path: root/drivers/mfd/tps6507x.c
2014-06-03mfd: tps6507x: Make of_device_id array constJingoo Han
Make of_device_id array const, because all OF functions handle it as const. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-01-06mfd: ti: Constify struct mfd_cell where possibleGeert Uytterhoeven
As of commit 03e361b25ee8dfb1fd9b890072c23c4aae01c6c7 ("mfd: Stop setting refcounting pointers in original mfd_cell arrays"), the "cell" parameter of mfd_add_devices() is "const" again. Hence make all cell data passed to mfd_add_devices() const where possible. Signed-off-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-10-23mfd: tps6507x: Include linux/of.h headerSachin Kamat
'of_match_ptr' is defined in linux/of.h. Include it explicitly to avoid breakage in the future. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-02-14mfd: tps6507x: Add DT supportVishwanathrao Badarkhe, Manish
Add device tree based initialization support for TI's tps6507x mfd device. Signed-off-by: Vishwanathrao Badarkhe, Manish <manishv.b@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-12-10mfd: tps6507x: Convert to devm_kzallocAxel Lin
Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-09-15mfd: core: Push irqdomain mapping out into devicesMark Brown
Currently the MFD core supports remapping MFD cell interrupts using an irqdomain but only if the MFD is being instantiated using device tree and only if the device tree bindings use the pattern of registering IPs in the device tree with compatible properties. This will be actively harmful for drivers which support non-DT platforms and use this pattern for their DT bindings as it will mean that the core will silently change remapping behaviour and it is also limiting for drivers which don't do DT with this particular pattern. There is also a potential fragility if there are interrupts not associated with MFD cells and all the cells are omitted from the device tree for some reason. Instead change the code to take an IRQ domain as an optional argument, allowing drivers to take the decision about the parent domain for their interrupts. The one current user of this feature is ab8500-core, it has the domain lookup pushed out into the driver. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-10-29mfd: Fix off-by-one value range checking for tps6507xAxel Lin
If bytes == (TPS6507X_MAX_REGISTER + 1), we have a buffer overflow when doing memcpy(&msg[1], src, bytes). Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-08-12mfd: Fix incorrect kfree(i2c) in tps6507x i2c_driver probeAxel Lin
The i2c_client received in probe() should not be kfree()'d. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28input: Touchscreen driver for TPS6507xTodd Fischer
Add touch screen input driver for TPS6507x family of multi-function chips. Uses the TPS6507x MFD driver. No interrupt support due to testing limitations of current hardware. Signed-off-by: Todd Fischer <todd.fischer@ridgerun.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Add TPS6507x supportTodd Fischer
TPS6507x are multi function (PM, touchscreen) chipsets from TI. This commit also changes the corresponding regulator driver from being standalone to an MFD subdevice. Signed-off-by: Todd Fischer <todd.fischer@ridgerun.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
