commit bcfe42e98047f1935c5571c8ea77beb2d43ec19d upstream.
There's a branch at the end of this function that
is supposed to normalize the return value with what
the mid-layer expects. In this one case, we get it wrong.
Also increase the verbosity of the INFO level printk
at the end of mptscsih_abort to include the actual return value
and the scmd->serial_number. The reason being success
or failure is actually determined by the state of
the internal tag list when a TMF is issued, and not the
return value of the TMF cmd. The serial_number is also
used in this decision, thus it's useful to know for debugging
purposes.
Reported-by: Peter M. Petrakis <peter.petrakis@canonical.com>
Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
commit 84857c8bf83e8aa87afc57d2956ba01f11d82386 upstream.
Added missing release callback for file_operations mptctl_fops.
Without release callback there will be never freed. It remains on
mptctl's eent list even after the file is closed and released.
Relavent RHEL bugzilla is 660871
commit 2a1b7e575b80ceb19ea50bfa86ce0053ea57181d upstream.
I may have an explanation for the LSI 1068 HBA hangs provoked by ATA
pass-through commands, in particular by smartctl.
First, my version of the symptoms. On an LSI SAS1068E B3 HBA running
01.29.00.00 firmware, with SATA disks, and with smartd running, I'm seeing
occasional task, bus, and host resets, some of which lead to hard faults of
the HBA requiring a reboot. Abusively looping the smartctl command,
# while true; do smartctl -a /dev/sdb > /dev/null; done
dramatically increases the frequency of these failures to nearly one per
minute. A high IO load through the HBA while looping smartctl seems to
improve the chance of a full scsi host reset or a non-recoverable hang.
I reduced what smartctl was doing down to a simple test case which
causes the hang with a single IO when pointed at the sd interface. See
the code at the bottom of this e-mail. It uses an SG_IO ioctl to issue
a single pass-through ATA identify device command. If the buffer
userspace gives for the read data has certain alignments, the task is
issued to the HBA but the HBA fails to respond. If run against the sg
interface, neither the test code nor smartctl causes a hang.
sd and sg handle the SG_IO ioctl slightly differently. Unless you
specifically set a flag to do direct IO, sg passes a buffer of its own,
which is page-aligned, to the block layer and later copies the result
into the userspace buffer regardless of its alignment. sd, on the other
hand, always does direct IO unless the userspace buffer fails an
alignment test at block/blk-map.c line 57, in which case a page-aligned
buffer is created and used for the transfer.
The alignment test currently checks for word-alignment, the default
setup by scsi_lib.c; therefore, userspace buffers of almost any
alignment are given directly to the HBA as DMA targets. The LSI 1068
hardware doesn't seem to like at least a couple of the alignments which
cross a page boundary (see the test code below). Curiously, many
page-boundary-crossing alignments do work just fine.
So, either the hardware has an bug handling certain alignments or the
hardware has a stricter alignment requirement than the driver is
advertising. If stricter alignment is required, then in no case should
misaligned buffers from userspace be allowed through without being
bounced or at least causing an error to be returned.
It seems the mptsas driver could use blk_queue_dma_alignment() to advertise
a stricter alignment requirement. If it does, sd does the right thing and
bounces misaligned buffers (see block/blk-map.c line 57). The following
patch to 2.6.34-rc5 makes my symptoms go away. I'm sure this is the wrong
place for this code, but it gets my idea across.
Acked-by: Kashyap Desai <Kashyap.Desai@lsi.com>
Use memdup_user when user data is immediately copied into the
allocated region.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
expression from,to,size,flag;
position p;
identifier l1,l2;
- to = \(kmalloc@p\|kzalloc@p\)(size,flag);
+ to = memdup_user(from,size);
if (
- to==NULL
+ IS_ERR(to)
<+... when != goto l1;
- -ENOMEM
+ PTR_ERR(to)
- if (copy_from_user(to, from, size) != 0) {
- <+... when != goto l2;
- -EFAULT
// </smpl>
The function name must be followed by a space, hypen, space, and a
short description.
Cc: Eric Moore <Eric.Moore@lsi.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (182 commits)
[SCSI] aacraid: add an ifdef'd device delete case instead of taking the device offline
[SCSI] aacraid: prohibit access to array container space
[SCSI] aacraid: add support for handling ATA pass-through commands.
[SCSI] aacraid: expose physical devices for models with newer firmware
[SCSI] aacraid: respond automatically to volumes added by config tool
[SCSI] fcoe: fix fcoe module ref counting
[SCSI] libfcoe: FIP Keep-Alive messages for VPorts are sent with incorrect port_id and wwn
[SCSI] libfcoe: Fix incorrect MAC address clearing
[SCSI] fcoe: fix a circular locking issue with rtnl and sysfs mutex
[SCSI] libfc: Move the port_id into lport
[SCSI] fcoe: move link speed checking into its own routine
[SCSI] libfc: Remove extra pointer check
[SCSI] libfc: Remove unused fc_get_host_port_type
[SCSI] fcoe: fixes wrong error exit in fcoe_create
[SCSI] libfc: set seq_id for incoming sequence
[SCSI] qla2xxx: Updates to ISP82xx support.
[SCSI] qla2xxx: Optionally disable target reset.
[SCSI] qla2xxx: ensure flash operation and host reset via sg_reset are mutually exclusive
[SCSI] qla2xxx: Silence bogus warning by gcc for wrap and did.
[SCSI] qla2xxx: T10 DIF support added.
This is just a cleanup and doesn't change how the code works.
The original code had a mix of returns and gotos so I changed everything
to just return directly.
Reviewed-by: Christoph Lameter <cl@linux-foundation.org>
Upgrade version from 3.04.14 to 3.04.15
Added proper error handling after mpt_config.
Now check of MPI_IOCSTATUS_CONFIG_INVALID_PAGE is added.
If error is MPI_IOCSTATUS_CONFIG_INVALID_PAGE, driver will return -ENODEV.
event_data needs to be 4 byte aligned to makes sure there is no unaligned
memory access take place.
1) Corrected name string as "MPT SAS HOST"
2) Added proper check conditions for MPT_MGMT_STATUS_COMMAND_GOOD.
1) corrected return value as SUCCESS instead of 0.
2) Added check in mptscsih_abort.
mptfusion do not support task abort for Volumes.
Added sanity checks before accessing vdevice and added vdevice->deleted
setting for mptfc.
Set factor, offset and width while target negotiation.
Added config timeout 60 seconds. It was missing for only
mptspi_read_spi_device_pg0
Added proper bus_type check before processing event/ reset handler.
Current design of mptsas is as follow.
MPTSAS will do probe() if pci id matches for available card in
system, irrespective of mode of controller. If controller is I/T mode
or I mode, things are fine. If controller is only in T mode, mptsas is
not doing complete process of mptsas_probe(). It will only make
sure IOC structure is created and IOC reference is available for
mptstm driver. Now While removing module we should take care
case of Target mode only mptsas. If we are removing IOC which is
only in Target mode, We should only detach IOC instead of
following rest of the cleanup process which is only required for T
mode controller. Now For T mode controller, only part clean up is
done instead of complete cleanup. mpt_detach will call early in case
of Target mode only controller.
mpt_config would only attempt a MUR before retrying the command. The
driver will now retry a second time with a hard reset before leaving
the function.
Behavior changes only for IOCTLs that time out. Current behavior of
Bus Reset remains the same for RAID Passthru Timeouts Current behavior
of Diagnostic reset for any other type of IOCTL remains the same
CHANGE: For IOCTL SCSI IOs that timeout, a Target Reset TM is sent,
instead of Bus Reset. All error handing from that point is the same as
what the driver currently does, which is to say that if the Device
Reset TM fails it escalates do diagnostic reset.
Message Unit Reset - instructs the IOC to reset the Reply Post and
Free FIFO's. All the Message Frames on Reply Free FIFO are
discarded. All posted buffers are freed, and event notification is
turned off. IOC doesnt reply to any outstanding request. This will
transfer IOC to READY state. Message unit ready is less expensive
operations than Hard Reset. soft reset will not force Firmware to
reload again, it only do clean up of Message units.
mpt_Soft_Hard_ResetHandler will first try for Soft Reset,if
it fails then go for big hammer reset which is Hard Reset.
This patch fixes some issues of mptctl_exit().
1) It doesn't call mpt_deregister() for mptctl_taskmgmt_id
=> Insmoding/rmmoding mptctl.ko repeadtedly (up to
MPT_MAX_PROTOCOL_DRIVERS-1 at most) can eat up all cb_idx,
and that would cause a lack of MptCallbacks[], MptDriverClass[],
and MptEvHandlers[].
2) It doesn't call mpt_event_deregister() for mptctl_id
=> Need to call it.
3) It calls mpt_reset_deregister() for mptctl_taskmgmt_id
=> This could accidentally deregister an innocent reset handler
that you don't want to.
This patch also adds a check for mptctl_taskmgmt_id.
Signed-off-by: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com>
Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com>
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
Documentation/filesystems/proc.txt
arch/arm/mach-u300/include/mach/debug-macro.S
drivers/net/qlge/qlge_ethtool.c
drivers/net/qlge/qlge_main.c
drivers/net/typhoon.c
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1341 commits)
virtio_net: remove forgotten assignment
be2net: fix tx completion polling
sis190: fix cable detect via link status poll
net: fix protocol sk_buff field
bridge: Fix build error when IGMP_SNOOPING is not enabled
bnx2x: Tx barriers and locks
scm: Only support SCM_RIGHTS on unix domain sockets.
vhost-net: restart tx poll on sk_sndbuf full
vhost: fix get_user_pages_fast error handling
vhost: initialize log eventfd context pointer
vhost: logging thinko fix
wireless: convert to use netdev_for_each_mc_addr
ethtool: do not set some flags, if others failed
ipoib: returned back addrlen check for mc addresses
netlink: Adding inode field to /proc/net/netlink
axnet_cs: add new id
bridge: Make IGMP snooping depend upon BRIDGE.
bridge: Add multicast count/interval sysfs entries
bridge: Add hash elasticity/max sysfs entries
bridge: Add multicast_snooping sysfs toggle
Trivial conflicts in Documentation/feature-removal-schedule.txt
* 'for-2.6.34' of git://git.kernel.dk/linux-2.6-block: (38 commits)
block: don't access jiffies when initialising io_context
cfq: remove 8 bytes of padding from cfq_rb_root on 64 bit builds
block: fix for "Consolidate phys_segment and hw_segment limits"
cfq-iosched: quantum check tweak
blktrace: perform cleanup after setup error
blkdev: fix merge_bvec_fn return value checks
cfq-iosched: requests "in flight" vs "in driver" clarification
cciss: Fix problem with scatter gather elements in the scsi half of the driver
cciss: eliminate unnecessary pointer use in cciss scsi code
cciss: do not use void pointer for scsi hba data
cciss: factor out scatter gather chain block mapping code
cciss: fix scatter gather chain block dma direction kludge
cciss: simplify scatter gather code
cciss: factor out scatter gather chain block allocation and freeing
cciss: detect bad alignment of scsi commands at build time
cciss: clarify command list padding calculation
cfq-iosched: rethink seeky detection for SSDs
cfq-iosched: rework seeky detection
block: remove padding from io_context on 64bit builds
block: Consolidate phys_segment and hw_segment limits
drivers/firmware/iscsi_ibft.c
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (158 commits)
[SCSI] Fix printing of failed 32-byte commands
[SCSI] Fix printing of variable length commands
[SCSI] libsrp: fix bug in ADDITIONAL CDB LENGTH interpretation
[SCSI] scsi_dh_alua: Add IBM Power Virtual SCSI ALUA device to dev list
[SCSI] scsi_dh_alua: add netapp to dev list
[SCSI] qla2xxx: Update version number to 8.03.02-k1.
[SCSI] qla2xxx: EEH: Restore PCI saved state during pci slot reset.
[SCSI] qla2xxx: Add firmware ETS burst support.
[SCSI] qla2xxx: Correct loop-resync issues during SNS scans.
[SCSI] qla2xxx: Correct use-after-free issue in terminate_rport_io callback.
[SCSI] qla2xxx: Correct EH bus-reset handling.
[SCSI] qla2xxx: Proper clean-up of BSG requests when request times out.
[SCSI] qla2xxx: Initialize payload receive length in failure path of vendor commands
[SCSI] fix duplicate removal on error path in scsi_sysfs_add_sdev
[SCSI] fix refcounting bug in scsi_get_host_dev
[SCSI] fix memory leak in scsi_report_lun_scan
[SCSI] lpfc: correct PPC build failure
[SCSI] raid_class: add raid1e
[SCSI] mpt2sas: Do not call sas_is_tlr_enabled for RAID volumes.
[SCSI] zfcp: Introduce header file for qdio structs and inline functions
Except for SCSI no device drivers distinguish between physical and
hardware segment limits. Consolidate the two into a single segment
limit.
The block layer calling convention is blk_queue_<limit name>.
blk_queue_max_sectors predates this practice, leading to some confusion.
Rename the function to appropriately reflect that its intended use is to
set max_hw_sectors.
Also introduce a temporary wrapper for backwards compability. This can
be removed after the merge window is closed.
After discussing this patch with LSI, I resubmitting with a recommended
40 second wait for the alternate ioc's initialization to complete.
Fusion FC chips are two function with some shared resources. During
initialization of one function its driver inhibits the ability of the
other function's driver to allocate message frames by clearing its
"active" flag. Should mid-layer error recovery be initiated for a
scsi command during this initialization (which can take up to 40 seconds)
error recovery will escalate to the level of host reset. This host
reset might fail (as the other function is resetting) resulting in
all connected targets being taken offline.
This patch holds off mid-layer error recovery for up to 40 seconds
to permit initialization of the other function to complete.
Signed-off-by: Michael Reed <mdr@sgi.com>
value 0.
retval should be SUCCESS/FAILED which is defined at scsi.h
retval = 0 is directing wrong return value. It must be retval = SUCCESS.
Version upgrade to 3.04.14.
commands
Modified the function type check to verify it is not
MPI_FUNCTION_RAID_SCSI_IO_PASSTHROUGH or MPI_FUNCTION_SCSI_IO_REQUEST.
Add support to set the sdev state to SDEV_BLOCK during device removal
to stop IOs comming to the deleting driver immediately.
of expander add.
Added new function mptsas_exp_manufacture_info, which will
obtain the REPORT_MANUFACTURING, and fill the details into the
sas_expander_device object when the expander port is created.
There is a 'ioprio' field in the BIO and the Request structure.
check this priority field and set MPI_SCSIIO_CONTROL_HEADOFQ
to pass down I/O priority.
An enhancement to the LSI Disk Array Controller firmware is being
developed to look at the Head Of Queue bit to allow I/Os with the HOQ bit
set to be processed before I/Os which do not have the HOQ bit set.
In order to set the HOQ bit, the mpt fusion driver needs to look at the
'ioprio' field in the request structure associated with the scsi command.
Fixes the following warning:
drivers/message/fusion/mptbase.c:129: warning: 'mpt_proc_root_dir' defined but not used
also moves it from public data section since it is static.
Signed-off-by: Erik Ekman <erik@kryo.se>
Since commit 9d2e9d66a3f032667934144cd61c396ba49f090d
mptsas driver fails to allocate memory for the MPT chain buffers
for second LSI adapter on PPC440SPe Katmai platform:
ioc1: LSISAS1068E B3: Capabilities={Initiator}
mptbase: ioc1: ERROR - Unable to allocate Reply, Request, Chain Buffers!
mptbase: ioc1: ERROR - didn't initialize properly! (-3)
mptsas: probe of 0002:31:00.0 failed with error -3
This commit increased MPT_FC_CAN_QUEUE value but initChainBuffers()
doesn't differentiate between SAS and FC causing increased allocation
for SAS case, too. Later pci_alloc_consistent() fails to allocate
increased chain buffer pool size for SAS case.
Provide a fix by looking at the bus type and using appropriate
MPT_SAS_CAN_QUEUE value while calculation of the number of chain
buffers.
Acked-by: Kashyap Desai <kashyap.desai@lsi.com>
Cc: Stable Tree <stable@kernel.org>
Use the %pM kernel extension to display the MAC address.
Nobody seems to want to own I2O patches so sending this one directly.
Signed-off-by: Alan Cox <alan@linux.intel.com>
Powerpc 44x uses 36 bit real address while the real address defined in
MPT Fusion driver is of type 32 bit. This causes ioremap to fail and
driver fails to initialize. This fix changes the data types
representing the real address from unsigned long 32-bit types to
resource_size_t which is 64-bit. The driver has been tested, the disks
get discovered correctly and can do IO.
[jejb: added printk fix for resource_size_t object]
Signed-off-by: Pravin Bathija <pbathija@amcc.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits)
tree-wide: fix misspelling of "definition" in comments
reiserfs: fix misspelling of "journaled"
doc: Fix a typo in slub.txt.
inotify: remove superfluous return code check
hdlc: spelling fix in find_pvc() comment
doc: fix regulator docs cut-and-pasteism
mtd: Fix comment in Kconfig
doc: Fix IRQ chip docs
tree-wide: fix assorted typos all over the place
drivers/ata/libata-sff.c: comment spelling fixes
fix typos/grammos in Documentation/edac.txt
sysctl: add missing comments
fs/debugfs/inode.c: fix comment typos
sgivwfb: Make use of ARRAY_SIZE.
sky2: fix sky2_link_down copy/paste comment error
tree-wide: fix typos "couter" -> "counter"
tree-wide: fix typos "offest" -> "offset"
fix kerneldoc for set_irq_msi()
spidev: fix double "of of" in comment
comment typo fix: sybsystem -> subsystem
This patch modifies scsi_host_template->change_queue_depth so that
it takes an argument indicating why it is being called. This will be
used so that if a LLD needs to do some extra processing when
handling queue fulls or later ramp ups, it can do so.
This is a simple port of the drivers setting a change_queue_depth
callback. In the patch I just have these LLDs adjust the queue depth
if the user was requesting it.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
[Vasu.Dev: v2
Also converted pmcraid_change_queue_depth and then verified
all modules compile using "make allmodconfig" for any new build
warnings on X86_64.
Updated original description after combing two original
patches from Mike to make this patch git bisectable.]
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
[jejb: fixed up 53c700]
That is "success", "unknown", "through", "performance", "[re|un]mapping"
, "access", "default", "reasonable", "[con]currently", "temperature"
, "channel", "[un]used", "application", "example","hierarchy", "therefore"
, "[over|under]flow", "contiguous", "threshold", "enough" and others.
Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com>
Bump version 3.04.13.
Errata:
Certain conditions on the scsi bus may casue the 53C1030 to incorrectly signal
a SCSI_DATA_UNDERRUN to the host.
Workaround 1:
For an Errata on LSI53C1030 When the length of request data
and transfer data are different with result of command (READ or VERIFY),
DID_SOFT_ERROR is set.
Workaround 2:
For potential trouble on LSI53C1030. It is checked whether the length of
request data is equal to the length of transfer and residual.
MEDIUM_ERROR is set by incorrect data.
var/log/message
After m68k's task_thread_info() doesn't refer to current,
it's possible to remove sched.h from interrupt.h and not break m68k!
Many thanks to Heiko Carstens for allowing this.
