush() after a batch of queued packets. The user space API does not change, so one call to FW_CDEV_IOC_QUEUE_ISO must specify multiple packets to take advantage of this optimization. In my measurements, this patch reduces the time needed to queue fifty skip packets from userspace to one sixth on a 2.5 GHz CPU, or to one third at 800 MHz. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2011-05-10firewire: octlet AT payloads can be stack-allocatedStefan Richter
We do not need slab allocations anymore in order to satisfy streaming DMA mapping constraints, thanks to commit da28947e7e36 "firewire: ohci: avoid separate DMA mapping for small AT payloads". (Besides, the slab-allocated buffers that firewire-core, firewire-sbp2, and firedtv used to provide for 8-byte write and lock requests were still not fully portable since they crossed cacheline boundaries or shared a cacheline with unrelated CPU-accessed data. snd-firewire-lib got this aspect right by using an extra kmalloc/ kfree just for the 8-byte transaction buffer.) This change replaces kmalloc'ed lock transaction scratch buffers in firewire-core, firedtv, and snd-firewire-lib by local stack allocations. Perhaps the most notable result of the change is simpler locking because there is no need to serialize usages of preallocated per-device buffers anymore. Also, allocations and deallocations are simpler. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: Clemens Ladisch <clemens@ladisch.de>
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-04Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: [media] ngene: Fix CI data transfer regression Fix CI data transfer regression introduced by previous cleanup. [media] v4l: make sure drivers supply a zeroed struct v4l2_subdev [media] Missing frontend config for LME DM04/QQBOX [media] rc_core: avoid kernel oops when rmmod saa7134 [media] imon: add conditional locking in change_protocol [media] rc: show RC_TYPE_OTHER in sysfs [media] ite-cir: modular build on ppc requires delay.h include [media] mceusb: add Dell transceiver ID
2011-05-04[media] V4L: soc-camera: regression fix: calculate .sizeimage in soc_camera.cSergio Aguirre
A recent patch has given individual soc-camera host drivers a possibility to calculate .sizeimage and .bytesperline pixel format fields internally, however, some drivers relied on the core calculating these values for them, following a default algorithm. This patch restores the default calculation for such drivers. Based on initial patch by Guennadi Liakhovetski, found here: http://www.spinics.net/lists/linux-media/msg31282.html Except that this covers try_fmt aswell. Signed-off-by: Sergio Aguirre <saaguirre@ti.com> Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-04[media] v4l2-subdev: fix broken subdev control enumerationHans Verkuil
The v4l2_subdev_* functions are meant for older V4L2 drivers that do not use the control framework yet. These functions should not be used by subdev_do_ioctl. Most of those backwards compatibility functions are just stubs, but commit 87a0c94ce616b231f3c0bd09d7dbd39d43b0557a actually changed the behavior of v4l2_subdev_queryctrl, so calling that one from subdev_do_ioctl broke the control enumeration in subdev nodes. The fix is simply not to use those compatibility functions in v4l2-subdev.c. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-04[media] Fix cx88 remote control inputLawrence Rust
In the IR interrupt handler of cx88-input.c there's a 32-bit multiply overflow which causes IR pulse durations to be incorrectly calculated. This is a regression caused by commit 2997137be8eba. Cc: stable@kernel.org Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-05-04[media] v4l: Release module if subdev registration failsLaurent Pinchart
If v4l2_device_register_subdev() fails, the reference to the subdev module taken by the function isn't released. Fix this. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: stable@kernel.org Acked-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-29[media] ngene: Fix CI data transfer regressionOliver Endriss
Fix CI data transfer regression introduced by previous cleanup. Signed-off-by: Oliver Endriss <o.endriss@gmx.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-29[media] v4l: make sure drivers supply a zeroed struct v4l2_subdevHerton Ronaldo Krzesinski
Some v4l drivers currently don't initialize their struct v4l2_subdev with zeros, and this is a problem since some of the v4l2 code expects this. One example is the addition of internal_ops in commit 45f6f84, after that we are at risk of random oopses with these drivers when code in v4l2_device_register_subdev tries to dereference sd->internal_ops->*, as can be shown by the report at http://bugs.launchpad.net/bugs/745213 and analysis of its crash at https://lkml.org/lkml/2011/4/1/168 Use kzalloc within problematic drivers to ensure we have a zeroed struct v4l2_subdev. BugLink: http://bugs.launchpad.net/bugs/745213 Cc: <stable@kernel.org> Signed-off-by: Herton Ronaldo Krzesinski <herton.krzesinski@canonical.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-29[media] Missing frontend config for LME DM04/QQBOXMalcolm Priestley
Forgot to add the DVB_STV0299/DVB_PLL to config Signed-off-by: Malcolm Priestley <tvboxspy@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-29[media] rc_core: avoid kernel oops when rmmod saa7134Hussam Al-Tayeb
The following is a patch to avoid a kernel oops when running rmmod saa7134 on kernel 2.6.27.1. The change is as suggested by mchehab on irc.freenode.org Signed-off-by: Hussam Al-Tayeb <ht990332@gmail.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-29[media] imon: add conditional locking in change_protocolJarod Wilson
The imon_ir_change_protocol function gets called two different ways, one way is from rc_register_device, for initial protocol selection/setup, and the other is via a userspace-initiated protocol change request, either by direct sysfs prodding or by something like ir-keytable. In the rc_register_device case, the imon context lock is already held, but when initiated from userspace, it is not, so we must acquire it, prior to calling send_packet, which requires that the lock is held. Without this change, there's an easily reproduceable deadlock when another function calls send_packet (such as either of the display write fops) after a userspace-initiated change_protocol. With a lock-debugging-enabled kernel, I was getting this: [ 15.014153] ===================================== [ 15.015048] [ BUG: bad unlock balance detected! ] [ 15.015048] ------------------------------------- [ 15.015048] ir-keytable/773 is trying to release lock (&ictx->lock) at: [ 15.015048] [<ffffffff814c6297>] mutex_unlock+0xe/0x10 [ 15.015048] but there are no more locks to release! [ 15.015048] [ 15.015048] other info that might help us debug this: [ 15.015048] 2 locks held by ir-keytable/773: [ 15.015048] #0: (&buffer->mutex){+.+.+.}, at: [<ffffffff8119d400>] sysfs_write_file+0x3c/0x144 [ 15.015048] #1: (s_active#87){.+.+.+}, at: [<ffffffff8119d4ab>] sysfs_write_file+0xe7/0x144 [ 15.015048] [ 15.015048] stack backtrace: [ 15.015048] Pid: 773, comm: ir-keytable Not tainted 2.6.38.4-20.fc15.x86_64.debug #1 [ 15.015048] Call Trace: [ 15.015048] [<ffffffff81089715>] ? print_unlock_inbalance_bug+0xca/0xd5 [ 15.015048] [<ffffffff8108b35c>] ? lock_release_non_nested+0xc1/0x263 [ 15.015048] [<ffffffff814c6297>] ? mutex_unlock+0xe/0x10 [ 15.015048] [<ffffffff814c6297>] ? mutex_unlock+0xe/0x10 [ 15.015048] [<ffffffff8108b67b>] ? lock_release+0x17d/0x1a4 [ 15.015048] [<ffffffff814c6229>] ? __mutex_unlock_slowpath+0xc5/0x125 [ 15.015048] [<ffffffff814c6297>] ? mutex_unlock+0xe/0x10 [ 15.015048] [<ffffffffa02964b6>] ? send_packet+0x1c9/0x264 [imon] [ 15.015048] [<ffffffff8108b376>] ? lock_release_non_nested+0xdb/0x263 [ 15.015048] [<ffffffffa0296731>] ? imon_ir_change_protocol+0x126/0x15e [imon] [ 15.015048] [<ffffffffa024a334>] ? store_protocols+0x1c3/0x286 [rc_core] [ 15.015048] [<ffffffff81326e4e>] ? dev_attr_store+0x20/0x22 [ 15.015048] [<ffffffff8119d4cc>] ? sysfs_write_file+0x108/0x144 ... The original report that led to the investigation was the following: [ 1679.457305] INFO: task LCDd:8460 blocked for more than 120 seconds. [ 1679.457307] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 1679.457309] LCDd D ffff88010fcd89c8 0 8460 1 0x00000000 [ 1679.457312] ffff8800d5a03b48 0000000000000082 0000000000000000 ffff8800d5a03fd8 [ 1679.457314] 00000000012dcd30 fffffffffffffffd ffff8800d5a03fd8 ffff88010fcd86f0 [ 1679.457316] ffff8800d5a03fd8 ffff8800d5a03fd8 ffff88010fcd89d0 ffff8800d5a03fd8 [ 1679.457319] Call Trace: [ 1679.457324] [<ffffffff810ff1a5>] ? zone_statistics+0x75/0x90 [ 1679.457327] [<ffffffff810ea907>] ? get_page_from_freelist+0x3c7/0x820 [ 1679.457330] [<ffffffff813b0a49>] __mutex_lock_slowpath+0x139/0x320 [ 1679.457335] [<ffffffff813b0c41>] mutex_lock+0x11/0x30 [ 1679.457338] [<ffffffffa0d54216>] display_open+0x66/0x130 [imon] [ 1679.457345] [<ffffffffa01d06c0>] usb_open+0x180/0x310 [usbcore] [ 1679.457349] [<ffffffff81143b3b>] chrdev_open+0x1bb/0x2d0 [ 1679.457350] [<ffffffff8113d93d>] __dentry_open+0x10d/0x370 [ 1679.457352] [<ffffffff81143980>] ? chrdev_open+0x0/0x2d0 ... Bump the driver version here so its easier to tell if people have this locking fix or not, and also make locking during probe easier to follow. CC: stable@kernel.org Reported-by: Benjamin Hodgetts <ben@xnode.org> Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-29[media] rc: show RC_TYPE_OTHER in sysfsJarod Wilson
2011-04-29[media] ite-cir: modular build on ppc requires delay.h includeJarod Wilson
2011-04-29[media] mceusb: add Dell transceiver IDJarod Wilson
Add device ID for a Dell-branded, Philips device ID transceiver reported by an OpenELEC user on their forums. http://openelec.tv/forum/27-hardware-support/5622-adding-support-for-an-ir-receiver--dell-branded--#5622 Signed-off-by: Jarod Wilson <jarod@redhat.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-27Merge branch 'spell-fix' of git://git.profusion.mobi/users/lucas/linux-2.6Linus Torvalds
* 'spell-fix' of git://git.profusion.mobi/users/lucas/linux-2.6: Revert wrong fixes for common misspellings
2011-04-27Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (42 commits) [media] media: vb2: correct queue initialization order [media] media: vb2: fix incorrect v4l2_buffer->flags handling [media] s5p-fimc: Add support for the buffer timestamps and sequence [media] s5p-fimc: Fix bytesperline and plane payload setup [media] s5p-fimc: Do not allow changing format after REQBUFS [media] s5p-fimc: Fix FIMC3 pixel limits on Exynos4 [media] tda18271: update tda18271c2_rf_cal as per NXP's rev.04 datasheet [media] tda18271: update tda18271_rf_band as per NXP's rev.04 datasheet [media] tda18271: fix bad calculation of main post divider byte [media] tda18271: prog_cal and prog_tab variables should be s32, not u8 [media] tda18271: fix calculation bug in tda18271_rf_tracking_filters_init [media] omap3isp: queue: Don't corrupt buf->npages when get_user_pages() fails [media] v4l: Don't register media entities for subdev device nodes [media] omap3isp: Don't increment node entity use count when poweron fails [media] omap3isp: lane shifter support [media] omap3isp: ccdc: support Y10/12, 8-bit bayer fmts [media] media: add missing 8-bit bayer formats and Y12 [media] v4l: add V4L2_PIX_FMT_Y12 format cx23885: Fix stv0367 Kconfig dependency [media] omap3isp: Use isp xclk defines ... Fix up trivial conflict (spelink errurs) in drivers/media/video/omap3isp/isp.c
2011-04-26Revert wrong fixes for common misspellingsLucas De Marchi
These changes were incorrectly fixed by codespell. They were now manually corrected. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi>
2011-04-26treewide: cleanup continuations and remove logging message whitespaceJoe Perches
Using C line continuation inside format strings is error prone. Clean up the unintended whitespace introduced by misuse of \. Neaten correctly used line continations as well for consistency. drivers/scsi/arcmsr/arcmsr_hba.c has these errors as well, but arcmsr needs a lot more work and the driver should likely be moved to staging instead. Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-19[media] media: vb2: correct queue initialization orderMarek Szyprowski
q->memory entry is initialized to late, so if allocation of memory buffers fails, the buffers might not be freed correctly (q->memory is tested in __vb2_free_mem, which can be called before setting q->memory). Reported-by: Kamil Debski <k.debski@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Pawel Osciak <pawel@osciak.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] media: vb2: fix incorrect v4l2_buffer->flags handlingMarek Szyprowski
Videobuf2 core assumes that driver doesn't set any buffer flags. This is correct for buffer state flags that videobuf2 manages, but the other flags like V4L2_BUF_FLAG_{KEY,P,B}FRAME, V4L2_BUF_FLAG_TIMECODE and V4L2_BUF_FLAG_INPUT should be passed from or to the driver. Reported-by: Jonghun Han <jonghun.han@samsung.com> Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> CC: Pawel Osciak <pawel@osciak.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] s5p-fimc: Add support for the buffer timestamps and sequenceSylwester Nawrocki
Add support for buffer timestamps and the sequence number in the video capture driver. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] s5p-fimc: Fix bytesperline and plane payload setupSylwester Nawrocki
Make sure the sizeimage for 3-planar color formats is width * height * 3/2 and the bytesperline is same for each plane in case of a multi-planar format. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] s5p-fimc: Do not allow changing format after REQBUFSSylwester Nawrocki
Protecting the color format with vb2_is_streaming() is not sufficient as this prevents changing the format only after VIDIOC_STREAMON. To prevent the color format reconfiguration as soon as buffers are allocated use vb2_is_busy() instead. Also make the videobuf queue ops structure static. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] s5p-fimc: Fix FIMC3 pixel limits on Exynos4Sylwester Nawrocki
Correct pixel limits for the fourth FIMC entity on Exynos4 SoCs. FIMC3 only supports the writeback input from the LCD mixer. Also rename s5pv310 variant to exynos4 which is needed after renaming s5pv310 series to Exynos4. Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19Revert "[media] V4L: videobuf, don't use dma addr as physical"Linus Torvalds
This reverts commit 35d9f510b67b10338161aba6229d4f55b4000f5b. Quoth Jiri Slaby: "It fixes mmap when IOMMU is used on x86 only, but breaks architectures like ARM or PPC where virt_to_phys(dma_alloc_coherent) doesn't work. We need there dma_mmap_coherent or similar (the trickery what snd_pcm_default_mmap does but in some saner way). But this cannot be done at this phase." Requested-by: Jiri Slaby <jslaby@suse.cz> Cc: Russell King - ARM Linux <linux@arm.linux.org.uk> Cc: Janusz Krzysztofik <jkrzyszt@tis.icnet.pl> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-04-19[media] tda18271: update tda18271c2_rf_cal as per NXP's rev.04 datasheetMichael Krufky
Cc: Stefan Sibiga <stefansibiga@yahoo.ca> Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] tda18271: update tda18271_rf_band as per NXP's rev.04 datasheetMichael Krufky
2011-04-19[media] tda18271: fix bad calculation of main post divider byteMichael Krufky
R_MPD bit 3 does not depend on analog vs. digital. Just use (0x7f & pd) directly from the values in the main pll table. Thanks to Stefan Sibiga for pointing this out. Cc: Stefan Sibiga <stefansibiga@yahoo.ca> Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] tda18271: prog_cal and prog_tab variables should be s32, not u8Michael Krufky
Fix type of prog_cal and prog_tab variables to avoid any possible calculation errors. Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] tda18271: fix calculation bug in tda18271_rf_tracking_filters_initMichael Krufky
Misplaced parenthesis cause a calculation bug in tda18271_rf_tracking_filters_init Thanks to Stefan Sibiga for pointing this out. Cc: Stefan Sibiga <stefansibiga@yahoo.ca> Signed-off-by: Michael Krufky <mkrufky@kernellabs.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] omap3isp: queue: Don't corrupt buf->npages when get_user_pages() failsLaurent Pinchart
get_user_pages() can return a negative error code when it fails. Set buf->npages to 0 in that case, to prevent isp_video_buffer_cleanup() from releasing invalid pages. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] v4l: Don't register media entities for subdev device nodesLaurent Pinchart
Subdevs already have their own entity, don't register as second one when registering the subdev device node. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Acked-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] omap3isp: Don't increment node entity use count when poweron failsLaurent Pinchart
When open a device node, all entities part of the same pipeline are powered on. If one of the entities fails to be powered on, the open operations fails. In that case the device node entity use count must not be incremented. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] omap3isp: lane shifter supportMichael Jones
To use the lane shifter, set different pixel formats at each end of the link at the CCDC input. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-19[media] omap3isp: ccdc: support Y10/12, 8-bit bayer fmtsMichael Jones
Add support for 8-bit bayer and 10- and 12-bit grey formats at the CCDC input. Y12 is truncated to Y10 at the CCDC output. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-17cx23885: Fix stv0367 Kconfig dependencyMauro Carvalho Chehab
2011-04-17[media] omap3isp: Use isp xclk definesStanimir Varbanov
Use isp defines for isp xclk selection in isp_set_xclk(). Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-17[media] omap3isp: isp: Reset the ISP when the pipeline can't be stoppedLaurent Pinchart
When a failure to stop a module in the pipeline is detected, the only way to recover is to reset the ISP. However, as other users can be using a different pipeline with other modules, the ISP can't be reset synchronously with the error detection. Mark the ISP as needing a reset when a failure to stop a pipeline is detected, and reset the ISP when the last user releases the last reference to the ISP. Modify the omap3isp_pipeline_set_stream() function to record the new ISP pipeline state only when no error occurs, except when stopping the pipeline in which case the pipeline is still marked as stopped. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-17[media] omap3isp: stat: update struct ispstat_generic_config's commentsDavid Cohen
struct ispstat_generic_config's comments refers to isph3a_aewb_config, isph3a_af_config and isphist_config. But those structs have had their names prefixed with 'omap3'. So, let's update the comments. Signed-off-by: David Cohen <david.cohen@nokia.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-17[media] media: Properly handle link flags in link setup, link notify callbackLaurent Pinchart
The link flags were not properly handled in __media_entity_setup_link which could lead to link_notify callback to be called when the flags are not modified. Fix this. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-17[media] omap3isp: Fix trivial typosMichael Jones
It doesn't get more trivial than these. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-17[media] omap3isp: resizer: Improved resizer rsz factor formulaSakari Ailus
Round properly the rsz factor so that we get highest rsz so that the input width (or height) is highest possible smaller or equal to what the user asks. Signed-off-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com> Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-04-17[media] omap3isp: resizer: Use 4-tap mode equations when the ratio is <= 512Laurent Pinchart
As the number of phases/taps, used to select the correct equations to compute the ratio, depends on the ratio, start with the 7-tap mode equations to compute an approximation of the ratio, and switch to the 4-tap mode equations if the approximation is lower than or equal to 512. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
