path: root/drivers/mfd/qcom-spmi-pmic.c
2016-01-11mfd: qcom-spmi-pmic: Don't access non-existing registersIvan T. Ivanov
Revision ID registers are available only on devices with Slave IDs that are even, so don't make access to unavailable registers. Signed-off-by: Ivan T. Ivanov <ivan.ivanov@linaro.org> [sboyd@codeaurora.org: Consider all slave ids that are even] Signed-off-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2015-03-30mfd: qcom-spmi-pmic: Add specific compatible strings for Qualcomm's SPMI PMIC'sIvan T. Ivanov
Some of the PMIC's could have specific regmap configuration tables in future, so add specific compatible strings for known PMIC's. Also print runtime detected chip revision information. Signed-off-by: Ivan T. Ivanov <iivanov@mm-sol.com> Acked-by: Stephen Boyd <sboyd@codeaurora.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-09-26mfd: Add support for Qualcomm SPMI PMICsJosh Cartwright
The Qualcomm SPMI PMIC chips are components used with the Snapdragon 800 series SoC family. This driver exists largely as a glue mfd component, it exists to be an owner of an SPMI regmap for children devices described in device tree. Signed-off-by: Josh Cartwright <joshc@codeaurora.org> Signed-off-by: Stanimir Varbanov <svarbanov@mm-sol.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
