path: root/drivers/message
2005-07-07[PATCH] pm: more u32 vs. pm_message_t fixesPavel Machek
Few more u32 vs. pm_message_t fixes. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-07[PATCH] i2o: config-osm build fixAndrew Morton
Various stuff missing on alpha: drivers/message/i2o/config-osm.c:35: error: field `fops' has incomplete type drivers/message/i2o/config-osm.c: In function `sysfs_create_fops_file': drivers/message/i2o/config-osm.c:71: error: storage size of `tmp' isn't known drivers/message/i2o/config-osm.c:78: error: dereferencing pointer to incomplete type drivers/message/i2o/config-osm.c:81: error: dereferencing pointer to incomplete type Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-27[PATCH] PCI: make drivers use the pci shutdown callback instead of the ↵Greg Kroah-Hartman
driver core callback. Now we can change the pci core to always set this pointer, as pci drivers should use it, not the driver core callback. Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-24[PATCH] tpm: device attribute fixesYani Ioannou
This patch updates all the device attribute callbacks that weren't updated with the new parameter, I guess because they weren't in Greg's tree (including drivers/pcmcia/ds.c). Without the patch these callbacks are probably broken (and generate a warning along the lines of "assignment from incompatible pointer type"). Please see http://lkml.org/lkml/2005/5/19/40 for the scripts I used to update the attributes automatically. Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] i2o build fixAndrew Morton
LD .tmp_vmlinux1 drivers/built-in.o: In function `i2o_cfg_parms': config-osm.c:(.text+0x12764a): undefined reference to `i2o_parm_issue' Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: Limit max sector workaround for Promise controllersMarkus Lidel
Set max sectors to 256 for Promise controllers. Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: Lindent run and replacement of printk through osm printing ↵Markus Lidel
functions Lindent run and replaced printk() through the corresponding osm_*() function Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: second code cleanup of sparse warnings and unneeded syncronizationMarkus Lidel
Changes: - Added header "core.h" for i2o_core.ko internal definitions - More sparse fixes - Changed display of TID's in sysfs attributes from XXX to 0xXXX - Use the right functions for accessing I/O and normal memory - Removed error handling of SCSI device errors and let the SCSI layer take care of it - Added new device / removed device handling to SCSI-OSM - Make status access volatile - Cleaned up activation of I2O controller - Removed unnecessary wmb() and rmb() calls - Use own struct i2o_io for I/O memory instead of struct i2o_dma Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: Adaptec specific SG_IO access, firmware access through sysfs ↵Markus Lidel
and 2400A workaround Changes: - Provide SG_IO access to BLOCK and EXECUTIVE class on Adaptec controllers - Use PRIVATE messages in SCSI-OSM because on some controllers normal SCSI class commands like READ or READ CAPACITY cause errors - Use new DMA and SG list creation function - Added workaround to limit sectors per request for Adaptec 2400A controllers Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: new sysfs attributes and Adaptec specific block device access ↵Markus Lidel
and 64-bit DMA support Changes: - Added Bus-OSM which could be used by user space programs to reset a channel on the controller - Make ioctl's in Config-OSM obsolete in prefer for sysfs attributes and move those to its own file - Added sysfs attribute for firmware read and write access for I2O controllers - Added special handling of firmware read and write access for Adaptec controllers - Added vendor id and product id as sysfs-attribute to Executive classes - Added automatic notification of LCT change handling to Exec-OSM - Added flushing function to Block-OSM for later barrier implementation - Use PRIVATE messages for Block access on Adaptec controllers, which are faster then BLOCK class access - Cleaned up support for Promise controller - New messages are now detected using the IRQ status register as suggested by the I2O spec - Added i2o_dma_high() and i2o_dma_low() functions - Added facility for SG tablesize calculation when using 32-bit and 64-bit DMA addresses - Added i2o_dma_map_single() and i2o_dma_map_sg() which could build the SG list for 32-bit as well as 64-bit DMA addresses Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: first code cleanup of spare warnings and unused functionsMarkus Lidel
Changes: - Removed unnecessary checking of NULL before calling kfree() - Make some functions static - Changed pr_debug() into osm_debug() - Use i2o_msg_in_to_virt() for getting a pointer to the message frame - Cleaned up some comments - Changed some le32_to_cpu() into readl() where necessary - Make error messages of OSM's look the same - Cleaned up error handling in i2o_block_end_request() - Removed unused error handling of failed messages in Block-OSM, which are not allowed by the I2O spec - Corrected the blocksize detection in i2o_block - Added hrt and lct sysfs-attribute to controller - Call done() function in SCSI-OSM after freeing DMA buffers - Removed unneeded variable for message size calculation in i2o_scsi_queuecommand() - Make some changes to remove sparse warnings - Reordered some functions - Cleaned up controller initialization - Replaced some magic numbers by defines - Removed unnecessary dma_sync_single_for_cpu() call on coherent DMA - Removed some unused fields in i2o_controller and removed some unused functions Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] I2O: bugfixes and compability enhancementsMarkus Lidel
Changes: - Fixed sysfs bug where user and parent links where added to the I2O device itself - Fixed bug when calculating TID for the event handler and cleaned up the workflow of i2o_driver_dispatch() - Fixed oops when no I2O device could be found for an event delivered to Exec-OSM - Fixed initialization of spinlock in Exec-OSM - Fixed memory leak in i2o_cfg_passthru() and i2o_cfg_passthru() - Removed MTRR support - Added PCI ID of Promise SX6000 with firmware >= 1.20.x.x - Turn of caching for ioremapped memory of in_queue - Added initialization sequence for Promise controllers - Moved definition of u8 / u16 / u32 for raidutils before first use Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-20[PATCH] Driver Core: drivers/i2c/chips/w83781d.c - ↵Yani Ioannou
drivers/s390/block/dcssblk.c: update device attribute callbacks Signed-off-by: Yani Ioannou <yani.ioannou@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-06-17merge by hand (fix up qla_os.c merge error)James Bottomley
2005-06-17[SCSI] allow sleeping in ->eh_host_reset_handler()Jeff Garzik
Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-06-17[SCSI] allow sleeping in ->eh_bus_reset_handler()Jeff Garzik
2005-06-17[SCSI] allow sleeping in ->eh_device_reset_handler()Jeff Garzik
2005-06-17[SCSI] allow sleeping in ->eh_abort_handler()Jeff Garzik
2005-06-14[PATCH] i2o: Fix free of event memory in i2o_block_event()Markus Lidel
Fixed freeing of event memory in i2o_block_event() Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-20[SCSI] fusion - bump driver version to 3.03.02Moore, Eric Dean
Bump driver version to 3.03.02 Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] fusion - mpi headers version 1.5.9Moore, Eric Dean
This patch contains update for mpi headers 1.5.9. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] fusion-kconfig-cleanupMoore, Eric Dean
* This patch clarifies help section in FUSION_MAX_SGE entry. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] fusion-kfree-cleanupMoore, Eric Dean
This patch is originally From: Jesper Juhl <juhl-lkml@dif.dk> This patch gets rid of redundant NULL checks prior to calling kfree() in drivers/message/* There are also a few small whitespace changes in there. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] fusion - Adding pci recog support for Fibre 949X and 939X chipsMoore, Eric Dean
* adding pci id support for new Fibre chips, 949X and 939X * adding errata workaround - disabling PIO access except during fwdlb. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: fix panic loading driver statically compiledMoore, Eric Dean
Adjust link ordering in the Makefile. Also, the ioc->DoneCtx handles for mptspi/mptfc in the message frame. And I'm now not seeing the panic. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: correct Kconfig problemJames Bottomley
The fusion Kconfig forgets to set CONFIG_FUSION, which is required to get the upper makefile to descend into the fusion directory. Add this back as a variable and make the two upper level modules select it. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: mptfc Adding Stub Driver - Fiber ChannelMoore, Eric Dean
(1) mptfc.c: This driver is having module_init, module_exit, and probe. (2) mptfc.c: Registering for Fibre Channel pci ids are done from this module. (3) mptfc.c: Convert MODULE_PARM to module_param Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: mptspi Adding Stub Driver - SCSI ParallelMoore, Eric Dean
(1) mptspi.c: This driver is having module_init, module_exit, and probe. (2) mptspi.c: Registering for SCSI pci ids are done from this module. (3) mptspi.c: Convert MODULE_PARM to module_param Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: mptscsih Split driver supportMoore, Eric Dean
(1) mptscsih.c: Remove credits, -sralston references , update copyright (2) mptscsih.c: split driver support (3) mptscsih.c: module_init, module_exit, and probe routines moved to new stub drivers, mptfc and mptspi (4) mptscsih.c: some global parameters are moved to MPT_SCSI_HOST (5) mptscsih.c: removed scsi_device_online check. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: mptlan Remove credits and update copyrightMoore, Eric Dean
(1) mptlan.c: Remove credits and update copyright (2) mptlan.c: Remove -sralston references Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: mptctl Remove credits and update copyrightMoore, Eric Dean
(1) mptctl.c: Remove credits and update copyright (2) mptctl.c: cleanup in get_iocinfo Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: mptbase cleanup, split driver support, DMA 32_BIT_MASKMoore, Eric Dean
(1) mptbase.c: Move registering pci ids to scsi lld drivers (2) mptbase.c: Use the DMA_32BIT_MASK constant (3) mptbase.c: Fix for multiple pci domains (4) mptbase.c: Remove le32 conversion from BlockSize, which was u8 size (5) mptbase.c: Remove credits, -sralston references , update copyright (6) mptbase.c: split driver support Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-05-20[SCSI] mptfusion: Kconfig Adding new bus type drivers for fusion drivers.Moore, Eric Dean
(1) Kconfig - added new mptspi and mptfc scsi lld drivers (2) Kconfig - increased MAX_SGE from 40 to 128 (2) Makefile - compilation support for split drivers (3) Makefile - cleaned up debug defines; e.g. removed obsolete, added others Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-18[PATCH] Convert i2o to compat_ioctl
Also broken design in its compat handlers - CONFIG_COMPAT doesn't mean that there should be no native ioctls. Signed-off-by: Andi Kleen <ak@muc.de> Reworked with comments from Markus Lidel by: Christoph Hellwig <hch@infradead.org> Rejections fixed and Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-04-16[PATCH] fix u32 vs. pm_message_t in drivers/messagePavel Machek
This fixes u32 vs. pm_message_t in drivers/message. Signed-off-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
