path: root/drivers/message/fusion/mptfc.c
2009-08-22[SCSI] mptsas : Removed mptscsih_timer_expired.Kashyap, Desai
Removed mptscsih_timer_expired. This timer is no more use. Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2009-06-09[SCSI] mpt fusion: rewrite of ioctl_cmds internal generated functionKashyap, Desai
1) rewrite of ioctl_cmds internal generated function that issue commands to firmware, porting them to be single threaded using the generic MPT_MGMT struct. All wait Queues are replace by completion Queue. 2) added seperate callback handler for ioctl task managment (mptctl_taskmgmt_reply), to handle command that timeout 3) rewrite mptctl_bus_reset Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: Adding DeviceResetCtx for internal Device reset frameKashyap, Desai
1.) Added taskmgmt_quiesce_io flag in IOC and removed resetPending from _MPT_SCSI_HOST struct. 2.) Reset from Scsi mid layer and internal Reset are seperate context. Adding DeviceResetCtx for internal Device reset frame. mptsas_taskmgmt_complete is optimized as part of implementation. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: rewrite of all internal generated functionsKashyap, Desai
Rewrite of all internal generated functions that issue commands to firmware, porting them to be single threaded using the generic MPT_MGMT struct. Implemented using completion Queue. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2009-06-09[SCSI] mpt fusion: Fixing 1078 data corruption issue for 36GB memory regionKashyap, Desai
The reason for this change is there is a data corruption when four different physical memory regions in the 36GB to 37GB region are accessed. This is only affecting 1078. The solution is we need to use different addressing when filling in the scatter gather table for the effected memory regions. So instead of snooping on all four different memory holes, we treat any physical addresses in the 36GB address with the same algorithm. The fix is explained below 1) Ensure that the message frames are NOT located in the trouble region. There is no remapping available for message frames, they must be allocated outside the problem region. 2) Ensure that Sense buffers are NOT in the trouble region. There is no remapping available. 3) Walk through the SGE entries and if any are inside the trouble region then they need to be remapped as discussed below. 1) Set the Local Address bit in the SGE Flags field. MPI_SGE_FLAGS_LOCAL_ADDRESS 2) Ensure we are using 64-bit SGEs 3) Set MSb (Bit 63) of the 64-bit address, this will indicate buffer location is Host Memory. Signed-off-by: Kashyap Desai <kadesai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-27[SCSI] replace __FUNCTION__ with __func__Harvey Harrison
[jejb: fixed up a ton of missed conversions. All of you are on notice this has happened, driver trees will now need to be rebased] Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: SCSI List <linux-scsi@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-07-21driver core: remove KOBJ_NAME_LEN defineKay Sievers
Kobjects do not have a limit in name size since a while, so stop pretending that they do. Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-06-05[SCSI] mpt fusion : Updated copyright statment with 2008 includedPrakash, Sathya
Updating copyright statement to include the year 2008 Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-05-27[SCSI] fusion mpt: fix target missing after resetting external raidMichael Reed
Following a hard reset of a SAS raid, one of the raid targets is occasionally missing. I tracked this down to a pretty obscure little bug. The LSI fusion drivers for SAS and Fibre Channel both use their respective transport layers. Those transport layers increment the target number assigned to new targets. The routine __scsi_scan_target uses the "this_id" element of the Scsi_Host structure to avoid scanning the scsi host adapter. Both fusion drivers set "this_id" from a value returned in a firmware PortFacts response. For my particular test case (SAS) the firmware id assigned to the initiator was 173. After enough raid resets to cause the raid targets to go and come a sufficient number of times, the id assigned by the transport to a raid target would match the id assigned by the host adapter to the "this_id" field, resulting in that target not being scanned. Fix by not assigning this_id and not checking it in slave_configure. Signed-off-by: Michael Reed <mdr@sgi.com> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-12[SCSI] mpt fusion: lock down ScsiLookupEric Moore
ScsiLookup is an array of pending scmd pointers that the scsi lld maintains. This array is touched from queuecommand, eh threads, and interrupt context. This array should put under locks, hence this patch to synchronize its access. I've added some nice little function wrappers for this, and moved the ScsiLookup array over to MPT_ADAPTER struct. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: add use of shost_priv and remove all the typecastingEric Moore
The driver is currently typecasting to obtain the shost hostdata. The driver is updated to use the shost_priv macro. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: removing references to hd->iocEric Moore
Cleaning up code by accesing the ioc pointer directly instead of via hd->ioc. In the future, most data members of struct MPT_SCSI_HOST will be either deleted or moved to struct MPT_ADAPTER. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: rename vdev to vdeviceEric Moore
common naming of vdevice through out driver Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: standardize printks and debug infoEric Moore
Standardize all prints using common MYIOC_s_XXX_FMT macro defined in mptbase.h. Currently the driver uses several different methods to display info, where in some cases the "controller name" generating the printk is not provided. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Change company name from LSI Logic to LSIPrakash, Sathya
Recently LSI Logic Corp was renamed as LSI Corp, so whereever there is a reference of LSI Logic, it is changed to LSI in mpt fusion driver code. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Link speed change display supportPrakash, Sathya
When there is state change in FC links, a message is displayed with old and new link speed. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Change call back indices to u8 from intPrakash, Sathya
The call back index requires only u8 but in lot of places it is referred as int, now everywhere the call back index variables are declared as u8 with uniform name cb_idx signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-28[SCSI] mpt fusion: Changes in mptfc.c mptlan.c mptsas.c and mptspi.c for ↵Prakash, Sathya
logging support This patch contains changes in mptfc.c, mptlan.c, mptsas.c and mptspi.c to support logging in MPT fusion drivers. The changes are majorly in debug printks, the existing debugprintk are modified accroding to new debug macros defined in the file mptbdebug.h signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-18[SCSI] mpt fusion: add support for Brocade branded LSI FC HBAPrakash, Sathya
Add support for Brocade 410/420 4Gbit FC HBAs. They are re-branded LSI HBAs [LSI7104EP-LC/LSI7204EP-LC] Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-18[SCSI] mpt fusion: add sysfs attributes to display IOC parametersPrakash, Sathya
New sysfs scsi_host attributes are added to provide information about Firmware version, BIOS version, MPI version and other product related information signed-off-by: Sathya Praksh <sathya.prakash@lsi.com> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] mpt fusion: remove unused header - linux_compat.hEric Moore
remove unused header Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-06-17[SCSI] mpt fusion: update MAINTAINERS (fusion part)Eric Moore
Update assocated fusion sources with new support email address. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - bump version - 3.04.04Eric Moore
bump version, and fix email addr for lsi support Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-02-02[SCSI] fusion - Greater than 255 target and lun supportEric Moore
Add support for greater than 255 target and luns. Kill the hd->Target[] field, and change all references of bus_id/target_id, to channel/id. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-01-06[SCSI] fusion: MODULE_VERSION supportEric Moore
* Add modinfo driver version support. * Change copyright year to 2007. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-12-07[PATCH] kernel-doc: fix fusion and i2o docsRandy Dunlap
Correct lots of typos, kernel-doc warnings, & kernel-doc usage in fusion and i2o drivers. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-25[SCSI] mptfc: stall eh handlers if resetting while rport blockedMichael Reed
Thanks to James Smart for the inspiration. Stall error handler if attempting recovery while an rport is blocked. This avoids device offline scenarios due to errors in the error handler. Also verify that VirtDevice is available before issuing scsi command. VirtDevice is removed when fc transport removes a target. See James Smart's patch of 08/17/2006 for greater detail. http://marc.theaimsgroup.com/?l=linux-scsi&m=115583213624803&w=2 Also bump version number per Eric's request. Signed-off-by: Michael Reed <mdr@sgi.com> Acked-by: Eric Moore <eric.moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-27Merge ../linux-2.6James Bottomley
2006-08-06[SCSI] mptfc: add additional fc transport attributesMichael Reed
Add host_supported_speeds, host_maxframe_size, host_speed, host_fabric_name, host_port_type, host_port_state, and host_symbolic_name transport attributes to fusion fibre channel. Signed-off-by: Michael Reed <mdr@sgi.com> Acked-by: Moore, Eric <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-06[SCSI] mptfc: correct out of order event processingMichael Reed
This patch corrects a problem in mptfc which can result in targets being removed after executing an "lsiutil 99" reset of the fibre channel ports. The last rescan event was being processed before the setup reset work due to an inappropriate optimization in the event processing logic. Every rescan event is now queued for execution and the setup reset work now executes in the proper sequence. Signed-off-by: Michael Reed <mdr@sgi.com> Acked-by: Moore, Eric <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-08-06[SCSI] mptfc: properly wait for firmware target discovery to completeMichael Reed
Based upon a conversation I had with LSI's fibre channel firmware guru, this patch adds another condition under which the driver waits for the firmware link initialization / target discovery to complete. Signed-off-by: Michael Reed <mdr@sgi.com> Acked-by: Moore, Eric <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-07-13[SCSI] mptfusion: misc fix'sEric Moore
* removing obsolete 1066, 1066E from Kconfig * initializing aen_event_read_flag after host reset * remove oem references * remove obsolete mpt_pq_filter command line option Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-28Merge ../linux-2.6/James Bottomley
Conflicts: drivers/scsi/aacraid/comminit.c Fixed up by removing the now renamed CONFIG_IOMMU option from aacraid Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-28[SCSI] mptsas: Adding 1078 ROC supportEric Moore
* Adding 1078 ROC (Raid On Chip) Support - New host adapter * Moving all PCI Vendor/Device ids to using internal defines; a request from Christoph/James B. some time ago for when the next chip was added. * Removing SAS 1066/1066E Vendor/Device IDs, as there are no plans to manufacture that controller. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-27[PATCH] Remove redundant NULL checks before [kv]free - in drivers/Jesper Juhl
Remove redundant NULL chck before kfree + tiny CodingStyle cleanup for drivers/ Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-10[SCSI] mptfc: abort of board reset leaves port dead requiring rebootMichael Reed
The driver uses msleep_interruptible() in the code path responsible for resetting the card's ports via the lsiutil command. If a <ctrl-c> is received during the reset it can leave a port in such a state that the only way to regain its use is to reboot the system. Changing from msleep_interruptible() to msleep() corrects the problem. Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] mptfc: fix fibre channel infinite request/response loopMichael Reed
While doing board reset testing I was able to put the system in an infinite request/response loop between the scsi layer and mptscsih_qcmd() by aborting the reset. This patch installs a "SETUP RESET" handler which calls fc_remote_port_delete() for all registered rports. This blocks the target which prevents the loop. Additionally, should the reset fail to complete, the transport will now terminate i/o to the target. Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] mptfc: set fibre channel fw target missing timers to one secondMichael Reed
The fibre channel firmware provides a timer which is similar in purpose to the fibre channel transport's device loss timer. The effect of this timer is to extend the total time that a target will be missing beyond the value associated with the transport's timer. This patch changes the firmware timer to a default of one second which significantly reduces the lag between when a target goes missing and the notification of the fibre channel transport. Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] mptfusion: move fc event/reset handling to mptfcMichael Reed
Move fibre channel event and reset handling to mptfc. This will result in fewer changes over time that need to be applied to either mptbase.c or mptscsih.c. Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-05-10[SCSI] mptfc: race between mptfc_register_dev and mptfc_target_allocmdr@sgi.com
A race condition exists in mptfc between the thread registering a device with the fc transport and the scan work generated by the transport. This race existed prior to the application of the mptfc bug fix patch. mptfc_register_dev() calls fc_remote_port_add() with the FC_RPORT_ROLE_TARGET bit set in the rport ids passed to the function. Having this bit set causes fc_remote_port_add() to schedule a scan of the device. This scan can execute before mptfc_register_dev() can fill in the dd_data in the rport structure. When this happens, mptfc_target_alloc() will fail because dd_data is null. Attached is a patch which fixes the problem. The patch changes the rport ids passed to fc_remote_port_add() to not have the TARGET bit set. This prevents the scan from being scheduled. After mptfc_register_dev() fills in the rport dd_data field, fc_remote_port_rolechg() is called, changing the role of the rport to TARGET. Thus, the scan is scheduled after dd_data is filled in which prevents the failure in mptfc_target_alloc(). Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-04-25[SCSI] - fusion - mptfc bug fix's to prevent deadlock situationsMoore, Eric
mptbase.h bump version number to 3.03.09 remove unneeded flags define workq and remove old fc specific locks mptbase.c initialize new lock and don't initialize two removed locks mptscsih.c when firmware reports target is no longer there, return DID_REQUEUE for fc hosts so that i/o doesn't get killed until the transport has an opportunity to manage the loss via its dev loss timer when the "eh_abort" routine is called, check to see if the driver has the command or not before looking to see if a reset is pending. James Smart and I talked about this and believe that the API for this routine is: if driver doesn't have command, return SUCCESS. This change helps prevent a target from being taken offline. SUCCESS is returned because it's likely that the command completed after error recovery timed it out but before it could be aborted. provide a routine to queue work to newly created workq, and use it. remove "ioc" from mptscsih_abort() it was only used one time. the other references were via hd->ioc, so I just moved it.... net change in references to ioc via hd->ioc is zero move hd->resetPending test and hd->timeouts increment to after the test for whether the command to be aborted remains known to the driver Make certain that the workq exists before queuing work to it. mptfc.c no longer need to lock rport data structures as I was able to single thread the code! I fixed up the debug code to eliminate compilation messages due to type mismatch in the printk. Got rid of some no longer needed rport flags. Initialize and destroy the workq used for the rescan work. simplify the logic regarding the increment of fc_rescan_work_count. use post increment and test for zero vs. pre increment and test for one; eliminate work_count variable: queue_work can be called with the work_lock held as it doesn't sleep Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-14[SCSI] fusion - removing target_id/bus_id from the VirtDevice structureMoore, Eric
It makes no sense in keeping the target_id and bus_id in the VirtDevice structure, when it can be obtained from the VirtTarget structure. In addition, this patch fix's couple compilation bugs in mptfc.c when MPT_DEBUG_FC is enabled. This provided by Micheal Reed. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-03-14[SCSI] fusion - move some debug firmware event debug msgs to verbose levelMoore, Eric
Created a debug level MPT_DEBUG_VERBOSE_EVENTS. Moving some of the more vebose debug messages for firwmare events into new debug level. Also added some more firmware events descriptions. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-27[SCSI] drivers/message/fusion/mptfc.c: make 2 functions staticAdrian Bunk
This patch makes two needlessly global functions static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: FC rport code fixesMichael Reed
This fix's problems with recent fc submission regarding i/o being redirected to the wrong target. Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] fusion - adding support for FC949ESMoore, Eric
Add software recognition for the new LSI Logic Fibre Channel controller. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] mptfusion - fc transport attributesMichael Reed
2006-01-14[SCSI] fusion: kzalloc / kcalloc conversionChristoph Hellwig
Convert kmalloc + memset to kzalloc or kcalloc in fusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
