path: root/drivers/memstick
2009-05-22block: Do away with the notion of hardsect_sizeMartin K. Petersen
Until now we have had a 1:1 mapping between storage device physical block size and the logical block sized used when addressing the device. With SATA 4KB drives coming out that will no longer be the case. The sector size will be 4KB but the logical block size will remain 512-bytes. Hence we need to distinguish between the physical block size and the logical ditto. This patch renames hardsect_size to logical_block_size. Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: implement and enforce request peek/start/fetchTejun Heo
Till now block layer allowed two separate modes of request execution. A request is always acquired from the request queue via elv_next_request(). After that, drivers are free to either dequeue it or process it without dequeueing. Dequeue allows elv_next_request() to return the next request so that multiple requests can be in flight. Executing requests without dequeueing has its merits mostly in allowing drivers for simpler devices which can't do sg to deal with segments only without considering request boundary. However, the benefit this brings is dubious and declining while the cost of the API ambiguity is increasing. Segment based drivers are usually for very old or limited devices and as converting to dequeueing model isn't difficult, it doesn't justify the API overhead it puts on block layer and its more modern users. Previous patches converted all block low level drivers to dequeueing model. This patch completes the API transition by... * renaming elv_next_request() to blk_peek_request() * renaming blkdev_dequeue_request() to blk_start_request() * adding blk_fetch_request() which is combination of peek and start * disallowing completion of queued (not started) requests * applying new API to all LLDs Renamings are for consistency and to break out of tree code so that it's apparent that out of tree drivers need updating. [ Impact: block request issue API cleanup, no functional change ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Mike Miller <mike.miller@hp.com> Cc: unsik Kim <donari75@gmail.com> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Cc: David S. Miller <davem@davemloft.net> Cc: Laurent Vivier <Laurent@lvivier.info> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Adrian McMenamin <adrian@mcmen.demon.co.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Stefan Weinhuber <wein@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to dequeueing model (easy ones)Tejun Heo
plat-omap/mailbox, floppy, viocd, mspro_block, i2o_block and mmc/card/queue are already pretty close to dequeueing model and can be converted with simple changes. Convert them. While at it, * xen-blkfront: !fs check moved downwards to share dequeue call with normal path. * mspro_block: __blk_end_request(..., blk_rq_cur_byte()) converted to __blk_end_request_cur() * mmc/card/queue: loop of __blk_end_request() converted to __blk_end_request_all() [ Impact: dequeue in-flight request ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Alex Dubov <oakad@yahoo.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: blk_rq_[cur_]_{sectors|bytes}() usage cleanupTejun Heo
With the previous changes, the followings are now guaranteed for all requests in any valid state. * blk_rq_sectors() == blk_rq_bytes() >> 9 * blk_rq_cur_sectors() == blk_rq_cur_bytes() >> 9 Clean up accessor usages. Notable changes are * nbd,i2o_block: end_all used instead of explicit byte count * scsi_lib: unnecessary conditional on request type removed [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-05-11block: convert to pos and nr_sectors accessorsTejun Heo
With recent cleanups, there is no place where low level driver directly manipulates request fields. This means that the 'hard' request fields always equal the !hard fields. Convert all rq->sectors, nr_sectors and current_nr_sectors references to accessors. While at it, drop superflous blk_rq_pos() < 0 test in swim.c. [ Impact: use pos and nr_sectors accessors ] Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com> Tested-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: Grant Likely <grant.likely@secretlab.ca> Tested-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Adrian McMenamin <adrian@mcmen.demon.co.uk> Acked-by: Mike Miller <mike.miller@hp.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Borislav Petkov <petkovbb@googlemail.com> Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: Alan Stern <stern@rowland.harvard.edu> Cc: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Clements <paul.clements@steeleye.com> Cc: Tim Waugh <tim@cyberelk.net> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Dario Ballabio <ballabio_dario@emc.com> Cc: David S. Miller <davem@davemloft.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: unsik Kim <donari75@gmail.com> Cc: Laurent Vivier <Laurent@lvivier.info> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-04-28block: implement and use [__]blk_end_request_all()Tejun Heo
There are many [__]blk_end_request() call sites which call it with full request length and expect full completion. Many of them ensure that the request actually completes by doing BUG_ON() the return value, which is awkward and error-prone. This patch adds [__]blk_end_request_all() which takes @rq and @error and fully completes the request. BUG_ON() is added to to ensure that this actually happens. Most conversions are simple but there are a few noteworthy ones. * cdrom/viocd: viocd_end_request() replaced with direct calls to __blk_end_request_all(). * s390/block/dasd: dasd_end_request() replaced with direct calls to __blk_end_request_all(). * s390/char/tape_block: tapeblock_end_request() replaced with direct calls to blk_end_request_all(). [ Impact: cleanup ] Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Mike Miller <mike.miller@hp.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Alex Dubov <oakad@yahoo.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-04-07dma-mapping: replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32)Yang Hongyang
Replace all DMA_32BIT_MASK macro with DMA_BIT_MASK(32) Signed-off-by: Yang Hongyang<yanghy@cn.fujitsu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-09memstick: annotate endianness of attribute structsHarvey Harrison
The code was shifting the endianness appropriately everywhere, annotate the structs to avoid the sparse warnings when assigning the endian types to the struct members, or passing them to be[16|32]_to_cpu: drivers/memstick/core/mspro_block.c:331:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:333:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:335:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:337:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:341:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:347:4: warning: cast to restricted __be32 drivers/memstick/core/mspro_block.c:356:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:358:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:364:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:367:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:369:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:371:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:377:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:478:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:480:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:482:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:484:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:486:4: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:689:22: expected unsigned int [unsigned] [assigned] data_address drivers/memstick/core/mspro_block.c:689:22: got restricted __be32 [usertype] <noident> drivers/memstick/core/mspro_block.c:697:3: warning: cast to restricted __be32 drivers/memstick/core/mspro_block.c:960:17: warning: incorrect type in initializer (different base types) drivers/memstick/core/mspro_block.c:960:17: expected unsigned short [unsigned] data_count drivers/memstick/core/mspro_block.c:960:17: got restricted __be16 [usertype] <noident> drivers/memstick/core/mspro_block.c:993:6: warning: cast to restricted __be16 drivers/memstick/core/mspro_block.c:995:28: warning: cast to restricted __be16 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-06memstick: struct device - replace bus_id with dev_name(), dev_set_name()Kay Sievers
Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-21[PATCH] switch memstickAl Viro
2008-10-21[PATCH] beginning of methods conversionAl Viro
To keep the size of changesets sane we split the switch by drivers; to keep the damn thing bisectable we do the following: 1) rename the affected methods, add ones with correct prototypes, make (few) callers handle both. That's this changeset. 2) for each driver convert to new methods. *ALL* drivers are converted in this series. 3) kill the old (renamed) methods. Note that it _is_ a flagday; all in-tree drivers are converted and by the end of this series no trace of old methods remain. The only reason why we do that this way is to keep the damn thing bisectable and allow per-driver debugging if anything goes wrong. New methods: open(bdev, mode) release(disk, mode) ioctl(bdev, mode, cmd, arg) /* Called without BKL */ compat_ioctl(bdev, mode, cmd, arg) locked_ioctl(bdev, mode, cmd, arg) /* Called with BKL, legacy */ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-10-20x86: sysfs: kill owner field from attributeParag Warudkar
Tejun's commit 7b595756ec1f49e0049a9e01a1298d53a7faaa15 made sysfs attribute->owner unnecessary. But the field was left in the structure to ease the merge. It's been over a year since that change and it is now time to start killing attribute->owner along with its users - one arch at a time! This patch is attempt #1 to get rid of attribute->owner only for CONFIG_X86_64 or CONFIG_X86_32 . We will deal with other arches later on as and when possible - avr32 will be the next since that is something I can test. Compile (make allyesconfig / make allmodconfig / custom config) and boot tested. akpm: the idea is that we put the declaration of sttribute.owner inside `#ifndef CONFIG_X86'. But that proved to be too ambitious for now because new usages kept on turning up in subsystem trees. [akpm: remove the ifdef for now] Signed-off-by: Parag Warudkar <parag.lkml@gmail.com> Cc: Greg KH <greg@kroah.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Tejun Heo <htejun@gmail.com> Cc: Len Brown <lenb@kernel.org> Cc: Jens Axboe <jens.axboe@oracle.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-09memstick: change to use __blk_end_request()Kiyoshi Ueda
This patch converts memstick to use __blk_end_request() directly so that end_{queued|dequeued}_request() can be removed. Signed-off-by: Kiyoshi Ueda <k-ueda@ct.jp.nec.com> Signed-off-by: Jun'ichi Nomura <j-nomura@ce.jp.nec.com> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-10-09block: don't depend on consecutive minor spaceTejun Heo
* Implement disk_devt() and part_devt() and use them to directly access devt instead of computing it from ->major and ->first_minor. Note that all references to ->major and ->first_minor outside of block layer is used to determine devt of the disk (the part0) and as ->major and ->first_minor will continue to represent devt for the disk, converting these users aren't strictly necessary. However, convert them for consistency. * Implement disk_max_parts() to avoid directly deferencing genhd->minors. * Update bdget_disk() such that it doesn't assume consecutive minor space. * Move devt computation from register_disk() to add_disk() and make it the only one (all other usages use the initially determined value). These changes clean up the code and will help disk->part dereference fix and extended block device numbers. Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-09-13memstick: fix MSProHG 8-bit interface mode supportAlex Dubov
- 8-bit interface mode never worked properly. The only adapter I have which supports the 8b mode (the Jmicron) had some problems with its clock wiring and they discovered it only now. We also discovered that ProHG media is more sensitive to the ordering of initialization commands. - Make the driver fall back to highest supported mode instead of always falling back to serial. The driver will attempt the switch to 8b mode for any new MSPro card, but not all of them support it. Previously, these new cards ended up in serial mode, which is not the best idea (they work fine with 4b, after all). - Edit some macros for better conformance to Sony documentation Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26memstick: use fully asynchronous request processingAlex Dubov
Instead of using a separate thread to pump requests from block layer queue to memstick, do so inline, utilizing the callback design of the memstick. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26memstick: add "start" and "stop" methods to memstick deviceAlex Dubov
In some cases it may be desirable to ensure that associated driver is not going to access the media in some period of time. "start" and "stop" methods are provided therefore to allow it. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26memstick: allow "set_param" method to return an error codeAlex Dubov
Some controllers (Jmicron, for instance) can report temporal failure condition during power-on. It is desirable to account for this using a return value of "set_param" device method. The return value can also be handy to distinguish between supported and unsupported device parameters in run time. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21driver core: remove DEVICE_ID_SIZE defineGreg Kroah-Hartman
There is no such thing as a "device id size" in the driver core, so remove the define and fix up any users of this odd define in the rest of the kernel. Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-19memstick: convert struct class_device to struct deviceGreg Kroah-Hartman
struct class_device is going away, struct device should be used instead. Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-28memstick: suppress uninitialized-var warningAndrew Morton
drivers/memstick/host/tifm_ms.c: In function 'tifm_ms_data_event': drivers/memstick/host/tifm_ms.c:185: warning: 'p_off' may be used uninitialized in this function Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19memstick: optimize setup of JMicron host parametersAlex Dubov
Set correct clock management values to improve over-all performance. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19memstick: add support for 8-bit parallel modeAlex Dubov
Newer MemoryStick (HG) cards and hosts support 8-bit parallel mode of operation in addition to original 4-bit and 1-bit modes. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19memstick: automatically retrieve "INT" value from command responseAlex Dubov
MemoryStick storage cards, when in parallel mode, send several meaningful bits of their "INT" register as part of command response. This data is stored by host and can be used to spare invocation of "GET_INT" TPC on each data page transferred between host and card. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19memstick: drivers/memstick/host/jmb38x_ms.c: suppress uninitialized var warningAndrew Morton
drivers/memstick/host/jmb38x_ms.c: In function 'jmb38x_ms_transfer_data': drivers/memstick/host/jmb38x_ms.c:294: warning: 'p_off' may be used uninitialized in this function Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19memstick: drivers/memstick/host/jmb38x_ms.c needs dma-mapping.hAndrew Morton
sparc32: drivers/memstick/host/jmb38x_ms.c: In function 'jmb38x_ms_probe': drivers/memstick/host/jmb38x_ms.c:818: error: 'DMA_32BIT_MASK' undeclared (first use in this function) drivers/memstick/host/jmb38x_ms.c:818: error: (Each undeclared identifier is reported only once drivers/memstick/host/jmb38x_ms.c:818: error: for each function it appears in.) Cc: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10memstick: add support for JMicron jmb38x MemoryStick host controllerAlex Dubov
2008-03-10memstick: try harder to recover from unsuccessful interface mode switchAlex Dubov
2008-03-10memstick: fix parsing of "assembly_date" attribute fieldAlex Dubov
2008-03-10memstick: add support for decoding "specfile" media attributesAlex Dubov
2008-03-10tifm: fix memorystick host initialization codeAlex Dubov
Instead of assuming that host is powered on only once at card insertion, allow for the possibility that memstick layer may need to cycle card's power to get it out from some unhealthy states. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10tifm: fix the MemoryStick host fifo handling codeAlex Dubov
Additional input received from JMicron on MemoryStick host interfaces showed that some assumtions in fifo handling code were incorrect. This patch also fixes data corruption used to occure during PIO transfers. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10memstick: drop DRIVER_VERSION numbers as meaninglessAlex Dubov
2008-03-10memstick: make sure number of command retries is exactly as specifiedAlex Dubov
2008-03-10memstick: add memstick_suspend/resume_host methodsAlex Dubov
Bus driver may need to be informed that host is being suspended/resumed. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-10memstick: introduce correct definitions in the headerAlex Dubov
Thanks to some input from kind people at JMicron it is now possible to have more correct definitions of protocol structures and bit field semantics. Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-13drivers/memstick/host/tifm_ms.c breakageAl Viro
writel(sock + ...) that should've been writel(sock->addr + ...) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-09memstick: initial commit for Sony MemoryStick supportAlex Dubov
Sony MemoryStick cards are used in many products manufactured by Sony. They are available both as storage and as IO expansion cards. Currently, only MemoryStick Pro storage cards are supported via TI FlashMedia MemoryStick interface. [mboton@gmail.com: biuld fix] [akpm@linux-foundation.org: build fix] Signed-off-by: Alex Dubov <oakad@yahoo.com> Signed-off-by: Miguel Boton <mboton@gmail.co> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
