This synchronize the subdevice entries for the AB8500 MFD driver
with the latest development of subdrivers for things like battery
charging and temperature monitoring.
Internal MFD device structs are marked as __devinitdata since the kernel
will allocate memory for the same when calling mfd_add_devices.
Signed-off-by: Robert Rosengren <robert.rosengren@stericsson.com>
Reviewed-by: Mattias Wallin <mattias.wallin@stericsson.com>
Reviewed-by: Johan Palsson <johan.palsson@stericsson.com>
Since functionality in MFD cells may need to be adjusted according to
chip revision, let's enumerate them and keep track of them.
To get rid of port expanders, the free GPIOs of ab8500
can be used. There are 42 GPIO pins. Out of which 16
are interrupt capable.This patch implements 16 virtual
IRQ mapped to 16 interrupt capable AB8500 GPIOs.
Signed-off-by: Bibek Basu <bibek.basu@stericsson.com>
[Renamed header file as per MFD structure]
Converted with coccinelle.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
This patch adds a sysfs file with the ab8500 switch off status.
The switch off status contains information of what caused the ab8500
chip to power off. A print during boot is also added.
Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com>
This patch adds support for ab8500 chip revision cut 3.0.
Also rephrased from Changes to Author in the header.
This patch adds support for chip version 2.0 or cut 2.0.
One new interrupt latch register - latch 12 - is introduced.
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
The genirq core is being converted to supply struct irq_data to chips
rather than the interrupt number.
Acked-by: Mattias Wallin <mattias.wallin@stericsson.com>
This patch adds the ioresources used by subdrivers to
retrieve their interrupt.
This patch makes the system wake up from suspend when an
ab8500 interrupt occur. This can for example be USB cable
insert or an RTC alarm.
This patch adds a file into sysfs for reading out chip id.
It has been requested for modem silent reboot.
Signed-off-by: Ludovic Barre <ludovic.barre@stericsson.com>
We check for dev before dereferencing it.
We want to find the first set bit on value, not status.
This patch adds the possibility to read and write registers
via the debug_fs. It also adds ranges of registers sorted by bank
which makes it possible to read all defined registers in a bank.
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
This patch adds a Pulse Width Modulation driver for Analog Baseband
Chip AB8500.
Signed-off-by: Arun Murthy <arun.murthy@stericsson.com>
Acked-by: Mike Rapoport <mike@compulab.co.il>
This patch makes the ab8500 mixed signal chip expose the same
interface for register access as the ab3100, ab3550 and ab5500 chip.
The ab8500_read() and ab8500_write() is removed and replaced with
abx500_get_register_interruptible() and
abx500_set_register_interruptible().
Add the PowerOn (PonKey) button support to detect power on/off events.
Signed-off-by: Sundar R Iyer <sundar.iyer@stericsson.com>
Acked-By: Mattias Wallin <mattias.wallin@stericsson.com>
Acked-By: Bengt JONSSON <bengt.g.jonsson@stericsson.com>
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
Add a new driver to support the AB8500 Power Management chip, replacing
the current AB4500. The new driver replaces the old one, instead of an
incremental modification, because this is a substantial overhaul
including:
- Split of the driver into -core and -spi portions, to allow another
interface layer to be added
- Addition of interrupt support
- Switch to MFD core API for handling subdevices
- Simplification of the APIs to remove a redundant block parameter
- Rename of the APIs and macros from ab4500_* to ab8500_*
- Rename of the files from ab4500* to ab8500*
- Change of the driver name from ab4500 to ab8500
Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com>
Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com>
