path: root/drivers/media
2014-02-04[media] adv7842: Composite free-run platfrom-data fixMartin Bugge
Incorrectly setting of free-run for Composite. Copy/paste regression fix. Signed-off-by: Martin Bugge <marbugge@cisco.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] v4l2-dv-timings: fix GTF calculationMartin Bugge
Round off image width to nearest 8 (GTF_CELL_GRAN) A source sending a GTF (Generalized Timing Formula) format have no means of signalling image width. The assumed aspect ratio may result in an odd image width but according to the standard image width should be in multiple of 8. Cc: Mats Randgaard <matrandg@cisco.com> Signed-off-by: Martin Bugge <marbugge@cisco.com> Reviewed-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] hdpvr: Fix memory leak in debugMasanari Iida
cppcheck reported memory leak in device_authorizatio() within hdpvr-core.c. When the debug option is specified and the code jump to "unlock:" label, print_buf was not freed. Confirm the module succesfully compiled without error. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] af9035: add ID [2040:f900] Hauppauge WinTV-MiniStick 2Antti Palosaari
Add USB ID [2040:f900] for Hauppauge WinTV-MiniStick 2. Device is build upon IT9135 chipset. Tested-by: Stefan Becker <schtefan@gmx.net> Signed-off-by: Antti Palosaari <crope@iki.fi> Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] mxl111sf: Fix compile when CONFIG_DVB_USB_MXL111SF is unsetDave Jones
Fix the following build error: drivers/media/usb/dvb-usb-v2/ mxl111sf-tuner.h:72:9: error: expected ‘;’, ‘,’ or ‘)’ before ‘struct’ struct mxl111sf_tuner_config *cfg) Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] mxl111sf: Fix unintentional garbage stack readDave Jones
mxl111sf_read_reg takes an address of a variable to write to as an argument. drivers/media/usb/dvb-usb-v2/mxl111sf-gpio.c:mxl111sf_config_pin_mux_modes passes several uninitialized stack variables to this routine, expecting them to be filled in. In the event that something unexpected happens when reading from the chip, we end up doing a pr_debug of the value passed in, revealing whatever garbage happened to be on the stack. Change the pr_debug to match what happens in the 'success' case, where we assign buf[1] to *data. Spotted with Coverity (Bugs 731910 through 731917) Signed-off-by: Dave Jones <davej@fedoraproject.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Cc: stable@vger.kernel.org Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] cx24117: use a valid dev pointer for dev_err printoutAndi Shyti
Don't use '&state->priv->i2c->dev' reference to device because state is still 'NULL'. Use '&i2c->dev' instead. This bug has been reported by scan.coverity.com Signed-off-by: Andi Shyti <andi@etezian.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Cc: vger@stable.kernel.org Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] cx24117: remove dead code in always 'false' if statementAndi Shyti
At this point of the execution in the function cx24117_attach() demod cannot be '0'. In that case the function returns earlier with an error value ('NULL'). Remove the if statement. This error has been reported by scan.coverity.com Signed-off-by: Andi Shyti <andi@etezian.org> Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] update Michael Krufky's email addressMichael Krufky
I am no longer available at the kernellabs.com or m1k.net email addresses. Update each instance of my email to my linuxtv.org account. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] vb2: Check if there are buffers before streamonRicardo Ribalda
This patch adds a test preventing streamon() if there is no buffer ready. Without this patch, a user could call streamon() before preparing any buffer. This leads to a situation where if he calls close() before calling streamoff() the device is kept streaming. Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Reviewed-by: Marek Szyprowski <m.szyprowski@samsung.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] Revert "[media] videobuf_vm_{open,close} race fixes"Hans Verkuil
This reverts commit a242f426108c284049a69710f871cc9f11b13e61. That commit actually caused deadlocks, rather then fixing them. If ext_lock is set to NULL (otherwise videobuf_queue_lock doesn't do anything), then you get this deadlock: The driver's mmap function calls videobuf_mmap_mapper which calls videobuf_queue_lock on q. videobuf_mmap_mapper calls __videobuf_mmap_mapper, __videobuf_mmap_mapper calls videobuf_vm_open and videobuf_vm_open calls videobuf_queue_lock on q (introduced by above patch): deadlocked. This affects drivers using dma-contig and dma-vmalloc. Only dma-sg is not affected since it doesn't call videobuf_vm_open from __videobuf_mmap_mapper. Most drivers these days have a non-NULL ext_lock. Those that still use NULL there are all fairly obscure drivers, which is why this hasn't been seen earlier. Since everything worked perfectly fine for many years I prefer to just revert this patch rather than trying to fix it. videobuf is quite fragile and I rather not touch it too much. Work is (slowly) progressing to move everything over to vb2 or at the very least use non-NULL ext_lock in videobuf. Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Cc: <stable@vger.kernel.org> # for v3.11 and up Cc: Al Viro <viro@ZenIV.linux.org.uk> Reported-by: Pete Eberlein <pete@sensoray.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] media: bt8xx: add missing put_device callLevente Kurusa
This is required so that we give up the last reference to the device. Remove the kfree() because the put_device() call will actually call release_sub_device which in turn kfrees the device. Signed-off-by: Levente Kurusa <levex@linux.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] exynos4-is: Compile in fimc-lite runtime PM callbacks conditionallySylwester Nawrocki
Enclose the runtime PM helpers in #ifdef CONFIG_PM_RUNTIME/#endif to avoid following compile warning when CONFIG_PM_RUNTIME is disabled: CC drivers/media/platform/exynos4-is/fimc-lite.o drivers/media/platform/exynos4-is/fimc-lite.c:1591:12: warning: ‘fimc_lite_runtime_resume’ defined but not used [-Wunused-function] drivers/media/platform/exynos4-is/fimc-lite.c:1599:12: warning: ‘fimc_lite_runtime_suspend’ defined but not used [-Wunused-function] Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] exynos4-is: Compile in fimc runtime PM callbacks conditionallySylwester Nawrocki
Enclose the runtime PM helpers in #ifdef CONFIG_PM_RUNTIME/#endif to avoid following compile warning when CONFIG_PM_RUNTIME is disabled: CC drivers/media/platform/exynos4-is/fimc-core.o drivers/media/platform/exynos4-is/fimc-core.c:1040:12: warning: ‘fimc_runtime_resume’ defined but not used drivers/media/platform/exynos4-is/fimc-core.c:1057:12: warning: ‘fimc_runtime_suspend’ defined but not used Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Reviewed-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] exynos4-is: Fix error paths in probe() for !pm_runtime_enabled()Sylwester Nawrocki
Ensure clk_disable() is called on error paths only when clk_enable() was previously called. This fixes following build warning: .../media-git/drivers/media/platform/exynos4-is/fimc-lite.c: In function 'fimc_lite_probe': .../media-git/drivers/media/platform/exynos4-is/fimc-lite.c:1583:1: warning: label 'err_sd' defined but not used [-Wunused-label] Reported-by: Hans Verkuil <hansverk@cisco.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] s5p-jpeg: Fix wrong NV12 format parametersJacek Anaszewski
NV12 format entries in the sjpeg_formats array had wrong colplanes, depth and v_align values. Signed-off-by: Jacek Anaszewski <j.anaszewski@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-02-04[media] s5k5baf: allow to handle arbitrary long i2c sequencesAndrzej Hajda
Using variable length array in s5k5baf_write_arr_seq caused an implicit assumption that i2c sequences should be short. The patch rewrites the function so it can handle sequences of any length and does not use variable length array. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrzej Hajda <a.hajda@samsung.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-31Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media Pull media updates from Mauro Carvalho Chehab: - a new jpeg codec driver for Samsung Exynos (jpeg-hw-exynos4) - a new dvb frontend for ds2103 chipset (m88ds2103) - a new sensor driver for Samsung S5K5BAF UXGA (s5k5baf) - new drivers for R-Car VSP1 - a new radio driver: radio-raremono - a new tuner driver for ts2022 chipset (m88ts2022) - the analog part of em28xx is now a separate module that only load/runs if the device is not a pure digital TV device - added a staging driver for bcm2048 radio devices - the omap 2 video driver (omap24xx) was moved to staging. This driver is for an old hardware and uses a deprecated Kernel internal API. If nobody cares enough to fix it, it would be removed on a couple Kernel releases - the sn9c102 driver was moved to staging. This driver was replaced by gspca, and disabled on some distros, as almost all devices are known to work properly with gspca. It should be removed from kernel on a couple Kernel releases - lots of driver fixes, improvements and cleanups * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-media: (421 commits) [media] media: v4l2-dev: fix video device index assignment [media] rc-core: reuse device numbers [media] em28xx-cards: properly initialize the device bitmap [media] Staging: media: Fix line length exceeding 80 characters in as102_drv.c [media] Staging: media: Fix line length exceeding 80 characters in as102_fe.c [media] Staging: media: Fix quoted string split across line in as102_fe.c [media] media: st-rc: Add reset support [media] m2m-deinterlace: fix allocated struct type [media] radio-usb-si4713: fix sparse non static symbol warnings [media] em28xx-audio: remove needless check before usb_free_coherent() [media] au0828: Fix sparse non static symbol warning Revert "[media] go7007-usb: only use go->dev after allocated" [media] em28xx-audio: provide an error code when URB submit fails [media] em28xx: fix check for audio only usb interfaces when changing the usb alternate setting [media] em28xx: fix usb alternate setting for analog and digital video endpoints > 0 [media] em28xx: make 'em28xx_ctrl_ops' static em28xx-alsa: Fix error patch for init/fini [media] em28xx-audio: flush work at .fini [media] drxk: remove the option to load firmware asynchronously [media] em28xx: adjust period size at runtime ...
2014-01-29Merge remote-tracking branch 'agust/next' into nextBenjamin Herrenschmidt
<< Switch mpc512x to the common clock framework and adapt mpc512x drivers to use the new clock driver. Old PPC_CLOCK code is removed entirely since there are no users any more. >>
2014-01-27[media] media: v4l2-dev: fix video device index assignmentMarek Szyprowski
The side effect of commit 1056e4388b045 ("v4l2-dev: Fix race condition on __video_register_device") is the increased number of index value assigned on video_device registration. Before that commit video_devices were numbered from 0, after it, the indexes starts from 1, because get_index() always count the device, which is being registered. Some device drivers rely on video_device index number for internal purposes, i.e. s5p-mfc driver stopped working after that patch. This patch restores the old method of numbering the video_device indexes. Cc: stable@vger.kernel.org # for v3.12 Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Acked-by: Ricardo Ribalda <ricardo.ribalda@gmail.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-25Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking updates from David Miller: 1) BPF debugger and asm tool by Daniel Borkmann. 2) Speed up create/bind in AF_PACKET, also from Daniel Borkmann. 3) Correct reciprocal_divide and update users, from Hannes Frederic Sowa and Daniel Borkmann. 4) Currently we only have a "set" operation for the hw timestamp socket ioctl, add a "get" operation to match. From Ben Hutchings. 5) Add better trace events for debugging driver datapath problems, also from Ben Hutchings. 6) Implement auto corking in TCP, from Eric Dumazet. Basically, if we have a small send and a previous packet is already in the qdisc or device queue, defer until TX completion or we get more data. 7) Allow userspace to manage ipv6 temporary addresses, from Jiri Pirko. 8) Add a qdisc bypass option for AF_PACKET sockets, from Daniel Borkmann. 9) Share IP header compression code between Bluetooth and IEEE802154 layers, from Jukka Rissanen. 10) Fix ipv6 router reachability probing, from Jiri Benc. 11) Allow packets to be captured on macvtap devices, from Vlad Yasevich. 12) Support tunneling in GRO layer, from Jerry Chu. 13) Allow bonding to be configured fully using netlink, from Scott Feldman. 14) Allow AF_PACKET users to obtain the VLAN TPID, just like they can already get the TCI. From Atzm Watanabe. 15) New "Heavy Hitter" qdisc, from Terry Lam. 16) Significantly improve the IPSEC support in pktgen, from Fan Du. 17) Allow ipv4 tunnels to cache routes, just like sockets. From Tom Herbert. 18) Add Proportional Integral Enhanced packet scheduler, from Vijay Subramanian. 19) Allow openvswitch to mmap'd netlink, from Thomas Graf. 20) Key TCP metrics blobs also by source address, not just destination address. From Christoph Paasch. 21) Support 10G in generic phylib. From Andy Fleming. 22) Try to short-circuit GRO flow compares using device provided RX hash, if provided. From Tom Herbert. The wireless and netfilter folks have been busy little bees too. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (2064 commits) net/cxgb4: Fix referencing freed adapter ipv6: reallocate addrconf router for ipv6 address when lo device up fib_frontend: fix possible NULL pointer dereference rtnetlink: remove IFLA_BOND_SLAVE definition rtnetlink: remove check for fill_slave_info in rtnl_have_link_slave_info qlcnic: update version to 5.3.55 qlcnic: Enhance logic to calculate msix vectors. qlcnic: Refactor interrupt coalescing code for all adapters. qlcnic: Update poll controller code path qlcnic: Interrupt code cleanup qlcnic: Enhance Tx timeout debugging. qlcnic: Use bool for rx_mac_learn. bonding: fix u64 division rtnetlink: add missing IFLA_BOND_AD_INFO_UNSPEC sfc: Use the correct maximum TX DMA ring size for SFC9100 Add Shradha Shah as the sfc driver maintainer. net/vxlan: Share RX skb de-marking and checksum checks with ovs tulip: cleanup by using ARRAY_SIZE() ip_tunnel: clear IPCB in ip_tunnel_xmit() in case dst_link_failure() is called net/cxgb4: Don't retrieve stats during recovery ...
2014-01-23Merge tag 'clk-for-linus-3.14-part1' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clk framework changes from Mike Turquette: "The first half of the clk framework pull request is made up almost entirely of new platform/driver support. There are some conversions of existing drivers to the common-clock Device Tree binding, and a few non-critical fixes to the framework. Due to an entirely unnecessary cyclical dependency with the arm-soc tree this pull request is broken into two pieces. The second piece will be sent out after arm-soc sends you the pull request that merged in core support for the HiSilicon 3620 platform. That same pull request from arm-soc depends on this pull request to merge in those HiSilicon bits without causing build failures" [ Just did the ARM SoC merges, so getting ready for the second clk tree pull request - Linus ] * tag 'clk-for-linus-3.14-part1' of git://git.linaro.org/people/mike.turquette/linux: (97 commits) devicetree: bindings: Document qcom,mmcc devicetree: bindings: Document qcom,gcc clk: qcom: Add support for MSM8660's global clock controller (GCC) clk: qcom: Add support for MSM8974's multimedia clock controller (MMCC) clk: qcom: Add support for MSM8974's global clock controller (GCC) clk: qcom: Add support for MSM8960's multimedia clock controller (MMCC) clk: qcom: Add support for MSM8960's global clock controller (GCC) clk: qcom: Add reset controller support clk: qcom: Add support for branches/gate clocks clk: qcom: Add support for root clock generators (RCGs) clk: qcom: Add support for phase locked loops (PLLs) clk: qcom: Add a regmap type clock struct clk: Add set_rate_and_parent() op reset: Silence warning in reset-controller.h clk: sirf: re-arch to make the codes support both prima2 and atlas6 clk: composite: pass mux_hw into determine_rate clk: shmobile: Fix MSTP clock array initialization clk: shmobile: Fix MSTP clock index ARM: dts: Add clock provider specific properties to max77686 node clk: max77686: Register OF clock provider ...
2014-01-15[media] rc-core: reuse device numbersMauro Carvalho Chehab
Before changeset d8b4b5822f51e, the remote controller device numbers were released when the device were unregistered. That helped to maintain some sanity, as, when USB devices are replugged, the remote controller would get the same number. Restore the same behaviour. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-15[media] em28xx-cards: properly initialize the device bitmapMauro Carvalho Chehab
Instead of just creating a long int, use DECLARE_BITMAP(). No functional changes. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-15[media] media: st-rc: Add reset supportSrinivas Kandagatla
Some of the SOCs hold the IRB IP in softreset state by default. For this IP to work driver needs to bring it out of softreset. This patch adds support to reset the IP via reset framework. Without this patch the driver can not work with SoCs which holds the IP in softreset. Signed-off-by: Srinivas Kandagatla <srinivas.kandagatla@st.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-15[media] m2m-deinterlace: fix allocated struct typeJassi Brar
'xt' points to a dma_interleaved_template and not a dma_async_tx_descriptor. Signed-off-by: Jassi Brar <jaswinder.singh@linaro.org> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-15[media] radio-usb-si4713: fix sparse non static symbol warningsWei Yongjun
Fixes the following sparse warnings: drivers/media/radio/si4713/radio-usb-si4713.c:226:31: warning: symbol 'start_seq' was not declared. Should it be static? drivers/media/radio/si4713/radio-usb-si4713.c:291:29: warning: symbol 'command_table' was not declared. Should it be static? Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-15[media] em28xx-audio: remove needless check before usb_free_coherent()Wei Yongjun
usb_free_coherent() is safe with NULL addr and this check is not required. Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-15[media] au0828: Fix sparse non static symbol warningWei Yongjun
Fixes the following sparse warning: drivers/media/usb/au0828/au0828-dvb.c:36:5: warning: symbol 'preallocate_big_buffers' was not declared. Should it be static? Signed-off-by: Wei Yongjun <yongjun_wei@trendmicro.com.cn> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx-audio: provide an error code when URB submit failsMauro Carvalho Chehab
Instead of just saying: [ 1646.412419] em2882/3 #0: submit of audio urb failed Print the reason why it failed, to help debugging and fixing it. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx: fix check for audio only usb interfaces when changing the ↵Frank Schaefer
usb alternate setting Previously, we've been assuming that the video endpoints are always at usb interface 0. Hence, if vendor audio endpoints are provided at a separate interface, they were supposed to be at interface number > 0. Instead of checking for (interface number > 0) to determine if an interface is a pure audio interface, dev->is_audio_only should be checked. Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx: fix usb alternate setting for analog and digital video ↵Frank Schaefer
endpoints > 0 The current code assumes that the analog + digital video endpoints are always at interface number 0 when changing the alternate setting. This seems to work fine for most existing devices. However, at least the SpeedLink VAD Laplace webcam has the video endpoint on interface number 3 (which fortunately doesn't cause any trouble because ist uses bulk transfers only). We already consider the actual interface number for audio endpoints, so rename the the audio_ifnum variable and use it for all device types. Also get get rid of a pointless (ifnum < 0) in em28xx-audio. Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx: make 'em28xx_ctrl_ops' staticFengguang Wu
sparse warnings: (new ones prefixed by >>) >> drivers/media/usb/em28xx/em28xx-video.c:1151:28: sparse: symbol 'em28xx_ctrl_ops' was not declared. Should it be static? Signed-off-by: Fengguang Wu <fengguang.wu@intel.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14em28xx-alsa: Fix error patch for init/finiMauro Carvalho Chehab
If something bad happens during init, we free the card data. However, we still keep it initialized, causing some dependent code to be called at .fini. Fix it. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx-audio: flush work at .finiMauro Carvalho Chehab
As a pending action might be still there at the work thread, flush it. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] drxk: remove the option to load firmware asynchronouslyMauro Carvalho Chehab
The option to load firmware asynchronously were added due to a requirement with a few versions of udev. It turns that this was a bad idea and caused regressions on drxk-based devices. So, we end by only letting the firmware to be loaded syncronously everywhere. So, let's remove the bad code. This patch partially reverts the changeset 8e30783b0b3. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx: adjust period size at runtimeMauro Carvalho Chehab
While the current hardcoded period is ok for the current values, we may latter change the driver to work with different bit rates or with different latencies than 64ms. So, adust the period size at runtime. Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx: push mutex down to extensions on .fini callbackMauro Carvalho Chehab
Avoid circular mutex lock by pushing the dev->lock to the .fini callback on each extension. As em28xx-dvb, em28xx-alsa and em28xx-rc have their own data structures, and don't touch at the common structure during .fini, only em28xx-v4l needs to be locked. [ 90.994317] ====================================================== [ 90.994356] [ INFO: possible circular locking dependency detected ] [ 90.994395] 3.13.0-rc1+ #24 Not tainted [ 90.994427] ------------------------------------------------------- [ 90.994458] khubd/54 is trying to acquire lock: [ 90.994490] (&card->controls_rwsem){++++.+}, at: [<ffffffffa0177b08>] snd_ctl_dev_free+0x28/0x60 [snd] [ 90.994656] [ 90.994656] but task is already holding lock: [ 90.994688] (&dev->lock){+.+.+.}, at: [<ffffffffa040db81>] em28xx_close_extension+0x31/0x90 [em28xx] [ 90.994843] [ 90.994843] which lock already depends on the new lock. [ 90.994843] [ 90.994874] [ 90.994874] the existing dependency chain (in reverse order) is: [ 90.994905] -> #1 (&dev->lock){+.+.+.}: [ 90.995057] [<ffffffff810b8fa3>] __lock_acquire+0xb43/0x1330 [ 90.995121] [<ffffffff810b9f82>] lock_acquire+0xa2/0x120 [ 90.995182] [<ffffffff816a5b6c>] mutex_lock_nested+0x5c/0x3c0 [ 90.995245] [<ffffffffa0422cca>] em28xx_vol_put_mute+0x1ba/0x1d0 [em28xx_alsa] [ 90.995309] [<ffffffffa017813d>] snd_ctl_elem_write+0xfd/0x140 [snd] [ 90.995376] [<ffffffffa01791c2>] snd_ctl_ioctl+0xe2/0x810 [snd] [ 90.995442] [<ffffffff811db8b0>] do_vfs_ioctl+0x300/0x520 [ 90.995504] [<ffffffff811dbb51>] SyS_ioctl+0x81/0xa0 [ 90.995568] [<ffffffff816b1929>] system_call_fastpath+0x16/0x1b [ 90.995630] -> #0 (&card->controls_rwsem){++++.+}: [ 90.995780] [<ffffffff810b7a47>] check_prevs_add+0x947/0x950 [ 90.995841] [<ffffffff810b8fa3>] __lock_acquire+0xb43/0x1330 [ 90.995901] [<ffffffff810b9f82>] lock_acquire+0xa2/0x120 [ 90.995962] [<ffffffff816a762b>] down_write+0x3b/0xa0 [ 90.996022] [<ffffffffa0177b08>] snd_ctl_dev_free+0x28/0x60 [snd] [ 90.996088] [<ffffffffa017a255>] snd_device_free+0x65/0x140 [snd] [ 90.996154] [<ffffffffa017a751>] snd_device_free_all+0x61/0xa0 [snd] [ 90.996219] [<ffffffffa0173af4>] snd_card_do_free+0x14/0x130 [snd] [ 90.996283] [<ffffffffa0173f14>] snd_card_free+0x84/0x90 [snd] [ 90.996349] [<ffffffffa0423397>] em28xx_audio_fini+0x97/0xb0 [em28xx_alsa] [ 90.996411] [<ffffffffa040dba6>] em28xx_close_extension+0x56/0x90 [em28xx] [ 90.996475] [<ffffffffa040f639>] em28xx_usb_disconnect+0x79/0x90 [em28xx] [ 90.996539] [<ffffffff814a06e7>] usb_unbind_interface+0x67/0x1d0 [ 90.996620] [<ffffffff8142920f>] __device_release_driver+0x7f/0xf0 [ 90.996682] [<ffffffff814292a5>] device_release_driver+0x25/0x40 [ 90.996742] [<ffffffff81428b0c>] bus_remove_device+0x11c/0x1a0 [ 90.996801] [<ffffffff81425536>] device_del+0x136/0x1d0 [ 90.996863] [<ffffffff8149e0c0>] usb_disable_device+0xb0/0x290 [ 90.996923] [<ffffffff814930c5>] usb_disconnect+0xb5/0x1d0 [ 90.996984] [<ffffffff81495ab6>] hub_port_connect_change+0xd6/0xad0 [ 90.997044] [<ffffffff814967c3>] hub_events+0x313/0x9b0 [ 90.997105] [<ffffffff81496e95>] hub_thread+0x35/0x170 [ 90.997165] [<ffffffff8108ea2f>] kthread+0xff/0x120 [ 90.997226] [<ffffffff816b187c>] ret_from_fork+0x7c/0xb0 [ 90.997287] [ 90.997287] other info that might help us debug this: [ 90.997287] [ 90.997318] Possible unsafe locking scenario: [ 90.997318] [ 90.997348] CPU0 CPU1 [ 90.997378] ---- ---- [ 90.997408] lock(&dev->lock); [ 90.997497] lock(&card->controls_rwsem); [ 90.997607] lock(&dev->lock); [ 90.997697] lock(&card->controls_rwsem); [ 90.997786] [ 90.997786] *** DEADLOCK *** [ 90.997786] [ 90.997817] 5 locks held by khubd/54: [ 90.997847] #0: (&__lockdep_no_validate__){......}, at: [<ffffffff81496564>] hub_events+0xb4/0x9b0 [ 90.998025] #1: (&__lockdep_no_validate__){......}, at: [<ffffffff81493076>] usb_disconnect+0x66/0x1d0 [ 90.998204] #2: (&__lockdep_no_validate__){......}, at: [<ffffffff8142929d>] device_release_driver+0x1d/0x40 [ 90.998383] #3: (em28xx_devlist_mutex){+.+.+.}, at: [<ffffffffa040db77>] em28xx_close_extension+0x27/0x90 [em28xx] [ 90.998567] #4: (&dev->lock){+.+.+.}, at: [<ffffffffa040db81>] em28xx_close_extension+0x31/0x90 [em28xx] Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Tested-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx: Fix usb diconnect logicMauro Carvalho Chehab
Now that everything is extension, the usb disconnect logic should be the same. While here, fix the device name. Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Tested-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx: print a message at disconnectMauro Carvalho Chehab
That helps to identify if something fails and explain why em28xx struct is not freed (if it ever happens). Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Tested-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx-audio: disconnect before freeing URBsMauro Carvalho Chehab
URBs might be in usage. Disconnect the device before freeing them. Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Tested-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx-audio: simplify error handlingMauro Carvalho Chehab
Cleanup the error handling code at em28xx-audio init. Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Tested-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx-audio: fix return code on device disconnectMauro Carvalho Chehab
Alsa has an special non-negative return code to indicate device removal at snd_em28xx_capture_pointer(). Use it, instead of an error code. Reviewed-by: Frank Schäfer <fschaefer.oss@googlemail.com> Tested-by: Antti Palosaari <crope@iki.fi> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx-v4l: fix the freeing of the video devices memoryFrank Schaefer
Remove some dead code from em28xx_v4l2_fini() and fix the leaking of the video, vbi and radio video_device struct memories. Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx: always call em28xx_release_resources() in the usb disconnect ↵Frank Schaefer
handler When the usb device is disconnected, the resources are no longer available, so there is no reason to keep them registered. This will also fix the various sysfs group removal warnings which we can see since kernel 3.13. Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx-v4l: move v4l2_ctrl_handler freeing and v4l2_device ↵Frank Schaefer
unregistration to em28xx_v4l2_fini v4l2_ctrl_handler_free() and v4l2_device_unregister() are currently only called when the last user closes the device and the device is already disconnected. But that's wrong, we need to call these functions whenever the em28xx-v4l extension is closed and we can already do this if the device is still opened by some users. Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx: move v4l2 dummy clock deregistration from the core to the ↵Frank Schaefer
v4l extension Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx: move v4l2_device_disconnect() call from the core to the v4l ↵Frank Schaefer
2014-01-14[media] em28xx: move usb transfer uninit on device disconnect from the core ↵Frank Schaefer
to the v4l-extension Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
2014-01-14[media] em28xx: move usb buffer pre-allocation and transfer uninit from the ↵Frank Schaefer
core to the dvb extension Signed-off-by: Frank Schäfer <fschaefer.oss@googlemail.com> Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
