commit 94e5395d2403c8bc2504a7cbe4c4caaacb7b8b84 upstream.
First generation MPT Fusion controllers can not translate WRITE SAME
when the attached device is a SATA drive. Disable WRITE SAME support.
Reported-by: Nikola Ciprich <nikola.ciprich@linuxbox.cz>
Cc: <stable@vger.kernel.org>
mptsas_smp_handler() checks for dma mapping errors by comparison
returned address with zero, while pci_dma_mapping_error() should be
used.
Found by Linux Driver Verification project (linuxtesting.org).
Signed-off-by: Alexey Khoroshilov <khoroshilov@ispras.ru>
Acked-by: Sathya Prakash Veerichetty <sathya.prakash@broadcom.com>
This patch changes the !blk-mq path to the same defaults as the blk-mq
I/O path by always enabling block tagging, and always using host wide
tags. We've had blk-mq available for a few releases so bugs with
this mode should have been ironed out, and this ensures we get better
coverage of over tagging setup over different configs.
Acked-by: Jens Axboe <axboe@kernel.dk>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Signed-off-by: James Bottomley <JBottomley@Odin.com>
A user of scsi_track_queue_full should pass to the function a constant value
untill the queue-depth changes, otherwise the internal logic in
scsi_track_queue_full rejects the change. Other users of this function use a
'sdev->queue_depth - 1' as depth parameter, let's do the same.
Signed-off-by: Tomas Henzl <thenzl@redhat.com>
Acked-by: "Sreekanth Reddy" <Sreekanth.reddy@avagotech.com>
Allow a driver to ask for block layer tags by setting .use_blk_tags in the
host template, in which case it will always see a valid value in
request->tag, similar to the behavior when using blk-mq. This means even
SCSI "untagged" commands will now have a tag, which is especially useful
when using a host-wide tag map.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
Fixes the following smatch warnings:
drivers/message/fusion/mptbase.c:652 mptbase_reply() warn: variable
dereferenced before check 'reply' (see line 639)
[JL: No-brainer, the enclosing switch statement dereferences
reply, so we can't get here unless reply is valid.]
drivers/message/fusion/mptsas.c:1255 mptsas_taskmgmt_complete() error:
we previously assumed 'pScsiTmReply' could be null (see line 1227)
[HCH: Reading the code in mptsas_taskmgmt_complete it's pretty
obvious that it can't do anything useful if mr/pScsiTmReply are
NULL, so I suspect it would be best to just return at the
beginning of the function.
I'd love to understand if it actually could ever be zero, which I
doubt. Maybe the LSI people can shed some light on that?]
drivers/message/fusion/mptsas.c:3888 mptsas_not_responding_devices()
error: we previously assumed 'port_info->phy_info' could be null
(see line 3875)
[HCH: It's pretty obvious from reading mptsas_sas_io_unit_pg0 that
we never register a port_info with a NULL phy_info in the lists,
so all NULL checks on it could be deleted.]
drivers/message/fusion/mptscsih.c:1284 mptscsih_info() error:
we previously assumed 'h' could be null (see line 1274)
[HCH: shost_priv can't return NULL, so the if (h) should be
removed.]
drivers/message/fusion/mptscsih.c:1388 mptscsih_qcmd() error: we
previously assumed 'vdevice' could be null (see line 1373)
[HCH: vdevice can't ever be NULL here, it's allocated in
->slave_alloc and thus guaranteed to be around when
->queuecommand is called.]
Signed-off-by: Joe Lawrence <joe.lawrence@stratus.com>
Acked-by: Sreekanth Reddy <Sreekanth.Reddy@avagotech.com>
Tack the firmware reply event_data payload to the end of its
corresponding struct fw_event_work allocation. Rework fw_event_work
allocation calculations to include the event_data size where
appropriate.
This clarifies the code a bit and avoids the following smatch warnings:
drivers/message/fusion/mptsas.c:1003 mptsas_queue_device_delete()
error: memcpy() 'fw_event->event_data' too small (29 vs 36)
drivers/message/fusion/mptsas.c:1017 mptsas_queue_rescan() error: not
allocating enough data 168 vs 160
Fixes the following sparse warnings:
drivers/message/fusion/mptbase.c:7011:1: warning: symbol
'mpt_SoftResetHandler' was not declared. Should it be static?
drivers/message/fusion/mptsas.c:1578:23: warning: symbol
'mptsas_refreshing_device_handles' was not declared. Should it be
static?
drivers/message/fusion/mptsas.c:3653:24: warning: symbol
'mptsas_expander_add' was not declared. Should it be static?
drivers/message/fusion/mptsas.c:5327:1: warning: symbol
'mptsas_shutdown' was not declared. Should it be static?
drivers/message/fusion/mptspi.c:624:1: warning: symbol
'mptscsih_quiesce_raid' was not declared. Should it be static?
Avoid taking the queue_lock to check the per-device queue limit. Instead
we do an atomic_inc_return early on to grab our slot in the queue,
and if necessary decrement it after finishing all checks.
Unlike the host and target busy counters this doesn't allow us to avoid the
queue_lock in the request_fn due to the way the interface works, but it'll
allow us to prepare for using the blk-mq code, which doesn't use the
queue_lock at all, and it at least avoids a queue_lock round trip in
scsi_device_unbusy, which is still important given how busy the queue_lock
is.
Reviewed-by: Webb Scales <webbnh@hp.com>
Tested-by: Bart Van Assche <bvanassche@acm.org>
Tested-by: Robert Elliott <elliott@hp.com>
Removing the host_lock from the I/O submission path gives a huge
scalability improvement.
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Reviewed-by: Nicholas Bellinger <nab@linux-iscsi.org>
Reviewed-by: Praveen Krishnamoorthy <Praveen.krishnamoorthy@lsi.com>
Acked-by: Sreekanth Reddy <Sreekanth.reddy@lsi.com>
When we start sharing biovecs, keeping bi_vcnt accurate for splits is
going to be error prone - and unnecessary, if we refactor some code.
So bio_segments() has to go - but most of the existing users just needed
to know if the bio had multiple segments, which is easier - add a
bio_multiple_segments() for them.
(Two of the current uses of bio_segments() are going to go away in a
couple patches, but the current implementation of bio_segments() is
unsafe as soon as we start doing driver conversions for immutable
biovecs - so implement a dumb version for bisectability, it'll go away
in a couple patches)
Signed-off-by: Kent Overstreet <kmo@daterainc.com>
Cc: Neil Brown <neilb@suse.de>
Cc: Nagalakshmi Nandigama <Nagalakshmi.Nandigama@lsi.com>
Cc: Sreekanth Reddy <Sreekanth.Reddy@lsi.com>
Cc: "James E.J. Bottomley" <JBottomley@parallels.com>
Pull block core updates from Jens Axboe:
- Major bit is Kents prep work for immutable bio vecs.
- Stable candidate fix for a scheduling-while-atomic in the queue
bypass operation.
- Fix for the hang on exceeded rq->datalen 32-bit unsigned when merging
discard bios.
- Tejuns changes to convert the writeback thread pool to the generic
workqueue mechanism.
- Runtime PM framework, SCSI patches exists on top of these in James'
tree.
- A few random fixes.
* 'for-3.10/core' of git://git.kernel.dk/linux-block: (40 commits)
relay: move remove_buf_file inside relay_close_buf
partitions/efi.c: replace useless kzalloc's by kmalloc's
fs/block_dev.c: fix iov_shorten() criteria in blkdev_aio_read()
block: fix max discard sectors limit
blkcg: fix "scheduling while atomic" in blk_queue_bypass_start
Documentation: cfq-iosched: update documentation help for cfq tunables
writeback: expose the bdi_wq workqueue
writeback: replace custom worker pool implementation with unbound workqueue
writeback: remove unused bdi_pending_list
aoe: Fix unitialized var usage
bio-integrity: Add explicit field for owner of bip_buf
block: Add an explicit bio flag for bios that own their bvec
block: Add bio_alloc_pages()
block: Convert some code to bio_for_each_segment_all()
block: Add bio_for_each_segment_all()
bounce: Refactor __blk_queue_bounce to not use bi_io_vec
raid1: use bio_copy_data()
pktcdvd: Use bio_reset() in disabled code to kill bi_idx usage
pktcdvd: use bio_copy_data()
block: Add bio_copy_data()
More prep work for immutable bvecs/effecient bio splitting - usage of
bi_vcnt has to be auditing, so getting rid of all the unnecessary usage
makes that easier.
Plus, bio_segments() is really what this code wanted, as it respects the
current value of bi_idx.
Signed-off-by: Kent Overstreet <koverstreet@google.com>
CC: Jens Axboe <axboe@kernel.dk>
CC: Eric Moore <Eric.Moore@lsi.com>
CC: "James E.J. Bottomley" <JBottomley@parallels.com>
CC: linux-scsi@vger.kernel.org
CONFIG_HOTPLUG is going away as an option. As a result, the __dev*
markings need to be removed.
This change removes the use of __devinit, __devexit_p, __devinitdata,
and __devexit from these drivers.
Based on patches originally written by Bill Pemberton, but redone by me
in order to handle some of the coding style issues better, by hand.
Cc: Bill Pemberton <wfp5p@virginia.edu>
Signed-off-by: Chandrakala Chavva <cchavva@caviumnetworks.com>
Signed-off-by: David Daney <david.daney@cavium.com>
Acked-by: "Nandigama, Nagalakshmi" <Nagalakshmi.Nandigama@lsi.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
[Resend patch as per Bernd Schubert comment ]
Issue:
Device goes offline while doing aggressive HBA reset
along with IO using some utility.
Root cause:
FW goes into bad state due to aggressive reset. Softreset does not
help to recover FW. And also aggressive reset open up the window for
Error handling thread to kicked off at the same time HBA will be in
constant RESET loop as part of aggressive reset test case can lead
Device to goes offline.
Changes:
1. Added extra check as below inside eh_timed_out call back as below.
if(ioc->ioc_reset_in_progress) Rc = EH_TIMER_RESET
2. Removed " DOORBELL_ACTIVE" check for SAS controller from task
management context. Since SAS controller uses high priority queue
for task management. This check is not required for SAS controller.
3. Moved SoftReset call to HardReset from Task Mgmt context.
Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com>
Driver will now schedule MPI event using "delay_work_queue_on" to
specify same CPU to be used to schedule work. Earlier it used
"delay_work_queue" which can cause migration of work due to kernel'
timer migration feature.
Find Non-Operation IOC and remove it from OS: Detecting
dead(non-functional) ioc will be done reading doorbell register value
from fault reset thread, which has been called from work thread
context after each specific interval. If doorbell value is 0xFFFFFFFF,
it will be considered as IOC is non-operational and marked as dead
ioc.
Once Dead IOC has been detected, it will be removed at pci layer using
"pci_remove_bus_device" API.
The max_sector setting is currently hard-coded in the driver to 8192
sectors (4MB transfers). Using new module parameter, if max_sectors is
specified at load time, the default of 8192 will be overridden.
Shut up
drivers/message/fusion/mptsas.c: In function 'mptsas_event_process':
drivers/message/fusion/mptsas.c:5015: warning: unused variable 'log_info'
for configs with CONFIG_SCSI_MPT2SAS_LOGGING unset.
Signed-off-by: Borislav Petkov <borislav.petkov@amd.com>
Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com>
Signed-off-by: James Bottomley <jbottomley@parallels.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
Bus reset is not required for SAS Controller. It is valid for mptspi
and mptfc, but for mptsas it is not required. It is an extra work for
Error handling escallation for mptsas. Removing bus reset from error
handling will eventually speedup Error handling for SAS controller.
SAS1.0 Controller was not able to detect SAS2.0 Expanders due to Link
RATE detection was limited to 1.5 Gbps and 3.0 Gbps for SAS1
controllers. Added detection for 6.0 Gbps link. Now, user can mix-up
6.0 Gpbs links with SAS1.0 controller.
e.g SAS1.0 HBA <----> SAS2.0 Expander <------> SAS2.0 Expander <--------> SAS1.0 Drive.
MAINTAINERS
arch/arm/mach-omap2/pm24xx.c
drivers/scsi/bfa/bfa_fcpim.c
Needed to update to apply fixes for which the old branch was too
outdated.
Move the mid-layer's ->queuecommand() invocation from being locked
with the host lock to being unlocked to facilitate speeding up the
critical path for drivers who don't need this lock taken anyway.
The patch below presents a simple SCSI host lock push-down as an
equivalent transformation. No locking or other behavior should change
with this patch. All existing bugs and locking orders are preserved.
Additionally, add one parameter to queuecommand,
struct Scsi_Host *
and remove one parameter from queuecommand,
void (*done)(struct scsi_cmnd *)
Scsi_Host* is a convenient pointer that most host drivers need anyway,
and 'done' is redundant to struct scsi_cmnd->scsi_done.
Minimal code disturbance was attempted with this change. Most drivers
needed only two one-line modifications for their host lock push-down.
Acked-by: James Bottomley <James.Bottomley@suse.de>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
error handling
Adding function name in original debug prints and few more debug prints are
added.
Cc: Stable Tree <stable@kernel.org>
Issue description:
In multipath topology, when device deletion is in transient state,
multipath driver can call blk_flush_queue() as part of path failure.
Before device get deleted from OS, Device may go OFFLINE as part of error
handling kicked off triggered from multipathing driver. Above condition hits
more frequently if device missing delay timer (which is LSI specific firmware
parameter) is non zero value.
root cause of this issue is Error handling thread is getting kicked off for
device which is not really present(in transient state of deleting).
This patch has solution for this issue. driver is now using eh_timed_out
callback. See below.
mptsas_transport_template->eh_timed_out = mptsas_eh_timed_out
Using mptsas_eh_timed_out function, driver can decide weather vdevice is
under Device missing delay or deleting state.
for either of those cases, there is BLK_EH_RESET_TIMER return to scsi mid
and error handling thread will not be kicked off for that particular scsi
command.
Printing Doorbell register in a case of hard reset and timeout
should be useful for figuring out the state of the system.
Signed-off-by: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com>
This patch fixes mptsas disk hot-removal processing. The
hot-removal processing doesn't complete because of this condition.
if ((mptsas_find_vtarget(ioc, channel, id)) && !ioc->fw_events_off)
mptsas_queue_device_delete(...);
mptsas_queue_device_delete(), which must be called for
hot-removal, never gets called because mptsas_find_vtarget()
always returns 0 here. At that time, the vtarget has already
been freed in mptsas_target_destroy(), and also the scsi_device
has been marked as SDEV_DEL.
As a result of the issue, port deletion functions won't get
called and the device ends up being in an incomplete state.
(Some data structures and sysfs entries, which should be
removed in hot-removal, remain.) One side effect of this is
that a hot-addition of the device (bringing the device back
on) fails.
This patch just removes mptsas_find_vtarget() from the if-state
condition.
Issue: SATA hotplug does not work sometimes.
At the time of ADD device/ADD phys disk, drive may fail to add SATA device
due to temporary SAS Address for SATA device generated by firmware. Final
SAS address for SATA driver will be generated only after disk spinup is
done. This may take some times for slow spining SATA drives.
At phy link up driver gets attached device sas address and stores into
phyinfo. At the time of ADD event driver will read sas device page0 using
channel and FW ID provided in ADD Device event. Here in case of SATA drives,
driver will see miss match in phyinfo->sas_address and latest sas address
read from SAS DEVICE PAGE0 and eventually device won't be added to OS.
Fix:
When Driver read SAS DEVICE PAGE0, it can identify Device type looking at
device_info. If device is SATA drive and sas address mismatch happens,
Driver will do same stuffs which happened at the time of LINK UP to get
correct piece of information from Pages. ( Find parent device and refresh
parent device phys either HBA refresh/Exp refresh)
Issue:
target reset will be queued to driver's internal queue to get schedule
later. When driver add target into internal target_reset queue we will block IOs
on those target using scsi midlayer API. Now due to some cause driver is not
executing those target_reset list and it is always in block state.
Changes:
now we are clearing target_reset queue from all other Callback context
instead of only DeviceReset context.Now wherever driver is clearing
taskmgmt_in_progress flag it is considering target_reset queue cleanup
also.
to OS
Added sanity check before treating any device is a valid device.
It is possible that firmware can have device page0 in its table, but that
devicemay not be available in topology. Device will be available in topology
only if there is Bus Target mapping is done in firmware. Driver will always
check B_T mapping of firmware before reporting device to upper layer.
device missing delay is 8 bit value in io unit pg1. Making correct variable
declaration for device_missing_delay.
The driver is storing the calculated device missing delay in IOC structure
as a u8 instead of a u16. It needs to be a u16 if the delay is > 255.
Added proper error handling after mpt_config.
Now check of MPI_IOCSTATUS_CONFIG_INVALID_PAGE is added.
If error is MPI_IOCSTATUS_CONFIG_INVALID_PAGE, driver will return -ENODEV.
1) Corrected name string as "MPT SAS HOST"
2) Added proper check conditions for MPT_MGMT_STATUS_COMMAND_GOOD.
Added proper bus_type check before processing event/ reset handler.
Current design of mptsas is as follow.
MPTSAS will do probe() if pci id matches for available card in
system, irrespective of mode of controller. If controller is I/T mode
or I mode, things are fine. If controller is only in T mode, mptsas is
not doing complete process of mptsas_probe(). It will only make
sure IOC structure is created and IOC reference is available for
mptstm driver. Now While removing module we should take care
case of Target mode only mptsas. If we are removing IOC which is
only in Target mode, We should only detach IOC instead of
following rest of the cleanup process which is only required for T
mode controller. Now For T mode controller, only part clean up is
done instead of complete cleanup. mpt_detach will call early in case
of Target mode only controller.
Message Unit Reset - instructs the IOC to reset the Reply Post and
Free FIFO's. All the Message Frames on Reply Free FIFO are
discarded. All posted buffers are freed, and event notification is
turned off. IOC doesnt reply to any outstanding request. This will
transfer IOC to READY state. Message unit ready is less expensive
operations than Hard Reset. soft reset will not force Firmware to
reload again, it only do clean up of Message units.
mpt_Soft_Hard_ResetHandler will first try for Soft Reset,if
it fails then go for big hammer reset which is Hard Reset.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Add support to set the sdev state to SDEV_BLOCK during device removal
to stop IOs comming to the deleting driver immediately.
of expander add.
Added new function mptsas_exp_manufacture_info, which will
obtain the REPORT_MANUFACTURING, and fill the details into the
sas_expander_device object when the expander port is created.
CACHE command
Normally In HBA reset path MPT driver will flush existing work in current work
queue (mpt/0) . This is just a dummy activity for MPT driver point of
view, since HBA reset will turn off Work queue events.
It means we will simply returns from work queue without doing anything.
But for the case where Work is already done (half the way), we have to have
that work to be done.
Considering above condition we stuck forever since Deadlock in scsi midlayer
and MPT driver. sd_sync_cache() will wait forever since HBA is not in
Running state, and it will never come into Running state since
sd_sync_cache() is called from HBA reset context.
Now new code will not wait for half cooked work to be finished
before returning from HBA reset.
Once we are out of HBA reset, EH thread will change host state to running from
recovery and work waiting for running state of HBA will be finished.
New code is turning ON firmware event from another special work called
Rescan toplogy.
tear off
On Big endian system kernel will crash due to address translation
is not handle properly.
Check for phyinfo->phy before calling sas_port_delete_phy.
Do not set max_id value received from FW. Once SAS transport layer is
introduced max_id value is missleading to SCSI mid layer. Use max_id to
infinite value.
logic of can queue of scsi host is changed.
Change config request timeout value to 30 seconds.
Removed mptscsih_timer_expired. This timer is no more use.
Change DEFINED value of can queue for FC and SAS devices.
