path: root/drivers/message/i2o/exec-osm.c
2010-08-11drivers/message/i2o/exec-osm.c: add missing mutex_unlockJulia Lawall
Add a mutex_unlock missing on the error path. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E1; @@ * mutex_lock(E1,...); <+... when != E1 if (...) { ... when != E1 * return ...; } ...+> * mutex_unlock(E1,...); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05i2o: Update my addressAlan Cox
Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16i2o: Fix 32/64bit DMA lockingAlan Cox
The I2O ioctls assume 32bits. In itself that is fine as they are old cards and nobody uses 64bit. However on LKML it was noted this assumption is also made for allocated memory and is unsafe on 64bit systems. Fixing this is a mess. It turns out there is tons of crap buried in a header file that does racy 32/64bit filtering on the masks. So we: - Verify all callers of the racy code can sleep (i2o_dma_[re]alloc) - Move the code into a new i2o/memory.c file - Remove the gfp_mask argument so nobody can try and misuse the function - Wrap a mutex around the problem area (a single mutex is easy to do and none of this is performance relevant) - Switch the remaining problem kmalloc holdout to use i2o_dma_alloc Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Vasily Averin <vvs@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-17I2O: Fix "defined but not used" build warningsSatyam Sharma
drivers/message/i2o/exec-osm.c:539: warning: `i2o_exec_lct_notify' defined but not used comes when CONFIG_I2O_LCT_NOTIFY_ON_CHANGES=n, because its only callsite is #ifdef'ed as such. So let's #ifdef the function definition also. Also move the definition to before the callsite, to get rid of forward prototype. [akpm@linux-foundation.org: fix warnings] Signed-off-by: Satyam Sharma <satyam@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17i2o proc reading oopsVasily Averin
Fix oops on reading from some i2o proc files (i2o_seq_show_driver_store() and other) because their handlers uses "exec" field in struct i2o_controller Signed-off-by: Vasily Averin <vvs@sw.ru> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17i2o message leak in i2o_msg_post_wait_mem()Vasily Averin
We need to free i2o msg in case of error. Signed-off-by: Vasily Averin <vvs@sw.ru> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Acked-by: Kirill Korotaev <dev@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Use mutexes instead of semaphores in I2O driverMatthias Kaehlcke
The I2O driver uses two semaphores as mutexes. Use the mutex API instead of the (binary) semaphores. Signed-off-by: Matthias Kaehlcke <matthias.kaehlcke@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-22[PATCH] fix kernel-doc warnings in 2.6.20-rc1Randy Dunlap
Fix kernel-doc warnings in 2.6.20-rc1. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-13[PATCH] i2o_exec_exit and i2o_driver_exit should not be __exit.Ralf Baechle
i2o_exec_exit and i2o_driver_exit were marked as __exit which is a bug because both are invoked from __init and __exit functions. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] kernel-doc: fix fusion and i2o docsRandy Dunlap
Correct lots of typos, kernel-doc warnings, & kernel-doc usage in fusion and i2o drivers. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-11-22WorkStruct: make allyesconfigDavid Howells
Fix up for make allyesconfig. Signed-Off-By: David Howells <dhowells@redhat.com>
2006-10-30[PATCH] lockdep: annotate DECLARE_WAIT_QUEUE_HEADPeter Zijlstra
kernel: INFO: trying to register non-static key. kernel: the code is fine but needs lockdep annotation. kernel: turning off the locking correctness validator. kernel: [<c04051ed>] show_trace_log_lvl+0x58/0x16a kernel: [<c04057fa>] show_trace+0xd/0x10 kernel: [<c0405913>] dump_stack+0x19/0x1b kernel: [<c043b1e2>] __lock_acquire+0xf0/0x90d kernel: [<c043bf70>] lock_acquire+0x4b/0x6b kernel: [<c061472f>] _spin_lock_irqsave+0x22/0x32 kernel: [<c04363d3>] prepare_to_wait+0x17/0x4b kernel: [<f89a24b6>] lpfc_do_work+0xdd/0xcc2 [lpfc] kernel: [<c04361b9>] kthread+0xc3/0xf2 kernel: [<c0402005>] kernel_thread_helper+0x5/0xb Another case of non-static lockdep keys; duplicate the paradigm set by DECLARE_COMPLETION_ONSTACK and introduce DECLARE_WAIT_QUEUE_HEAD_ONSTACK. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Greg KH <gregkh@suse.de> Cc: Markus Lidel <markus.lidel@shadowconnect.com> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Arjan van de Ven <arjan@infradead.org> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-21[PATCH] i2o/exec-osm.c: use "unsigned long flags;"Alexey Dobriyan
Just like everyone else. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-17[PATCH] I2O: handle a few sysfs errorsJeff Garzik
Signed-off-by: Jeff Garzik <jeff@garzik.org> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-10[PATCH] I2O: Bugfixes to get I2O working againMarkus Lidel
From: Markus Lidel <Markus.Lidel@shadowconnect.com> - Fixed locking of struct i2o_exec_wait in Executive-OSM - Removed LCT Notify in i2o_exec_probe() which caused freeing memory and accessing freed memory during first enumeration of I2O devices - Added missing locking in i2o_exec_lct_notify() - removed put_device() of I2O controller in i2o_iop_remove() which caused the controller structure get freed to early - Fixed size of mempool in i2o_iop_alloc() - Fixed access to freed memory in i2o_msg_get() See http://bugzilla.kernel.org/show_bug.cgi?id=6561 Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-12[SCSI] i2o: fix memory leak in i2o_exec_lct_modifiedVasily Averin
i2o_exec_lct_modified() does not release memory allocated for work_struct. Signed-off-by: Vasily Averin <vvs@sw.ru> Although your patch is the same, i've rewritten it a little bit for naming consistency in the I2O driver. Acked-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-06[PATCH] I2O: Lindent runMarkus Lidel
Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] I2O: OptimizingMarkus Lidel
- make i2o_iop_free() static inline (from Adrian Bunk) - changed kmalloc() + memset(0) into kzalloc() Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] I2O: SPARC fixesMarkus Lidel
Fix lot of BE <-> LE bugs which prevent it from working on SPARC. Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] I2O: changed I2O API to create I2O messages in kernel memoryMarkus Lidel
Changed the I2O API to create I2O messages first in kernel memory and then transfer it at once over the PCI bus instead of sending each quad-word over the PCI bus. Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] fix remaining missing includesTim Schmielau
Fix more include file problems that surfaced since I submitted the previous fix-missing-includes.patch. This should now allow not to include sched.h from module.h, which is done by a followup patch. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-30[PATCH] fix missing includesTim Schmielau
I recently picked up my older work to remove unnecessary #includes of sched.h, starting from a patch by Dave Jones to not include sched.h from module.h. This reduces the number of indirect includes of sched.h by ~300. Another ~400 pointless direct includes can be removed after this disentangling (patch to follow later). However, quite a few indirect includes need to be fixed up for this. In order to feed the patches through -mm with as little disturbance as possible, I've split out the fixes I accumulated up to now (complete for i386 and x86_64, more archs to follow later) and post them before the real patch. This way this large part of the patch is kept simple with only adding #includes, and all hunks are independent of each other. So if any hunk rejects or gets in the way of other patches, just drop it. My scripts will pick it up again in the next round. Signed-off-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] tpm: device attribute fixesYani Ioannou
This patch updates all the device attribute callbacks that weren't updated with the new parameter, I guess because they weren't in Greg's tree (including drivers/pcmcia/ds.c). Without the patch these callbacks are probably broken (and generate a warning along the lines of "assignment from incompatible pointer type"). Please see http://lkml.org/lkml/2005/5/19/40 for the scripts I used to update the attributes automatically. Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: Lindent run and replacement of printk through osm printing ↵Markus Lidel
functions Lindent run and replaced printk() through the corresponding osm_*() function Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: second code cleanup of sparse warnings and unneeded syncronizationMarkus Lidel
Changes: - Added header "core.h" for i2o_core.ko internal definitions - More sparse fixes - Changed display of TID's in sysfs attributes from XXX to 0xXXX - Use the right functions for accessing I/O and normal memory - Removed error handling of SCSI device errors and let the SCSI layer take care of it - Added new device / removed device handling to SCSI-OSM - Make status access volatile - Cleaned up activation of I2O controller - Removed unnecessary wmb() and rmb() calls - Use own struct i2o_io for I/O memory instead of struct i2o_dma Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: new sysfs attributes and Adaptec specific block device access ↵Markus Lidel
and 64-bit DMA support Changes: - Added Bus-OSM which could be used by user space programs to reset a channel on the controller - Make ioctl's in Config-OSM obsolete in prefer for sysfs attributes and move those to its own file - Added sysfs attribute for firmware read and write access for I2O controllers - Added special handling of firmware read and write access for Adaptec controllers - Added vendor id and product id as sysfs-attribute to Executive classes - Added automatic notification of LCT change handling to Exec-OSM - Added flushing function to Block-OSM for later barrier implementation - Use PRIVATE messages for Block access on Adaptec controllers, which are faster then BLOCK class access - Cleaned up support for Promise controller - New messages are now detected using the IRQ status register as suggested by the I2O spec - Added i2o_dma_high() and i2o_dma_low() functions - Added facility for SG tablesize calculation when using 32-bit and 64-bit DMA addresses - Added i2o_dma_map_single() and i2o_dma_map_sg() which could build the SG list for 32-bit as well as 64-bit DMA addresses Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: first code cleanup of spare warnings and unused functionsMarkus Lidel
Changes: - Removed unnecessary checking of NULL before calling kfree() - Make some functions static - Changed pr_debug() into osm_debug() - Use i2o_msg_in_to_virt() for getting a pointer to the message frame - Cleaned up some comments - Changed some le32_to_cpu() into readl() where necessary - Make error messages of OSM's look the same - Cleaned up error handling in i2o_block_end_request() - Removed unused error handling of failed messages in Block-OSM, which are not allowed by the I2O spec - Corrected the blocksize detection in i2o_block - Added hrt and lct sysfs-attribute to controller - Call done() function in SCSI-OSM after freeing DMA buffers - Removed unneeded variable for message size calculation in i2o_scsi_queuecommand() - Make some changes to remove sparse warnings - Reordered some functions - Cleaned up controller initialization - Replaced some magic numbers by defines - Removed unnecessary dma_sync_single_for_cpu() call on coherent DMA - Removed some unused fields in i2o_controller and removed some unused functions Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: bugfixes and compability enhancementsMarkus Lidel
Changes: - Fixed sysfs bug where user and parent links where added to the I2O device itself - Fixed bug when calculating TID for the event handler and cleaned up the workflow of i2o_driver_dispatch() - Fixed oops when no I2O device could be found for an event delivered to Exec-OSM - Fixed initialization of spinlock in Exec-OSM - Fixed memory leak in i2o_cfg_passthru() and i2o_cfg_passthru() - Removed MTRR support - Added PCI ID of Promise SX6000 with firmware >= 1.20.x.x - Turn of caching for ioremapped memory of in_queue - Added initialization sequence for Promise controllers - Moved definition of u8 / u16 / u32 for raidutils before first use Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
