path: root/drivers/mfd/twl-core.c
2013-07-31mfd: Use dev_get_platdata()Jingoo Han
Use the wrapper function for retrieving the platform data instead of accessing dev->platform_data directly. Signed-off-by: Jingoo Han <jg1.han@samsung.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-06-20mfd: twl-core: Change TWL6025 references to TWL6032Graeme Gregory
The TWL6025 was never released beyond sample form and was replaced by the PhoenixLite range of chips - TWL6032. Change the references to reference the TWL6032 class and name the registers to twl6032 in line with an actual released chip name to avoid confusion. Currently there are no users of TWL6025 in the code. Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Oleksandr Kozaruk <oleksandr.kozaruk@ti.com> Acked-by: Lee Jones <lee.jones@linaro.org> Reviwed-by: Mark Brown <broonie@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-06-19mfd: twl4030-power: Split from twl-core into a dedicated moduleFlorian Vaussard
For now, the call to twl4030-power is hard-wired inside twl-core. To ease the future transition to DT, make twl4030-power as a separate module, like what is already done for twl4030-audio and others. Signed-off-by: Florian Vaussard <florian.vaussard@epfl.ch> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-06-11mfd: twl-core: Convert to module_i2c_driver()Grygorii Strashko
Shift TWL initialization to module/device init layer, because I2C now is not initialized on subsys init layer and shifted to module/device init layer instead. The I2C <--> TWL dependency should be resolved in drivers/Makefile now. Cc: Santosh Shilimkar <santosh.shilimkar@ti.com> Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: twl-core: Fix kernel panic on bootJon Hunter
Commit 8a6aaa3 (mfd: twl-core: Collect global variables behind one private structure (global)) removed the variable "inuse" that is used to determine if the device has been initialised and now use the twl_priv structure instead. This is causing the kernel to panic on OMAP3+ devices using the twl driver, because we try to access the twl_priv->ready member before checking if twl_priv is initialised. Fix this and move this test to the beginning of the twl_i2c_read/write function because twl_get_last_module() also uses the twl_priv structure. Signed-off-by: Jon Hunter <jon-hunter@ti.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: twl-core: Move twl_i2c_read/write_u8 to header as inline functionPeter Ujfalusi
twl_i2c_read/write_u8 become as a simple wrapper over the twl_i2c_read/write. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: twl-core: Remove no longer valid comment regarding to write buffer sizePeter Ujfalusi
With the regmap conversion there is no longeer a need to allocate bigger buffer for writes Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: twl-core: Collect global variables behind one private structure (global)Peter Ujfalusi
Gather the global variables under a single structure and allocate it with devm_kzalloc(). It is easier to see them and if in the future we try to add support for multiple instance of twl in the system it is going to be much simpler. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: twl-core: Move 'inuse' check early at probe timePeter Ujfalusi
We can fail earlier in case multiple instance of the twl-core is tried to be loaded. The twl-core by design only supports one instance. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: twl-core: Do not create dummy pdata when booted with DTPeter Ujfalusi
When booted with DT we can manage without the dummy pdata. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: twl-core: Do not try to call legacy mfd add_children() when booted with DTPeter Ujfalusi
There is really no point to retry to add children devices in case the of_platform_populate() fails. We do not have any information provided via pdata in this case anyways. Depending on the boot type (legacy or DT) only execute either one. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: twl-core: Allocate twl_modules dynamicallyPeter Ujfalusi
At boot time we can allocate the twl_modules array dynamically based on the twl class we are using with devm_kzalloc() instead of the static twl_modules[] array. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: twl-core: Use the lookup table to find the correct subchip for the modulesPeter Ujfalusi
Instead of using SUB_CHIP_ID* or magic numbers use the twl_mapping table to look for the subchip ID. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: twl-core: No need to check for invalid subchip IDPeter Ujfalusi
The module id table no longer can have invalid/unused entries. No need for checking the ID for validity. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: twl-core: Clean up module id lookup and definitionsPeter Ujfalusi
Use enums for all module definitions: twl_module_ids for common functionality among twl4030/twl6030 twl4030_module_ids for twl4030 specific ids twl6030_module_ids for twl6030 specific ids In this way the list can be managed easier when new functionality going to be implemented. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-12-16Merge tag 'mfd-3.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFS update from Samuel Ortiz: "This is the MFD patch set for the 3.8 merge window. We have several new drivers, most of the time coming with their sub devices drivers: - Austria Microsystem's AS3711 - Nano River's viperboard - TI's TPS80031, AM335x TS/ADC, - Realtek's MMC/memstick card reader - Nokia's retu We also got some notable cleanups and improvements: - tps6586x got converted to IRQ domains. - tps65910 and tps65090 moved to the regmap IRQ API. - STMPE is now Device Tree aware. - A general twl6040 and twl-core cleanup, with moves to the regmap I/O and IRQ APIs and a conversion to the recently added PWM framework. - sta2x11 gained regmap support. Then the rest is mostly tiny cleanups and fixes, among which we have Mark's wm5xxx and wm8xxx patchset." Far amount of annoying but largely trivial conflicts. Many due to __devinit/exit removal, others due to one or two of the new drivers also having come in through another tree. * tag 'mfd-3.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (119 commits) mfd: tps6507x: Convert to devm_kzalloc mfd: stmpe: Update DT support for stmpe driver mfd: wm5102: Add readback of DSP status 3 register mfd: arizona: Log if we fail to create the primary IRQ domain mfd: tps80031: MFD_TPS80031 needs to select REGMAP_IRQ mfd: tps80031: Add terminating entry for tps80031_id_table mfd: sta2x11: Fix potential NULL pointer dereference in __sta2x11_mfd_mask() mfd: wm5102: Add tuning for revision B mfd: arizona: Defer patch initialistation until after first device boot mfd: tps65910: Fix wrong ack_base register mfd: tps65910: Remove unused data mfd: stmpe: Get rid of irq_invert_polarity mfd: ab8500-core: Fix invalid free of devm_ allocated data mfd: wm5102: Mark DSP memory regions as volatile mfd: wm5102: Correct default for LDO1_CONTROL_2 mfd: arizona: Register haptics devices mfd: wm8994: Make current device behaviour the default mfd: tps65090: MFD_TPS65090 needs to select REGMAP_IRQ mfd: Fix stmpe.c build when OF is not enabled mfd: jz4740-adc: Use devm_kzalloc ...
2012-12-11Merge tag 'driver-core-3.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core Pull driver core updates from Greg Kroah-Hartman: "Here's the large driver core updates for 3.8-rc1. The biggest thing here is the various __dev* marking removals. This is going to be a pain for the merge with different subsystem trees, I know, but all of the patches included here have been ACKed by their various subsystem maintainers, as they wanted them to go through here. If this is too much of a pain, I can pull all of them out of this tree and just send you one with the other fixes/updates and then, after 3.8-rc1 is out, do the rest of the removals to ensure we catch them all, it's up to you. The merges should all be trivial, and Stephen has been doing them all in linux-next for a few weeks now quite easily. Other than the __dev* marking removals, there's nothing major here, some firmware loading updates and other minor things in the driver core. All of these have (much to Stephen's annoyance), been in linux-next for a while. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>" Fixed up trivial conflicts in drivers/gpio/gpio-{em,stmpe}.c due to gpio update. * tag 'driver-core-3.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core: (93 commits) modpost.c: Stop checking __dev* section mismatches init.h: Remove __dev* sections from the kernel acpi: remove use of __devinit PCI: Remove __dev* markings PCI: Always build setup-bus when PCI is enabled PCI: Move pci_uevent into pci-driver.c PCI: Remove CONFIG_HOTPLUG ifdefs unicore32/PCI: Remove CONFIG_HOTPLUG ifdefs sh/PCI: Remove CONFIG_HOTPLUG ifdefs powerpc/PCI: Remove CONFIG_HOTPLUG ifdefs mips/PCI: Remove CONFIG_HOTPLUG ifdefs microblaze/PCI: Remove CONFIG_HOTPLUG ifdefs dma: remove use of __devinit dma: remove use of __devexit_p firewire: remove use of __devinitdata firewire: remove use of __devinit leds: remove use of __devexit leds: remove use of __devinit leds: remove use of __devexit_p mmc: remove use of __devexit ...
2012-11-28mfd: remove use of __devinitBill Pemberton
CONFIG_HOTPLUG is going away as an option so __devinit is no longer needed. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Cc: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Daniel Walker <dwalker@fifo99.com> Cc: Bryan Huntsman <bryanh@codeaurora.org> Acked-by: David Brown <davidb@codeaurora.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-11-21mfd: twl-core: Change TWL4030_MODULE_* ids to TWL_MODULE_*Peter Ujfalusi
To facilitate upcoming cleanup in twl stack. No functional changes. Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-21mfd: twl-core: re-group the twl_mapping table for easier readingPeter Ujfalusi
Group the twl_mapping table in 5 lines chunks so it is more easier to find the row we are looking for (if we need to). Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-21mfd: twl: Convert module id definitions to enumsPeter Ujfalusi
Use enum list for the module definitions (TWL4030_MODULE_*) which will ease up future work with the IDs. At the same time group the IDs in block of five so it is easier to find the ID we are looking for (to count the number they stand for). At the same time define TWL_MODULE_LED so client drivers can switch to use it as soon as it is possible. Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-21mfd: twl-core: Clean up and correct child registrationPeter Ujfalusi
Make the twl child registration calls a bit more uniform by always using the SUB_CHIP_ID* define instead of the mixed use of the define and magic number. At the same time correct the following devices so they are registered for the correct parent device (i2c slave): twl4030_wdt is accessible on 0x4b address and not 0x48 twl4030_pwrbutton is accessible on 0x4b address and not 0x49 twl4030-audio is on 0x49 all the time Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-21mfd/rtc/gpio: twl: No need to allocate bigger buffer for writePeter Ujfalusi
Since the twl-core has been converted to use regmap it is no longer needed to allocate bigger buffer for data when writing to twl. CC: Grant Likely <grant.likely@secretlab.ca> CC: Alessandro Zummo <a.zummo@towertech.it> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-21mfd: twl-core: Convert to use regmap for I/OPeter Ujfalusi
Remove the custom code to do I/O and replace it with standard regmap calls. Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-21mfd: twl-core: Support for proper PWM driversPeter Ujfalusi
The twl6030-pwm driver is going to be deleted since it was only able to control the Charging indicator LED on the twl6030 PMIC. The new set of drivers are going to provide support for both PWMs and PWM driven LED outputs on TWL4030 and TWL6030 PMICs. The twl-pwm driver will handle the PWMs (2 instance) while the twl-pwmled driver is to control the two LED instance on TWL4030 and to charging indicator LED (1 instance) on TWL6030. Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-21mfd: twl-core: Register twl4030-madc child only for twl4030 classPeter Ujfalusi
twl4030-madc driver can only handle twl4030 class MADC. The newer revisions of twl does not have MADC, instead they have different IP called GPADC which is not backward compatible. Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-11-20mfd: twl-core: Fix chip ID for the twl6030-pwm modulePeter Ujfalusi
The correct chip id is 1 since the PWM module is on address 0x49. With the current TWL6030_MODULE_ID1 the kernel will crash early since we have: #define TWL6030_MODULE_ID1 0x0E and static struct twl_client twl_modules[4]; Down in the stack we try to get the module by: struct twl_client *twl = &twl_modules[chip]; Which is obviously going to do nasty things. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-10-05Merge tag 'mfd-3.7-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD changes from Samuel Ortiz: "MFD bits for the 3.7 merge window. As usual we have a few new drivers: - TI LP8788 - TI OMAP USB TLL - Maxim MAX8907 - SMSC ECE1099 - Dialog Semiconductor DA9055 - A simpler syscon driver that allow us to get rid of the anatop one. Drivers are also gradually getting Device Tree and IRQ domain support. The following drivers got DT support: - palmas, 88pm860x, tc3589x and twl4030-audio And those ones now use the IRQ domain APIs: - 88pm860x, tc3589x, db8500_prcmu Also some other interesting changes: - Intel's ICH LPC now supports Lynx Point - TI's twl4030-audio added a GPO child - tps6527 enabled its backlight subdevice - The twl6030 pwm driver moved to the new PWM subsystem And finally a bunch of cleanup and casual fixes for mc13xxx, 88pm860x, palmas, ab8500, wm8994, wm5110, max8907 and the tps65xxx family." Fix up various annoying conflicts: the DT and IRQ domain support came in twice and was already in 3.6. And then it was apparently rebased. Guys, DON'T REBASE! * tag 'mfd-3.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (89 commits) ARM: dts: Enable 88pm860x pmic mfd: 88pm860x: Move gpadc init into touch mfd: 88pm860x: Device tree support mfd: 88pm860x: Use irqdomain mfd: smsc: Add support for smsc gpio io/keypad driver backlight: tps65217_bl: Add missing platform_set_drvdata in tps65217_bl_probe mfd: DA9055 core driver mfd: tps65910: Add alarm interrupt of TPS65910 RTC to mfd device list mfd: wm5110: Add register patches for revision B mfd: wm5110: Disable control interface error report for WM5110 rev B mfd: max8907: Remove regulator-compatible from DT docs backlight: Add TPS65217 WLED driver mfd: Add backlight as subdevice to the tps65217 mfd: Provide the PRCMU with its own IRQ domain mfd: Fix max8907 sparse warning mfd: Add lp8788 mfd driver mfd: dbx500: Provide a more accurate smp_twd clock mfd: rc5t583: Fix warning messages regulator: palmas: Add DT support mfd: palmas: Change regulator defns to better suite DT ...
2012-09-19pwm: Move TWL6030 PWM driver to PWM frameworkThierry Reding
This commit moves the driver to drivers/pwm and converts it to the new PWM framework. In order for this to work properly, register the PWM as child of the multi-function TWL6030 device. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-09-19mfd: twl: Replace twl_has_*() macros by IS_ENABLED()Thierry Reding
Instead of reinventing macros for the same purpose, use the standard macros. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-09-18mfd: twl-core: Add API to query the HFCLK ratePeter Ujfalusi
CFG_BOOT register's HFCLK_FREQ field hold information about the used HFCLK frequency. Add possibility for users to get the configured rate based on this register. This register was configured during boot, without it the chip would not operate correctly, so we can trust on this information. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-09-17mfd: Fix compile for twl-core.c by removing cpu_is_omap usageTony Lindgren
Commit 7d7e1eba (ARM: OMAP2+: Prepare for irqs.h removal) broke compile for non-omap as include plat/cpu.h was added. This header was indirectly included earlier when SPARSE_IRQ was not set, but does not exist on most platforms. Fix the problem by removing the cpu_is_omap usage that should not exist in drivers at all. We can do this by adding proper clock aliases for the twl-core.c drivers, and drop separate handling for cases when clock framework is not available as the behaviour will stay the same. Note that we need to add a platform device to avoid using the i2c provided names that may be different on various omaps. Reported-by: Fengguang Wu <fengguang.wu@intel.com> Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Paul Walmsley <paul@pwsan.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Cc: Olof Johansson <olof@lixom.net> Cc: Felipe Balbi <balbi@ti.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-09-12ARM: OMAP2+: Prepare for irqs.h removalTony Lindgren
As the interrupts should only be defined in the platform_data, and eventually coming from device tree, there's no need to define them in header files. Let's remove the hardcoded references to irqs.h and fix up the includes so we don't rely on headers included in irqs.h. Note that we're defining OMAP_INTC_START as 0 to the interrupts. This will be needed when we enable SPARSE_IRQ. For some drivers we need to add #include <plat/cpu.h> for now until these drivers are fixed to remove cpu_is_omapxxxx() usage. While at it, sort som of the includes the standard way, and add the trailing commas where they are missing in the related data structures. Note that for drivers/staging/tidspbridge we just define things locally. Cc: Paul Walmsley <paul@pwsan.com> Signed-off-by: Tony Lindgren <tony@atomide.com>
2012-07-31Merge tag 'for-v3.6' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery updates from Anton Vorontsov: "The tag contains just a few battery-related changes for v3.6. It's is all pretty straightforward, except one thing. One of our patches added thermal support for power supply class, but thermal/ subsystem changed under our feet. We (well, Stephen, that is) caught the issue and it was decided[1] that I'd just delay the battery pull request, and then will fix it up by merging upstream back into battery tree at the specific commit. That's not all though: another[2] small fixup for thermal subsystem was needed to get rid of a warning in power supply subsystem (the warning was not drivers/power's "fault", the thermal registration function just needed a proper const annotation, which is also done by a small commit on top of the merge. So, to sum this up: - The 'master' branch of the battery tree was in the -next tree for weeks, was never rebased, altered etc. It should be all OK; - Although, for-v3.6 tag contains the 'master' branch + merge + the warning fix. [1] http://lkml.org/lkml/2012/6/19/23 [2] http://lkml.org/lkml/2012/6/18/28" * tag 'for-v3.6' of git://git.infradead.org/battery-2.6: (23 commits) thermal: Constify 'type' argument for the registration routine olpc-battery: update CHARGE_FULL_DESIGN property for BYD LiFe batteries olpc-battery: Add VOLTAGE_MAX_DESIGN property charger-manager: Fix build break related to EXTCON lp8727_charger: Move header file into platform_data directory power_supply: Add min/max alert properties for CAPACITY, TEMP, TEMP_AMBIENT bq27x00_battery: Add support for BQ27425 chip charger-manager: Set current limit of regulator for over current protection charger-manager: Use EXTCON Subsystem to detect charger cables for charging test_power: Add VOLTAGE_NOW and BATTERY_TEMP properties test_power: Add support for USB AC source gpio-charger: Use cansleep version of gpio_set_value bq27x00_battery: Add support for power average and health properties sbs-battery: Don't trigger false supply_changed event twl4030_charger: Allow charger to control the regulator that feeds it twl4030_charger: Add backup-battery charging twl4030_charger: Fix some typos max17042_battery: Support CHARGE_COUNTER power supply attribute smb347-charger: Add constant charge and current properties power_supply: Add constant charge_current and charge_voltage properties ...
2012-07-09mfd: Move twl-core device_init_wakeup to after platform_device_addNeilBrown
device_init_wakeup uses the dev_name() of the device to set the name of the wakeup_source which appears in /sys/kernel/debug/wakeup_sources. For a platform device, that name is not set until platform_device_add calls dev_set_name. So the call to device_init_wakeup() must be after the call to platform_device_add(). Making this change causes correct names to appear in the wakeup_sources file. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-06-19twl4030_charger: Allow charger to control the regulator that feeds itNeilBrown
The charger needs usb3v1 to be running, so add a new consumer to keep it running. This allows the charger to draw current even when the USB driver has powered down. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: Tero Kristo <t-kristo@ti.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2012-05-09mfd: twl: define all feature flags in one place.NeilBrown
twl-regulator has a collection of feature flags, some defined in twl-core.c and one defined in i2c/twl.h. This is confusing for anyone adding a new feature flag. So collect them together and place them in twl.h immediately after the structure in which they are initially set. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-28Merge tag 'mfd_3.4-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD changes from Samuel Ortiz: - 4 new drivers: Freescale i.MX on-chip Anatop, Ricoh's RC5T583 and TI's TPS65090 and TPS65217. - New variants support (8420, 8520 ab9540), cleanups and bug fixes for the abx500 and db8500 ST-E chipsets. - Some minor fixes and update for the wm8994 from Mark. - The beginning of a long term TWL cleanup effort coming from the TI folks. - Various fixes and cleanups for the s5m, TPS659xx, pm860x, and MAX8997 drivers. Fix up trivial conflicts due to duplicate patches and header file cleanups (<linux/device.h> removal etc). * tag 'mfd_3.4-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (97 commits) gpio/twl: Add DT support to gpio-twl4030 driver gpio/twl: Allocate irq_desc dynamically for SPARSE_IRQ support mfd: Detach twl6040 from the pmic mfd driver mfd: Replace twl-* pr_ macros by the dev_ equivalent and do various cleanups mfd: Micro-optimization on twl4030 IRQ handler mfd: Make twl4030 SIH SPARSE_IRQ capable mfd: Move twl-core IRQ allocation into twl[4030|6030]-irq files mfd: Remove references already defineid in header file from twl-core mfd: Remove unneeded header from twl-core mfd: Make twl-core not depend on pdata->irq_base/end ARM: OMAP2+: board-omap4-*: Do not use anymore TWL6030_IRQ_BASE in board files mfd: Return twl6030_mmc_card_detect IRQ for board setup Revert "mfd: Add platform data for MAX8997 haptic driver" mfd: Add support for TPS65090 mfd: Add some da9052-i2c section annotations mfd: Build rtc5t583 only if I2C config is selected to y. mfd: Add anatop mfd driver mfd: Fix compilation error in tps65910.h mfd: Add 8420 variant to db8500-prcmu mfd: Add 8520 PRCMU variant to db8500-prcmu ...
2012-03-22mfd: Detach twl6040 from the pmic mfd driverPeter Ujfalusi
On OMAP4 platform audio has separate IC, it is no longer part of the pmic chip. Prevent twl-core to claim the 0x4b address, which belongs to the twl6040 audio IC. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-03-22mfd: Replace twl-* pr_ macros by the dev_ equivalent and do various cleanupsBenoit Cousson
Since a structure device is available now, use the dev_ macros instead of the pr_ ones. Clean some badly formatted comments. Remove some unused variables. Move some variable to the place they belong. Clean some badly wrapped lines. Align variable definition Add missing braces in if-then-else block. Add blank line for better readability. Move stuff here and there... Conflicts: drivers/mfd/twl-core.c Signed-off-by: Benoit Cousson <b-cousson@ti.com> Cc: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-03-22mfd: Move twl-core IRQ allocation into twl[4030|6030]-irq filesBenoit Cousson
During DT adaptation, the irq_alloc_desc was added into twl-core, but due to the rather different and weird IRQ management required by the twl4030, it is much better to have a different approach for it. The issue is that twl4030 uses a two level IRQ mechanism but handles all the PWR interrupts as part of the twl-core interrupt range. It ends up with a range of 16 interrupts total for CORE and PWR. The other twl4030 functionalities already have a dedicated driver and thus their IRQs and irqdomain can and should be defined localy. twl6030 is using a single level IRQ controller and thus does not require any trick. Move the irq_alloc_desc and irq_domain_add_legacy in twl4030-irq and twl6030-irq. Allocate together CORE and PWR IRQs for twl4030-irq. Conflicts: drivers/mfd/twl-core.c Signed-off-by: Benoit Cousson <b-cousson@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-03-22mfd: Remove references already defineid in header file from twl-coreBenoit Cousson
The twl-core exported functions are already declared in twl-core.h Include the header file instead or re-declaring the functions. Signed-off-by: Benoit Cousson <b-cousson@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-03-22mfd: Remove unneeded header from twl-coreFelipe Balbi
This driver doesn't really need <plat/cpu.h>, so remove it. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-03-22mfd: Make twl-core not depend on pdata->irq_base/endFelipe Balbi
With sparse IRQs the driver shouldn't depend at all on any IRQ values coming from board-file. Remove every occurences of pdata->irq_base/end. Signed-off-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Benoit Cousson <b-cousson@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-03-21Merge tag 'regulator-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator Pull regulator updates for 3.4 from Mark Brown: "This has been a fairly quiet release from a regulator point of view, the only real framework features added were devm support and a convenience helper for setting up fixed voltage regulators. We also added a couple of drivers (but will drop the BQ240022 driver via the arm-soc tree as it's been replaced by the more generic gpio-regulator driver) and Axel Lin continued his relentless and generally awesome stream of fixes and cleanups." * tag 'regulator-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/regulator: (93 commits) regulator: Fix up a confusing dev_warn when DT lookup fails regulator: Convert tps6507x to set_voltage_sel regulator: Refactor tps6507x to use one tps6507x_pmic_ops for all LDOs and DCDCs regulator: Make s5m8767_get_voltage_register always return correct register regulator: s5m8767: Check pdata->buck[2|3|4]_gpiodvs earlier regulator: tps65910: Provide settling time for DCDC voltage change regulator: Add Anatop regulator driver regulator: Simplify implementation of tps65912_get_voltage_dcdc regulator: Use tps65912_set_voltage_sel for both DCDCx and LDOx regulator: tps65910: Provide settling time for enabling rails regulator: max8925: Use DIV_ROUND_UP macro regulator: tps65912: Use simple equations to get register address regulator: Fix the logic of tps65910_get_mode regulator: Merge tps65217_pmic_ldo234_ops and tps65217_pmic_dcdc_ops to tps65217_pmic_ops regulator: Use DIV_ROUND_CLOSEST in wm8350_isink_get_current regulator: Use array to store dcdc_range settings for tps65912 regulator: Rename s5m8767_convert_voltage to s5m8767_convert_voltage_to_sel regulator: tps6524x: Remove unneeded comment for N_REGULATORS regulator: Rename set_voltage_sel callback function name to *_sel regulator: Fix s5m8767_set_voltage_time_sel calculation value ...
2012-03-19Merge tag 'topic/twl' into regulator-nextMark Brown
TWL specific changes, cross-merged with OMAP due to arch/arm wanting to use the new ability to override the voltage set and get operations to support the in-CPU voltage management. The other changes are minor fixes, the addition of a few new regulators and device tree support.
2012-03-18Merge remote-tracking branch 'regulator/topic/supply' into regulator-nextMark Brown
2012-03-11mfd: twl-core: regulator configuration for twl6030 V1V8, V2V1 SMPSPeter Ujfalusi
To be able to attach consumers to these supplies from board files we need to have regulator_init_data for them. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-11regulator: twl6030: add support for vdd1, vdd2 and vdd3 regulatorsTero Kristo
vdd1 and vdd2 are now common regulators for twl4030 and twl6030. Also added vdd3 as a new regulator for twl6030. twl6030 vdd1...vdd3 smps regulator voltages can only be controlled through the smartreflex voltage channel, thus the support for the voltage_get and set is minimal and requires external controller. Signed-off-by: Tero Kristo <t-kristo@ti.com> Signed-off-by: Rajendra Nayak <rnayak@ti.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-11regulator: twl4030: add support for external voltage get/setTero Kristo
This is needed for SMPS regulators, which use the OMAP voltage processor for voltage get/set functions instead of the normal I2C channel. For this purpose, regulator_init_data->driver_data contents are expanded, it is now a struct which contains function pointers for the set/get voltage operations, a data pointer for these, and the previously used features bitmask. Signed-off-by: Tero Kristo <t-kristo@ti.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> [for the MFD part] Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
