The EXTRA_CFLAGS assignment in memstick/Makefile was not accomplishing
anything because this flag only has effect on sources at the same level
as the makefile (i.e., per directory). Since both core/ and host/ rely
on MEMSTICK_DEBUG, the subdir-ccflags-y variant seems to be the
appropriate choice.
Signed-off-by: matt mooney <mfm@muteddisk.com>
Acked-by: WANG Cong <xiyou.wangcong@gmail.com>
There are two spellings in use for 'freeze' + 'able' - 'freezable' and
'freezeable'. The former is the more prominent one. The latter is
mostly used by workqueue and in a few other odd places. Unify the
spelling to 'freezable'.
Reported-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: "Rafael J. Wysocki" <rjw@sisk.pl>
Acked-by: Dmitry Torokhov <dtor@mail.ru>
Cc: Alex Dubov <oakad@yahoo.com>
Cc: Steven Whitehouse <swhiteho@redhat.com>
Apart from currently used standard memstick data transfer method, Sony
introduced several newer ones, to uncover full bandwidth/capacity of its
Pro, HG and XC media formats. This patch lays a foundation to enable
those methods as made possible by host/media capabilities.
As a side effect of this patch, mspro_block_read_attributes became more
streamlined and readable.
[akpm@linux-foundation.org: fix printk warning]
Signed-off-by: Alex Dubov <oakad@yahoo.com>
Reported-by: Maxim Levitsky <maximlevitsky@gmail.com>
mspro_block_mutex is identical in scope to mspro_block_disk_lock and therefore
unnecessary.
Implement the usual pattern around idr_pre_get() and idr_get_new() to
handlethe situation where another thread concurrently steals this thread's
idr_pre_get() preallocation.
If device_register() fails then call put_device(). See comment to
device_register.
Signed-off-by: Vasiliy Kulikov <segooon@gmail.com>
Cc: Maxim Levitsky <maximlevitsky@gmail.com>
The block device drivers have all gained new lock_kernel
calls from a recent pushdown, and some of the drivers
were already using the BKL before.
This turns the BKL into a set of per-driver mutexes.
Still need to check whether this is safe to do.
file=$1
name=$2
if grep -q lock_kernel ${file} ; then
if grep -q 'include.*linux.mutex.h' ${file} ; then
sed -i '/include.*<linux\/smp_lock.h>/d' ${file}
else
sed -i 's/include.*<linux\/smp_lock.h>.*$/include <linux\/mutex.h>/g' ${file}
fi
sed -i ${file} \
-e "/^#include.*linux.mutex.h/,$ {
1,/^\(static\|int\|long\)/ {
/^\(static\|int\|long\)/istatic DEFINE_MUTEX(${name}_mutex);
-e "s/\(un\)*lock_kernel\>[ ]*()/mutex_\1lock(\&${name}_mutex)/g" \
-e '/[ ]*cycle_kernel_lock();/d'
else
sed -i -e '/include.*\<smp_lock.h\>/d' ${file} \
-e '/cycle_kernel_lock()/d'
fi
mspro_block_remove() is called from detect thread that first calls the
mspro_block_stop(), which stops the request queue. If we call
del_gendisk() with the queue stopped we get a deadlock.
Signed-off-by: Maxim Levitsky <maximlevitsky@gmail.com>
Cc: <stable@kernel.org>
Otherwise lockdep complains.
The open and release block_device_operations are currently
called with the BKL held. In order to change that, we must
first make sure that all drivers that currently rely
on this have no regressions.
This blindly pushes the BKL into all .open and .release
operations for all block drivers to prepare for the
next step. The drivers can subsequently replace the BKL
with their own locks or remove it completely when it can
be shown that it is not needed.
The functions blkdev_get and blkdev_put are the only
remaining users of the big kernel lock in the block
layer, besides a few uses in the ioctl code, none
of which need to serialize with blkdev_{get,put}.
Most of these two functions is also under the protection
of bdev->bd_mutex, including the actual calls to
->open and ->release, and the common code does not
access any global data structures that need the BKL.
Acked-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in
struct requests. This allows much easier grepping for different request
types instead of unwinding through macros.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Except for SCSI no device drivers distinguish between physical and
hardware segment limits. Consolidate the two into a single segment
limit.
The block layer calling convention is blk_queue_<limit name>.
blk_queue_max_sectors predates this practice, leading to some confusion.
Rename the function to appropriately reflect that its intended use is to
set max_hw_sectors.
Also introduce a temporary wrapper for backwards compability. This can
be removed after the merge window is closed.
id_reg.if_mode might be unitialized when (*mrq)->error is nonzero. move
dev_dbg() inside the if so that we are sure we can use id_reg values.
Signed-off-by: Jiri Slaby <jirislaby@gmail.com>
Until now we have had a 1:1 mapping between storage device physical
block size and the logical block sized used when addressing the device.
With SATA 4KB drives coming out that will no longer be the case. The
sector size will be 4KB but the logical block size will remain
512-bytes. Hence we need to distinguish between the physical block size
and the logical ditto.
This patch renames hardsect_size to logical_block_size.
Till now block layer allowed two separate modes of request execution.
A request is always acquired from the request queue via
elv_next_request(). After that, drivers are free to either dequeue it
or process it without dequeueing. Dequeue allows elv_next_request()
to return the next request so that multiple requests can be in flight.
Executing requests without dequeueing has its merits mostly in
allowing drivers for simpler devices which can't do sg to deal with
segments only without considering request boundary. However, the
benefit this brings is dubious and declining while the cost of the API
ambiguity is increasing. Segment based drivers are usually for very
old or limited devices and as converting to dequeueing model isn't
difficult, it doesn't justify the API overhead it puts on block layer
and its more modern users.
Previous patches converted all block low level drivers to dequeueing
model. This patch completes the API transition by...
* renaming elv_next_request() to blk_peek_request()
* renaming blkdev_dequeue_request() to blk_start_request()
* adding blk_fetch_request() which is combination of peek and start
* disallowing completion of queued (not started) requests
* applying new API to all LLDs
Renamings are for consistency and to break out of tree code so that
it's apparent that out of tree drivers need updating.
[ Impact: block request issue API cleanup, no functional change ]
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Mike Miller <mike.miller@hp.com>
Cc: unsik Kim <donari75@gmail.com>
Cc: Paul Clements <paul.clements@steeleye.com>
Cc: Tim Waugh <tim@cyberelk.net>
Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Cc: Laurent Vivier <Laurent@lvivier.info>
Cc: Jeff Garzik <jgarzik@pobox.com>
Cc: Jeremy Fitzhardinge <jeremy@xensource.com>
Cc: Grant Likely <grant.likely@secretlab.ca>
Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk>
Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com>
Cc: Borislav Petkov <petkovbb@googlemail.com>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
Cc: Pierre Ossman <drzeus@drzeus.cx>
Cc: Markus Lidel <Markus.Lidel@shadowconnect.com>
Cc: Stefan Weinhuber <wein@de.ibm.com>
Cc: Pete Zaitcev <zaitcev@redhat.com>
Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
plat-omap/mailbox, floppy, viocd, mspro_block, i2o_block and
mmc/card/queue are already pretty close to dequeueing model and can be
converted with simple changes. Convert them.
While at it,
* xen-blkfront: !fs check moved downwards to share dequeue call with
normal path.
* mspro_block: __blk_end_request(..., blk_rq_cur_byte()) converted to
__blk_end_request_cur()
* mmc/card/queue: loop of __blk_end_request() converted to
__blk_end_request_all()
[ Impact: dequeue in-flight request ]
With the previous changes, the followings are now guaranteed for all
requests in any valid state.
* blk_rq_sectors() == blk_rq_bytes() >> 9
* blk_rq_cur_sectors() == blk_rq_cur_bytes() >> 9
Clean up accessor usages. Notable changes are
* nbd,i2o_block: end_all used instead of explicit byte count
* scsi_lib: unnecessary conditional on request type removed
[ Impact: cleanup ]
Cc: Boaz Harrosh <bharrosh@panasas.com>
With recent cleanups, there is no place where low level driver
directly manipulates request fields. This means that the 'hard'
request fields always equal the !hard fields. Convert all
rq->sectors, nr_sectors and current_nr_sectors references to
accessors.
While at it, drop superflous blk_rq_pos() < 0 test in swim.c.
[ Impact: use pos and nr_sectors accessors ]
Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Tested-by: Grant Likely <grant.likely@secretlab.ca>
Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk>
Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk>
Acked-by: Mike Miller <mike.miller@hp.com>
Cc: Eric Moore <Eric.Moore@lsi.com>
Cc: Alan Stern <stern@rowland.harvard.edu>
Cc: Dario Ballabio <ballabio_dario@emc.com>
There are many [__]blk_end_request() call sites which call it with
full request length and expect full completion. Many of them ensure
that the request actually completes by doing BUG_ON() the return
value, which is awkward and error-prone.
This patch adds [__]blk_end_request_all() which takes @rq and @error
and fully completes the request. BUG_ON() is added to to ensure that
this actually happens.
Most conversions are simple but there are a few noteworthy ones.
* cdrom/viocd: viocd_end_request() replaced with direct calls to
__blk_end_request_all().
* s390/block/dasd: dasd_end_request() replaced with direct calls to
* s390/char/tape_block: tapeblock_end_request() replaced with direct
calls to blk_end_request_all().
[ Impact: cleanup ]
The code was shifting the endianness appropriately everywhere, annotate
the structs to avoid the sparse warnings when assigning the endian types
to the struct members, or passing them to be[16|32]_to_cpu:
drivers/memstick/core/mspro_block.c:331:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:333:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:335:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:337:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:341:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:347:4: warning: cast to restricted __be32
drivers/memstick/core/mspro_block.c:356:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:358:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:364:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:367:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:369:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:371:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:377:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:478:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:480:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:482:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:484:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:486:4: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:689:22: expected unsigned int [unsigned] [assigned] data_address
drivers/memstick/core/mspro_block.c:689:22: got restricted __be32 [usertype] <noident>
drivers/memstick/core/mspro_block.c:697:3: warning: cast to restricted __be32
drivers/memstick/core/mspro_block.c:960:17: warning: incorrect type in initializer (different base types)
drivers/memstick/core/mspro_block.c:960:17: expected unsigned short [unsigned] data_count
drivers/memstick/core/mspro_block.c:960:17: got restricted __be16 [usertype] <noident>
drivers/memstick/core/mspro_block.c:993:6: warning: cast to restricted __be16
drivers/memstick/core/mspro_block.c:995:28: warning: cast to restricted __be16
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
To keep the size of changesets sane we split the switch by drivers;
to keep the damn thing bisectable we do the following:
1) rename the affected methods, add ones with correct
prototypes, make (few) callers handle both. That's this changeset.
2) for each driver convert to new methods. *ALL* drivers
are converted in this series.
3) kill the old (renamed) methods.
Note that it _is_ a flagday; all in-tree drivers are converted and by the
end of this series no trace of old methods remain. The only reason why
we do that this way is to keep the damn thing bisectable and allow per-driver
debugging if anything goes wrong.
New methods:
open(bdev, mode)
release(disk, mode)
ioctl(bdev, mode, cmd, arg) /* Called without BKL */
compat_ioctl(bdev, mode, cmd, arg)
locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs
attribute->owner unnecessary. But the field was left in the structure to
ease the merge. It's been over a year since that change and it is now
time to start killing attribute->owner along with its users - one arch at
a time!
This patch is attempt #1 to get rid of attribute->owner only for
CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on
as and when possible - avr32 will be the next since that is something I
can test. Compile (make allyesconfig / make allmodconfig / custom config)
and boot tested.
akpm: the idea is that we put the declaration of sttribute.owner inside
`#ifndef CONFIG_X86'. But that proved to be too ambitious for now because
new usages kept on turning up in subsystem trees.
[akpm: remove the ifdef for now]
Signed-off-by: Parag Warudkar <parag.lkml@gmail.com>
Cc: Greg KH <greg@kroah.com>
Cc: Tejun Heo <htejun@gmail.com>
Cc: Len Brown <lenb@kernel.org>
Cc: Jens Axboe <jens.axboe@oracle.com>
Cc: Jean Delvare <khali@linux-fr.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: David Brownell <david-b@pacbell.net>
Cc: Alessandro Zummo <a.zummo@towertech.it>
This patch converts memstick to use __blk_end_request() directly
so that end_{queued|dequeued}_request() can be removed.
Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com>
Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com>
* Implement disk_devt() and part_devt() and use them to directly
access devt instead of computing it from ->major and ->first_minor.
Note that all references to ->major and ->first_minor outside of
block layer is used to determine devt of the disk (the part0) and as
->major and ->first_minor will continue to represent devt for the
disk, converting these users aren't strictly necessary. However,
convert them for consistency.
* Implement disk_max_parts() to avoid directly deferencing
genhd->minors.
* Update bdget_disk() such that it doesn't assume consecutive minor
space.
* Move devt computation from register_disk() to add_disk() and make it
the only one (all other usages use the initially determined value).
These changes clean up the code and will help disk->part dereference
fix and extended block device numbers.
- 8-bit interface mode never worked properly. The only adapter I have
which supports the 8b mode (the Jmicron) had some problems with its
clock wiring and they discovered it only now. We also discovered that
ProHG media is more sensitive to the ordering of initialization
commands.
- Make the driver fall back to highest supported mode instead of always
falling back to serial. The driver will attempt the switch to 8b mode
for any new MSPro card, but not all of them support it. Previously,
these new cards ended up in serial mode, which is not the best idea
(they work fine with 4b, after all).
- Edit some macros for better conformance to Sony documentation
Instead of using a separate thread to pump requests from block layer queue
to memstick, do so inline, utilizing the callback design of the memstick.
[akpm@linux-foundation.org: fix warnings]
In some cases it may be desirable to ensure that associated driver is not
going to access the media in some period of time. "start" and "stop"
methods are provided therefore to allow it.
Some controllers (Jmicron, for instance) can report temporal failure
condition during power-on. It is desirable to account for this using a
return value of "set_param" device method. The return value can also be
handy to distinguish between supported and unsupported device parameters
in run time.
struct class_device is going away, struct device should be used instead.
Signed-off-by: Tony Jones <tonyj@suse.de>
Newer MemoryStick (HG) cards and hosts support 8-bit parallel mode of
operation in addition to original 4-bit and 1-bit modes.
MemoryStick storage cards, when in parallel mode, send several meaningful bits
of their "INT" register as part of command response. This data is stored by
host and can be used to spare invocation of "GET_INT" TPC on each data page
transferred between host and card.
Bus driver may need to be informed that host is being suspended/resumed.
Thanks to some input from kind people at JMicron it is now possible to have
more correct definitions of protocol structures and bit field semantics.
Sony MemoryStick cards are used in many products manufactured by Sony.
They are available both as storage and as IO expansion cards. Currently,
only MemoryStick Pro storage cards are supported via TI FlashMedia
MemoryStick interface.
[mboton@gmail.com: biuld fix]
[akpm@linux-foundation.org: build fix]
Signed-off-by: Miguel Boton <mboton@gmail.co>
