Pull SCSI updates from James Bottomley:
"This consists of the usual driver updates (ufs, qla2xxx, smartpqi,
target, zfcp, fnic, mpt3sas, ibmvfc) plus a load of cleanups, a major
power management rework and a load of assorted minor updates.
There are a few core updates (formatting fixes being the big one) but
nothing major this cycle"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (279 commits)
scsi: mpt3sas: Update driver version to 36.100.00.00
scsi: mpt3sas: Handle trigger page after firmware update
scsi: mpt3sas: Add persistent MPI trigger page
scsi: mpt3sas: Add persistent SCSI sense trigger page
scsi: mpt3sas: Add persistent Event trigger page
scsi: mpt3sas: Add persistent Master trigger page
scsi: mpt3sas: Add persistent trigger pages support
scsi: mpt3sas: Sync time periodically between driver and firmware
scsi: qla2xxx: Update version to 10.02.00.104-k
scsi: qla2xxx: Fix device loss on 4G and older HBAs
scsi: qla2xxx: If fcport is undergoing deletion complete I/O with retry
scsi: qla2xxx: Fix the call trace for flush workqueue
scsi: qla2xxx: Fix flash update in 28XX adapters on big endian machines
scsi: qla2xxx: Handle aborts correctly for port undergoing deletion
scsi: qla2xxx: Fix N2N and NVMe connect retry failure
scsi: qla2xxx: Fix FW initialization error on big endian machines
scsi: qla2xxx: Fix crash during driver load on big endian machines
scsi: qla2xxx: Fix compilation issue in PPC systems
scsi: qla2xxx: Don't check for fw_started while posting NVMe command
scsi: qla2xxx: Tear down session if FW say it is down
in_interrupt() is referenced all over the place in these drivers. Most of
these references are comments which are outdated and wrong.
Aside of that in_interrupt() is deprecated as it does not provide what the
name suggests. It covers more than hard/soft interrupt servicing context
and is semantically ill defined.
>From reading the mpt_config() code and the history this is clearly a debug
mechanism and should probably be replaced by might_sleep() or completely
removed because such checks are already in the subsequent functions.
Remove the in_interrupt() references and replace the usage in mpt_config()
with might_sleep().
Link: https://lore.kernel.org/r/20201126132952.2287996-14-bigeasy@linutronix.de
Cc: Sathya Prakash <sathya.prakash@broadcom.com>
Cc: Sreekanth Reddy <sreekanth.reddy@broadcom.com>
Cc: Suganath Prabu Subramani <suganath-prabu.subramani@broadcom.com>
Cc: MPT-FusionLinux.pdl@broadcom.com
Reviewed-by: Daniel Wagner <dwagner@suse.de>
Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de>
The mptscsih_remove() function triggers a kernel oops if the Scsi_Host
pointer (ioc->sh) is NULL, as can be seen in this syslog:
ioc0: LSI53C1030 B2: Capabilities={Initiator,Target}
Begin: Waiting for root file system ...
scsi host2: error handler thread failed to spawn, error = -4
mptspi: ioc0: WARNING - Unable to register controller with SCSI subsystem
Backtrace:
[<000000001045b7cc>] mptspi_probe+0x248/0x3d0 [mptspi]
[<0000000040946470>] pci_device_probe+0x1ac/0x2d8
[<0000000040add668>] really_probe+0x1bc/0x988
[<0000000040ade704>] driver_probe_device+0x160/0x218
[<0000000040adee24>] device_driver_attach+0x160/0x188
[<0000000040adef90>] __driver_attach+0x144/0x320
[<0000000040ad7c78>] bus_for_each_dev+0xd4/0x158
[<0000000040adc138>] driver_attach+0x4c/0x80
[<0000000040adb3ec>] bus_add_driver+0x3e0/0x498
[<0000000040ae0130>] driver_register+0xf4/0x298
[<00000000409450c4>] __pci_register_driver+0x78/0xa8
[<000000000007d248>] mptspi_init+0x18c/0x1c4 [mptspi]
This patch adds the necessary NULL-pointer checks. Successfully tested on
a HP C8000 parisc workstation with buggy SCSI drives.
Link: https://lore.kernel.org/r/20201022090005.GA9000@ls3530.fritz.box
Cc: <stable@vger.kernel.org>
Signed-off-by: Helge Deller <deller@gmx.de>
"The usual driver updates (ufs, qla2xxx, tcmu, ibmvfc, lpfc, smartpqi,
hisi_sas, qedi, qedf, mpt3sas) and minor bug fixes.
There are only three core changes: adding sense codes, cleaning up
noretry and adding an option for limitless retries"
* tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: (226 commits)
scsi: hisi_sas: Recover PHY state according to the status before reset
scsi: hisi_sas: Filter out new PHY up events during suspend
scsi: hisi_sas: Add device link between SCSI devices and hisi_hba
scsi: hisi_sas: Add check for methods _PS0 and _PR0
scsi: hisi_sas: Add controller runtime PM support for v3 hw
scsi: hisi_sas: Switch to new framework to support suspend and resume
scsi: hisi_sas: Use hisi_hba->cq_nvecs for calling calling synchronize_irq()
scsi: qedf: Remove redundant assignment to variable 'rc'
scsi: lpfc: Remove unneeded variable 'status' in lpfc_fcp_cpu_map_store()
scsi: snic: Convert to use DEFINE_SEQ_ATTRIBUTE macro
scsi: qla4xxx: Delete unneeded variable 'status' in qla4xxx_process_ddb_changed
scsi: sun_esp: Use module_platform_driver to simplify the code
scsi: sun3x_esp: Use module_platform_driver to simplify the code
scsi: sni_53c710: Use module_platform_driver to simplify the code
scsi: qlogicpti: Use module_platform_driver to simplify the code
scsi: mac_esp: Use module_platform_driver to simplify the code
scsi: jazz_esp: Use module_platform_driver to simplify the code
scsi: mvumi: Fix error return in mvumi_io_attach()
scsi: lpfc: Drop nodelist reference on error in lpfc_gen_req()
scsi: be2iscsi: Fix a theoretical leak in beiscsi_create_eqs()
This addresses the following gcc warning with "make W=1":
drivers/message/fusion/mptscsih.c: In function ‘mptscsih_IssueTaskMgmt’:
drivers/message/fusion/mptscsih.c:1519:17: warning: variable ‘timeleft’
set but not used [-Wunused-but-set-variable]
1519 | unsigned long timeleft;
Link: https://lore.kernel.org/r/20200827125925.428357-1-yanaijie@huawei.com
Signed-off-by: Jason Yan <yanaijie@huawei.com>
Replace the existing /* fall through */ comments and its variants with
the new pseudo-keyword macro fallthrough[1]. Also, remove unnecessary
fall-through markings when it is the case.
[1] https://www.kernel.org/doc/html/v5.7/process/deprecated.html?highlight=fallthrough#implicit-switch-case-fall-through
Signed-off-by: Gustavo A. R. Silva <gustavoars@kernel.org>
The sense data buffer in sense_buf_pool is allocated with size of
MPT_SENSE_BUFFER_ALLOC(64) (multiplied by req_depth) while SNS_LEN(sc)(96)
is used when reading the data. That may lead to a read from unallocated
area, sometimes from another (unallocated) page. To fix this, limit the
read size to MPT_SENSE_BUFFER_ALLOC.
Link: https://lore.kernel.org/r/20200616150446.4840-1-thenzl@redhat.com
Co-developed-by: Stanislav Saner <ssaner@redhat.com>
Signed-off-by: Stanislav Saner <ssaner@redhat.com>
Signed-off-by: Tomas Henzl <thenzl@redhat.com>
In preparation to enabling -Wimplicit-fallthrough, mark switch cases
where we are expecting to fall through.
This patch fixes the following warnings:
drivers/message/fusion/mptscsih.c: In function mptscsih_io_done :
drivers/message/fusion/mptscsih.c:741:7: warning: this statement may fall through [-Wimplicit-fallthrough=]
if ( ioc->bus_type == SAS ) {
drivers/message/fusion/mptscsih.c:790:3: note: here
case MPI_IOCSTATUS_SCSI_TASK_TERMINATED: /* 0x0048 */
drivers/message/fusion/mptscsih.c:884:4: warning: this statement may fall through [-Wimplicit-fallthrough=]
scsi_set_resid(sc, 0);
drivers/message/fusion/mptscsih.c:885:3: note: here
case MPI_IOCSTATUS_SCSI_RECOVERED_ERROR: /* 0x0040 */
Warning level 3 was used: -Wimplicit-fallthrough=3
This patch is part of the ongoing efforts to enable
-Wimplicit-fallthrough.
Signed-off-by: Gustavo A. R. Silva <gustavo@embeddedor.com>
There are several statements and code blocks there are incorrectly
indented. Fix these.
Commit c5ce0abeb628 ("scsi: sas: move scsi_remove_host call...") moved
the call to scsi_remove_host() into sas_remove_host(), but forgot to
modify the mpt drivers.
Fixes: c5ce0abeb628 ("scsi: sas: move scsi_remove_host call into sas_remove_host")
Signed-off-by: Hannes Reinecke <hare@suse.com>
Having an I/O priority does not mean we should send all requests as HEAD
OF QUEUE tags.
Reported-by: Adam Manzanares <adam.manzanares@wdc.com>
Reviewed-by: Hannes Reinicke <hare@suse.de>
Drop the now unused reason argument from the ->change_queue_depth method.
Also add a return value to scsi_adjust_queue_depth, and rename it to
scsi_change_queue_depth now that it can be used as the default
->change_queue_depth implementation.
Reviewed-by: Mike Christie <michaelc@cs.wisc.edu>
Reviewed-by: Hannes Reinecke <hare@suse.de>
Remove the tagged argument from scsi_adjust_queue_depth, and just let it
handle the queue depth. For most drivers those two are fairly separate,
given that most modern drivers don't care about the SCSI "tagged" status
of a command at all, and many old drivers allow queuing of multiple
untagged commands in the driver.
Instead we start out with the ->simple_tags flag set before calling
->slave_configure, which is how all drivers actually looking at
->simple_tags except for one worke anyway. The one other case looks
broken, but I've kept the behavior as-is for now.
Except for that we only change ->simple_tags from the ->change_queue_type,
and when rejecting a tag message in a single driver, so keeping this
churn out of scsi_adjust_queue_depth is a clear win.
Now that the usage of scsi_adjust_queue_depth is more obvious we can
also remove all the trivial instances in ->slave_alloc or ->slave_configure
that just set it to the cmd_per_lun default.
Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com>
This function shouldn't change the queue type, just the depth.
Remove the ordered_tags field, we haven't been issuing ordered tags based
on it since the big barrier rework in 2010.
Reviewed-by: Bart Van Assche <bvanassche@acm.org>
Fixes the following smatch warnings:
drivers/message/fusion/mptbase.c:652 mptbase_reply() warn: variable
dereferenced before check 'reply' (see line 639)
[JL: No-brainer, the enclosing switch statement dereferences
reply, so we can't get here unless reply is valid.]
drivers/message/fusion/mptsas.c:1255 mptsas_taskmgmt_complete() error:
we previously assumed 'pScsiTmReply' could be null (see line 1227)
[HCH: Reading the code in mptsas_taskmgmt_complete it's pretty
obvious that it can't do anything useful if mr/pScsiTmReply are
NULL, so I suspect it would be best to just return at the
beginning of the function.
I'd love to understand if it actually could ever be zero, which I
doubt. Maybe the LSI people can shed some light on that?]
drivers/message/fusion/mptsas.c:3888 mptsas_not_responding_devices()
error: we previously assumed 'port_info->phy_info' could be null
(see line 3875)
[HCH: It's pretty obvious from reading mptsas_sas_io_unit_pg0 that
we never register a port_info with a NULL phy_info in the lists,
so all NULL checks on it could be deleted.]
drivers/message/fusion/mptscsih.c:1284 mptscsih_info() error:
we previously assumed 'h' could be null (see line 1274)
[HCH: shost_priv can't return NULL, so the if (h) should be
removed.]
drivers/message/fusion/mptscsih.c:1388 mptscsih_qcmd() error: we
previously assumed 'vdevice' could be null (see line 1373)
[HCH: vdevice can't ever be NULL here, it's allocated in
->slave_alloc and thus guaranteed to be around when
->queuecommand is called.]
Signed-off-by: Joe Lawrence <joe.lawrence@stratus.com>
Acked-by: Sreekanth Reddy <Sreekanth.Reddy@avagotech.com>
The SCSI standard defines 64-bit values for LUNs, and large arrays
employing large or hierarchical LUN numbers become more and more
common.
So update the linux SCSI stack to use 64-bit LUN numbers.
Signed-off-by: Hannes Reinecke <hare@suse.de>
Reviewed-by: Christoph Hellwig <hch@infradead.org>
Reviewed-by: Ewan Milne <emilne@redhat.com>
Removing the host_lock from the I/O submission path gives a huge
scalability improvement.
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
Reviewed-by: Nicholas Bellinger <nab@linux-iscsi.org>
Reviewed-by: Praveen Krishnamoorthy <Praveen.krishnamoorthy@lsi.com>
Acked-by: Sreekanth Reddy <Sreekanth.reddy@lsi.com>
This happens to do the right thing in all cases on fibre channel but not on
other media types
Signed-off-by: Alan Cox <alan@linux.intel.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
Cc: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com>
Cc: Kashyap Desai <kashyap.desai@lsi.com>
ERRATA
When READ_16 command is issued, the setting of SILI Bit in CDB is confirmed
and if SILI bit is off, the processing of relavent Errata is executed.
Added code for checking SILI bit for READ_16 as described in "SSC-4".
Signed-off-by: Nagalakshmi Nandigama <nagalakshmi.nandigama@lsi.com>
Signed-off-by: James Bottomley <JBottomley@Parallels.com>
[Resend patch as per Bernd Schubert comment ]
Issue:
Device goes offline while doing aggressive HBA reset
along with IO using some utility.
Root cause:
FW goes into bad state due to aggressive reset. Softreset does not
help to recover FW. And also aggressive reset open up the window for
Error handling thread to kicked off at the same time HBA will be in
constant RESET loop as part of aggressive reset test case can lead
Device to goes offline.
Changes:
1. Added extra check as below inside eh_timed_out call back as below.
if(ioc->ioc_reset_in_progress) Rc = EH_TIMER_RESET
2. Removed " DOORBELL_ACTIVE" check for SAS controller from task
management context. Since SAS controller uses high priority queue
for task management. This check is not required for SAS controller.
3. Moved SoftReset call to HardReset from Task Mgmt context.
Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com>
Find Non-Operation IOC and remove it from OS: Detecting
dead(non-functional) ioc will be done reading doorbell register value
from fault reset thread, which has been called from work thread
context after each specific interval. If doorbell value is 0xFFFFFFFF,
it will be considered as IOC is non-operational and marked as dead
ioc.
Once Dead IOC has been detected, it will be removed at pci layer using
"pci_remove_bus_device" API.
ERRATA
When READ_6 command is issued, the setting of SILI Bit in CDB is confirmed and
Earlier we did not have check for SILI bit in READ_6 CDB.
As described in "ssc-r22", Now Driver is checking SILI bit for READ_6.
Remove debug print from mptscsih_qcmd function call.
This debug print cause flood of prints and difficult to debug other issues.
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
The SCSI midlayer stops all command processing when in error handling, which
means there is no chance for command reuse when the abort handler is called.
There's a branch at the end of this function that
is supposed to normalize the return value with what
the mid-layer expects. In this one case, we get it wrong.
Also increase the verbosity of the INFO level printk
at the end of mptscsih_abort to include the actual return value
and the scmd->serial_number. The reason being success
or failure is actually determined by the state of
the internal tag list when a TMF is issued, and not the
return value of the TMF cmd. The serial_number is also
used in this decision, thus it's useful to know for debugging
purposes.
Cc: stable@kernel.org
Reported-by: Peter M. Petrakis <peter.petrakis@canonical.com>
Issue description:
In multipath topology, when device deletion is in transient state,
multipath driver can call blk_flush_queue() as part of path failure.
Before device get deleted from OS, Device may go OFFLINE as part of error
handling kicked off triggered from multipathing driver. Above condition hits
more frequently if device missing delay timer (which is LSI specific firmware
parameter) is non zero value.
root cause of this issue is Error handling thread is getting kicked off for
device which is not really present(in transient state of deleting).
This patch has solution for this issue. driver is now using eh_timed_out
callback. See below.
mptsas_transport_template->eh_timed_out = mptsas_eh_timed_out
Using mptsas_eh_timed_out function, driver can decide weather vdevice is
under Device missing delay or deleting state.
for either of those cases, there is BLK_EH_RESET_TIMER return to scsi mid
and error handling thread will not be kicked off for that particular scsi
command.
Cc: Stable Tree <stable@kernel.org>
Printing Doorbell register in a case of hard reset and timeout
should be useful for figuring out the state of the system.
Signed-off-by: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com>
Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com>
Issue:
target reset will be queued to driver's internal queue to get schedule
later. When driver add target into internal target_reset queue we will block IOs
on those target using scsi midlayer API. Now due to some cause driver is not
executing those target_reset list and it is always in block state.
Changes:
now we are clearing target_reset queue from all other Callback context
instead of only DeviceReset context.Now wherever driver is clearing
taskmgmt_in_progress flag it is considering target_reset queue cleanup
also.
Changed the return value for Nexus Loss IOs to be DID_TRANSPORT_DISRUPTED.
What this will allow is the multi-path driver to delay the fail over
process. They would like the path to keep up as long as the nexus loss
Loginfo is return from firmware. With DID_BUS_BUSY the path fails over
immediately.
I may have an explanation for the LSI 1068 HBA hangs provoked by ATA
pass-through commands, in particular by smartctl.
First, my version of the symptoms. On an LSI SAS1068E B3 HBA running
01.29.00.00 firmware, with SATA disks, and with smartd running, I'm seeing
occasional task, bus, and host resets, some of which lead to hard faults of
the HBA requiring a reboot. Abusively looping the smartctl command,
# while true; do smartctl -a /dev/sdb > /dev/null; done
dramatically increases the frequency of these failures to nearly one per
minute. A high IO load through the HBA while looping smartctl seems to
improve the chance of a full scsi host reset or a non-recoverable hang.
I reduced what smartctl was doing down to a simple test case which
causes the hang with a single IO when pointed at the sd interface. See
the code at the bottom of this e-mail. It uses an SG_IO ioctl to issue
a single pass-through ATA identify device command. If the buffer
userspace gives for the read data has certain alignments, the task is
issued to the HBA but the HBA fails to respond. If run against the sg
interface, neither the test code nor smartctl causes a hang.
sd and sg handle the SG_IO ioctl slightly differently. Unless you
specifically set a flag to do direct IO, sg passes a buffer of its own,
which is page-aligned, to the block layer and later copies the result
into the userspace buffer regardless of its alignment. sd, on the other
hand, always does direct IO unless the userspace buffer fails an
alignment test at block/blk-map.c line 57, in which case a page-aligned
buffer is created and used for the transfer.
The alignment test currently checks for word-alignment, the default
setup by scsi_lib.c; therefore, userspace buffers of almost any
alignment are given directly to the HBA as DMA targets. The LSI 1068
hardware doesn't seem to like at least a couple of the alignments which
cross a page boundary (see the test code below). Curiously, many
page-boundary-crossing alignments do work just fine.
So, either the hardware has an bug handling certain alignments or the
hardware has a stricter alignment requirement than the driver is
advertising. If stricter alignment is required, then in no case should
misaligned buffers from userspace be allowed through without being
bounced or at least causing an error to be returned.
It seems the mptsas driver could use blk_queue_dma_alignment() to advertise
a stricter alignment requirement. If it does, sd does the right thing and
bounces misaligned buffers (see block/blk-map.c line 57). The following
patch to 2.6.34-rc5 makes my symptoms go away. I'm sure this is the wrong
place for this code, but it gets my idea across.
The function name must be followed by a space, hypen, space, and a
short description.
Cc: Eric Moore <Eric.Moore@lsi.com>
1) corrected return value as SUCCESS instead of 0.
2) Added check in mptscsih_abort.
mptfusion do not support task abort for Volumes.
Added sanity checks before accessing vdevice and added vdevice->deleted
setting for mptfc.
Current design of mptsas is as follow.
MPTSAS will do probe() if pci id matches for available card in
system, irrespective of mode of controller. If controller is I/T mode
or I mode, things are fine. If controller is only in T mode, mptsas is
not doing complete process of mptsas_probe(). It will only make
sure IOC structure is created and IOC reference is available for
mptstm driver. Now While removing module we should take care
case of Target mode only mptsas. If we are removing IOC which is
only in Target mode, We should only detach IOC instead of
following rest of the cleanup process which is only required for T
mode controller. Now For T mode controller, only part clean up is
done instead of complete cleanup. mpt_detach will call early in case
of Target mode only controller.
Message Unit Reset - instructs the IOC to reset the Reply Post and
Free FIFO's. All the Message Frames on Reply Free FIFO are
discarded. All posted buffers are freed, and event notification is
turned off. IOC doesnt reply to any outstanding request. This will
transfer IOC to READY state. Message unit ready is less expensive
operations than Hard Reset. soft reset will not force Firmware to
reload again, it only do clean up of Message units.
mpt_Soft_Hard_ResetHandler will first try for Soft Reset,if
it fails then go for big hammer reset which is Hard Reset.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (158 commits)
[SCSI] Fix printing of failed 32-byte commands
[SCSI] Fix printing of variable length commands
[SCSI] libsrp: fix bug in ADDITIONAL CDB LENGTH interpretation
[SCSI] scsi_dh_alua: Add IBM Power Virtual SCSI ALUA device to dev list
[SCSI] scsi_dh_alua: add netapp to dev list
[SCSI] qla2xxx: Update version number to 8.03.02-k1.
[SCSI] qla2xxx: EEH: Restore PCI saved state during pci slot reset.
[SCSI] qla2xxx: Add firmware ETS burst support.
[SCSI] qla2xxx: Correct loop-resync issues during SNS scans.
[SCSI] qla2xxx: Correct use-after-free issue in terminate_rport_io callback.
[SCSI] qla2xxx: Correct EH bus-reset handling.
[SCSI] qla2xxx: Proper clean-up of BSG requests when request times out.
[SCSI] qla2xxx: Initialize payload receive length in failure path of vendor commands
[SCSI] fix duplicate removal on error path in scsi_sysfs_add_sdev
[SCSI] fix refcounting bug in scsi_get_host_dev
[SCSI] fix memory leak in scsi_report_lun_scan
[SCSI] lpfc: correct PPC build failure
[SCSI] raid_class: add raid1e
[SCSI] mpt2sas: Do not call sas_is_tlr_enabled for RAID volumes.
[SCSI] zfcp: Introduce header file for qdio structs and inline functions
value 0.
retval should be SUCCESS/FAILED which is defined at scsi.h
retval = 0 is directing wrong return value. It must be retval = SUCCESS.
There is a 'ioprio' field in the BIO and the Request structure.
check this priority field and set MPI_SCSIIO_CONTROL_HEADOFQ
to pass down I/O priority.
An enhancement to the LSI Disk Array Controller firmware is being
developed to look at the Head Of Queue bit to allow I/Os with the HOQ bit
set to be processed before I/Os which do not have the HOQ bit set.
In order to set the HOQ bit, the mpt fusion driver needs to look at the
'ioprio' field in the request structure associated with the scsi command.
This patch modifies scsi_host_template->change_queue_depth so that
it takes an argument indicating why it is being called. This will be
used so that if a LLD needs to do some extra processing when
handling queue fulls or later ramp ups, it can do so.
This is a simple port of the drivers setting a change_queue_depth
callback. In the patch I just have these LLDs adjust the queue depth
if the user was requesting it.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
[Vasu.Dev: v2
Also converted pmcraid_change_queue_depth and then verified
all modules compile using "make allmodconfig" for any new build
warnings on X86_64.
Updated original description after combing two original
patches from Mike to make this patch git bisectable.]
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
[jejb: fixed up 53c700]
Errata:
Certain conditions on the scsi bus may casue the 53C1030 to incorrectly signal
a SCSI_DATA_UNDERRUN to the host.
Workaround 1:
For an Errata on LSI53C1030 When the length of request data
and transfer data are different with result of command (READ or VERIFY),
DID_SOFT_ERROR is set.
Workaround 2:
For potential trouble on LSI53C1030. It is checked whether the length of
request data is equal to the length of transfer and residual.
MEDIUM_ERROR is set by incorrect data.
Driver is modified to return DID_NO_CONNECT for all pending I/O
requests for bus type SAS, if it founds the target is removed at
the firmware level.
Do not set max_id value received from FW. Once SAS transport layer is
introduced max_id value is missleading to SCSI mid layer. Use max_id to
infinite value.
logic of can queue of scsi host is changed.
status
Handle insufficient resources status as similar to busy status.
Removed mptscsih_timer_expired. This timer is no more use.
Fix recent fusion driver kernel-doc fatal error and warnings.
Cc: Eric.Moore@lsi.com
Cc: support@lsi.com
Cc: DL-MPTFusionLinux@lsi.com
Several of the doc book in the previous patches had incorrect multi-line short
function descriptors. Fixed it all to be the correct single line descriptor.
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
Firmware is able to handle Broadcast primitives, but upstream driver does not
have support for broadcast primitive handling. Now this patch is mainly to
support broadcast primitives.
Signed-off-by: Kashyap Desai <kadesai@lsi.com>
