commit 1db56284b9da9056093681f28db48a09a243274b upstream.
disable_irqs() was mistakenly disabling all interrupts when called.
This cause all port stream to stop even if only stopping one of them.
Cc: stable <stable@vger.kernel.org>
Signed-off-by: Benoit Parrot <bparrot@ti.com>
Signed-off-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Signed-off-by: Mauro Carvalho Chehab <mchehab+huawei@kernel.org>
commit a246b4d547708f33ff4d4b9a7a5dbac741dc89d8 upstream.
Make sure to check that we have two alternate settings and at least one
endpoint before accessing the second altsetting structure and
dereferencing the endpoint arrays.
This specifically avoids dereferencing NULL-pointers or corrupting
memory when a device does not have the expected descriptors.
Note that the sanity check in cit_get_packet_size() is not redundant as
the driver is mixing looking up altsettings by index and by number,
which may not coincide.
Fixes: 659fefa0eb17 ("V4L/DVB: gspca_xirlink_cit: Add support for camera with a bcd version of 0.01")
Fixes: 59f8b0bf3c12 ("V4L/DVB: gspca_xirlink_cit: support bandwidth changing for devices with 1 alt setting")
Cc: stable <stable@vger.kernel.org> # 2.6.37
Cc: Hans de Goede <hdegoede@redhat.com>
Signed-off-by: Johan Hovold <johan@kernel.org>
commit 485b06aadb933190f4bc44e006076bc27a23f205 upstream.
Note that the sanity checks in stv06xx_start() and pb0100_start() are
not redundant as the driver is mixing looking up altsettings by index
and by number, which may not coincide.
Fixes: 8668d504d72c ("V4L/DVB (12082): gspca_stv06xx: Add support for st6422 bridge and sensor")
Fixes: c0b33bdc5b8d ("[media] gspca-stv06xx: support bandwidth changing")
Cc: stable <stable@vger.kernel.org> # 2.6.31
commit f52981019ad8d6718de79b425a574c6bddf81f7c upstream.
Make sure to use the current alternate setting when verifying the
interface descriptors to avoid submitting an URB to an invalid endpoint.
Failing to do so could cause the driver to misbehave or trigger a WARN()
in usb_submit_urb() that kernels with panic_on_warn set would choke on.
Fixes: c4018fa2e4c0 ("[media] dib0700: fix RC support on Hauppauge Nova-TD")
Cc: stable <stable@vger.kernel.org> # 3.16
Signed-off-by: Sean Young <sean@mess.org>
commit 998912346c0da53a6dbb71fab3a138586b596b30 upstream.
Make sure to check that we have at least one endpoint before accessing
the endpoint array to avoid dereferencing a NULL-pointer on stream
start.
Note that these sanity checks are not redundant as the driver is mixing
looking up altsettings by index and by number, which need not coincide.
Fixes: 1876bb923c98 ("V4L/DVB (12079): gspca_ov519: add support for the ov511 bridge")
Fixes: b282d87332f5 ("V4L/DVB (12080): gspca_ov519: Fix ov518+ with OV7620AE (Trust spacecam 320)")
commit 536f561d871c5781bc33d26d415685211b94032e upstream.
The driver was issuing synchronous uninterruptible control requests
without using a timeout. This could lead to the driver hanging on
various user requests due to a malfunctioning (or malicious) device
until the device is physically disconnected.
The USB upper limit of five seconds per request should be more than
enough.
Fixes: f3d27f34fdd7 ("[media] usbtv: Add driver for Fushicai USBTV007 video frame grabber")
Fixes: c53a846c48f2 ("[media] usbtv: add video controls")
Cc: stable <stable@vger.kernel.org> # 3.11
Acked-by: Lubomir Rintel <lkundrak@v3.sk>
Reviewed-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
commit bca243b1ce0e46be26f7c63b5591dfbb41f558e5 upstream.
commit 1b976fc6d684 ("media: b2c2-flexcop-usb: add sanity checking") added
an endpoint sanity check to address a NULL-pointer dereference on probe.
Unfortunately the check was done on the current altsetting which was later
changed.
Fix this by moving the sanity check to after the altsetting is changed.
Fixes: 1b976fc6d684 ("media: b2c2-flexcop-usb: add sanity checking")
Cc: Oliver Neukum <oneukum@suse.com>
bdisp_device_run()
[ Upstream commit bb6d42061a05d71dd73f620582d9e09c8fbf7f5b ]
The driver may sleep while holding a spinlock.
The function call path (from bottom to top) in Linux 4.19 is:
drivers/media/platform/sti/bdisp/bdisp-hw.c, 385:
msleep in bdisp_hw_reset
drivers/media/platform/sti/bdisp/bdisp-v4l2.c, 341:
bdisp_hw_reset in bdisp_device_run
drivers/media/platform/sti/bdisp/bdisp-v4l2.c, 317:
_raw_spin_lock_irqsave in bdisp_device_run
To fix this bug, msleep() is replaced with udelay().
This bug is found by a static analysis tool STCheck written by myself.
Signed-off-by: Jia-Ju Bai <baijiaju1990@gmail.com>
Reviewed-by: Fabien Dessenne <fabien.dessenne@st.com>
[ Upstream commit 1451d5ae351d938a0ab1677498c893f17b9ee21d ]
This driver supports both the mt9v032 (color) and the mt9v022 (mono)
sensors. Depending on which sensor is used, the format from the sensor is
different. The format.code inside the dev struct holds this information.
The enum mbus and enum frame sizes need to take into account both type of
sensors, not just the color one. To solve this, use the format.code in
these functions instead of the hardcoded bayer color format (which is only
used for mt9v032).
[Sakari Ailus: rewrapped commit message]
Suggested-by: Wenyou Yang <wenyou.yang@microchip.com>
Signed-off-by: Eugen Hristev <eugen.hristev@microchip.com>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Signed-off-by: Sakari Ailus <sakari.ailus@linux.intel.com>
commit 3c7470b6f68434acae459482ab920d1e3fabd1c7 upstream.
After DMA is complete, and the device and CPU caches are synchronized,
it's still required to mark the CPU pages as dirty, if the data was
coming from the device. However, this driver was just issuing a bare
put_page() call, without any set_page_dirty*() call.
Fix the problem, by calling set_page_dirty_lock() if the CPU pages were
potentially receiving data from the device.
Link: http://lkml.kernel.org/r/20200107224558.2362728-11-jhubbard@nvidia.com
Signed-off-by: John Hubbard <jhubbard@nvidia.com>
Acked-by: Hans Verkuil <hverkuil-cisco@xs4all.nl>
Cc: Mauro Carvalho Chehab <mchehab@kernel.org>
Cc: <stable@vger.kernel.org>
Cc: Alex Williamson <alex.williamson@redhat.com>
Cc: Aneesh Kumar K.V <aneesh.kumar@linux.ibm.com>
Cc: Björn Töpel <bjorn.topel@intel.com>
Cc: Daniel Vetter <daniel.vetter@ffwll.ch>
Cc: Dan Williams <dan.j.williams@intel.com>
Cc: Ira Weiny <ira.weiny@intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Jason Gunthorpe <jgg@mellanox.com>
Cc: Jason Gunthorpe <jgg@ziepe.ca>
Cc: Jerome Glisse <jglisse@redhat.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: Kirill A. Shutemov <kirill@shutemov.name>
Cc: Leon Romanovsky <leonro@mellanox.com>
Cc: Mike Rapoport <rppt@linux.ibm.com>
commit 68035c80e129c4cfec659aac4180354530b26527 upstream.
Way back in 2017, fuzzing the 4.14-rc2 USB stack with syzkaller kicked
up the following WARNING from the UVC chain scanning code:
| list_add double add: new=ffff880069084010, prev=ffff880069084010,
| next=ffff880067d22298.
| ------------[ cut here ]------------
| WARNING: CPU: 1 PID: 1846 at lib/list_debug.c:31 __list_add_valid+0xbd/0xf0
| Modules linked in:
| CPU: 1 PID: 1846 Comm: kworker/1:2 Not tainted
| 4.14.0-rc2-42613-g1488251d1a98 #238
| Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011
| Workqueue: usb_hub_wq hub_event
| task: ffff88006b01ca40 task.stack: ffff880064358000
| RIP: 0010:__list_add_valid+0xbd/0xf0 lib/list_debug.c:29
| RSP: 0018:ffff88006435ddd0 EFLAGS: 00010286
| RAX: 0000000000000058 RBX: ffff880067d22298 RCX: 0000000000000000
| RDX: 0000000000000058 RSI: ffffffff85a58800 RDI: ffffed000c86bbac
| RBP: ffff88006435dde8 R08: 1ffff1000c86ba52 R09: 0000000000000000
| R10: 0000000000000002 R11: 0000000000000000 R12: ffff880069084010
| R13: ffff880067d22298 R14: ffff880069084010 R15: ffff880067d222a0
| FS: 0000000000000000(0000) GS:ffff88006c900000(0000) knlGS:0000000000000000
| CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
| CR2: 0000000020004ff2 CR3: 000000006b447000 CR4: 00000000000006e0
| Call Trace:
| __list_add ./include/linux/list.h:59
| list_add_tail+0x8c/0x1b0 ./include/linux/list.h:92
| uvc_scan_chain_forward.isra.8+0x373/0x416
| drivers/media/usb/uvc/uvc_driver.c:1471
| uvc_scan_chain drivers/media/usb/uvc/uvc_driver.c:1585
| uvc_scan_device drivers/media/usb/uvc/uvc_driver.c:1769
| uvc_probe+0x77f2/0x8f00 drivers/media/usb/uvc/uvc_driver.c:2104
Looking into the output from usbmon, the interesting part is the
following data packet:
ffff880069c63e00 30710169 C Ci:1:002:0 0 143 = 09028f00 01030080
00090403 00000e01 00000924 03000103 7c003328 010204db
If we drop the lead configuration and interface descriptors, we're left
with an output terminal descriptor describing a generic display:
/* Output terminal descriptor */
buf[0] 09
buf[1] 24
buf[2] 03 /* UVC_VC_OUTPUT_TERMINAL */
buf[3] 00 /* ID */
buf[4] 01 /* type == 0x0301 (UVC_OTT_DISPLAY) */
buf[5] 03
buf[6] 7c
buf[7] 00 /* source ID refers to self! */
buf[8] 33
The problem with this descriptor is that it is self-referential: the
source ID of 0 matches itself! This causes the 'struct uvc_entity'
representing the display to be added to its chain list twice during
'uvc_scan_chain()': once via 'uvc_scan_chain_entity()' when it is
processed directly from the 'dev->entities' list and then again
immediately afterwards when trying to follow the source ID in
'uvc_scan_chain_forward()'
Add a check before adding an entity to a chain list to ensure that the
entity is not already part of a chain.
Link: https://lore.kernel.org/linux-media/CAAeHK+z+Si69jUR+N-SjN9q4O+o5KFiNManqEa-PjUta7EOb7A@mail.gmail.com/
Fixes: c0efd232929c ("V4L/DVB (8145a): USB Video Class driver")
Reported-by: Andrey Konovalov <andreyknvl@google.com>
Signed-off-by: Will Deacon <will@kernel.org>
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
[ Upstream commit 1b257870a78b0a9ce98fdfb052c58542022ffb5b ]
Make sure to use the current alternate setting, which need not be the
first one by index, when verifying the endpoint descriptors and
initialising the URBs.
Fixes: 26ff63137c45 ("[media] Add support for the IguanaWorks USB IR Transceiver")
Fixes: ab1cbdf159be ("media: iguanair: add sanity checks")
Cc: stable <stable@vger.kernel.org> # 3.6
A pointer to 'struct si470x_device' is currently used after free:
drivers/media/radio/si470x/radio-si470x-i2c.c:462:25-30: ERROR: reference
preceded by free on line 460
Shift the call to free() down past its final use.
NB: Not sending to Mainline, since the problem does not exist there, it was
caused by the backport of 2df200ab234a ("media: si470x-i2c: add missed
operations in remove") to the stable trees.
Cc: <stable@vger.kernel.org> # v3.18+
Reported-by: kbuild test robot <lkp@intel.com>
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
commit 569bc8d6a6a50acb5fcf07fb10b8d2d461fdbf93 upstream.
This fixes a syzbot failure since actlen could be uninitialized,
but it was still used.
Syzbot link:
https://syzkaller.appspot.com/bug?extid=6bf9606ee955b646c0e1
Reported-and-tested-by: syzbot+6bf9606ee955b646c0e1@syzkaller.appspotmail.com
Acked-by: Sean Young <sean@mess.org>
commit de89d0864f66c2a1b75becfdd6bf3793c07ce870 upstream.
Allocate gspca_dev->usb_buf with kzalloc instead of kmalloc to
ensure it is property zeroed. This fixes various syzbot errors
about uninitialized data.
Syzbot links:
https://syzkaller.appspot.com/bug?extid=32310fc2aea76898d074
https://syzkaller.appspot.com/bug?extid=99706d6390be1ac542a2
https://syzkaller.appspot.com/bug?extid=64437af5c781a7f0e08e
Reported-and-tested-by: syzbot+32310fc2aea76898d074@syzkaller.appspotmail.com
Reported-and-tested-by: syzbot+99706d6390be1ac542a2@syzkaller.appspotmail.com
Reported-and-tested-by: syzbot+64437af5c781a7f0e08e@syzkaller.appspotmail.com
commit 51d0c99b391f0cac61ad7b827c26f549ee55672c upstream.
If usb_bulk_msg() fails, actual_length can be uninitialized.
Reported-by: syzbot+9d42b7773d2fecd983ab@syzkaller.appspotmail.com
commit eecc70d22ae51225de1ef629c1159f7116476b2e upstream.
This results in an uninitialized variable read.
Reported-by: syzbot+6bf9606ee955b646c0e1@syzkaller.appspotmail.com
[ Upstream commit 39034bb0c26b76a2c3abc54aa28c185f18b40c2f ]
Commit da298c6d98d5 ("[media] v4l2: replace video op g_mbus_fmt by pad
op get_fmt") converted a former ov6650_g_fmt() video operation callback
to an ov6650_get_fmt() pad operation callback. However, the converted
function disregards a format->which flag that pad operations should
obey and always returns active frame format settings.
That can be fixed by always responding to V4L2_SUBDEV_FORMAT_TRY with
-EINVAL, or providing the response from a pad config argument, likely
updated by a former user call to V4L2_SUBDEV_FORMAT_TRY .set_fmt().
Since implementation of the latter is trivial, go for it.
Fixes: da298c6d98d5 ("[media] v4l2: replace video op g_mbus_fmt by pad op get_fmt")
Signed-off-by: Janusz Krzysztofik <jmkrzyszt@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
[ Upstream commit 1c6a2b63095154bbf9e8f38d79487a728331bf65 ]
User arguments passed to .get/set_fmt() pad operation callbacks may
contain unsupported values. The driver takes control over frame size
and pixel code as well as colorspace and field attributes but has never
cared for remainig format attributes, i.e., ycbcr_enc, quantization
and xfer_func, introduced by commit 11ff030c7365 ("[media]
v4l2-mediabus: improve colorspace support"). Fix it.
Set up a static v4l2_mbus_framefmt structure with attributes
initialized to reasonable defaults and use it for updating content of
user provided arguments. In case of V4L2_SUBDEV_FORMAT_ACTIVE,
postpone frame size update, now performed from inside ov6650_s_fmt()
helper, util the user argument is first updated in ov6650_set_fmt() with
default frame format content. For V4L2_SUBDEV_FORMAT_TRY, don't copy
all attributes to pad config, only those handled by the driver, then
fill the response with the default frame format updated with resulting
pad config format code and frame size.
Fixes: 11ff030c7365 ("[media] v4l2-mediabus: improve colorspace support")
[ Upstream commit 12500731895ef09afc5b66b86b76c0884fb9c7bf ]
Since its initial submission, the driver selects V4L2_COLORSPACE_JPEG
for supported formats other than V4L2_MBUS_FMT_SBGGR8_1X8. According
to v4l2-compliance test program, V4L2_COLORSPACE_JPEG applies
exclusively to V4L2_PIX_FMT_JPEG. Since the sensor does not support
JPEG format, fix it to always select V4L2_COLORSPACE_SRGB.
Fixes: 2f6e2404799a ("[media] SoC Camera: add driver for OV6650 sensor")
[ Upstream commit d4ec9550e4b2d2e357a46fdc65d8ef3d4d15984c ]
The assigment of FB_VMODE_NONINTERLACE to var->vmode should be a
bit-wise or of FB_VMODE_NONINTERLACE instead of an assignment,
otherwise the previous clearing of the FB_VMODE_MASK bits of
var->vmode makes no sense and is redundant.
Addresses-Coverity: ("Unused value")
Fixes: ad4e02d5081d ("[media] vivid: add a simple framebuffer device for overlay testing")
[ Upstream commit b72845ee5577b227131b1fef23f9d9a296621d7b ]
In vpbe_enum_outputs() we check if (temp_index >= cfg->num_outputs) but
the problem is that "temp_index" can be negative. This patch changes
the types to unsigned to address this array underflow bug.
Fixes: 66715cdc3224 ("[media] davinci vpbe: VPBE display driver")
Acked-by: "Lad, Prabhakar" <prabhakar.csengg@gmail.com>
[ Upstream commit dd6e2a981bfe83aa4a493143fd8cf1edcda6c091 ]
The "b->index" is a u32 the comes from the user in the ioctl. It hasn't
been checked. We aren't supposed to use it but we're instead supposed
to use the value that gets written to it when we call videobuf_dqbuf().
The videobuf_dqbuf() first memsets it to zero and then re-initializes it
inside the videobuf_status() function. It's this final value which we
want.
Hans Verkuil pointed out that we need to check the return from
videobuf_dqbuf(). I ended up doing a little cleanup related to that as
well.
Fixes: 72915e851da9 ("[media] V4L2: OMAP: VOUT: dma map and unmap v4l2 buffers in qbuf and dqbuf")
[ Upstream commit 384538bda10913e5c94ec5b5d34bd3075931bcf4 ]
Avoid returning with mutex locked.
Fixes: fa8cb6444c32 ("[media] ov2659: Don't depend on subdev API")
Cc: "Lad, Prabhakar" <prabhakar.csengg@gmail.com>
Acked-by: Lad, Prabhakar <prabhakar.csengg@gmail.com>
[ Upstream commit 2e7682ebfc750177a4944eeb56e97a3f05734528 ]
'vb' null check should be done before dereferencing it in
tw5864_handle_frame, otherwise a NULL pointer dereference
may occur.
Fixes: 34d1324edd31 ("[media] pci: Add tw5864 driver")
Signed-off-by: YueHaibing <yuehaibing@huawei.com>
[ Upstream commit 0e633f97162c1c74c68e2eb20bbd9259dce87cd9 ]
clang warns about a possible variable use that gcc never
complained about:
drivers/media/platform/davinci/isif.c:982:32: error: variable 'frame_size' is uninitialized when used here
[-Werror,-Wuninitialized]
dm365_vpss_set_pg_frame_size(frame_size);
drivers/media/platform/davinci/isif.c:887:2: note: variable 'frame_size' is declared here
struct vpss_pg_frame_size frame_size;
1 error generated.
There is no initialization for this variable at all, and there
has never been one in the mainline kernel, so we really should
not put that stack data into an mmio register.
On the other hand, I suspect that gcc checks the condition
more closely and notices that the global
isif_cfg.bayer.config_params.test_pat_gen flag is initialized
to zero and never written to from any code path, so anything
depending on it can be eliminated.
To shut up the clang warning, just remove the dead code manually,
it has probably never been used because any attempt to do so
would have resulted in undefined behavior.
Fixes: 63e3ab142fa3 ("V4L/DVB: V4L - vpfe capture - source for ISIF driver on DM365")
Reviewed-by: Nathan Chancellor <natechancellor@gmail.com>
[ Upstream commit a3d7f22ef34ec4206b50ee121384d5c8bebd5591 ]
Checking of kmalloc() seems to have been committed - as
cx23885_dvb_register() is checking for != 0 return, returning
-ENOMEM should be fine here. While at it address the coccicheck
suggestion to move to kmemdup rather than using kmalloc+memcpy.
Fixes: 46b21bbaa8a8 ("[media] Add support for DViCO FusionHDTV DVB-T Dual Express2")
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
[ Upstream commit ef4bb63dc1f7213c08e13f6943c69cd27f69e4a3 ]
We forgot to set "ret" on this error path.
Fixes: e8454ff7b9a4 ("[media] drivers:media:radio: wl128x: FM Driver Common sources")
[ Upstream commit 7afb0df554292dca7568446f619965fb8153085d ]
We should be updating *pos. The current code is a no-op.
Fixes: 1c1e45d17b66 ("V4L/DVB (7786): cx18: new driver for the Conexant CX23418 MPEG encoder chip")
[ Upstream commit f8e579f3ca0973daef263f513da5edff520a6c0d ]
We had intended to update *pos, but the current code is a no-op.
Fixes: 1a0adaf37c30 ("V4L/DVB (5345): ivtv driver for Conexant cx23416/cx23415 MPEG encoder/decoder")
[ Upstream commit 19c624c6b29e244c418f8b44a711cbf5e82e3cd4 ]
This commit corrects max and step values for v4l2 control for
V4L2_CID_JPEG_RESTART_INTERVAL. Max should be 0xffff and step should be 1.
It was found by using v4l2-compliance tool and checking result of
VIDIOC_QUERY_EXT_CTRL/QUERYMENU test.
Previously it was complaining that step was bigger than difference
between max and min.
Fixes: 15f4bc3b1f42 ("[media] s5p-jpeg: Add JPEG controls support")
Signed-off-by: Pawe? Chmiel <pawel.mikolaj.chmiel@gmail.com>
Reviewed-by: Jacek Anaszewski <jacek.anaszewski@gmail.com>
Reviewed-by: Sylwester Nawrocki <s.nawrocki@samsung.com>
commit 704c6c80fb471d1bb0ef0d61a94617d1d55743cd upstream.
>From isp_video_release(), &isp->video_lock is held and subsequent
vb2_fop_release() tries to lock vdev->lock which is same with the
previous one. Replace vb2_fop_release() with _vb2_fop_release() to
fix the recursive locking.
Fixes: 1380f5754cb0 ("[media] videobuf2: Add missing lock held on vb2_fop_release")
Signed-off-by: Seung-Woo Kim <sw0312.kim@samsung.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@kernel.org>
commit 5d2e73a5f80a5b5aff3caf1ec6d39b5b3f54b26e upstream.
SyzKaller hit the null pointer deref while reading from uninitialized
udev->product in zr364xx_vidioc_querycap().
BUG: KASAN: null-ptr-deref in read_word_at_a_time+0xe/0x20
include/linux/compiler.h:274
Read of size 1 at addr 0000000000000000 by task v4l_id/5287
CPU: 1 PID: 5287 Comm: v4l_id Not tainted 5.1.0-rc3-319004-g43151d6 #6
Hardware name: Google Google Compute Engine/Google Compute Engine, BIOS
Google 01/01/2011
Call Trace:
__dump_stack lib/dump_stack.c:77 [inline]
dump_stack+0xe8/0x16e lib/dump_stack.c:113
kasan_report.cold+0x5/0x3c mm/kasan/report.c:321
read_word_at_a_time+0xe/0x20 include/linux/compiler.h:274
strscpy+0x8a/0x280 lib/string.c:207
zr364xx_vidioc_querycap+0xb5/0x210 drivers/media/usb/zr364xx/zr364xx.c:706
v4l_querycap+0x12b/0x340 drivers/media/v4l2-core/v4l2-ioctl.c:1062
__video_do_ioctl+0x5bb/0xb40 drivers/media/v4l2-core/v4l2-ioctl.c:2874
video_usercopy+0x44e/0xf00 drivers/media/v4l2-core/v4l2-ioctl.c:3056
v4l2_ioctl+0x14e/0x1a0 drivers/media/v4l2-core/v4l2-dev.c:364
vfs_ioctl fs/ioctl.c:46 [inline]
file_ioctl fs/ioctl.c:509 [inline]
do_vfs_ioctl+0xced/0x12f0 fs/ioctl.c:696
ksys_ioctl+0xa0/0xc0 fs/ioctl.c:713
__do_sys_ioctl fs/ioctl.c:720 [inline]
__se_sys_ioctl fs/ioctl.c:718 [inline]
__x64_sys_ioctl+0x74/0xb0 fs/ioctl.c:718
do_syscall_64+0xcf/0x4f0 arch/x86/entry/common.c:290
entry_SYSCALL_64_after_hwframe+0x49/0xbe
RIP: 0033:0x7f3b56d8b347
Code: 90 90 90 48 8b 05 f1 fa 2a 00 64 c7 00 26 00 00 00 48 c7 c0 ff ff ff
ff c3 90 90 90 90 90 90 90 90 90 90 b8 10 00 00 00 0f 05 <48> 3d 01 f0 ff
ff 73 01 c3 48 8b 0d c1 fa 2a 00 31 d2 48 29 c2 64
RSP: 002b:00007ffe005d5d68 EFLAGS: 00000202 ORIG_RAX: 0000000000000010
RAX: ffffffffffffffda RBX: 0000000000000003 RCX: 00007f3b56d8b347
RDX: 00007ffe005d5d70 RSI: 0000000080685600 RDI: 0000000000000003
RBP: 0000000000000000 R08: 0000000000000000 R09: 0000000000000000
R10: 0000000000000000 R11: 0000000000000202 R12: 0000000000400884
R13: 00007ffe005d5ec0 R14: 0000000000000000 R15: 0000000000000000
For this device udev->product is not initialized and accessing it causes a NULL pointer deref.
The fix is to check for NULL before strscpy() and copy empty string, if
product is NULL
Reported-by: syzbot+66010012fd4c531a1a96@syzkaller.appspotmail.com
Signed-off-by: Vandana BN <bnvandana@gmail.com>
[bwh: Backported to 4.9: This function uses strlcpy() instead of strscpy()]
Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk>
commit 2289adbfa559050d2a38bcd9caac1c18b800e928 upstream.
In af9005_identify_state when returning -EIO the allocated buffer should
be released. Replace the "return -EIO" with assignment into ret and move
deb_info() under a check.
Fixes: af4e067e1dcf ("V4L/DVB (5625): Add support for the AF9005 demodulator from Afatech")
Signed-off-by: Navid Emamdoost <navid.emamdoost@gmail.com>
commit 74a96b51a36de4d86660fbc56b05d86668162d6b upstream.
An earlier commit hard coded a return 0 to function flexcop_usb_i2c_req
even though the an -EIO was intended to be returned in the case where
ret != buflen. Fix this by replacing the return 0 with the return of
ret to return the error return code.
Fixes: b430eaba0be5 ("[media] flexcop-usb: don't use stack for DMA")
[ Upstream commit 2df200ab234a86836a8879a05a8007d6b884eb14 ]
The driver misses calling v4l2_ctrl_handler_free and
v4l2_device_unregister in remove like what is done in probe failure.
Add the calls to fix it.
Signed-off-by: Chuhong Yuan <hslester96@gmail.com>
[ Upstream commit 7f404ae9cf2a285f73b3c18ab9303d54b7a3d8e1 ]
In some device configurations there's no radio or radio support in the
driver. That's OK, as the driver sets itself up accordingly. However
on tear-down in these caes it's still trying to tear down radio
related context when there isn't anything there, leading to
dereferences through a null pointer and chaos follows.
How this bug survived unfixed for 11 years in the pvrusb2 driver is a
mystery to me.
[hverkuil: fix two checkpatch warnings]
Signed-off-by: Mike Isely <isely@pobox.com>
[ Upstream commit e20b248051ca0f90d84b4d9378e4780bc31f16c6 ]
v4l2-compliance fails with this message:
fail: v4l2-test-formats.cpp(672): \
Video Capture Multiplanar: TRY_FMT(G_FMT) != G_FMT
Video Output Multiplanar: TRY_FMT(G_FMT) != G_FMT
test VIDIOC_TRY_FMT: FAIL
The default pixel format was setup as pointing to a specific offset in
the vpe_formats table assuming it was pointing to the V4L2_PIX_FMT_YUYV
entry. This became false after the addition on the NV21 format (see
above commid-id)
So instead of hard-coding an offset which might change over time we need
to use a lookup helper instead so we know the default will always be what
we intended.
Fixes: 40cc823f7005 ("media: ti-vpe: Add support for NV21 format")
Reviewed-by: Tomi Valkeinen <tomi.valkeinen@ti.com>
[ Upstream commit 2444846c0dbfa4ead21b621e4300ec32c90fbf38 ]
fail: v4l2-test-buffers.cpp(294): \
(int)g_sequence() < seq.last_seq + 1
fail: v4l2-test-buffers.cpp(740): \
buf.check(m2m_q, last_m2m_seq)
fail: v4l2-test-buffers.cpp(974): \
captureBufs(node, q, m2m_q, frame_count, true)
test MMAP: FAIL
The driver is failing to update the source frame sequence number in the
vb2 buffer object. Only the destination frame sequence was being
updated.
This is only a reporting issue if the user space app actually cares
about the frame sequence number. But it is fixed nonetheless.
[ Upstream commit 06bec72b250b2cb3ba96fa45c2b8e0fb83745517 ]
v4l2-compliance warns with this message:
warn: v4l2-test-formats.cpp(717): \
TRY_FMT cannot handle an invalid pixelformat.
warn: v4l2-test-formats.cpp(718): \
This may or may not be a problem. For more information see:
warn: v4l2-test-formats.cpp(719): \
http://www.mail-archive.com/linux-media@vger.kernel.org/msg56550.html
We need to make sure that the returns a valid pixel format in all
instance. Based on the v4l2 framework convention drivers must return a
valid pixel format when the requested pixel format is either invalid or
not supported.
[ Upstream commit 649cd16c438f51d4cd777e71ca1f47f6e0c5e65d ]
If usb_set_interface() failed, iface->cur_altsetting will
not be assigned and it will be used in flexcop_usb_transfer_init()
It may lead a NULL pointer dereference.
Check usb_set_interface() return value in flexcop_usb_init()
and return failed to avoid using this NULL pointer.
Signed-off-by: Yang Yingliang <yangyingliang@huawei.com>
[ Upstream commit 3143b459de4cdcce67b36827476c966e93c1cf01 ]
The driver stores frame format settings supposed to be in line with
hardware state in a device private structure. Since the driver initial
submission, those settings are updated before they are actually applied
on hardware. If an error occurs on device update, the stored settings
my not reflect hardware state anymore and consecutive calls to
.get_fmt() may return incorrect information. That in turn may affect
ability of a bridge device to use correct DMA transfer settings if such
incorrect informmation on active frame format returned by .get_fmt() is
used.
Assuming a failed device update means its state hasn't changed, update
frame format related settings stored in the device private structure
only after they are successfully applied so the stored values always
reflect hardware state as closely as possible.
[ Upstream commit 9d669fbfca20e6035ead814e55d9ef1a6b500540 ]
The initial registers sequence is only loaded at probe
time. Afterward only the resolution and format specific
register are modified. Care must be taken to make sure
registers modified by one resolution setting are reverted
back when another resolution is programmed.
This was not done properly for the 720p case.
[ Upstream commit 85c4043f1d403c222d481dfc91846227d66663fb ]
In ov2659_s_stream() return value for invoked function should be checked
and propagated.
[ Upstream commit 13aa21cfe92ce9ebb51824029d89f19c33f81419 ]
VIDIOC_S_STD should not return an error if the value is identical
to the current one.
This error was highlighted by the v4l2-compliance test.
Acked-by: Lad Prabhakar <prabhakar.csengg@gmail.com>
commit 1091eb830627625dcf79958d99353c2391f41708 upstream.
If a process is interrupted while accessing the radio device and the
core lock is contended, release() could return early and fail to update
the interrupt mask.
Note that the return value of the v4l2 release file operation is
ignored.
Fixes: 87d1a50ce451 ("[media] V4L2: WL1273 FM Radio: TI WL1273 FM radio driver")
Cc: stable <stable@vger.kernel.org> # 2.6.38
Cc: Matti Aaltonen <matti.j.aaltonen@nokia.com>
commit 11609a7e21f8cea42630350aa57662928fa4dc63 upstream.
If a process is interrupted while accessing the video device and the
device lock is contended, release() could return early and fail to free
related resources.
ignored.
Fixes: 28ffeebbb7bd ("[media] bdisp: 2D blitter driver using v4l2 mem2mem framework")
Cc: stable <stable@vger.kernel.org> # 4.2
[ Upstream commit 3c28b91380dd1183347d32d87d820818031ebecf ]
usb_control_msg returns in case of a successfully sent message the number
of sent bytes as a positive number. Don't use this value as a return value
for stk_camera_read_reg, as a non-zero return value is used as an error
condition in some cases when stk_camera_read_reg is called.
Signed-off-by: Andreas Pape <ap@ca-pape.de>
Reviewed-by: Kieran Bingham <kieran.bingham@ideasonboard.com>
commit 1e4e25c4959c10728fbfcc6a286f9503d32dfe02 upstream.
The subsystem will free the asd memory on notifier cleanup, if the asd is
added to the notifier.
However the memory is freed using kfree.
Thus, we cannot allocate the asd using devm_*
This can lead to crashes and problems.
To test this issue, just return an error at probe, but cleanup the
notifier beforehand.
Fixes: 106267444f ("[media] atmel-isc: add the Image Sensor Controller code")
commit a0816e5088baab82aa738d61a55513114a673c8e upstream.
Control DO_WHITE_BALANCE is a button, with read only and execute-on-write flags.
Adding this control in the proper list in the fill function.
After adding it here, we can see output of v4l2-ctl -L
do_white_balance 0x0098090d (button) : flags=write-only, execute-on-write
