[ Upstream commit 10628e3ecf544fa2e4e24f8e112d95c37884dc98 ]
This function is supposed to return zero on success or negative error
codes on error. Unfortunately, there is a bug so it sometimes returns
non-zero, positive numbers on success.
I noticed this bug during review and I can't test it. It does appear
that the return is sometimes propogated back to _regmap_read() where all
non-zero returns are treated as failure so this may affect run time.
Fixes: 47c1697508f2 ("mfd: Align ab8500 with the abx500 interface")
Signed-off-by: Lee Jones <lee.jones@linaro.org>
Except for the constant DB8500_PRCMU_FW_VERSION_OFFSET number, nothing
is ever passed through the platform data and used in a driver, so we
can simply stop passing it around.
Acked-by: Lee Jones <lee.jones@linaro.org>
WARNING: Block comments use a trailing */ on a separate line
+ * bank on higher 8 bits and reg in lower */
WARNING: suspect code indent for conditional statements (8, 24)
+ if (unlikely(*offset == 17))
+ *offset = 24;
+ if (unlikely(*offset == 16))
+ *offset = 25;
+ if ((i == 3) && (*offset >= 24))
+ *offset += 2;
WARNING: ENOSYS means 'invalid syscall nr' and nothing else
+ return -ENOSYS;
WARNING: static const char * array should probably be static const char * const
+ static const char *switch_off_status[] = {
+ static const char *turn_on_status[] = {
total: 0 errors, 9 warnings, 1867 lines checked
Cc: Linus Walleij <linus.walleij@linaro.org>
The platforms that use the AB8500 define all IRQ resources in the
device tree and they are automatically populated by matching
the .of_compatible string. These static resources are just
surplus baggage these days.
set_irq_flags is ARM specific with custom flags which have genirq
equivalents. Convert drivers to use the genirq interfaces directly, so we
can kill off set_irq_flags. The translation of flags is as follows:
IRQF_VALID -> !IRQ_NOREQUEST
IRQF_PROBE -> !IRQ_NOPROBE
IRQF_NOAUTOEN -> IRQ_NOAUTOEN
For IRQs managed by an irqdomain, the irqdomain core code handles clearing
and setting IRQ_NOREQUEST already, so there is no need to do this in
.map() functions and we can simply remove the set_irq_flags calls. Some
users also modify IRQ_NOPROBE and this has been maintained although it
is not clear that is really needed. There appears to be a great deal of
blind copy and paste of this code.
Signed-off-by: Rob Herring <robh@kernel.org>
Constify in various drivers configuration data which is not modified:
- regmap_irq_chip,
- individual regmap_irq's in array,
- regmap_config,
- irq_domain_ops,
Signed-off-by: Krzysztof Kozlowski <k.kozlowski.k@gmail.com>
A platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The config symbol 'CONFIG_DEBUG_FS' should be protected by a 'ifdef' instead
of a plain 'if'.
Soothes the following checkpatch warnings:
WARNING: line over 80 characters
#151: FILE: drivers/mfd/ab8500-core.c:151:
+ 0, 1, 2, 3, 4, -1, -1, -1, -1, 11, 18, 19, 20, 21, 12, 13, 24, 5, 22, 23,
ERROR: spaces required around that '=' (ctx:VxW)
#325: FILE: drivers/mfd/ab8500-core.c:325:
+ ret= mask_and_set_register_interruptible(ab8500, bank, reg,
#418: FILE: drivers/mfd/ab8500-core.c:418:
+ else if (offset >= AB9540_INT_GPIO50R && offset <= AB9540_INT_GPIO54R)
#420: FILE: drivers/mfd/ab8500-core.c:420:
+ else if (offset == AB8540_INT_GPIO43R || offset == AB8540_INT_GPIO44R)
ERROR: spaces required around that '==' (ctx:VxV)
#454: FILE: drivers/mfd/ab8500-core.c:454:
+ if ((i==3) && (*offset >= 24))
ERROR: code indent should use tabs where possible
#576: FILE: drivers/mfd/ab8500-core.c:576:
+ .map = ab8500_irq_map,$
WARNING: please, no spaces at the start of a line
#577: FILE: drivers/mfd/ab8500-core.c:577:
+ .xlate = irq_domain_xlate_twocell,$
WARNING: char * array declaration might be better as static const
#1554: FILE: drivers/mfd/ab8500-core.c:1554:
+ static char *switch_off_status[] = {
#1563: FILE: drivers/mfd/ab8500-core.c:1563:
+ static char *turn_on_status[] = {
WARNING: sizeof *ab8500 should be sizeof(*ab8500)
#1582: FILE: drivers/mfd/ab8500-core.c:1582:
+ ab8500 = devm_kzalloc(&pdev->dev, sizeof *ab8500, GFP_KERNEL);
ERROR: space required after that close brace '}'
#1639: FILE: drivers/mfd/ab8500-core.c:1639:
+ }/* Configure AB8500 or AB9540 IRQ */
#1652: FILE: drivers/mfd/ab8500-core.c:1652:
+ ab8500->oldmask = devm_kzalloc(&pdev->dev, ab8500->mask_size, GFP_KERNEL);
WARNING: Prefer [subsystem eg: netdev]_cont([subsystem]dev, ... then dev_cont(dev, ... then pr_cont(... to printk(KERN_CONT ...
#1677: FILE: drivers/mfd/ab8500-core.c:1677:
+ printk(KERN_CONT " \"%s\"",
#1682: FILE: drivers/mfd/ab8500-core.c:1682:
+ printk(KERN_CONT "\n");
#1684: FILE: drivers/mfd/ab8500-core.c:1684:
+ printk(KERN_CONT " None\n");
WARNING: printk() should include KERN_ facility level
#1695: FILE: drivers/mfd/ab8500-core.c:1695:
+ printk("\"%s\" ", turn_on_status[i]);
#1700: FILE: drivers/mfd/ab8500-core.c:1700:
+ printk("None\n");
total: 5 errors, 14 warnings, 1869 lines checked
Save a line of code (albeit, it's replaced by a blank line, but
still), as the else is superfluous.
The AD8500 defines itself as interrupt-controller in DT,
but it doesn't assign DT node to IRQ domain when creates it.
As result, of_irq_xx() helpers don't work because they can't
find necessary IRQ domain.
Hence, fix it by assigning AD8500 core device DT node to IRQ
domain when it's created.
This patch fixes STE u8500 Snowball boot failure reported by Kevin Hilman
https://lkml.org/lkml/2014/5/27/624
Reported-and-tested-by: Kevin Hilman <khilman@linaro.org>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
The DBx500 and ABx500 should be getting their IRQs from the
device tree and nowhere else. Get rid of all the static assignments
everywhere, delete it from the driver, platform data and the
board files in one swift strike.
Lots of cross-dependencies in the MFD drivers for PRCMU and
AB8500 makes it necessary to strike everywhere at once to
eradicate IRQs passed as resources and platform data to the left
and right around the platform.
Cc: Mark Brown <broonie@kernel.org>
Cc: Samuel Ortiz <sameo@linux.intel.com>
All subdrivers use the irqdomain to demux AB8500 IRQs but here
in the hierarchical path we find a leftover instance using the
hard-coded IRQ base. Convert it to use irqdomain with a
oneliner.
As of commit 03e361b25ee8dfb1fd9b890072c23c4aae01c6c7 ("mfd: Stop setting
refcounting pointers in original mfd_cell arrays"), the "cell" parameter of
mfd_add_devices() is "const" again. Hence make all cell data passed to
mfd_add_devices() const where possible.
The AB8500 external regulator driver is now a device in its own right,
so it requires registering and probing in the normal way. This patch
will ensure the driver is probed once registered for all devices which
support them.
Add of_compatible string to the ab8500-codec cell to allow the driver to
grab handlers such as regulators from device-tree when available.
Signed-off-by: Fabio Baltieri <fabio.baltieri@linaro.org>
AB8540 RTC have changed between AB8540_cut1 and AB8540_cut2.Different
ressources to define for those two version.
Signed-off-by: Julien Delacou <julien.delacou@stericsson.com>
Signed-off-by: Alexandre Torgue <alexandre.torgue@st.com>
The ab8500-leds driver has never been upstreamed and was replaced by a
PWM framework based driver, so these references are not needed anymore.
When booting with Device Tree enabled the MFD core uses each device's
compatible string to find and allocate its associated of_node pointer,
which in turn is passed to the driver via the platform_device struct.
Without it, the driver won't be able to interrogate the Device Tree or
locate suitable regulators and will most likely fail to probe.
When we're using Device Tree to enable GPIO drivers we're forced to be
OS agnostic, thus we are forbidden use names like pinctrl as they are
specific only to Linux, at least for the time being. However, when we
are registering devices using internal systems such as MFD or platform
registration, we can use such terminology. In this case we can and
should use the platform device ID mechanism to specify which device we
wish to utilise by detailing pinctrl-<device_name>.
This patch fixes a regression that when booting with Device Tree
enabled the ABx500 GPIO/Pinctrl devices are not probed.
The AB8500 debug code which was merged in parallell with the
multiplatform work incidentally introduced a new instance using
the <mach/irqs.h> header which is now deleted, causing this
build regression:
drivers/mfd/ab8500-debugfs.c:95:23:
fatal error: mach/irqs.h: No such file or directory
compilation terminated.
make[4]: *** [drivers/mfd/ab8500-debugfs.o] Error 1
The code most certainly never worked with device tree either
since that does not rely on this kind of hard-coded interrupt
numbers.
Fix the problem at the root by passing it as a named resource
from the ab8500-core driver. Use an untyped resource to
stop the MFD core from remapping this IRQ relative to the
AB8500 irqdomain.
Add of_comptabile string to the ab8500-usb cell to allow the driver to
grab properties from device-tree when available.
AB8500 asserts LATCH bits for masked out interrupts. This patch
explicitly masks those out using the cached mask value to prevent
handle_nested_irq() being called for masked IRQ on the same register as
unmasked ones.
Add support for a power cut feature which allows user to
configure when ab8505 and ab8540 based platforms should shut
down system due to low battery.
Make use of the hierarchical interrupt rergister called
ITLatchHier1 - 3 also for the 8500 platform (currently the
hierarchical interrupt registers are used only for the 8540
and 9540 platforms). This will make the interrupt routing
go faster since fewer i2c reads need to made in the most
common cases.
Signed-off-by: Dariusz Szymczak <dariusz.xd.szymczak@stericsson.com>
Reviewed-by: Mian Yousaf KAUKAB <mian.yousaf.kaukab@stericsson.com>
Acked-by: Samuel Ortiz <sameo@linux.intel.com>
Hierarchically, the abx500-clk shall be considered as a child of the
ab8500 core. The abx500-clk is intiated at arch init and thus the clks
will be available when clients needs them.
Signed-off-by: Ulf Hansson <ulf.hansson@stericsson.com>
Reviewed-by: Philippe LANGLAIS <philippe.langlais@stericsson.com>
Reviewed-by: Patrice CHOTARD <patrice.chotard@stericsson.com>
Reviewed-by: Gabriel FERNANDEZ <gabriel.fernandez@stericsson.com>
Reviewed-by: Philippe BEGNIC <philippe.begnic@stericsson.com>
Several states can be detected when a device is initially turned on.
This patch displays these states in the log. If none of the states
are true, then we report that too.
Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com>
Reviewed-by: Marcus COOPER <marcus.xm.cooper@stericsson.com>
Reviewed-by: Jonas ABERG <jonas.aberg@stericsson.com>
Add VBUS_DET_R, VBUS_DET_F IRQ, ID_DET_PLUGR and ID_DET_PLUGF IRQ
information to ab8505_iddet_resources. These are required to get
interrupts for AB8505 cut-2.
Signed-off-by: Alexandre Torgue <alexandre.torgue@stericsson.com>
Reviewed-by: Mattias WALLIN <mattias.wallin@stericsson.com>
Tested-by: Maxime COQUELIN <maxime.coquelin@stericsson.com>
ITSource/ITLatch 7, 8, 9 and 10 don't exist on AB8540. This patch
replaces them with '-1' in the interrupt list, and handles the '-1'
in the code accordingly.
Here we're separating Battery Management devices into their own
structure, removing the common device structure & redistribute them
amongst the individual platform structs and completing the population
of them.
There are missing register descriptions from the AB8505 user manual
and these need to be masked so that the APEINT line can toggle.
This patch also affects the behaviour of AB9540.
Signed-off-by: Marcus Cooper <marcus.xm.cooper@stericsson.com>
Reviewed-by: Maxime COQUELIN <maxime.coquelin@stericsson.com>
Reviewed-by: Alexandre TORGUE <alexandre.torgue@stericsson.com>
In L9540, turn_on_status register is not updated correctly if
the device is rebooted with AC/USB charger connected. Due to
this, the device boots android instead of entering into charge
only mode. Read the AC/USB status register to detect the charger
presence and update the turn on status manually.
Signed-off-by: Rajkumar Kasirajan <rajkumar.kasirajan@stericsson.com>
Signed-off-by: Per Forlin <per.forlin@stericsson.com>
Reviewed-by: Rupesh KUMAR <rupesh.kumar@stericsson.com>
Tested-by: Rupesh KUMAR <rupesh.kumar@stericsson.com>
Tested-by: Philippe LANGLAIS <philippe.langlais@stericsson.com>
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6
Pull MFS updates from Samuel Ortiz:
"This is the MFD pull request for the 3.9 merge window.
No new drivers this time, but a bunch of fairly big cleanups:
- Roger Quadros worked on a OMAP USBHS and TLL platform data
consolidation, OMAP5 support and clock management code cleanup.
- The first step of a major sync for the ab8500 driver from Lee
Jones. In particular, the debugfs and the sysct interfaces got
extended and improved.
- Peter Ujfalusi sent a nice patchset for cleaning and fixing the
twl-core driver, with a much needed module id lookup code
improvement.
- The regular wm5102 and arizona cleanups and fixes from Mark Brown.
- Laxman Dewangan extended the palmas APIs in order to implement the
palmas GPIO and rt drivers.
- Laxman also added DT support for the tps65090 driver.
- The Intel SCH and ICH drivers got a couple fixes from Aaron Sierra
and Darren Hart.
- Linus Walleij patchset for the ab8500 driver allowed ab8500 and
ab9540 based devices to switch to the new abx500 pin-ctrl driver.
- The max8925 now has device tree and irqdomain support thanks to
Qing Xu.
- The recently added rtsx driver got a few cleanups and fixes for a
better card detection code path and now also supports the RTS5227
chipset, thanks to Wei Wang and Roger Tseng."
* tag 'mfd-3.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (109 commits)
mfd: lpc_ich: Use devres API to allocate private data
mfd: lpc_ich: Add Device IDs for Intel Wellsburg PCH
mfd: lpc_sch: Accomodate partial population of the MFD devices
mfd: da9052-i2c: Staticize da9052_i2c_fix()
mfd: syscon: Fix sparse warning
mfd: twl-core: Fix kernel panic on boot
mfd: rtsx: Fix issue that booting OS with SD card inserted
mfd: ab8500: Fix compile error
mfd: Add missing GENERIC_HARDIRQS dependecies
Documentation: Add docs for max8925 dt
mfd: max8925: Add dts
mfd: max8925: Support dt for backlight
mfd: max8925: Fix onkey driver irq base
mfd: max8925: Fix mfd device register failure
mfd: max8925: Add irqdomain for dt
mfd: vexpress: Allow vexpress-sysreg to self-initialise
mfd: rtsx: Support RTS5227
mfd: rtsx: Implement driving adjustment to device-dependent callbacks
mfd: vexpress: Add pseudo-GPIO based LEDs
mfd: ab8500: Rename ab8500 to abx500 for hwmon driver
Pull battery updates from Anton Vorontsov:
"Four new drivers:
- goldfish_battery:
This is Android Emulator battery driver. Originally from Google,
but Intel folks reshaped it for mainline
- pm2301_charger:
A new driver for ST-Ericsson 2301 Power Management chip, uses
AB8500 battery management core
- qnap-poweroff:
The driver adds poweroff functionality for QNAP NAS boxes
- restart-poweroff:
A generic driver that implements 'power off by restarting'. The
actual poweroff functionality is implemented through a bootloader,
so Linux' task is just to restart the box. The driver is useful on
Buffalo Linkstation LS-XHL and LS-CHLv2 boards. Andrew Lunn worked
on submitting the driver (as well as qnap-poweroff above).
Additionally:
- A lot of fixes for ab8500 drivers. This is a part of efforts of
syncing internal ST-Ericsson development tree with the mainline.
Lee Jones @ Linaro worked on compilation and reshaping these
series.
- New health properties for the power supplies: "Watchdog timer
expire" and "Safety timer expire"
- As usual, a bunch of fixes/cleanups here and there"
* tag 'for-v3.9' of git://git.infradead.org/battery-2.6: (81 commits)
bq2415x_charger: Add support for offline and 100mA mode
generic-adc-battery: Fix forever loop in gab_remove()
goldfish_battery: Add missing GENERIC_HARDIRQS dependency
da9030_battery: Include notifier.h
bq27x00_battery: Fix reporting battery temperature
power/reset: Remove newly introduced __dev* annotations
lp8727_charger: Small cleanup in naming
ab8500_btemp: Demote initcall sequence
ds2782_battery: Add power_supply_changed() calls for proper uevent support
power: Add battery driver for goldfish emulator
u8500-charger: Delay for USB enumeration
ab8500-bm: Remove individual [charger|btemp|fg|chargalg] pdata structures
ab8500-charger: Do not touch VBUSOVV bits
ab8500-fg: Use correct battery charge full design
pm2301: LPN mode control support
pm2301: Enable vbat low monitoring
ab8500-bm: Flush all work queues before suspending
ab8500-fg: Go to INIT_RECOVERY when charger removed
ab8500-charger: Add support for autopower on AB8505 and AB9540
abx500-chargalg: Add new sysfs interface to get current charge status
Fix up fairly straightforward conflicts in the ab8500 driver. But since
it seems to be ARM-specific, I can't even compile-test the result..
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-pinctrl into for-next
into for-next
We are using a generic abx500 hwmon layer, so rename specific ab8500 to generic
abx500 for hwmon device and driver matching.
Signed-off-by: Hongbo Zhang <hongbo.zhang@linaro.org>
The old AB8500 GPIO driver has been un-BROKEN and converted into a
multi-platform pinctrl driver. If any AB9540 based devices wish to
request any GPIO pins that it offers, they can after this patch.
The old, BROKEN AB8500 GPIO driver has been revamped as a shiny
new pinctrl driver and has been renamed as such. So, if we would
like to make use of it, we need to register it via its new name.
In the AB8500 IRQ mask and unmask functions, we rely on testing for
IRQ_TYPE_EDGE_RISING and IRQ_TYPE_EDGE_FALLING interrupts to
physically mask and unmask the correct interrupt lines. In order
for us to do that, the trigger needs to be set in the associated
flags. However, unless a irq_set_type() function pointer is passed
when registering the IRQ chip, the IRQ subsystem will refuse to do
it. For that reason, we're providing one.
The patch:
"mfd: ab8500: prepare to handle AB8500 GPIO's IRQs correctly"
altered the AB8500 IRQ mask/unmask functions such that they
would handle masking on/off the falling edge IRQ if this was
requested by the consumer. However the bit mask for hwirqs
43 and 44 was shifting the bit mask incorrectly, resulting in
the wrong IRQ being mased/unmasked.
Further while the patch would mask/unmask the correct line,
when the interrupt actually came in, it would still be treated
as a valid hwirq. The offsetting applied when masking/unmasking
was not applied when handling the IRQ, i.e. the falling edge
lines were not routed back to the rising edge lines.
This fixes both cases. The end result has been tested with
the SIM detect IRQ, GPIO12, hwirq 46 and 62.
Cc: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Linus Walleij <linus.walleij@stericsson.com>
In an upcoming patch, the gpio-ab8500 driver will relinquish all
IRQ handling capability and pass it back into the AB8500 core
driver. This will aid in reducing massive code duplication within
the kernel. Also, most of the functionality is already in the
AB8500 core driver, as the GPIO IRQs are actually sandwiched
between lots of other IRQs which the core driver already handles.
All we're doing here is providing the core driver with knowledge
that each GPIO has two IRQs assigned to it; one for rising and
a separate one for falling.
This patch adds an entry in debugfs to check number of interrupts
from the AB.
Signed-off-by: Bengt Jonsson <bengt.g.jonsson@stericsson.com>
Reviewed-by: Rabin VINCENT <rabin.vincent@stericsson.com>
Implement an API so that a user may dump all AB8500 registers
via debugfs file access.
Signed-off-by: Mian Yousaf Kaukab <mian.yousaf.kaukab@stericsson.com>
Reviewed-by: Linus WALLEIJ <linus.walleij@stericsson.com>
If charging is started before USB enumeration of an Accessory
Charger Adapter has finished, the AB8500 will generate a
VBUS_ERROR. This in turn results in timeouts and delays the
enumeration with around 15 seconds. This patch delays the
charging and then ramps currents slowly to avoid VBUS errors.
The delay allows the enumeration to have finished before
charging is turned on.
Signed-off-by: Martin Sjoblom <martin.w.sjoblom@stericsson.com>
Tested-by: Jonas ABERG <jonas.aberg@stericsson.com>
drivers/mfd/ab8500-core.c:1015:21: error: ‘ab8500_bm_data’ undeclared here
include/linux/mfd/abx500/ab8500-bm.h:445:13: warning: ‘ab8500_fg_reinit’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:448:13: warning: ‘ab8500_charger_usb_state_changed’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:451:29: warning: ‘ab8500_btemp_get’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:455:12: warning: ‘ab8500_btemp_get_batctrl_temp’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:463:12: warning: ‘ab8500_fg_inst_curr_blocking’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:442:12: warning: ‘ab8500_fg_inst_curr_done’ defined but not used
include/linux/mfd/abx500/ab8500-bm.h:447:26: warning: ‘ab8500_fg_get’ defined but not used
Pull MFS update from Samuel Ortiz:
"This is the MFD patch set for the 3.8 merge window.
We have several new drivers, most of the time coming with their sub
devices drivers:
- Austria Microsystem's AS3711
- Nano River's viperboard
- TI's TPS80031, AM335x TS/ADC,
- Realtek's MMC/memstick card reader
- Nokia's retu
We also got some notable cleanups and improvements:
- tps6586x got converted to IRQ domains.
- tps65910 and tps65090 moved to the regmap IRQ API.
- STMPE is now Device Tree aware.
- A general twl6040 and twl-core cleanup, with moves to the regmap
I/O and IRQ APIs and a conversion to the recently added PWM
framework.
- sta2x11 gained regmap support.
Then the rest is mostly tiny cleanups and fixes, among which we have
Mark's wm5xxx and wm8xxx patchset."
Far amount of annoying but largely trivial conflicts. Many due to
__devinit/exit removal, others due to one or two of the new drivers also
having come in through another tree.
* tag 'mfd-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (119 commits)
mfd: tps6507x: Convert to devm_kzalloc
mfd: stmpe: Update DT support for stmpe driver
mfd: wm5102: Add readback of DSP status 3 register
mfd: arizona: Log if we fail to create the primary IRQ domain
mfd: tps80031: MFD_TPS80031 needs to select REGMAP_IRQ
mfd: tps80031: Add terminating entry for tps80031_id_table
mfd: sta2x11: Fix potential NULL pointer dereference in __sta2x11_mfd_mask()
mfd: wm5102: Add tuning for revision B
mfd: arizona: Defer patch initialistation until after first device boot
mfd: tps65910: Fix wrong ack_base register
mfd: tps65910: Remove unused data
mfd: stmpe: Get rid of irq_invert_polarity
mfd: ab8500-core: Fix invalid free of devm_ allocated data
mfd: wm5102: Mark DSP memory regions as volatile
mfd: wm5102: Correct default for LDO1_CONTROL_2
mfd: arizona: Register haptics devices
mfd: wm8994: Make current device behaviour the default
mfd: tps65090: MFD_TPS65090 needs to select REGMAP_IRQ
mfd: Fix stmpe.c build when OF is not enabled
mfd: jz4740-adc: Use devm_kzalloc
