path: root/drivers/message/fusion
2008-04-19SCSI: convert struct class_device to struct deviceTony Jones
It's big, but there doesn't seem to be a way to split it up smaller... Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: Kay Sievers <kay.sievers@vrfy.org> Cc: Roland Dreier <rolandd@cisco.com> Cc: Sean Hefty <sean.hefty@intel.com> Cc: Hal Rosenstock <hal.rosenstock@gmail.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-07[SCSI] mpt fusion: fix up msi_enable in mpt_suspendJames Bottomley
There's a problem with the combination of the upstream power management fixes and the enabling of MSI by default in that the suspend path still uses the global variable. Convert it to check ioc->msi_enable. Cc: "Moore, Eric" <Eric.Moore@lsi.com> Cc: "Prakash, Sathya" <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] mptsas: do not use ioc->handle to locate hba portinfo structureMichael Reed
While performing hardware raid reset testing via the raid's client, I noticed that sometimes, following the reset, that there would be more raid targets in the lsscsi output than there actually were raid targets. I tracked this down to the following issue. Fusion cannot always find the mptsas_portinfo structure for the hba because it uses the handle stored in ioc->handle to locate it. The problem is that the firmware can change the handle associated with the hba when h/w raid is reset (via the raid client). When this happens, the driver will allocate another mptsas_portinfo structure and link it into the chain of said structures. This ultimately causes confusion within the driver resulting in targets not being removed when they should be. Eric Moore pointed out that the hba's portinfo structure is always the first structure on the sas_topology list. This patch modifies mptsas.c to access the hba's portinfo structure by taking the first structure on said list. Signed-off-by: Michael Reed <mdr@sgi.com> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] mpt fusion: convert inactive_list_mutex to a mutexMatthias Kaehlcke
the semaphore inactive_list_mutex is used as a mutex, convert it to the mutex API Signed-off-by: Matthias Kaehlcke <matthias@kaehlcke.net> Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-04-07[SCSI] mpt fusion: Enable MSI by default for SAS controllersPrakash, Sathya
This patch modifies the driver to enable MSI by default for all SAS chips. Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-18[SCSI] mpt fusion: Power Management fixes for MPT SAS PCI-E controllersPrakash, Sathya
The system power state changes like hibernation and standby are not happening properly with 106XE controllers, this patch modifies the driver to free resources and allocate resources in power management entry points [jejb: compile fixes for upstream] Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-05[SCSI] mpt fusion: don't oops if NumPhys==0Krzysztof Oledzki
Don't oops if NumPhys==0, instead return -ENODEV. This patch fixes http://bugzilla.kernel.org/show_bug.cgi?id=9909 Signed-off-by: Krzysztof Piotr Oledzki <ole@ans.pl> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-03-03[SCSI] docbook: fix fusion source filesRandy Dunlap
Fix docbook problems in fusion source files. These cause the generated docbook to be incorrect. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-22[SCSI] mptbase: fix use-after-free'sAdrian Bunk
ioc->name is used in the printk's after ioc has been freed. Free after prinks to fix this. This patch fixes two use-after-free's introduced by commit e78d5b8f1e73ab82f3fd041d05824cfee7d83a2c and spotted by the Coverity checker. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-18[SCSI] mpt fusion: kill warnings in mptbase.h on parisc64Kyle McMartin
Verified all the arches necessary select the CONFIG_64BIT symbol. This also kills the warning (since it was using the 32-bit case) on parisc64 and mips64. Signed-off-by: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] mpt fusion: Request I/O resources only when requiredPrakash, Sathya
This patch modifies the I/O resource allocation behavior of FUSION driver. The current version of driver allocates the I/O resources even if they are not required and this creates trouble in low resource environments. This driver now uses pci_enable_device_mem/pci_enable_device functions to differentiate the resource allocations. Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-11[SCSI] mpt fusion: Avoid racing when mptsas and mptcl module are loaded in ↵Prakash, Sathya
parallel This patch sets the IOC pointer in drvrdata of pcidev before adding the IOC into the list of IOCs. Without this patch the driver oops when the mptsas and mptctl modules are loaded in parallel. Signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-02-03drivers/message/: Spelling fixesJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03Spelling fixes: lenght->lengthPaulius Zaleckas
Signed-off-by: Paulius Zaleckas <pauliusz@yahoo.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-01-23[SCSI] replace sizeof sense_buffer with SCSI_SENSE_BUFFERSIZEFUJITA Tomonori
This replaces sizeof sense_buffer with SCSI_SENSE_BUFFERSIZE in several LLDs. It's a preparation for the future changes to remove sense_buffer array in scsi_cmnd structure. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-23[SCSI] mpt fusion: Fix for module unload problem in flash less controller ↵Prakash, Sathya
environment This patch fixes the module unload problem in flash less 1030 controller environment where firmware download boot functionality is invoked. The problem is due to the firmware download is being done in the reverse order, which this patch solves by insureing the download occurs to the last controller being reset. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2008-01-11[SCSI] mpt fusion: make mptsas_smp_handler update residFUJITA Tomonori
This patch fixes mptsas_smp_handler to update both din_resid or dout_resid on success. bsg can report back the residual. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-16Merge branch 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-block: (63 commits) Fix memory leak in dm-crypt SPARC64: sg chaining support SPARC: sg chaining support PPC: sg chaining support PS3: sg chaining support IA64: sg chaining support x86-64: enable sg chaining x86-64: update pci-gart iommu to sg helpers x86-64: update nommu to sg helpers x86-64: update calgary iommu to sg helpers swiotlb: sg chaining support i386: enable sg chaining i386 dma_map_sg: convert to using sg helpers mmc: need to zero sglist on init Panic in blk_rq_map_sg() from CCISS driver remove sglist_len remove blk_queue_max_phys_segments in libata revert sg segment size ifdefs Fixup u14-34f ENABLE_SG_CHAINING qla1280: enable use_sg_chaining option ...
2007-10-16Fusion: sg chaining supportJens Axboe
2007-10-15docbook: fix kernel-api contentRandy Dunlap
Fix kernel-api docbook warnings. Warning(linux-2.6.23-git8//drivers/message/fusion/mptscsih.c:2618): No description found for parameter 'sc' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (207 commits) [SCSI] gdth: fix CONFIG_ISA build failure [SCSI] esp_scsi: remove __dev{init,exit} [SCSI] gdth: !use_sg cleanup and use of scsi accessors [SCSI] gdth: Move members from SCp to gdth_cmndinfo, stage 2 [SCSI] gdth: Setup proper per-command private data [SCSI] gdth: Remove gdth_ctr_tab[] [SCSI] gdth: switch to modern scsi host registration [SCSI] gdth: gdth_interrupt() gdth_get_status() & gdth_wait() fixes [SCSI] gdth: clean up host private data [SCSI] gdth: Remove virt hosts [SCSI] gdth: Reorder scsi_host_template intitializers [SCSI] gdth: kill gdth_{read,write}[bwl] wrappers [SCSI] gdth: Remove 2.4.x support, in-kernel changelog [SCSI] gdth: split out pci probing [SCSI] gdth: split out eisa probing [SCSI] gdth: split out isa probing gdth: Make one abuse of scsi_cmnd less obvious [SCSI] NCR5380: Use scsi_eh API for REQUEST_SENSE invocation [SCSI] usb storage: use scsi_eh API in REQUEST_SENSE execution [SCSI] scsi_error: Refactoring scsi_error to facilitate in synchronous REQUEST_SENSE ...
2007-10-12[SCSI] mptctl : shutup uninitialized variable warningsEric Moore
drivers/message/fusion/mptctl.c: In function ‘mptctl_mpt_command’: drivers/message/fusion/mptctl.c:1764: warning: ‘bufIn.len’ may be used uninitialized in this function drivers/message/fusion/mptctl.c:1765: warning: ‘bufOut.len’ may be used uninitialized in this function come because gcc gets confused by some "goto" statements in above function. The warnings have been verified to be bogus, however, the function does initialize these later (after the offending goto's) in the function anyway. So let's move those initializations to top of function, thereby also shutting up these warnings. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mptlan: bug fix, only half the message frame is dma'd resulting in ↵Eric Moore
corruption NB = number of blocks. This represents the number of blocks to transfer. The block size is based on the message frame size provided in the ioc_facts. A value of zero indicates the entire message frame should be copied. This is two bit value. So by setting this to non-zero vaule, you increase performance by reducing amount of data needing to be dma'd. The value that is stored in ioc->ReqeustNB is sometimes a non-zero vaule, which creates a bug in mptlan, where not the entire message frame is getting transfer to firware, resulting in corruption. This fix sets the default to zero, thus entire message frame is copied. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: fix up fusion prints using the sdev_printk, dev_printk, ↵Eric Moore
and shost_printk API Cleaning up prints that use the xxx_printk API, in that the fusion preamble "mptbase: iocX" follows the info provided by the print API. The way its currently coded, the [H:C:T] print in sdev_printk will be inbetween "mptbase" and "iocX", instead of before. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: lock down ScsiLookupEric Moore
ScsiLookup is an array of pending scmd pointers that the scsi lld maintains. This array is touched from queuecommand, eh threads, and interrupt context. This array should put under locks, hence this patch to synchronize its access. I've added some nice little function wrappers for this, and moved the ScsiLookup array over to MPT_ADAPTER struct. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Fix sparse warningsEric Moore
List below is output from C=2 sparse compilation, which are fixed with this patch. 1) mptspi: pg0 is defined in x86 version of include/asm/pgtable.h 2) mptsas: context imbalance in 'mptsas_probe' different lock contexts for basic block 3) mptbase: from mpt_attach - cast adds address space to expression 4) mptbase: from mpt_do_upload - request[] is bad constant expression Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: add use of shost_priv and remove all the typecastingEric Moore
The driver is currently typecasting to obtain the shost hostdata. The driver is updated to use the shost_priv macro. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: bump version to 3.04.06Eric Moore
bump version Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Kconfig cleanupEric Moore
Adding 949X, 949E, and 1078 to Kconfig. Adding "depends on FUSION" required in the FUSION_LOGGING section, and fixing a spelling error. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: removing Dell copyrightEric Moore
Some other vender has concerns over this copyright, and Dell has approved removing it. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: removing references to hd->iocEric Moore
Cleaning up code by accesing the ioc pointer directly instead of via hd->ioc. In the future, most data members of struct MPT_SCSI_HOST will be either deleted or moved to struct MPT_ADAPTER. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: rename vdev to vdeviceEric Moore
common naming of vdevice through out driver Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: adding/removing white spaceEric Moore
cleaning up some white space that was introduce in a recent "cb_idx int to u8" patch. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: standardize printks and debug infoEric Moore
Standardize all prints using common MYIOC_s_XXX_FMT macro defined in mptbase.h. Currently the driver uses several different methods to display info, where in some cases the "controller name" generating the printk is not provided. Signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: remove redundant memsetMariusz Kozlowski
alloc_fcdev() calls alloc_netdev() which uses kzalloc to alloc all the memory together with dev->priv region hence no zeroing of structs inside struct mpt_lan_priv needed. Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Acked-by: "Moore, Eric Dean" <Eric.Moore@lsil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: fix two potential mem leaksJesper Juhl
The Coverity checker spotted two potential memory leaks in drivers/message/fusion/mptbase.c::mpt_attach(). There are two returns that may leak the storage allocated for 'ioc' (sizeof(MPT_ADAPTER) bytes). A simple fix would be to simply add two kfree() calls before the return statements, but a better fix (that this patch implements) is to reorder the code so that if we hit the first return condition we don't have to do the allocation at all and then just add a kfree() call for the second case. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Acked-by: "Moore, Eric Dean" <Eric.Moore@lsil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: mostly kmalloc + memset conversion to kzallocMariusz Kozlowski
This patch does kmalloc + memset conversion to kzalloc anSigned-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> d simplifies mptctl_probe(). drivers/message/fusion/mptctl.c | 82092 -> 81884 (-208 bytes) drivers/message/fusion/mptctl.o | 201784 -> 200648 (-1136 bytes) Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Acked-by: "Moore, Eric Dean" <Eric.Moore@lsil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Use menuconfig objectsJan Engelhardt
Change Kconfig objects from "menu, config" into "menuconfig" so that the user can disable the whole feature without having to enter the menu first. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Acked-by: "Moore, Eric Dean" <Eric.Moore@lsil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Change company name from LSI Logic to LSIPrakash, Sathya
Recently LSI Logic Corp was renamed as LSI Corp, so whereever there is a reference of LSI Logic, it is changed to LSI in mpt fusion driver code. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Link speed change display supportPrakash, Sathya
When there is state change in FC links, a message is displayed with old and new link speed. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Creation of mptsas.h header filePrakash, Sathya
The data structure definitions from mptsas.c are moved to a new header file mptsas.h signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Change call back indices to u8 from intPrakash, Sathya
The call back index requires only u8 but in lot of places it is referred as int, now everywhere the call back index variables are declared as u8 with uniform name cb_idx signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Usage of high priority request FIFO to send task ↵Prakash, Sathya
management commands Added support for sending the task management requests through High priority request FIFO instead of Doorbell writes when firmware support High priority FIFO. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Acked-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-12[SCSI] mpt fusion: Add support for ATTO 4LD: Rebranded LSI 53C1030Eric Moore
Per request from Matthew Wilcox - using PCI_VENDOR_ATTO. Add support for ATTO UL4D, they are rebranded 53C1030. The changes are 1. Adding a new PCI vendor ID in pci table 2. The spi_port_page_2 is in different format than that of LSI generic spi_port_page_2 and hence mapping code is added. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> signed-off-by: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-10-10[NET]: Nuke SET_MODULE_OWNER macro.Ralf Baechle
It's been a useless no-op for long enough in 2.6 so I figured it's time to remove it. The number of people that could object because they're maintaining unified 2.4 and 2.6 drivers is probably rather small. [ Handled drivers added by netdev tree and some missed IRDA cases... -DaveM ] Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-31[SCSI] mptsas: add SMP passthrough support via bsgFUJITA Tomonori
This patch adds support for SAS Management Protocol (SMP) passthrough support via bsg. Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp> Acked-by: Eric Moore <eric.moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-31[SCSI] mpt fusion: make logging a global sysfs parameterJames Bottomley
Wire up the mpt_debug_level module parameter so you can write to the /sys/module/mptbase/parameters/mpt_debug_level and have it take effect in every ioc. Acked-by: "Moore, Eric" <Eric.Moore@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-28[SCSI] mpt fusion: Changes in mptctl.c for logging supportPrakash, Sathya
This patch contains changes in mptctl.c to support logging in MPT fusion drivers The changes are majorly in debug printks, the existing debugprintk are modified accroding to new debug macros defined in the file mptbdebug.h signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-28[SCSI] mpt fusion: Changes in mptfc.c mptlan.c mptsas.c and mptspi.c for ↵Prakash, Sathya
logging support This patch contains changes in mptfc.c, mptlan.c, mptsas.c and mptspi.c to support logging in MPT fusion drivers. The changes are majorly in debug printks, the existing debugprintk are modified accroding to new debug macros defined in the file mptbdebug.h signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2007-07-28[SCSI] mpt fusion: Changes in mptscsih.c for logging supportPrakash, Sathya
This patch contains changes in mptscsih.c to support logging in MPT fusion drivers. The changes are majorly in debug printks, the existing debugprintk are modified accroding to new debug macros defined in the file mptbdebug.h A new sysfs attribute is added to retrieve and modify the debug level. signed-off-by: Sathya Prakash <sathya.prakash@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
