path: root/drivers/message
2010-08-14fusion: add function parameter names to kernel-docRandy Dunlap
Fix fusion missing kernel-doc: Warning(drivers/message/fusion/mptbase.c:649): No description found for parameter 'func_name' Warning(drivers/message/fusion/mptbase.c:8010): No description found for parameter 'cb_idx' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14fusion: fix non-kernel-doc comment blockRandy Dunlap
Fix comment begin notation not to look like kernel-doc since it's not. Removes kernel-doc warnings. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-14Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (28 commits) [SCSI] qla4xxx: fix compilation warning [SCSI] make error handling more robust in the face of reservations [SCSI] tgt: fix warning [SCSI] drivers/message/fusion: Adjust confusing if indentation [SCSI] Return NEEDS_RETRY for eh commands with status BUSY [SCSI] ibmvfc: Driver version 1.0.9 [SCSI] ibmvfc: Fix terminate_rport_io [SCSI] ibmvfc: Fix rport add/delete race resulting in oops [SCSI] lpfc 8.3.16: Change LPFC driver version to 8.3.16 [SCSI] lpfc 8.3.16: FCoE Discovery and Failover Fixes [SCSI] lpfc 8.3.16: SLI Additions, updates, and code cleanup [SCSI] pm8001: introduce missing kfree [SCSI] qla4xxx: Update driver version to 5.02.00-k3 [SCSI] qla4xxx: Added AER support for ISP82xx [SCSI] qla4xxx: Handle outstanding mbx cmds on hung f/w scenarios [SCSI] qla4xxx: updated mbx_sys_info struct to sync with FW 4.6.x [SCSI] qla4xxx: clear AF_DPC_SCHEDULED flage when exit from do_dpc [SCSI] qla4xxx: Stop firmware before doing init firmware. [SCSI] qla4xxx: Use the correct request queue. [SCSI] qla4xxx: set correct value in sess->recovery_tmo ...
2010-08-12Merge branch 'params' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus * 'params' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: (22 commits) param: don't deref arg in __same_type() checks param: update drivers/acpi/debug.c to new scheme param: use module_param in drivers/message/fusion/mptbase.c ide: use module_param_named rather than module_param_call param: update drivers/char/ipmi/ipmi_watchdog.c to new scheme param: lock if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes. param: lock myri10ge_fw_name against sysfs changes. param: simple locking for sysfs-writable charp parameters param: remove unnecessary writable charp param: add kerneldoc to moduleparam.h param: locking for kernel parameters param: make param sections const. param: use free hook for charp (fix leak of charp parameters) param: add a free hook to kernel_param_ops. param: silence .init.text references from param ops Add param ops struct for hvc_iucv driver. nfs: update for module_param_named API change AppArmor: update for module_param_named API change param: use ops in struct kernel_param, rather than get and set fns directly param: move the EXPORT_SYMBOL to after the definitions. ...
2010-08-11fusion: fix kernel-doc warningsRandy Dunlap
Fix (delete) empty kernel-doc lines/warnings: Warning(drivers/message/fusion/mptbase.c:6916): bad line: Warning(drivers/message/fusion/mptbase.c:7060): bad line: Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11i2o: check return code from put_user()Kulikov Vasiliy
Check return value of put_user() and return -EFAULT if it failed. Original comment "We did a get user...so assuming mem is ok...is this bad?" is incorrect because memory can be read only. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11i2o: fix overflow of copy_to_user()Kulikov Vasiliy
If (len > reslen) we must not call copy_to_user() since kernel buffer is smaller than we want to copy. Similar code in this file is correct, so this bug was a typo. Signed-off-by: Kulikov Vasiliy <segooon@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11drivers/message/i2o/exec-osm.c: add missing mutex_unlockJulia Lawall
Add a mutex_unlock missing on the error path. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression E1; @@ * mutex_lock(E1,...); <+... when != E1 if (...) { ... when != E1 * return ...; } ...+> * mutex_unlock(E1,...); // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11mpt fusion: convert to seq_fileAlexey Dobriyan
Convert everything except ->proc_info() stuff, it is done within separate ->proc_info path series. Problem with ->read_proc et al is described here commit 786d7e1612f0b0adb6046f19b906609e4fe8b1ba "Fix rmmod/read/write races in /proc entries" Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Eric Moore <Eric.Moore@lsi.com> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11drivers/message: move dereference after NULL testJulia Lawall
If the NULL test on dev->i2o_dev or i2o_dev is needed, then the dereference should be after the NULL test. A simplified version of the semantic match that detects this problem is as follows (http://coccinelle.lip6.fr/): // <smpl> @match exists@ expression x, E; identifier fld; @@ * x->fld ... when != \(x = E\|&x\) * x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Cc: James Bottomley <James.Bottomley@suse.de> Cc: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-11param: use module_param in drivers/message/fusion/mptbase.cRusty Russell
No need to open code this! Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de>
2010-08-11[SCSI] drivers/message/fusion: Adjust confusing if indentationJulia Lawall
Indent the branch of an if. The semantic match that finds this problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @r disable braces4@ position p1,p2; statement S1,S2; @@ ( if (...) { ... } | if (...) S1@p1 S2@p2 ) @script:python@ p1 << r.p1; p2 << r.p2; @@ if (p1[0].column == p2[0].column): cocci.print_main("branch",p1) cocci.print_secs("after",p2) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-07scsi/i2o: restore ioctl changesArnd Bergmann
This restores the changes from "scsi/i2o_block: cleanup ioctl handling", which accidentally got reverted. Origignal changelog: This fixes the ioctl function of the i2o_block driver, which has multiple problems: * The BLKI2OSRSTRAT and BLKI2OSWSTRAT commands always return -ENOTTY on success, where they should return 0. * Support for 32 bit compat is missing * The driver should use the .ioctl function and because .locked_ioctl is going away. The use of the big kernel lock remains for now, but gets made explictit in the ioctl function. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push down BKL into .open and .releaseArnd Bergmann
The open and release block_device_operations are currently called with the BKL held. In order to change that, we must first make sure that all drivers that currently rely on this have no regressions. This blindly pushes the BKL into all .open and .release operations for all block drivers to prepare for the next step. The drivers can subsequently replace the BKL with their own locks or remove it completely when it can be shown that it is not needed. The functions blkdev_get and blkdev_put are the only remaining users of the big kernel lock in the block layer, besides a few uses in the ioctl code, none of which need to serialize with blkdev_{get,put}. Most of these two functions is also under the protection of bdev->bd_mutex, including the actual calls to ->open and ->release, and the common code does not access any global data structures that need the BKL. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07block: push down BKL into .locked_ioctlArnd Bergmann
As a preparation for the removal of the big kernel lock in the block layer, this removes the BKL from the common ioctl handling code, moving it into every single driver still using it. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-07scsi/i2o_block: cleanup ioctl handlingArnd Bergmann
2010-08-07block: remove wrappers for request type/flagsChristoph Hellwig
Remove all the trivial wrappers for the cmd_type and cmd_flags fields in struct requests. This allows much easier grepping for different request types instead of unwinding through macros. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-07-28[SCSI] mptfusion: release resources in error return pathTomas Henzl
We should release the resources in error return code path. The requested pci bars should be released under an error condition, when mpt_mapresources fails. Signed-off-by: Tomas Henzl <thenzl@redhat.com> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-28[SCSI] mptfusion: Bump version 03.04.17Kashyap, Desai
Version upgrade patch. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-28[SCSI] mptfusion: Extra debug prints added relavent to Device missing delay ↵Kashyap, Desai
error handling Adding function name in original debug prints and few more debug prints are added. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-28[SCSI] mptfusion: Block Error handling for deleting devices or Device in DMDKashyap, Desai
Issue description: In multipath topology, when device deletion is in transient state, multipath driver can call blk_flush_queue() as part of path failure. Before device get deleted from OS, Device may go OFFLINE as part of error handling kicked off triggered from multipathing driver. Above condition hits more frequently if device missing delay timer (which is LSI specific firmware parameter) is non zero value. root cause of this issue is Error handling thread is getting kicked off for device which is not really present(in transient state of deleting). This patch has solution for this issue. driver is now using eh_timed_out callback. See below. mptsas_transport_template->eh_timed_out = mptsas_eh_timed_out Using mptsas_eh_timed_out function, driver can decide weather vdevice is under Device missing delay or deleting state. for either of those cases, there is BLK_EH_RESET_TIMER return to scsi mid and error handling thread will not be kicked off for that particular scsi command. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Cc: Stable Tree <stable@kernel.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptfusion: print Doorbell register in a case of hard reset and timeoutKei Tokunaga
Printing Doorbell register in a case of hard reset and timeout should be useful for figuring out the state of the system. Signed-off-by: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptsas: fixed hot-removal processingKei Tokunaga
This patch fixes mptsas disk hot-removal processing. The hot-removal processing doesn't complete because of this condition. drivers/message/fusion/mptsas.c: mptsas_taskmgmt_complete() if ((mptsas_find_vtarget(ioc, channel, id)) && !ioc->fw_events_off) mptsas_queue_device_delete(...); mptsas_queue_device_delete(), which must be called for hot-removal, never gets called because mptsas_find_vtarget() always returns 0 here. At that time, the vtarget has already been freed in mptsas_target_destroy(), and also the scsi_device has been marked as SDEV_DEL. As a result of the issue, port deletion functions won't get called and the device ends up being in an incomplete state. (Some data structures and sysfs entries, which should be removed in hot-removal, remain.) One side effect of this is that a hot-addition of the device (bringing the device back on) fails. This patch just removes mptsas_find_vtarget() from the if-state condition. Signed-off-by: Kei Tokunaga <tokunaga.keiich@jp.fujitsu.com> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mpt fusion: Cleanup some duplicate calls in mptbase.cBandan Das
In mpt_detach, call to pci_set_drvdata is redundant because it has already been called in mpt_adapter_disable. In mpt_attach, ioc->pcidev is set to pdev two times. Signed-off-by: Bandan Das <bandan.das@stratus.com> Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptfusion: Bump version 03.04.16Kashyap, Desai
Upgrade driver version to 3.4.16 Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptfusion: Added missing reset for ioc_reset_in_progress in SoftResetKashyap, Desai
Added missing part which will reset ioc_reset_in_progress before returning from SoftResetHandler. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptfusion: Added code for occationally SATA hotplug failure.Kashyap, Desai
Issue: SATA hotplug does not work sometimes. At the time of ADD device/ADD phys disk, drive may fail to add SATA device due to temporary SAS Address for SATA device generated by firmware. Final SAS address for SATA driver will be generated only after disk spinup is done. This may take some times for slow spining SATA drives. At phy link up driver gets attached device sas address and stores into phyinfo. At the time of ADD event driver will read sas device page0 using channel and FW ID provided in ADD Device event. Here in case of SATA drives, driver will see miss match in phyinfo->sas_address and latest sas address read from SAS DEVICE PAGE0 and eventually device won't be added to OS. Fix: When Driver read SAS DEVICE PAGE0, it can identify Device type looking at device_info. If device is SATA drive and sas address mismatch happens, Driver will do same stuffs which happened at the time of LINK UP to get correct piece of information from Pages. ( Find parent device and refresh parent device phys either HBA refresh/Exp refresh) Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptfusion: schedule_target_reset from all Reset contextKashyap, Desai
Issue: target reset will be queued to driver's internal queue to get schedule later. When driver add target into internal target_reset queue we will block IOs on those target using scsi midlayer API. Now due to some cause driver is not executing those target_reset list and it is always in block state. Changes: now we are clearing target_reset queue from all other Callback context instead of only DeviceReset context.Now wherever driver is clearing taskmgmt_in_progress flag it is considering target_reset queue cleanup also. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptfusion: Added sanity to check B_T mapping for device before adding ↵Kashyap, Desai
to OS Added sanity check before treating any device is a valid device. It is possible that firmware can have device page0 in its table, but that devicemay not be available in topology. Device will be available in topology only if there is Bus Target mapping is done in firmware. Driver will always check B_T mapping of firmware before reporting device to upper layer. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptfusion: Corrected declaration of device_missing_delayKashyap, Desai
device missing delay is 8 bit value in io unit pg1. Making correct variable declaration for device_missing_delay. The driver is storing the calculated device missing delay in IOC structure as a u8 instead of a u16. It needs to be a u16 if the delay is > 255. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptfusion: Use DID_TRANSPORT_DISRUPTED instead of DID_BUS_BUSYKashyap, Desai
Changed the return value for Nexus Loss IOs to be DID_TRANSPORT_DISRUPTED. What this will allow is the multi-path driver to delay the fail over process. They would like the path to keep up as long as the nexus loss Loginfo is return from firmware. With DID_BUS_BUSY the path fails over immediately. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptfusion: Set fw_events_off to 1 at driver load time.Kashyap, Desai
fw_events_off is flag checking for driver to do Event handling or not. Normally it should be OFF at the time of initialization. Only enable it at the time of INTR enable of device first time. This will always occur only after resource allocation. ioc->fw_events_off = 1 is set in mpt_attach() Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-07-27[SCSI] mptsas: fix hangs caused by ATA pass-throughRyan Kuester
I may have an explanation for the LSI 1068 HBA hangs provoked by ATA pass-through commands, in particular by smartctl. First, my version of the symptoms. On an LSI SAS1068E B3 HBA running 01.29.00.00 firmware, with SATA disks, and with smartd running, I'm seeing occasional task, bus, and host resets, some of which lead to hard faults of the HBA requiring a reboot. Abusively looping the smartctl command, # while true; do smartctl -a /dev/sdb > /dev/null; done dramatically increases the frequency of these failures to nearly one per minute. A high IO load through the HBA while looping smartctl seems to improve the chance of a full scsi host reset or a non-recoverable hang. I reduced what smartctl was doing down to a simple test case which causes the hang with a single IO when pointed at the sd interface. See the code at the bottom of this e-mail. It uses an SG_IO ioctl to issue a single pass-through ATA identify device command. If the buffer userspace gives for the read data has certain alignments, the task is issued to the HBA but the HBA fails to respond. If run against the sg interface, neither the test code nor smartctl causes a hang. sd and sg handle the SG_IO ioctl slightly differently. Unless you specifically set a flag to do direct IO, sg passes a buffer of its own, which is page-aligned, to the block layer and later copies the result into the userspace buffer regardless of its alignment. sd, on the other hand, always does direct IO unless the userspace buffer fails an alignment test at block/blk-map.c line 57, in which case a page-aligned buffer is created and used for the transfer. The alignment test currently checks for word-alignment, the default setup by scsi_lib.c; therefore, userspace buffers of almost any alignment are given directly to the HBA as DMA targets. The LSI 1068 hardware doesn't seem to like at least a couple of the alignments which cross a page boundary (see the test code below). Curiously, many page-boundary-crossing alignments do work just fine. So, either the hardware has an bug handling certain alignments or the hardware has a stricter alignment requirement than the driver is advertising. If stricter alignment is required, then in no case should misaligned buffers from userspace be allowed through without being bounced or at least causing an error to be returned. It seems the mptsas driver could use blk_queue_dma_alignment() to advertise a stricter alignment requirement. If it does, sd does the right thing and bounces misaligned buffers (see block/blk-map.c line 57). The following patch to 2.6.34-rc5 makes my symptoms go away. I'm sure this is the wrong place for this code, but it gets my idea across. Acked-by: "Desai, Kashyap" <Kashyap.Desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-06-16Merge branch 'master' into for-nextJiri Kosina
2010-06-16fix typos concerning "initiali[zs]e"Uwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-05-27drivers/message/i2o/i2o_config.c: use memdup_userJulia Lawall
Use memdup_user when user data is immediately copied into the allocated region. The semantic patch that makes this change is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression from,to,size,flag; position p; identifier l1,l2; @@ - to = \(kmalloc@p\|kzalloc@p\)(size,flag); + to = memdup_user(from,size); if ( - to==NULL + IS_ERR(to) || ...) { <+... when != goto l1; - -ENOMEM + PTR_ERR(to) ...+> } - if (copy_from_user(to, from, size) != 0) { - <+... when != goto l2; - -EFAULT - ...+> - } // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-24fusion: fix kernel-doc notationBen Hutchings
The function name must be followed by a space, hypen, space, and a short description. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Eric Moore <Eric.Moore@lsi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21Merge git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (182 commits) [SCSI] aacraid: add an ifdef'd device delete case instead of taking the device offline [SCSI] aacraid: prohibit access to array container space [SCSI] aacraid: add support for handling ATA pass-through commands. [SCSI] aacraid: expose physical devices for models with newer firmware [SCSI] aacraid: respond automatically to volumes added by config tool [SCSI] fcoe: fix fcoe module ref counting [SCSI] libfcoe: FIP Keep-Alive messages for VPorts are sent with incorrect port_id and wwn [SCSI] libfcoe: Fix incorrect MAC address clearing [SCSI] fcoe: fix a circular locking issue with rtnl and sysfs mutex [SCSI] libfc: Move the port_id into lport [SCSI] fcoe: move link speed checking into its own routine [SCSI] libfc: Remove extra pointer check [SCSI] libfc: Remove unused fc_get_host_port_type [SCSI] fcoe: fixes wrong error exit in fcoe_create [SCSI] libfc: set seq_id for incoming sequence [SCSI] qla2xxx: Updates to ISP82xx support. [SCSI] qla2xxx: Optionally disable target reset. [SCSI] qla2xxx: ensure flash operation and host reset via sg_reset are mutually exclusive [SCSI] qla2xxx: Silence bogus warning by gcc for wrap and did. [SCSI] qla2xxx: T10 DIF support added. ...
2010-04-26i2o: cleanup some exit pathsDan Carpenter
This is just a cleanup and doesn't change how the code works. The original code had a mix of returns and gotos so I changed everything to just return directly. Signed-off-by: Dan Carpenter <error27@gmail.com> Reviewed-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-04-11[SCSI] mptfusion: Bump version 03.04.15Kashyap, Desai
Upgrade version from 3.04.14 to 3.04.15 Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mptfusion: Proper error handling is added after mpt_config timeoutKashyap, Desai
Added proper error handling after mpt_config. Now check of MPI_IOCSTATUS_CONFIG_INVALID_PAGE is added. If error is MPI_IOCSTATUS_CONFIG_INVALID_PAGE, driver will return -ENODEV. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mptfusion: Event data alignment with 4 byte.Kashyap, Desai
event_data needs to be 4 byte aligned to makes sure there is no unaligned memory access take place. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mptfusion: Check for command status is added after completion.Kashyap, Desai
1) Corrected name string as "MPT SAS HOST" 2) Added proper check conditions for MPT_MGMT_STATUS_COMMAND_GOOD. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mptfusion: Task abort is not supported for VolumesKashyap, Desai
1) corrected return value as SUCCESS instead of 0. 2) Added check in mptscsih_abort. mptfusion do not support task abort for Volumes. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mptfusion: sanity check for vdevice pointer is addedKashyap, Desai
Added sanity checks before accessing vdevice and added vdevice->deleted setting for mptfc. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mptfusion: Setting period,offset and width for SPI driverKashyap, Desai
Set factor, offset and width while target negotiation. Added config timeout 60 seconds. It was missing for only mptspi_read_spi_device_pg0 Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mptfusion: Proper bus_type check is addedKashyap, Desai
Added proper bus_type check before processing event/ reset handler. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2010-04-11[SCSI] mptfusion: mpt_detach is called properly at the time of rmmodKashyap, Desai
Current design of mptsas is as follow. MPTSAS will do probe() if pci id matches for available card in system, irrespective of mode of controller. If controller is I/T mode or I mode, things are fine. If controller is only in T mode, mptsas is not doing complete process of mptsas_probe(). It will only make sure IOC structure is created and IOC reference is available for mptstm driver. Now While removing module we should take care case of Target mode only mptsas. If we are removing IOC which is only in Target mode, We should only detach IOC instead of following rest of the cleanup process which is only required for T mode controller. Now For T mode controller, only part clean up is done instead of complete cleanup. mpt_detach will call early in case of Target mode only controller. Signed-off-by: Kashyap Desai <kashyap.desai@lsi.com> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
