path: root/drivers/mfd/rts5229.c
2013-02-14mfd: rtsx: Implement driving adjustment to device-dependent callbacksRoger Tseng
Implement different ways of selecting driving capability(a necessary adjustment along with voltage change). It was origionally in device-independent mmc/host/rtsx_pci_sdmmc.c. Moving it here to support devices which may have a different way of adjustment. Signed-off-by: Roger Tseng <rogerable@realtek.com> Reviewed-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-27mfd: rtsx: Add clock divider hookWei WANG
Add callback function conv_clk_and_div_n to convert between SSC clock and its divider N. For rtl8411, the formula to calculate SSC clock divider N is different with the other card reader models. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-27mfd: rtsx: Add output voltage switch hookWei WANG
Different card reader has different method to switch output voltage, add this callback to let the card reader implement its individual switch function. This is needed as rtl8411 has a specific switch output voltage procedure. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-15drivers/mfd: Add realtek pcie card reader driverWei WANG
Realtek PCI-E card reader driver adapts requests from upper-level sdmmc/memstick layer to the real physical card reader. Signed-off-by: Wei WANG <wei_wang@realsil.com.cn> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Tested-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
