path: root/drivers/message/fusion/mptfc.c
2006-01-31[SCSI] fusion: FC rport code fixesMichael Reed
This fix's problems with recent fc submission regarding i/o being redirected to the wrong target. Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] fusion - adding support for FC949ESMoore, Eric
Add software recognition for the new LSI Logic Fibre Channel controller. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] mptfusion - fc transport attributesMichael Reed
2006-01-14[SCSI] fusion: kzalloc / kcalloc conversionChristoph Hellwig
Convert kmalloc + memset to kzalloc or kcalloc in fusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] mptfusion - mapping fixs required support for transport layers.Moore, Eric Dean
This utilizes the hostdata area that is hung off of scsi_target and scsi_device for saving unique firmware mapping. This will be required for supporting new Fibre and SPI transport support. This also fixs problems in error handling error code for SAS controllers, in which the incorrect mapping was passed to the firmware. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] mptfusion - cleaning up xxx_probe error handlingMoore, Eric Dean
This cleans the returning failure conditions of the mptsas/mptfc/mptspi probe routines. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-12-13[SCSI] mptfusion - adding = THIS_MODULEMoore, Eric Dean
2005-09-19[SCSI] fusion SAS support (mptsas driver) updatesMoore, Eric Dean
Summary of Changes: * splitting mpt_interrupt per Christophs suggestion about a month ago * rename ScsiCfgData to SpiCfgData structure, then move all the raid related info into new structure called RaidCfgData. This is done because SAS supports RAID, as well as SPI, so the raid stuff should be seperate. * incorrect timeout calculation for cntdn inside WaitForDoorbellAck and WaitForDoortbellInt * add support for interpreting SAS Log Info * Increase Event Log Size from 0xA to 0x32 * Fix bug in mptsas/mptfc/mptspi - when controller has Initiator Mode Disabled, and only running in TargetMode, the mptctl would panic when loading. The fix is to return 0, instead of -ENODEV, in SCSI LLD respective probe routines * Fix bug in mptlan.c - driver will panic if there is host reset, due to dev being set to zero in mpt_lan_ioc_reset * Fix's for SPI - Echo Buffer * Several fix's in mptscsih_io_done - FCP Response info, RESIDUAL_MISMATCH, Data Underrun, etc. * Cleanup Error Handling - EH handlers, mptscsih_flush_cmds, and zeroing out ScsiLookup from mptscsih_qcmd * Cleanup asyn event handling from mptscsih -> mptscsih_event_process. Also added support for SAS Persistent Table Full, an asyn event Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-07-26Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-for-linus-2.6Linus Torvalds
2005-07-01[SCSI] - mptfusion - convert to new change_queue_depth APIMoore, Eric Dean
Convert driver to use new change_queue_depth API. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Fixed up rejections and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-27[PATCH] PCI: make drivers use the pci shutdown callback instead of the ↵Greg Kroah-Hartman
driver core callback. Now we can change the pci core to always set this pointer, as pci drivers should use it, not the driver core callback. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-26[SCSI] remove scsi_set_deviceChristoph Hellwig
scsi_add_host is the proper place to set the device, but people copy the scsi_set_device usage from older drivers again and again. note that this leaves some legacy drivers like qlogicisp/qlogicfc without pci association in sysfs, but they're scheduled to go away soon anyway. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] fusion - Adding pci recog support for Fibre 949X and 939X chipsMoore, Eric Dean
* adding pci id support for new Fibre chips, 949X and 939X * adding errata workaround - disabling PIO access except during fwdlb. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: fix panic loading driver statically compiledMoore, Eric Dean
Adjust link ordering in the Makefile. Also, the ioc->DoneCtx handles for mptspi/mptfc in the message frame. And I'm now not seeing the panic. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: mptfc Adding Stub Driver - Fiber ChannelMoore, Eric Dean
(1) mptfc.c: This driver is having module_init, module_exit, and probe. (2) mptfc.c: Registering for Fibre Channel pci ids are done from this module. (3) mptfc.c: Convert MODULE_PARM to module_param Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
