path: root/drivers/mfd/tc6387xb.c
2011-06-10treewide: Convert uses of struct resource to resource_size(ptr)Joe Perches
Several fixes as well where the +1 was missing. Done via coccinelle scripts like: @@ struct resource *ptr; @@ - ptr->end - ptr->start + 1 + resource_size(ptr) and some grep and typing. Mostly uncompiled, no cross-compilers. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-05-26mmc: Use device platform_data to retrieve tmio_mmc platform bitsSamuel Ortiz
With the addition of the platform device mfd_cell pointer, we can now cleanly pass the sub device drivers platform data pointers through the regular device platform_data one, and get rid of mfd_get_data() Cc: Ian Molton <spyro@f2s.com> Cc: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Cc: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mmc: Use mfd_data instead of driver_data for tmio-mmcAndres Salomon
Use mfd_data for passing information from mfd drivers to mfd clients. The mfd_cell's driver_data field is being phased out. Clients that were using driver_data now access .mfd_data via mfd_get_data(). This changes tmio-mmc only; mfd drivers with other cells are not modified. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-03-23mfd: mfd_cell is now implicitly available to tc6387xb driversAndres Salomon
No need to explicitly set the cell's platform_data/data_size. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-08-12mfd: Annotate tc6387xb probe/remove routines with __devinit/__devexitAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-08-12mfd: Fix tc6387xb resource reclaimAxel Lin
This patch includes below fixes: 1. add a missing iounmap in tc6387xb_probe() error path 2. fix resource reclaim in tc6387xb_remove() Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-01-18mfd: tmio_mmc hardware abstraction for CNF areaIan Molton
This patch abstracts out the CNF area code from tmio_mmc which is not present in all hardware that can use this driver. This is required so that we can support non-toshiba based hardware. ASIC3 support by Philipp Zabel Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-17mfd: fix tmio related warningsSamuel Ortiz
We can not have .driver_data as const since platform_set_drvdata() doesnt take a const. The hclk mmc_data field can be const though. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-13MFD,mmc: tmio_mmc: make HCLK configurablePhilipp Zabel
The Toshiba parts all have a 24 MHz HCLK, but HTC ASIC3 has a 24.576 MHz HCLK and AMD Imageon w228x's HCLK is 80 MHz. With this patch, the MFD driver provides the HCLK frequency to tmio_mmc via mfd_cell->driver_data. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Ian Molton <ian@mnementh.co.uk> Acked-by: Samuel Ortiz <sameo@openedhand.com> Signed-off-by: Pierre Ossman <pierre@ossman.eu>
2008-10-19mfd: update TMIO drivers to use the clock APIIan Molton
This patch updates the remaining two TMIO drivers to use the clock API rather than callback hooks into platform code. Signed-off-by: Ian Molton <spyro@f2s.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-08-10mfd: tc6387 MMC platform dataIan Molton
We need to pass the cell as the platform data. Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-08-10mfd: Fix 7l66 and 6387 according to the new mfd-core APISamuel Ortiz
2008-08-10mfd: driver for the TC6387XB TMIO controller.Ian Molton
This patch adds support for the TC6387XB. Unlike other TMIO devices this one has only one subdevice and no interrupt mux, however using the MFD framework allows it to share the TMIO MMC driver. Signed-off-by: Ian Molton <spyro@f2s.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
