It's big, but there doesn't seem to be a way to split it up smaller...
Signed-off-by: Tony Jones <tonyj@suse.de>
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
Cc: Roland Dreier <rolandd@cisco.com>
Cc: Sean Hefty <sean.hefty@intel.com>
Cc: Hal Rosenstock <hal.rosenstock@gmail.com>
Cc: James Bottomley <James.Bottomley@HansenPartnership.com>
the semaphore inactive_list_mutex is used as a mutex, convert it to
the mutex API
Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net>
Acked-by: "Moore, Eric" <Eric.Moore@lsi.com>
Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
The system power state changes like hibernation and standby are not happening
properly with 106XE controllers, this patch modifies the driver to free
resources and allocate resources in power management entry points
[jejb: compile fixes for upstream]
Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com>
Fix docbook problems in fusion source files.
These cause the generated docbook to be incorrect.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in
several LLDs. It's a preparation for the future changes to remove
sense_buffer array in scsi_cmnd structure.
Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
* 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-block: (63 commits)
Fix memory leak in dm-crypt
SPARC64: sg chaining support
SPARC: sg chaining support
PPC: sg chaining support
PS3: sg chaining support
IA64: sg chaining support
x86-64: enable sg chaining
x86-64: update pci-gart iommu to sg helpers
x86-64: update nommu to sg helpers
x86-64: update calgary iommu to sg helpers
swiotlb: sg chaining support
i386: enable sg chaining
i386 dma_map_sg: convert to using sg helpers
mmc: need to zero sglist on init
Panic in blk_rq_map_sg() from CCISS driver
remove sglist_len
remove blk_queue_max_phys_segments in libata
revert sg segment size ifdefs
Fixup u14-34f ENABLE_SG_CHAINING
qla1280: enable use_sg_chaining option
Fix kernel-api docbook warnings.
Warning(linux-2.6.23-git8//drivers/message/fusion/mptscsih.c:2618): No description found for parameter 'sc'
and shost_printk API
Cleaning up prints that use the xxx_printk API, in that the fusion
preamble "mptbase: iocX" follows the info provided by the print API.
The way its currently coded, the [H:C:T] print in sdev_printk will be
inbetween "mptbase" and "iocX", instead of before.
Signed-off-by: Eric Moore <Eric.Moore@lsi.com>
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
ScsiLookup is an array of pending scmd pointers that the scsi lld
maintains. This array is touched from queuecommand, eh threads, and
interrupt context. This array should put under locks, hence this patch
to synchronize its access. I've added some nice little function
wrappers for this, and moved the ScsiLookup array over to MPT_ADAPTER
struct.
The driver is currently typecasting to obtain the shost hostdata. The
driver is updated to use the shost_priv macro.
Cleaning up code by accesing the ioc pointer directly instead of via hd->ioc. In the future, most data members of struct MPT_SCSI_HOST will be either deleted or moved to struct MPT_ADAPTER.
common naming of vdevice through out driver
Standardize all prints using common MYIOC_s_XXX_FMT macro defined in mptbase.h. Currently the driver uses several different methods to display info, where in some cases the "controller name" generating the printk is not provided.
Recently LSI Logic Corp was renamed as LSI Corp, so whereever there is
a reference of LSI Logic, it is changed to LSI in mpt fusion driver
code.
signed-off-by: Sathya Prakash <sathya.prakash@lsi.com>
Acked-by: Eric Moore <Eric.Moore@lsi.com>
management commands
Added support for sending the task management requests through High priority
request FIFO instead of Doorbell writes when firmware support High priority
FIFO.
This patch contains changes in mptscsih.c to support logging in MPT fusion
drivers.
The changes are majorly in debug printks, the existing debugprintk are
modified accroding to new debug macros defined in the file mptbdebug.h
A new sysfs attribute is added to retrieve and modify the debug level.
New sysfs scsi_host attributes are added to provide information about Firmware
version, BIOS version, MPI version and other product related information
signed-off-by: Sathya Praksh <sathya.prakash@lsi.com>
If there is IO going to the volume while a hidden disk is being torn down,
there is a case where we would return a DID_NO_CONNECT for IO sent to the
volume. The end result is the volume goes read-only. This problem is due to the
fact the firmware mapped target ids saved in per device object is phys_disk_num
for hidden raid components, and target_id for the volume. There is a single
case when both phys_disk_num and target_id are equal, so enters this issue. We
fix this issue by checking the tflags when the device is torned down,
insuring the IO being completed is meant for hidden raid component, not the
volume. In addition to this fix, there are a couple other cases to address
hidden raid components. For instance task_abort and device reset are not
supported by mpt fw for hidden raid components, a bus reset would be required
or target reset to volume.
nice cosmetic cleaning of eh thread callback funtions
remove unused header
Update assocated fusion sources with new support email address.
drivers/scsi/jazz_esp.c
Same changes made by both SCSI and SPARC trees: problem with UTF-8
conversion in the copyright.
- remove the unnecessary map_single path.
- convert to use the new accessors for the sg lists and the
parameters.
TODO: use scsi_for_each_sg().
Acked-by: Eric Moore <eric.moore@lsi.com>
There are several cases where the fusion driver uses the logical || to
try to do an arithmetical or ... fix by replacing with |.
Signed-off-by: Dave Jones <davej@redhat.com>
This address the issue of VMWare guest OS being remounted as read-only
becuase the underlying device was held busy too long and at the
same time address Engenio MPP driver concerns over infinite retries.
This patch removes the code that snoops the SAM STATUS on busy, which
would be returning DID_BUS_BUSY, instead we return the status as is.
Retry hanlding seems to be properly handled in scsi_softirq_done,
where a busy sam status would only occurr for the time specified by
(cmd->allowed +1) * cmd->timeout_per_command.
Honour the return value of pci_enable_device(), which
seems to be a desirable thing to do:
2.6.20-rc4
gcc (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
CC [M] drivers/message/fusion/mptbase.o
drivers/message/fusion/mptbase.c: In function `mpt_resume':
drivers/message/fusion/mptbase.c:1541: warning: ignoring return value
of `pci_enable_device', declared with attribute warn_unused_result
It also in turn has mptscsih_resume() honour the return value of
mpt_resume()
I'm not sure about the handling of the other potential error cases
in mpt_resume(), of which there appear to be many. But this does
seem to be a good start.
Signed-off-by: Simon Horman <horms@verge.net.au>
It seems that most of the code in mptscsih_resume() doesn't
do anything. This patch removes that code.
Fix kernel-doc warnings in fusion driver code.
After Al Viro (finally) succeeded in removing the sched.h #include in module.h
recently, it makes sense again to remove other superfluous sched.h includes.
There are quite a lot of files which include it but don't actually need
anything defined in there. Presumably these includes were once needed for
macros that used to live in sched.h, but moved to other header files in the
course of cleaning it up.
To ease the pain, this time I did not fiddle with any header files and only
removed #includes from .c-files, which tend to cause less trouble.
Compile tested against 2.6.20-rc2 and 2.6.20-rc2-mm2 (with offsets) on alpha,
arm, i386, ia64, mips, powerpc, and x86_64 with allnoconfig, defconfig,
allmodconfig, and allyesconfig as well as a few randconfigs on x86_64 and all
configs in arch/arm/configs on arm. I also checked that no new warnings were
introduced by the patch (actually, some warnings are removed that were emitted
by unnecessarily included header files).
Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de>
Acked-by: Russell King <rmk+kernel@arm.linux.org.uk>
bump version, and fix email addr for lsi support
misc error handling bug fix's
- properly interpret iocstatus returned after task management request
- clear tmState after a failed doorbell
- cleanup mptscsih_taskmgmt_complete
inactive raid support, e.g. exposing hidden raid components
belonging to a volume that are inactive. Also misc bug fix's for
various raid asyn events.
various string updates for iocstatus, logingo, and fw asyn events.
Move some functions that only apply to the mptspi module over from mptscsih.c
Add support for greater than 255 target and luns.
Kill the hd->Target[] field, and change all references
of bus_id/target_id, to channel/id.
* Add modinfo driver version support.
* Change copyright year to 2007.
* Endian fix's for warnings found in ppc environment.
* Fix compile time warning when calling scsi_device_reprobe, where
in newer kernels this API expects its return value to be examined.
* Fix compile errors when debug messages are enabled.
MPI_IOCSTATUS_SCSI_IOC_TERMINATED
A repost of a patch forwarded by Mikael Reed from 2006-12-20.
The fibre channel IOC may kill a request for a variety of
reasons, some of which may be recovered by a retry, some of
which are unlikely to be recovered. Return DID_ERROR
instead of DID_RESET to permit retry of the command,
just not an infinite number of them.
Signed-off-by: Michael Reed <mdr@sgi.com>
Correct lots of typos, kernel-doc warnings, & kernel-doc usage in fusion and
i2o drivers.
Fix's to insure proper status is returned to midlayer
when a task abort failed to be aborted by controller
firmware.
Also sanity checks to prevent scsi cmd from being
double completed during error recovery.
Signed-off-by: Eric Moore <Eric.Moore@lsil.com>
sas nexus loss support for systems that suport failover.
Adding support for sas enclosures with smart drives.
The driver uses msleep_interruptible() in the code path responsible
for resetting the card's ports via the lsiutil command. If a
<ctrl-c> is received during the reset it can leave a port in such
a state that the only way to regain its use is to reboot the system.
Changing from msleep_interruptible() to msleep() corrects the problem.
Move fibre channel event and reset handling to mptfc. This will
result in fewer changes over time that need to be applied to
either mptbase.c or mptscsih.c.
mptbase.h
bump version number to 3.03.09
remove unneeded flags
define workq and remove old fc specific locks
mptbase.c
initialize new lock and don't initialize two removed locks
mptscsih.c
when firmware reports target is no longer there, return
DID_REQUEUE for fc hosts so that i/o doesn't get killed until
the transport has an opportunity to manage the loss via its
dev loss timer
when the "eh_abort" routine is called, check to see if the
driver has the command or not before looking to see if a reset
is pending. James Smart and I talked about this and believe
that the API for this routine is: if driver doesn't have
command, return SUCCESS. This change helps prevent a target
from being taken offline. SUCCESS is returned because it's
likely that the command completed after error recovery timed
it out but before it could be aborted.
provide a routine to queue work to newly created workq, and
use it.
remove "ioc" from mptscsih_abort() it was only used one time.
the other references were via hd->ioc, so I just moved it....
net change in references to ioc via hd->ioc is zero
move hd->resetPending test and hd->timeouts increment to after
the test for whether the command to be aborted remains known
to the driver
Make certain that the workq exists before queuing work to it.
mptfc.c
no longer need to lock rport data structures as I was able to
single thread the code! I fixed up the debug code to
eliminate compilation messages due to type mismatch in the
printk. Got rid of some no longer needed rport flags.
Initialize and destroy the workq used for the rescan work.
simplify the logic regarding the increment of
fc_rescan_work_count. use post increment and test for zero
vs. pre increment and test for one; eliminate work_count
variable: queue_work can be called with the work_lock held as
it doesn't sleep
This patch handles case where raid hidden components
are not being removed when power turned off to device
attached to expander, as well as the case of
exposing raid components when power is turned back on
to devices attached to an expander. (This is a repost
of this patch, with mptsas_is_end_device declared
further up in the code.)
This patch contains some other miscellaneous bug fix's.
Suppport for exposing hidden raid components
for sg interface. The sdev->no_uld_attach flag
will set set accordingly.
The sas module supports adding/removing raid
volumes using online storage management application
interface.
This patch rely's on patch's provided to me
by Christoph Hellwig, that exports device_reprobe.
I will post those patch's on behalf of Christoph.
It makes no sense in keeping the target_id and bus_id
in the VirtDevice structure, when it can be obtained
from the VirtTarget structure.
In addition, this patch fix's couple compilation bugs
in mptfc.c when MPT_DEBUG_FC is enabled. This
provided by Micheal Reed.
