path: root/drivers/message
2006-02-16Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6Linus Torvalds
2006-02-05[PATCH] Fix i2o_scsi oops on abortMarkus Lidel
Fix http://bugzilla.kernel.org/show_bug.cgi?id=5923 When a scsi command failed, an oops would result. Back-to-back SMART queries would make the Seagate drives unhappy. The second SMART query would timeout, and the command would be aborted. Acked-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Kenny Simpson <theonetruekenny@yahoo.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-04[SCSI] fusion - mptctl -adding asyn event notification supportMoore, Eric
Adding aen support. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl -firmware download fixMoore, Eric
Fix's firmware download ioctl to work with SAS. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl - backplane istwi fixMoore, Eric
Moving the toolbox call from mptbase.c, over to mptctl.c, and using the mptctl infastructure to issue the call. The existing code is hanging on certain HP platforms when this ioctl is issued, and this patch fix's that. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl -sense width fixMoore, Eric
Bug fix for correctly setting sense width for the MPTCOMMAND ioctl. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl - Event Log FixMoore, Eric
Use the hard coded value MPTCTL_EVENT_LOG_SIZE to fix bug where in certain cases, the ioc->eventLogSize was initialized. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mtctl - change to wait_event_timeoutMoore, Eric
Change from using wait_event_interruptible_timeout to wait_event_timeout. Also delete white space and duplicate line of code. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl - adding support for bus_type=SASMoore, Eric
Add bus_type recognization in ioctl path for SAS. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-04[SCSI] fusion - mptctl - MPTCOMMAND - adding function types.Moore, Eric
This adds support for new function types in the existing MPTCOMMAND ioctl. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-02-03[PATCH] I2O: fix and workaround for Motorola/Freescale controllerMarkus Lidel
- This controller violates the I2O spec for the I/O registers. The patch contains a workaround which moves the registers to the proper location. (originally author: Matthew Starzewski) - If a message frame is beyond the mapped address range a error is returned. Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-03[PATCH] I2O: don't disable PCI device if it is enabled before probingMarkus Lidel
If PCI device is enabled before probing, it will not be disabled at exit. Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-31[SCSI] fusion: add message sanity checkMoore, Eric
This adds a sanity check in the interrupt routine insures incoming message frames are a valid message frames. The code for setting 0xdeadbeaf in the freed message frames, apparently was already submitted by Christoph in previous patch submission. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: unloading the driver - only set asyn narrow for configured ↵Moore, Eric
devices This patch inhibits sending spi negotiation parameters for non-configured devices from the slave_destroy function. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: unloading the driver results in panic - fixMoore, Eric
The ioc->alt_ioc->alt_ioc pointer is not getting cleared during driver unload time. This dangling pointer can result in panic in certain circumstances, such as error recovery, or firmware download in flashless environments. This only impacts dual functions controllers, such as 1030. Please apply. This patch also includes a small cosmetic name change for mpt_spi_log_info. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] mptsas: don't complain on bogus slave_alloc callsChristoph Hellwig
When people use the userspace scanning facilities on SAS hardware the LLDD gets bogus slave_alloc calls. Just fail those gracefully instead of printing a warning in mptsas and another one in the midlayer. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: add task managment response code infoMoore, Eric
Adding verbose message returned from firmware when a task mangment request fails. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: add MSI supportChristoph Hellwig
On Mon, Jan 16, 2006 at 06:53:24PM -0700, Moore, Eric wrote: > Adding MSI support, and command line for enabling > it. By default, the command line option has MSI disabled. mpt_msi_enable is initialized to 0 implicitly, no need to do that. Also replace if (mpt_msi_enable == 1) tests with just if (mpt_msi_enable). Updated patch below: Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: overrun tape fixMoore, Eric
2006-01-31[SCSI] fusion: add verbose messages for RAID actionsMoore, Eric
A customer request to send raid asyn actions from firmware to the event syslog. This shows when raid volumes go degraded, or complete resync, or volumes created/deleted, etc. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: increase reply frame size from 0x40 to 0x50 bytesMoore, Eric
Increasing the reply frame size by 16 bytes, to be in sync with the other fusion drivers. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: setting timeouts in eh threads appropiatley for fc/sas/spiChristoph Hellwig
On Mon, Jan 16, 2006 at 06:53:13PM -0700, Moore, Eric wrote: > The task managment request timeout in the eh threads was set > for U320 timing, which is between 2-5 seconds. > This is too small for FC and SAS. > According to the firmware engineers, Fibre needs to be 40 seconds > and SAS needs to be 10 seconds. The timeout selection should probably be done in a little helper instead of duplicated in a few places. Updated patch below. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: mptsas, increase discovery timout to 300 secondsMoore, Eric
Increase the port enable timeout only for SAS from 30 to 300 seconds. A customer request for the handling large topologies. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: spi bus reset when driver loadsMoore, Eric
This patch is for spi. This issues bus reset when driver loads. Handling cases when initator has negotiated for packetized, and target negotiated for non-packetized; effectly this bus reset is getting both target and initiator on the same sheet of music. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: fix compileJames Bottomley
The prior fusion patches moved an invocation of a function, mptscsih_TMHandler(), static to mptscsih.c into mptsas.c Make the function unstatic, move the header to mptscsih.h and export it. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: bump versionMoore, Eric
2006-01-31[SCSI] fusion: FC rport code fixesMichael Reed
This fix's problems with recent fc submission regarding i/o being redirected to the wrong target. Signed-off-by: Michael Reed <mdr@sgi.com> Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: move sas persistent event handling over to the mptsas moduleMoore, Eric
This moves code intented for SAS from the generic mptscsih module over to the mptsas module. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: target reset when drive is being removedMoore, Eric
The issuing of the target reset used in device hot removal case so the firmware queue is flushed out off outstanding commands. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-31[SCSI] fusion: add support for raid hot add/del supportMoore, Eric
RAID event support. This will hot add and remove raid volumes when managment application creates and deletes the volumes. The driver is basically responding to firmware asyn events, and reporting the changes to the above layers. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[SCSI] mptfc: need to select transport attrsJames Bottomley
Now that mptfc actually uses the transport class, it can't be built without it. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] fusion - fix pci express bugMoore, Eric
The fix is to write 'MPI_HIM_DIM' to the Host Interrupt Mask register, when enabling interrupts. Instead of the tilde of MPI_HIM_RIM. Apparently writing '1's to some of the reserved bits was causing all the bits to go to `1`, which effectly disabled all interrupts. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] fusion - mpi header udpateMoore, Eric
This updates mpi headers in fusion drivers to version 1.5.12. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] fusion - adding raid support in mptsasMoore, Eric
The SAS RAID volumes are reported beyond the expected number of phys. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] fusion - adding support for FC949ESMoore, Eric
Add software recognition for the new LSI Logic Fibre Channel controller. Signed-off-by: Eric Moore <Eric.Moore@lsil.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] mptfusion - fc transport attributesMichael Reed
2006-01-14[SCSI] fix up message/i2o/pci.cJames Bottomley
There was a use before initialisation of c->name Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] fusion: kzalloc / kcalloc conversionChristoph Hellwig
Convert kmalloc + memset to kzalloc or kcalloc in fusion. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] fusion: convert semaphores to mutexesChristoph Hellwig
2006-01-14[SCSI] mptsas: support basic hotplugChristoph Hellwig
Adds hotplug support for SAS end devices. Unfortunately the fusion firmware doesn't generate similar events for expanders addition/removal so we can't support them yet. Eric has an idea about a clever scheme to find out about expander changes so that'll be added later on. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-14[SCSI] I2O: move pci_request_regions() just behind pci_enable_device()Salyzyn, Mark
The problem in dpt_i2o could be the pci config space accesses it triggers as it loads, dangerous to do if there is any I/O activity going on in the other driver (probable if a boot driver I guess). I approve this patch to dpt_i2o.c, and am applying it to the Adaptec branch of the driver. Thanks for the investigation Ryoji. --- In linux 2.6.15, data transfer does hang when both dpt_i2o and i2o_block drivers are loaded. It seems that location of pci_request_regions() are wrong. I moved it just behind pci_enable_device() like other drivers, and it becomes fine. Signed-off-by: Ryoji Kamei <kamei@miraclelinux.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-01-10[PATCH] don't include ioctl32.h in driversChristoph Hellwig
These days ioctl32.h is only used for communication of fs/compat.c and fs/compat_ioctl.c and doesn't contain anything of interest to drivers. Remove inclusion in various drivers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10spelling: s/retreive/retrieve/Adrian Bunk
2006-01-08[PATCH] Add block_device_operations.getgeo block device methodChristoph Hellwig
HDIO_GETGEO is implemented in most block drivers, and all of them have to duplicate the code to copy the structure to userspace, as well as getting the start sector. This patch moves that to common code [1] and adds a ->getgeo method to fill out the raw kernel hd_geometry structure. For many drivers this means ->ioctl can go away now. [1] the s390 block drivers are odd in this respect. xpram sets ->start to 4 always which seems more than odd, and the dasd driver shifts the start offset around, probably because of it's non-standard sector size. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jens Axboe <axboe@suse.de> Cc: <mike.miller@hp.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo Giarrusso <blaisorblade@yahoo.it> Cc: Bartlomiej Zolnierkiewicz <B.Zolnierkiewicz@elka.pw.edu.pl> Cc: Neil Brown <neilb@cse.unsw.edu.au> Cc: Markus Lidel <Markus.Lidel@shadowconnect.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: James Bottomley <James.Bottomley@steeleye.com> Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06Merge branch 'post-2.6.15' of git://brick.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
Manual fixup for merge with Jens' "Suspend support for libata", commit ID 9b847548663ef1039dd49f0eb4463d001e596bc3. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] I2O: Lindent runMarkus Lidel
2006-01-06[PATCH] I2O: OptimizingMarkus Lidel
- make i2o_iop_free() static inline (from Adrian Bunk) - changed kmalloc() + memset(0) into kzalloc() Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] I2O: BeautifyingMarkus Lidel
Fix some typos and minor code beautifying. Signed-off-by: Markus Lidel <Markus.Lidel@shadowconnect.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] I2O: BugfixesMarkus Lidel
- Removed some kmalloc's with __GFP_ZERO and replace it with memset() because it didn't work properly. - Fixed returned message frame in i2o_cfg_passthru() which caused raidutils to display wrong error message in case a disk was missing. - Fixed size of printk() in i2o_scsi.c. - Fixed get_device() and put_device() in probing of the I2O controller. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
