path: root/drivers/mfd/vexpress-sysreg.c
2015-03-03mfd: vexpress: Remove non-DT codePawel Moll
Now, as all VE platforms have to be booted with DT, the code handling non-DT case can be removed. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2014-11-04of: Eliminate of_allnodes listGrant Likely
The device tree structure is composed of two lists; the 'allnodes' list which is a singly linked list containing every node in the tree, and the child->parent structure where each parent node has a singly linked list of children. All of the data in the allnodes list can be easily reproduced with the parent-child lists, so of_allnodes is actually unnecessary. Remove it entirely which saves a bit of memory and simplifies the data structure quite a lot. Signed-off-by: Grant Likely <grant.likely@linaro.org> Cc: Rob Herring <robh@kernel.org> Cc: Gaurav Minocha <gaurav.minocha.os@gmail.com> Cc: Pantelis Antoniou <pantelis@pantelis.antoniou@konsulko.com>
2014-05-15ARM: vexpress: move HBI check to sysreg driverPawel Moll
The last reason for static memory mapping is the HBI (board identification number) check early in the machine code. Moving the check to the sysreg driver makes it possible to completely remove the early mapping and init functions. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Lee Jones <lee.jones@linaro.org>
2014-05-15mfd: vexpress: Define the device as MFD cellsPawel Moll
This patch - finally, after over 6 months! :-( - addresses Samuel's request to split the vexpress-sysreg driver into smaller portions and define the device in a form of MFD cells: * LEDs code has been completely removed and replaced with "gpio-leds" nodes in the tree (referencing dedicated GPIO subnodes in sysreg - bindings documentation updated); this also better fits the reality as some variants of the motherboard don't have all the LEDs populated * syscfg bridge code has been extracted into a separate driver (placed in drivers/misc for no better place) * all the ID & MISC registers are defined as sysconf making them available for other drivers should they need to use them (and also to the user via /sys/kernel/debug/regmap which can be helpful in platform debugging) Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Lee Jones <lee.jones@linaro.org>
2014-05-15mfd: vexpress: Convert custom func API to regmapPawel Moll
Components of the Versatile Express platform (configuration microcontrollers on motherboard and daughterboards in particular) talk to each other over a custom configuration bus. They provide miscellaneous functions (from clock generator control to energy sensors) which are represented as platform devices (and Device Tree nodes). The transactions on the bus can be generated by different "bridges" in the system, some of which are universal for the whole platform (for the price of high transfer latencies), others restricted to a subsystem (but much faster). Until now drivers for such functions were using custom "func" API, which is being replaced in this patch by regmap calls. This required: * a rework (and move to drivers/bus directory, as suggested by Samuel and Arnd) of the config bus core, which is much simpler now and uses device model infrastructure (class) to keep track of the bridges; non-DT case (soon to be retired anyway) is simply covered by a special device registration function * the new config-bus driver also takes over device population, so there is no need for special matching table for of_platform_populate nor "simple-bus" hack in the arm64 model dtsi file (relevant bindings documentation has been updated); this allows all the vexpress devices fit into normal device model, making it possible to remove plenty of early inits and other hacks in the near future * adaptation of the syscfg bridge implementation in the sysreg driver, again making it much simpler; there is a special case of the "energy" function spanning two registers, where they should be both defined in the tree now, but backward compatibility is maintained in the code * modification of the relevant drivers: * hwmon - just a straight-forward API change * power/reset driver - API change * regulator - API change plus error handling simplification * osc clock driver - this one required larger rework in order to turn in into a standard platform driver Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Mark Brown <broonie@linaro.org> Acked-by: Lee Jones <lee.jones@linaro.org> Acked-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Mike Turquette <mturquette@linaro.org>
2014-03-19mfd: vexpress-sysreg: Initialize 'site' variableSemen Protsenko
'site' variable should be initialized with 0 so that when 'site' property doesn't exist in DTB it can be handled correctly. '0' value means board site number is motherboard (see Documentation/devicetree/bindings/arm/vexpress.txt for details). Signed-off-by: Semen Protsenko <semen.protsenko@linaro.org> Signed-off-by: Lee Jones <lee.jones@linaro.org>
2013-06-19mfd: vexpress: Make the driver optional for arm and arm64Pawel Moll
The driver can be used on either arm or arm64 platforms, but the latter doesn't have any platform-specific configuration options, so it must be possible to manually enable the driver. As the gpiolib is optional for arm64 arch, the gpio/led code must be compiled conditionally. Signed-off-by: Pawel Moll <pawel.moll@arm.com> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-04-09mfd: vexpress: Give the "leds-gpio" device a real parentPawel Moll
The registration of the "leds-gpio" device was using "vexpress_sysreg_dev" as a parent before it was actually set to something different than NULL. Trivial fix by reordering the code. Reported-by: Lorenzo Pieralisi <lorenzo.pieralisi@arm.com> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-24Merge tag 'mfd-3.9-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFS updates from Samuel Ortiz: "This is the MFD pull request for the 3.9 merge window. No new drivers this time, but a bunch of fairly big cleanups: - Roger Quadros worked on a OMAP USBHS and TLL platform data consolidation, OMAP5 support and clock management code cleanup. - The first step of a major sync for the ab8500 driver from Lee Jones. In particular, the debugfs and the sysct interfaces got extended and improved. - Peter Ujfalusi sent a nice patchset for cleaning and fixing the twl-core driver, with a much needed module id lookup code improvement. - The regular wm5102 and arizona cleanups and fixes from Mark Brown. - Laxman Dewangan extended the palmas APIs in order to implement the palmas GPIO and rt drivers. - Laxman also added DT support for the tps65090 driver. - The Intel SCH and ICH drivers got a couple fixes from Aaron Sierra and Darren Hart. - Linus Walleij patchset for the ab8500 driver allowed ab8500 and ab9540 based devices to switch to the new abx500 pin-ctrl driver. - The max8925 now has device tree and irqdomain support thanks to Qing Xu. - The recently added rtsx driver got a few cleanups and fixes for a better card detection code path and now also supports the RTS5227 chipset, thanks to Wei Wang and Roger Tseng." * tag 'mfd-3.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (109 commits) mfd: lpc_ich: Use devres API to allocate private data mfd: lpc_ich: Add Device IDs for Intel Wellsburg PCH mfd: lpc_sch: Accomodate partial population of the MFD devices mfd: da9052-i2c: Staticize da9052_i2c_fix() mfd: syscon: Fix sparse warning mfd: twl-core: Fix kernel panic on boot mfd: rtsx: Fix issue that booting OS with SD card inserted mfd: ab8500: Fix compile error mfd: Add missing GENERIC_HARDIRQS dependecies Documentation: Add docs for max8925 dt mfd: max8925: Add dts mfd: max8925: Support dt for backlight mfd: max8925: Fix onkey driver irq base mfd: max8925: Fix mfd device register failure mfd: max8925: Add irqdomain for dt mfd: vexpress: Allow vexpress-sysreg to self-initialise mfd: rtsx: Support RTS5227 mfd: rtsx: Implement driving adjustment to device-dependent callbacks mfd: vexpress: Add pseudo-GPIO based LEDs mfd: ab8500: Rename ab8500 to abx500 for hwmon driver ...
2013-02-14mfd: vexpress: Allow vexpress-sysreg to self-initialiseCatalin Marinas
The vexpress_sysreg_init() is a core_initcall() already and it can trigger the early initialisation if a matching node is found. This patch allows the SoC code to avoid calling vexpress_sysreg_of_early_init() explicitly. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-02-14mfd: vexpress: Add pseudo-GPIO based LEDsPawel Moll
The LEDs on the Versatile Express motherboard are controlled through simple memory-mapped register. This patch extends the pseudo-GPIO controller definition for these lines and creates generic "leds-gpio" device using them Signed-off-by: Pawel Moll <pawel.moll@arm.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2013-01-28mfd/vexpress: vexpress_sysreg_setup must not be __initArnd Bergmann
The patch 52666298a 'mfd: vexpress-sysreg: Don't skip initialization on probe' adds a call to vexpress_sysreg_setup from a non-__init function, so this also has to lose its __init annotation. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Pawel Moll <pawel.moll@arm.com> Cc: arm@kernel.org Signed-off-by: Olof Johansson <olof@lixom.net>
2013-01-24mfd: vexpress-sysreg: Don't skip initialization on probePawel Moll
The vexpress-sysreg driver does not have to be initialized early, when the platform doesn't require this. Unfortunately in such case it wasn't initialized correctly - master site lookup and config bridge registration were missing. Fixed now. Signed-off-by: Pawel Moll <pawel.moll@arm.com>
2013-01-03Drivers: mfd: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from these drivers. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Cc: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-12-07mfd: vexpress-sysreg: Remove LEDs codePawel Moll
As the current LEDs code breaks other platform, remove it. It shall be replaced by a generic "MMIO LEDs" driver. Reported-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Pawel Moll <pawel.moll@arm.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-11-05mfd: Versatile Express system registers driverPawel Moll
This is a platform driver for Versatile Express' "system register" block. It's a random collection of registers providing the following functionality: - low level platform functions like board ID access; in order to use those, the driver must be initialized early, either statically or based on the DT - config bus bridge via "system control" interface; as the response from the controller does not generate interrupt (yet), the status register is periodically polled using a timer - pseudo GPIO lines providing MMC card status and Flash WP# signal control - LED interface for a set of 8 LEDs on the motherboard, with "heartbeat", "mmc0" and "cpu0" to "cpu5" as default triggers Signed-off-by: Pawel Moll <pawel.moll@arm.com>
