path: root/drivers/mfd/tc6393xb.c
2011-01-14mfd: Convert tc6393xb driver to new irq_ APIsMark Brown
The genirq core is being update to pass struct irq_data to irq_chip rather than an irq number to operations. Update tc6393 to the new API. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Remove __devinitdata from tc6393xb_mmc_resourcesMarek Vasut
This static struct resource tc6393xb_mmc_resources[] is used in resume function, therefore the data can not be wiped after init. Also, this causes a section mismatch. Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-08-12mfd: Fix wrong goto labels for tc6393xb error handlingAxel Lin
This patch corrects the error handling path. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07mfd: Use resouce_size for tc6393xbH Hartley Sweeten
Use resource_size() for ioremap. Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Cc: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-01-18mfd: tmio_mmc hardware abstraction for CNF areaIan Molton
This patch abstracts out the CNF area code from tmio_mmc which is not present in all hardware that can use this driver. This is required so that we can support non-toshiba based hardware. ASIC3 support by Philipp Zabel Signed-off-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-17mfd: fix tmio related warningsSamuel Ortiz
We can not have .driver_data as const since platform_set_drvdata() doesnt take a const. The hclk mmc_data field can be const though. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-06-13MFD,mmc: tmio_mmc: make HCLK configurablePhilipp Zabel
The Toshiba parts all have a 24 MHz HCLK, but HTC ASIC3 has a 24.576 MHz HCLK and AMD Imageon w228x's HCLK is 80 MHz. With this patch, the MFD driver provides the HCLK frequency to tmio_mmc via mfd_cell->driver_data. Signed-off-by: Philipp Zabel <philipp.zabel@gmail.com> Acked-by: Ian Molton <ian@mnementh.co.uk> Acked-by: Samuel Ortiz <sameo@openedhand.com> Signed-off-by: Pierre Ossman <pierre@ossman.eu>
2009-04-05mfd: Storage class should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-10-19mfd: support tmiofb cell on tc6393xbDmitry Baryshkov
Add support for tmiofb cell found in tc6393xb chip. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-10-19mfd: add OHCI cell to tc6393xbDmitry Baryshkov
Add information regarding OHCI cell of the tc6393xb Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Ian Molton <spyro@f2s.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-10-19mfd: do tcb6393xb state restore on resume only if requestedDmitry Baryshkov
As requested by Ian make state restore only if it's requested by platform data: some platforms do correctly save the state of the chip during suspend/resume, but some (like tosa) incorrectly power off the chip at suspend, so the driver supports restoring some bits of the tc6393xb state (not full, merely enough to support resume on tosa). With this patch this code is disabled by default. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Acked-by: Ian Molton <spyro@f2s.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-10-19mfd: provide and use setup hook for tc6393xbDmitry Baryshkov
Instead of using bitfields for initial gpio setup, provide generic setup/teardown hooks that can be used to set the gpio states, register child devices, etc. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-08-10mfd: tc6393 cleanup and updateIan Molton
This patchset cleans up the TC6393XB support. * Add provision for the MMC subdevice * Disable / enable clocks on suspend / resume * Remove fragments of badly merged code (eg. linux/fb include etc.) * Use a device specific clock name to break dependancy on ARM/PXA2XX * Drop unnecessary resource names * Switch to tmio_io* accessors Signed-off-by: Ian Molton <spyro@f2s.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-08-10mfd: Fix tc6393 according to the new tmio.hSamuel Ortiz
2008-07-29mfd: accept pure device as a parent, not only platform_deviceDmitry Baryshkov
2008-07-29mfd: add platform_data to mfd_cellMike Rapoport
Adding platform_data to mfd_cell allows passing of platform data directly to the platform_device created for each cell and thus reuse of existing drivers. On the other side it can be used as a hook to mfd_cell itself removing the need in mfd_get_cell method. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Acked-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Samuel Ortiz <sameo@openedhand.com>
2008-07-27[ARM] 5179/1: Replace obsolete IRQT_* and __IRQT_* values with IRQ_TYPE_*Dmitry Baryshkov
IRQT_* and __IRQT_* were obsoleted long ago by patch [3692/1]. Remove them completely. Sed script for the reference: s/__IRQT_RISEDGE/IRQ_TYPE_EDGE_RISING/g s/__IRQT_FALEDGE/IRQ_TYPE_EDGE_FALLING/g s/__IRQT_LOWLVL/IRQ_TYPE_LEVEL_LOW/g s/__IRQT_HIGHLVL/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_RISING/IRQ_TYPE_EDGE_RISING/g s/IRQT_FALLING/IRQ_TYPE_EDGE_FALLING/g s/IRQT_BOTHEDGE/IRQ_TYPE_EDGE_BOTH/g s/IRQT_LOW/IRQ_TYPE_LEVEL_LOW/g s/IRQT_HIGH/IRQ_TYPE_LEVEL_HIGH/g s/IRQT_PROBE/IRQ_TYPE_PROBE/g s/IRQT_NOEDGE/IRQ_TYPE_NONE/g Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-07-07[ARM] 5128/1: tc6393xb: tmio-nand supportDmitry Baryshkov
2008-07-07[ARM] 5096/2: Support Toshiba TC6393XB Mobile I/O Controller.Dmitry Baryshkov
Add support for Toshiba TC6393XB companion chip. Currently only GPIO and part of IRQ features of the device are supported. Signed-off-by: Dmitry Baryshkov <dbaryshkov@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
