commit 722f191080de641f023feaa7d5648caf377844f5 upstream.
Make sure to drop the reference taken by bus_find_device_by_name()
before returning from mfd_clone_cell().
Fixes: a9bbba996302 ("mfd: add platform_device sharing support for mfd")
Signed-off-by: Johan Hovold <johan@kernel.org>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
There is at least one board on the market, i.e. Intel Galileo Gen2, that uses
_ADR to distinguish the devices under one actual device. Due to this we have to
improve the quirk in the MFD core to handle that board.
Acked-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The newly introduced device_for_each_child_reverse() would be used when MFD
core removes the device.
After this patch applied the devices will be removed in a reversed order. This
behaviour is useful when devices have implicit dependency on order, i.e.
consider MFD device with serial bus controller, such as SPI, and DMA IP that is
attached to serial bus controller: before remove the DMA driver we have to be
ensured that no DMA transfers is ongoing and the requested channel are unused.
Current code in mfd-core calls into ACPI to check resources even
on a system that booted with a DT (on kernels with both DT and ACPI
support compiled in). This triggers ACPI exceptions since we may
end up calling the ACPI interpreter when it has not been initialized:
"ACPI Exception: AE_BAD_PARAMETER, Thread 2064154624 could not acquire
Mutex [0x1] (20150410/utmutex-285)"
This patch fixes the issues by adding a check for an ACPI companion
device before carrying out ACPI resources checks to avoid calling
the ACPI interpreter if the fwnode representing the device is an OF one.
Cc: Sudeep Holla <sudeep.holla@arm.com>
Signed-off-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com>
Since commit 6e3f62f0793e ("mfd: core: Fix platform-device id
generation") we honour PLATFORM_DEVID_AUTO and PLATFORM_DEVID_NONE when
registering mfd-devices.
Unfortunately, some mfd-drivers rely on the old behaviour of generating
platform-device ids by adding the cell id also to the special value of
PLATFORM_DEVID_NONE. The resulting platform ids are not only used to
generate device-unique names, but are also used instead of the cell id
to identify cells when probing subdevices.
These drivers should be updated to use PLATFORM_DEVID_AUTO, which would
also allow more than one device to be registered without resorting to
hacks (see for example wm831x), but lets fix the regression first by
partially reverting the above mentioned commit with respect to
Fixes: 6e3f62f0793e ("mfd: core: Fix platform-device id generation")
Cc: stable <stable@vger.kernel.org> # v3.19
Reported-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Acked-by: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com>
Make sure to always honour multi-function devices registered with
PLATFORM_DEVID_NONE (-1) or PLATFORM_DEVID_AUTO (-2) as id base. In this
case it does not make sense to append the cell id to the mfd-id base and
potentially change the requested behaviour.
Specifically this will allow multi-function devices to be registered
with PLATFORM_DEVID_AUTO while still having non-zero cell ids.
If an MFD device is backed by ACPI namespace, we should allow subdevice
drivers to access their corresponding ACPI companion devices through normal
means (e.g using ACPI_COMPANION()).
This patch adds such support to the MFD core. If the MFD parent device
does not specify any ACPI _HID/_CID for the child device, the child
device will share the parent ACPI companion device. Otherwise the child
device will be assigned with the corresponding ACPI companion, if found
in the namespace below the parent.
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Reviewed-by: Darren Hart <dvhart@linux.intel.com>
dma_mask and dma_parms are already inherited from the parent device but
dma_coherent_mask was left uninitialized (set to zero thanks to kzalloc).
Set sub-device coherent_dma_mask to its parent value to simplify
sub-drivers making use of dma coherent helper functions (those drivers
currently have to explicitly set the dma coherent mask using
dma_set_coherent_mask function).
Signed-off-by: Boris BREZILLON <boris.brezillon@free-electrons.com>
The supply aliases for the MFD devices were being added using devres but
the device hasn't been added at this point and as such we can't use
devres.
The MFD already has a function that removes devices this patch uses the
non-devres versions of the supply alias functions and adds an unregister
in mfd_remove_devices_fn.
Reported-by: Carlo Caione <carlo@caione.org>
Reported-by: Mark Brown <broonie@kernel.org>
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
Reviewed-by: Mark Brown <broonie@kernel.org>
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next
Pull MFD updates from Samuel Ortiz:
"For the 3.13 merge window we have a couple of new drivers for the AMS
AS3722 PMIC and for STMicroelectronics STw481x PMIC.
Although this is a smaller update than usual, we also have:
- Device tree support for the max77693 driver
- linux/of.h inclusion for all DT compatible MFD drivers, to avoid
build breakage in the future
- Support for Intel Wildcat Point-LP PCH through the lpc_ich driver
- A small arizona update for new wm5110 DSP registers and a few fixes
- A small palmas update as well, including an of_device table
addition and a few minor fixes
- Two small mfd-core changes, one including a memory leak fix for
when mfd_add_device() fails
- Our usual round of minor cleanups and janitorial fixes"
* tag 'mfd-3.13-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-next: (63 commits)
Documentation: mfd: Update s2mps11.txt
mfd: pm8921: Potential NULL dereference in pm8921_remove()
mfd: Fix memory leak in mfd_add_devices()
mfd: Stop setting refcounting pointers in original mfd_cell arrays
mfd: wm5110: Enable micd clamp functionality
mfd: lpc_ich: Add Device IDs for Intel Wildcat Point-LP PCH
mfd: max77693: Fix up bug of wrong interrupt number
mfd: as3722: Don't export the regmap config
mfd: twl6040: Remove obsolete cleanup for i2c clientdata
mfd: tps65910: Remove warning during dt node parsing
mfd: lpc_sch: Ignore resource conflicts when adding mfd cells
mfd: ti_am335x_tscadc: Avoid possible deadlock of reg_lock
mfd: syscon: Return -ENOSYS if CONFIG_MFD_SYSCON is not enabled
mfd: Add support for ams AS3722 PMIC
mfd: max77693: Include linux/of.h header
mfd: tc3589x: Detect the precise version
mfd: omap-usb: prepare/unprepare clock while enable/disable
mfd: max77686: Include linux/of.h header
mfd: max8907: Include linux/of.h header
mfd: max8997: Include linux/of.h header
If the first call to mfd_add_device() fails, no child devices have been
registered to the parent yet, and thus mfd_remove_devices() won't find
anything to remove nor free.
Hence the previously allocated array of atomic_t objects will leak.
Free the array instead of calling mfd_remove_devices() on failure during
the first loop iteration to fix this.
Commit 1e29af62f2b285bd18685da93c3ce8c33ca2d1db ("mfd: Add refcounting
support to mfd_cells") had to drop the "const" keyword on the "cell"
parameter of mfd_add_devices(), as it added the refcounting pointers
to the objects of the passed mfd_cell array itself.
However, the mfd core code operates on copies of the mfd_cell objects,
so there's no need to modify the originally passed objects.
Hence, move the setting of the refcounting pointers from mfd_add_devices()
to mfd_platform_add_cell(), where the copy of the mfd_cell objects is made.
mfd_clone_cell() can just pass (a copy of) the original usage_count
pointer.
This allows to make the "cell" parameter of mfd_add_devices() "const"
again, and avoids future race conditions when registering multiple
instances of the same device in parallel.
Occasionally, it is useful to map supplies from a child device onto the
MFD device. A typical usecase for this would be if the MFD device is
represented as a single node in device tree. All supplies will be
defined in device tree as existing on the MFD device. When a child
depends on frameworks which might have no knowledge of MFD to lookup
supplies on its behalf the supply will not be found.
This patch adds a list of supplies that should be looked up on the
parent rather than the child as part of the mfd_cell structure.
Signed-off-by: Mark Brown <broonie@linaro.org>
The child device intends to perform DMA operations then it needs a dma
mask and params set. This patches copies them from the parent device.
Signed-off-by: Benedikt Spranger <b.spranger@linutronix.de>
Signed-off-by: Holger Dengler <dengler@linutronix.de>
mfd_remove_devices would iterate over all devices sharing a parent with
an mfd device regardless of whether they were allocated by the mfd core
or not. This especially caused problems when the device structure was
not contained within a platform_device, because to_platform_device is
used on each device pointer.
This patch defines a device_type for mfd devices and checks this is
present from mfd_remove_devices_fn before processing the device.
Cc: stable@vger.kernel.org
Tested-by: Peter Tyser <ptyser@xes-inc.com>
Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Currently the MFD core supports remapping MFD cell interrupts using an
irqdomain but only if the MFD is being instantiated using device tree
and only if the device tree bindings use the pattern of registering IPs
in the device tree with compatible properties. This will be actively
harmful for drivers which support non-DT platforms and use this pattern
for their DT bindings as it will mean that the core will silently change
remapping behaviour and it is also limiting for drivers which don't do
DT with this particular pattern. There is also a potential fragility if
there are interrupts not associated with MFD cells and all the cells are
omitted from the device tree for some reason.
Instead change the code to take an IRQ domain as an optional argument,
allowing drivers to take the decision about the parent domain for their
interrupts. The one current user of this feature is ab8500-core, it has
the domain lookup pushed out into the driver.
During Device Tree enablement of the ab8500 and db8500-prcmu drivers,
a decision was made to omit registration through the MFD API and use
Device Tree directly. However, because MFD devices have a different
address space and the ab8500 and db8500 both use I2C to communicate,
this causes issues with address translation during execution of
of_platform_populate(). So the solution is to make the MFD core aware
of Device Tree and have it assign the correct node pointers instead.
To make this work the MFD core also needs to be awere of IRQ domains,
as Device Tree insists on IRQ domain compatibility. So, instead of
providing an irq-base via platform code, in the DT case we simply
look up the IRQ domain and map to the correct virtual IRQ.
The code is currently always checking the first resource of every
device only (several times.) This has been broken since the ACPI check
was added in February 2010 in commit
91fedede0338eb6203cdd618d8ece873fdb7c22c.
Fix the check to run on each resource individually, once.
The first parameter should be "number of elements" and the second parameter
should be "element size".
With the pending module.h cleanup, these files will fail to compile,
unless they explicitly call out the include of this file.
[omap-usb-host addition courtesy of Anand Gadiyar <gadiyar@ti.com>]
Now that we have a way to pass MFD cells down to the sub drivers,
we can gradually get rid of mfd_data by putting the platform pointer
back in place.
In order for MFD drivers to fetch their cell pointer but also their
platform data one, an mfd cell pointer is added to the platform_device
structure.
That allows all MFD sub devices drivers to be MFD agnostic, unless
they really need to access their MFD cell data. Most of them don't,
especially the ones for IPs used by both MFD and non MFD SoCs.
Cc: Grant Likely <grant.likely@secretlab.ca>
Acked-by: Greg KH <gregkh@suse.de>
Replace mfd_shared_platform_driver_register with mfd_clone_cell. The
former was called by an mfd client, and registered both a platform driver
and device. The latter is called by an mfd driver, and registers only a
platform device.
The downside of this is that mfd drivers need to be modified whenever
new clients are added that share a cell; the upside is that it fits
Linux's driver model better. It's also simpler.
This also converts cs5535-mfd/olpc-xo1 from the old API. cs5535-mfd
now creates the olpc-xo1-{acpi,pms} devices, while olpc-xo1 binds to
them via platform drivers.
Signed-off-by: Andres Salomon <dilinger@queued.net>
As requested by Samuel, there's not really any reason to have "shared"
in the name.
This also modifies the only user of the function, as well.
This adds functions to enable platform_device sharing for mfd clients.
Each platform driver (mfd client) that wants to share an mfd_cell's
platform_device uses the mfd_shared_platform_driver_{un,}register()
functions instead of platform_driver_{un,}register(). Along with
registering the platform driver, these also register a new platform
device with the same characteristics as the original cell, but a different
name. Given an mfd_cell with the name "foo", drivers that want to
share access to its resources can call mfd_shared_platform_driver_register
with platform drivers named (for example) "bar" and "baz". This
will register two platform devices and drivers named "bar" and "baz"
that share the same cell as the platform device "foo". The drivers
can then call "foo" cell's enable hooks (or mfd_shared_cell_enable)
to enable resources, and obtain platform resources as they normally
would.
This deals with platform handling only; mfd driver-specific details,
hardware handling, refcounting, etc are all dealt with separately.
This provides convenience functions for sharing of cells across
multiple mfd clients. Mfd drivers can provide enable/disable hooks
to actually tweak the hardware, and clients can call
mfd_shared_cell_{en,dis}able without having to worry about whether
or not another client happens to have enabled or disabled the
cell/hardware.
Note that this is purely optional; drivers can continue to use
the mfd_cell's enable/disable hooks for their own purposes, if
desired.
All users of this have now been switched over to using mfd_data;
it can go away now.
Previously, one would set the mfd_cell's platform_data/data_size to point
to the current mfd_cell in order to pass that information along to drivers.
This causes the current mfd_cell to always be available to drivers. It
also adds a wrapper function for fetching the mfd cell from a platform
device, similar to what originally existed for mfd devices.
Drivers who previously used platform_data for other purposes can still
use it; the difference is that mfd_get_data() must be used to
access it (and the pdata structure is no longer allocated in
mfd_add_devices).
Note that mfd_get_data is intentionally vague (in name) about where
the data is stored; variable name changes can come later without having
to touch brazillions of drivers.
Allow MFD cells to have pm_runtime_no_callbacks() called on them during
registration. This causes the runtime PM framework to ignore them,
allowing use of runtime PM to suspend the device as a whole even if
not all drivers for the MFD can usefully implement runtime PM. For
example, RTCs are likely to run continuously regardless of the power
state of the system.
When the cell data_size is 0, the resulting platform_data pointer will be
set to ZERO_SIZE_PTR. That could be misleading for device drivers running
a NULL check on thei platform_data pointer before dereferencing it.
Signed-off-by: Brian Harring <ferringb@gmail.com>
The upcoming VIA VX855 MFD driver needs to communicate resources
to subdevices where the resources may be claimed by ACPI.
Add a flag to mfd_cell to request that resources are not policed.
Signed-off-by: Daniel Drake <dsd@laptop.org>
platform_device_add_resources may fail, thus add error checking for it.
If mem_base is NULL, then we fall back to the default case, just copying the
original resource.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
For ACPI based systems, we should check for ACPI conflicts when adding the
platform devices. The test will always succeed for non ACPI platforms.
Provide basic support for MFDs having multiple cells of a given
type with different IDs by adding an id to the mfd_cell structure
and then adding that to the id passed in to mfd_add_devices().
As it stands this approach requires that MFDs using this feature
deal with ensuring that there aren't any ID collisions resulting
from multiple MFDs of the same type being instantiated. This needs
to happen with the existing code too, but with this approach there
is a knock on effect on the IDs for non-duplicated devices.
The MFD cell structure provides a driver_data field but doesn't pass it
on to the child devices when instantiating them - do that.
Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
This patch moves the allocation of the resources off the stack in
mfd_add_device().
Signed-off-by: Ian Molton <spyro@f2s.com>
Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Adding platform_data to mfd_cell allows passing of platform data directly
to the platform_device created for each cell and thus reuse of existing
drivers.
On the other side it can be used as a hook to mfd_cell itself
removing the need in mfd_get_cell method.
Signed-off-by: Mike Rapoport <mike@compulab.co.il>
Acked-by: Dmitry Baryshkov <dbaryshkov@gmail.com>
Fix some coding style fixes in the mfd core driver.
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Convert mfd_remove_devices_fn() to use to_platform_device()
instead of doing container_of().
For it doesn't exist on i386.
Cc: Ian Molton <spyro@f2s.com>
Cc: Dmitry Baryshkov <dbaryshkov@gmail.com>
Cc: Russell King <rmk+kernel@arm.linux.org.uk>
This patch provides a common subdevice registration system for MFD type
chips, using platfrom device.
