path: root/drivers/mfd
2012-02-28ENGR00175219-3 wm8958: add audio codec supportGary Zhang
add wm8958 audio codec support Signed-off-by: Gary Zhang <b13634@freescale.com>
2012-02-17ENGR00173964 make hdmi audio init dependent on hdmi video initAlan Tull
Don't show hdmi as an audio playback device if hdmi isn't configured on the command line. Signed-off-by: Alan Tull <r80115@freescale.com>
2012-02-08ENGR00172342-2 EDID parse audio data blocksAlan Tull
Add functionality to parse Audio Data Blocks from EDID data to find out what modes of LPCM are suppored by the HDMI sink device. The parsed settings are saved in the hdmi mfd. The HDMI audio driver will check the settings when the audio stream is opened and will then apply appropriate constraints. If we are unable to read from the EDID, then we default to supporting Basic Audio as defined by the HDMI specification (stereo, 16 bit, 32KHz, 44.1KHz, 48KHz PCM). Signed-off-by: Alan Tull <r80115@freescale.com>
2012-01-25ENGR00172752-2 Remove usless code in pfuze100 regulator driverNancy Chen
Remove usless code in pfuze100 regulator driver Signed-off-by: Robin Gong <b38343@freescale.com> Signed-off-by: Nancy Chen <Nancy.Chen@freescale.com>
2012-01-19ENGR00172374-2: pfuze: use pdata_size from mfd_cell structJason Liu
fix the building errors when upgrade to v3.0 we use data_size from mfd_cell struct on 2.6.38, but after that there are some changes for this field of mfd_cell struct, see: commit 40e03f571b2e63827f2afb90ea9aa459612c29e3 Author: Andres Salomon <dilinger@queued.net> Date: Thu Feb 17 19:07:24 2011 -0800 mfd: Drop data_size from mfd_cell struct Now that there are no more users of this, drop it. Signed-off-by: Andres Salomon <dilinger@queued.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> and this: commit eb8956074e7652e802be5f078080c704c2c87104 Author: Samuel Ortiz <sameo@linux.intel.com> Date: Wed Apr 6 16:52:52 2011 +0200 mfd: Add platform data pointer back Now that we have a way to pass MFD cells down to the sub drivers, we can gradually get rid of mfd_data by putting the platform pointer back in place. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> But the above commit also change the name from data_size to pdata_size, This patch just give one fix for the pfuze driver to use pdata_size field. Signed-off-by: Jason Liu <r64343@freescale.com>
2012-01-09ENGR00171001-2 MX6Q PFUZE100: fix build warningsRobin Gong
fix build warnings on pfuze driver: arch/arm/mach-mx6/mx6q_sabreauto_pmic_pfuze100.c:388: warning: initialization from incompatible pointer type drivers/mfd/pfuze-core.c:523: warning: initialization from incompatible pointer type drivers/mfd/pfuze-core.c:412: warning: 'pfuze_add_subdevice' defined but not used Signed-off-by: Robin Gong <B38343@freescale.com>
2012-01-09ENGR00170255-2 MX6Q PFUZE100: add pfuze100 driverRobin Gong
add pfuze core driver for mx6 Signed-off-by: Robin Gong <B38343@freescale.com>
2012-01-09ENGR00169872-2 rework hdmi initialization and hotplug sequenceAlan Tull
This commit intends to implement the flowchart and details documented in the HDMI Transmitter Controller User Guide section entitled "Programming Model". Some input is also from the Synopsys API code. The HDMI specification requires HDMI to set itself to VGA DVI mode before reading the EDID. So follow this sequence when HDMI is hotplugged: 1. Hdmi connector is plugged in, HDMI video gets an interrupt. 2. Clear out video mode list. Add only VGA DVI mode to list. 3. Request VGA DVI mode (call fb_set_var()) 4. HDMI video driver will get FB_EVENT_MODE_CHANGE callback and call mxc_hdmi_setup() to set up HDMI. 5. Read the edid and add video modes from edid. Select the video mode that is similar to the command line default. 6. Request VGA DVI mode (call fb_set_var()) 7. HDMI video driver will get FB_EVENT_MODE_CHANGE callback and do mxc_hdmi_setup(). Also included is a workaround for an overflow condition in the HDMI. The frame composer has an arithmetic unit that gets updated every time we write to one of the FC registers. But sometimes, depending on the relation between the tmds and sfr clocks, it may happen that this unit doesn't get updated, even though the registers are holding correct values. The workaround for this is, after completing the controller configuration, to rewrite one of the FC registers (i.e. FC_INVIDCONF) three or four times with the same value, and then follow it up by a SW reset to the TMDS clock domain (MC_SWRSTZ). We clear the overflow condition as described above every time we change video mode. Also an overflow interupt handler will clear the overflow condition if it happens again. This overflow condition is expected (and not a problem) when we are in DVI (non-HDMI) mode, so we do not worry about it in that case. Signed-off-by: Alan Tull <alan.tull@freescale.com>
2012-01-09ENGR00143921-1 - EPDC/MAX17135: Add controls for V3P3 regulatorDanny Nold
- Added V3P3 regulator to max17135 - Added calls to enable/disable V3P3 regulator from EPDC driver - Improved Kconfig detail for max17135 MFD and HWMON entries Signed-off-by: Danny Nold <dannynold@freescale.com>
2012-01-09ENGR00160860-2 hdmi audio driverAlan Tull
Audio driver for i.Mx built-in HDMI Transmitter. * Uses HDMI Transmitter's built-in DMA. * Adds IEC958-style digital audio header info to the raw audio. * Gets pixel clock from the IPU driver and calculates clock regenerator values (cts and N). * Move ipu_id, and disp_id from the HDMI's platform data to the HDMI mfd's platform data. Saves them in the hdmi mfd. * Add mfd functionality to update the clock regenerator values when the hdmi changes the pixel clock rate or when requested from the audio driver with a new audio sample rate. Signed-off-by: Alan Tull <alan.tull@freescale.com>
2012-01-09ENGR00159530-1 mc34708: add new pmic core driver based on MFDRobin Gong
add new mc34708's core driver based on MFD Signed-off-by: Robin Gong <B38343@freescale.com>
2012-01-09ENGR00160061 - MXC HDMI: Optimize HDMI clock managementDanny Nold
- Ensure HDMI clocks are disabled when leaving HDMI core probe function. - Create HDMI core api to allow HDMI sub-drivers to init, enable, and disable the HDMI IRQ. Required to optimally manage HDMI clocks, allow IAHB to be disabled, and still have video and audio sub-drivers able to receive interrupts. - Update code to adjust for decoupled ISFR and IAHB clocks. - Disable IAHB clocks whenever HDMI not plugged in. Signed-off-by: Danny Nold <dannynold@freescale.com>
2012-01-09ENGR00155845-1 mfd for hdmiAlan Tull
This is a mfd for the internal HDMI Transmitter on i.Mx. It handles resources that are shared by the seperate video and audio drivers. Signed-off-by: Alan Tull <alan.tull@freescale.com>
2012-01-09ENGR00142950-2 - MAX17135 EPD PMIC: Ported to 2.6.38 kernelDanny Nold
- Ported MAX17135 MFD core driver to 2.6.38 - Ported MAX17135 HWMON temperature sensor driver to 2.6.38 - Ported MAX17135 regulator driver to 2.6.38 Signed-off-by: Danny Nold <dannynold@freescale.com>
2012-01-09ENGR00141391-2 PMIC: porting da9053 to i.mx platformZhou Jingyu
Fix da9053 backlight Kconfig error porting da9052 regulator driver Signed-off-by: Zhou Jingyu <Jingyu.Zhou@freescale.com> Acked-by: Lily Zhang <r58066@freescale.com>
2012-01-09ENGR00141391-1 PMIC: Add DA9053 source code from DialogZhou Jingyu
Add DA9053 original source code Signed-off-by: Zhou Jingyu <Jingyu.Zhou@freescale.com> Acked-by: Lily Zhang <r58066@freescale.com>
2011-12-09revert "mfd: Fix twl4030 dependencies for audio codec"Greg Kroah-Hartman
This reverts commit 11b8fc6ae54bf18a48c94e181c37ca135b858b42, which was commit f09ee0451a44a4e913a7c3cec3805508f7de6c54 upstream. Koen Kooi <koen@dominion.thruhere.net> reports that this shouldn't have been applied to the 3.0 kernel as it isn't relevant there, only 3.1. Reported-by: Koen Kooi <koen@dominion.thruhere.net> Cc: Thomas Weber <weber@corscience.de> Cc: Peter Ujfalusi <peter.ujfalusi@ti.com> Cc: Samuel Ortiz <sameo@linux.intel.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-21mfd: Fix twl4030 dependencies for audio codecThomas Weber
commit f09ee0451a44a4e913a7c3cec3805508f7de6c54 upstream. The codec for Devkit8000 (TWL4030) was not detected except when build with CONFIG_SND_SOC_ALL_CODECS. twl-core.c still uses the CONFIG_TWL4030_CODEC for twl_has_codec(). In commit 57fe7251f5bfc4332f24479376de48a1e8ca6211 the CONFIG_TWL4030_CODEC was renamed into CONFIG_MFD_TWL4030_AUDIO, thatswhy the codec was not detected. This patch renames the CONFIG_ TWL4030_CODEC into CONFIG_MFD_TWL4030_AUDIO in twl-core.c. Signed-off-by: Thomas Weber <weber@corscience.de> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Cc: Jarkko Nikula <jarkko.nikula@bitmer.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03mfd: Make omap-usb-host TLL mode work againAnand Gadiyar
commit e600cffe618ff0da29ae1f8b8d3824ce0e2409fc upstream. This code section seems to have been accidentally copy pasted. It causes incorrect bits to be set up in the TLL_CHANNEL_CONF register and prevents the TLL mode from working correctly. Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Cc: Keshava Munegowda <keshava_mgowda@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-10-03mfd: Fix initialisation of tps65910 interruptsJohan Hovold
commit fa948761e685fb03823b3029e5b6bdb52229d6ce upstream. Fix regression introduced by commit a2974732ca7614aaf0baf9d6dd3ad893d50ce1c5 (TPS65911: Add new irq definitions) which caused irq_num to be incorrectly set for tps65910. Signed-off-by: Johan Hovold <jhovold@gmail.com> Acked-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-08w1: ds1wm: add a reset recovery parameterJean-François Dagenais
This fixes a regression in 3.0 reported by Paul Parsons regarding the removal of the msleep(1) in the ds1wm_reset() function: : The linux-3.0-rc4 DS1WM 1-wire driver is logging "bus error, retrying" : error messages on an HP iPAQ hx4700 PDA (XScale-PXA270): : : <snip> : Driver for 1-wire Dallas network protocol. : DS1WM w1 busmaster driver - (c) 2004 Szabolcs Gyurko : 1-Wire driver for the DS2760 battery monitor chip - (c) 2004-2005, Szabolcs Gyurko : ds1wm ds1wm: pass: 1 bus error, retrying : ds1wm ds1wm: pass: 2 bus error, retrying : ds1wm ds1wm: pass: 3 bus error, retrying : ds1wm ds1wm: pass: 4 bus error, retrying : ds1wm ds1wm: pass: 5 bus error, retrying : ... : : The visible result is that the battery charging LED is erratic; sometimes : it works, mostly it doesn't. : : The linux-2.6.39 DS1WM 1-wire driver worked OK. I haven't tried 3.0-rc1, : 3.0-rc2, or 3.0-rc3. This sleep should not be required on normal circuitry provided the pull-ups on the bus are correctly adapted to the slaves. Unfortunately, this is not always the case. The sleep is restored but as a parameter to the probe function in the pdata. [akpm@linux-foundation.org: coding-style fixes] Reported-by: Paul Parsons <lost.distance@yahoo.com> Tested-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Jean-François Dagenais <dagenaisj@sonatest.com> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-05mfd: Add Makefile and Kconfig Entries for tps65911 comparatorAxel Lin
Base on Mark's comment [1], I make the Kconfig entry invisible to users. [1] https://lkml.org/lkml/2011/5/14/136 Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-07-05mfd: Fix build error for tps65911-comparator.cAxel Lin
Fix below build error: CC drivers/mfd/tps65911-comparator.o drivers/mfd/tps65911-comparator.c: In function 'tps65911_comparator_probe': drivers/mfd/tps65911-comparator.c:131: error: 'struct tps65910_platform_data' has no member named 'vmbch_threshold' drivers/mfd/tps65911-comparator.c:137: error: 'struct tps65910_platform_data' has no member named 'vmbch2_threshold' make[2]: *** [drivers/mfd/tps65911-comparator.o] Error 1 make[1]: *** [drivers/mfd] Error 2 make: *** [drivers] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-07-05Revert "mfd: Add omap-usbhs runtime PM support"Keshava Munegowda
This reverts commit 7e6502d577106fb5b202bbaac64c5f1b065e6daa. Oops are produced during initialization of ehci and ohci drivers. This is because the run time pm apis are used by the driver but the corresponding hwmod structures and initialization is not merged. hence revering back the commit id 7e6502d577106fb5b202bbaac64c5f1b065e6daa Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Reported-by: Luciano Coelho <coelho@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-28mfd: Fix build breakage caused by tps65910 gpio directory moveLiam Girdwood
Signed-off-by: Liam Girdwood <lrg@ti.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-28mfd: Use mfd cell platform_data for db8500-prcmu cells platform bitsMattias Wallin
With the addition of a device platform mfd_cell pointer, MFD drivers can go back to passing platform data back to their sub drivers. This allows for an mfd_cell->mfd_data removal and thus keep the sub drivers MFD agnostic. This is mostly needed for non MFD aware sub drivers. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-27TPS65911: Comparator: Add comparator driverJorge Eduardo Candelaria
This driver adds functionality to the tps65911 chip driver. Two of the comparators are configurable by software and measures VCCS voltage to detect high or low voltage scenarios. Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-27GPIO: TPS65910: Move driver to drivers/gpio/Jorge Eduardo Candelaria
The GPIO driver should reside in drivers/gpio/ for better organization. Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-27TPS65911: Add new irq definitionsJorge Eduardo Candelaria
TPS65911 adds new interrupt sources, as well as two new registers to handle them, one for interrupt status and one for interrupt masking. The added irqs are: -VMBCH2 - Low and High threshold -GPIO1-8 - Rising and falling edge detection -WTCHDG - Watchdog interrupt -PWRDN - PWRDN reset interrupt The code should handle these new registers only when the chip version is TPS65911. Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-27MFD: TPS65910: Add support for TPS65911 deviceJorge Eduardo Candelaria
The TPS65911 is the next generation of the TPS65910 family of PMIC chips. It adds a few features: - Watchdog Timer - PWM & LED generators - Comparators for system control status It also adds a set of Interrupts and GPIOs, among other things. The driver exports a function to identify between different versions of the tps65910 family, allowing other modules to identify the capabilities of the current chip. Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-27mfd: Fix off-by-one value range checking for tps65910_i2c_writeAxel Lin
If bytes == (TPS65910_MAX_REGISTER + 1), we have a buffer overflow when doing memcpy(&msg[1], src, bytes). Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-27linux-next: build failure after merge of the voltage treeJorge Eduardo Candelaria
On May 10, 2011, at 9:27 PM, Stephen Rothwell wrote: > Hi Jorge, > > On Tue, 10 May 2011 12:30:36 -0500 Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> wrote: >> >> On May 10, 2011, at 3:38 AM, Liam Girdwood wrote: >> >>> On Tue, 2011-05-10 at 12:44 +1000, Stephen Rothwell wrote: >>>> Hi Liam, >>>> >>>> After merging the voltage tree, today's linux-next build (x86_64 >>>> allmodconfig) failed like this: >>>> >>>> ERROR: "tps65910_gpio_init" [drivers/mfd/tps65910.ko] undefined! >>>> ERROR: "tps65910_irq_init" [drivers/mfd/tps65910.ko] undefined! >>>> ERROR: "irq_modify_status" [drivers/mfd/tps65910-irq.ko] undefined! >>>> ERROR: "irq_set_chip_and_handler_name" [drivers/mfd/tps65910-irq.ko] undefined! >>>> ERROR: "handle_edge_irq" [drivers/mfd/tps65910-irq.ko] undefined! >>>> >>>> I have used the voltage tree from next-20110509 for today. >>> >>> Jorge, could you send a fix for this today. >> >> The following patch should solve this: >> >> From: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> >> MFD: Fix TPS65910 build >> >> Support for tps65910 as a module is not available. The driver can >> only be compiled as built-in. OTOH, the regulator driver can still >> be built as module without breaking the compilation. >> >> Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> > > Today (even with the above patch included) I got these errors from the > x86_64 allmodconfig build: > > tps65910.c:(.text+0xf4140): undefined reference to `i2c_master_send' > drivers/built-in.o: In function `tps65910_i2c_read': > tps65910.c:(.text+0xf41d2): undefined reference to `i2c_transfer' > drivers/built-in.o: In function `tps65910_i2c_init': > tps65910.c:(.init.text+0xcb83): undefined reference to `i2c_register_driver' > drivers/built-in.o: In function `tps65910_i2c_exit': > tps65910.c:(.exit.text+0x6e0): undefined reference to `i2c_del_driver' > > I have used the voltage tree from next-20110509 again today. Following patch should fix the dependency problems. Please review: From: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> [PATCH] MFD: TPS65910: Fix I2C dependency TPS65910 driver can only be compiled built-in, so the I2C driver should be as well. Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
On May 10, 2011, at 3:38 AM, Liam Girdwood wrote: > On Tue, 2011-05-10 at 12:44 +1000, Stephen Rothwell wrote: >> Hi Liam, >> >> After merging the voltage tree, today's linux-next build (x86_64 >> allmodconfig) failed like this: >> >> ERROR: "tps65910_gpio_init" [drivers/mfd/tps65910.ko] undefined! >> ERROR: "tps65910_irq_init" [drivers/mfd/tps65910.ko] undefined! >> ERROR: "irq_modify_status" [drivers/mfd/tps65910-irq.ko] undefined! >> ERROR: "irq_set_chip_and_handler_name" [drivers/mfd/tps65910-irq.ko] undefined! >> ERROR: "handle_edge_irq" [drivers/mfd/tps65910-irq.ko] undefined! >> >> I have used the voltage tree from next-20110509 for today. > > Jorge, could you send a fix for this today. > > Thanks > > Liam > The following patch should solve this: From: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> MFD: Fix TPS65910 build Support for tps65910 as a module is not available. The driver can only be compiled as built-in. OTOH, the regulator driver can still be built as module without breaking the compilation. Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-27TPS65910: IRQ: Add interrupt controllerGraeme Gregory
This module controls the interrupt handling for the tps chip. The interrupt sources are the following: - GPIO falling/rising edge detection - Battery voltage below/above threshold - PWRON signal - PWRHOLD signal - Temperature detection - RTC alarm and periodic event Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-27TPS65910: GPIO: Add GPIO driverGraeme Gregory
TPS65910 has one configurable GPIO that can be used for several purposes. Subsequent versions of the TPS chip support more than one GPIO. Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-27MFD: TPS65910: Add new mfd device for TPS65910Graeme Gregory
The TPS65910 chip is a power management IC for multimedia and handheld devices. It contains the following components: - Regulators - GPIO controller - RTC The tps65910 core driver is registered as a platform driver and provides communication through I2C with the host device for the different components. Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Jorge Eduardo Candelaria <jedu@slimlogic.co.uk> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2011-05-26mfd: Add omap-usbhs runtime PM supportKeshava Munegowda
The usbhs core driver does not enable/disable the interface and functional clocks; These clocks are handled by hwmod and runtime pm, hence insted of the clock enable/disable, the runtime pm APIS are used. however,the port clocks and tll clocks are handled by the usbhs core. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Fix ASIC3 SD Host Controller Configuration sizePaul Parsons
The size of the TC6380AF SD Host Controller Configuration area is 0x200 bytes (assuming registers are aligned on 32-bit boundaries), not 0x400 bytes. Source: Toshiba TC6380AF Specification sections 4.2 and 4.3.1 Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Fix omap_usbhs_alloc_children error handlingAxel Lin
1. Return proper error if omap_usbhs_alloc_child fails 2. In the case of goto err_ehci, we should call platform_device_unregister(ehci) instead of platform_device_put(ehci) because we have already added the platform device to device hierarchy. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Axel Lin <axel.lin@gmail.com> Tested-by: Keshava Munegowda <keshava_mgowda@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Fix omap usbhs crash when rmmoding ehci or ohciKeshava Munegowda
The disabling of clocks and freeing GPIO are changed to fix the occurrence of the crash of rmmod of ehci and ohci drivers. The GPIOs should be freed after the spin locks are unlocked. Signed-off-by: Keshava Munegowda <keshava_mgowda@ti.com> Acked-by: Felipe Balbi <balbi@ti.com> Cc: stable@kernel.org Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Add ASIC3 LED supportPaul Parsons
Add LED support for the HTC ASIC3. Underlying support is provided by the mfd/asic3 and leds/leds-asic3 drivers. An example configuration is provided by the pxa/hx4700 platform. Signed-off-by: Paul Parsons <lost.distance@yahoo.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Update twl4030-code maintainer e-mail addressPeter Ujfalusi
Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Correct the name and bitmask for ab8500-gpadc BTempPullUpJohan Palsson
The bitmask for enabling the BatTemp pull-up was wrong and is corrected. The name is also changed to be inline with the AB8500 register description Signed-off-by: Johan Palsson <johan.palsson@stericsson.com> Reviewed-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Add manual ab8500-gpadc batt temp activation for AB8500 3.0Karl Komierowski
In AB8500 3.0 the pull-up supplying the NTC must be manually activated. Add enumerators to chip version detection logic. Signed-off-by: Kalle Komierowski <karl.komierowski@stericsson.com> Reviewed-by: Johan Palsson <johan.palsson@stericsson.com> Reviewed-by: Daniel Willerud <daniel.willerud@stericsson.com> Reviewed-by: Jonas Aberg <jonas.aberg@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Provide ab8500-core enumerators for chip cutsLinus Walleij
Since functionality in MFD cells may need to be adjusted according to chip revision, let's enumerate them and keep track of them. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Check twl4030-power remove script error condition after i2cwriteLesly A M
Fixing the error condition check in twl4030 remove script function. Due to some typo in commit ID: 11a441ce82d6ffecfd39b324024de0cd630b36c1 Signed-off-by: Lesly A M <leslyam@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Fix twl6030 irq definitionsGraeme Gregory
The charger fault IRQs from the twl will in future patches be handled by a seperate IRQ handler in the charger driver than the general charger IRQ. Give them different IRQ numbers now to allow the charger driver to be merged in the future. Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Add phoenix lite (twl6025) support to twl6030Graeme Gregory
Phoenix Lite is based on the twl6030 family of PMICs. It has mostly the same feature set of twl6030 but with small changes. The codec block has also been removed. It also has a new charger block and new features in its ADC block. VUSB handling also differs. Signed-off-by: Graeme Gregory <gg@slimlogic.co.uk> Reviewed-by: Mark Brown <broonie@opensource.wolfsonicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Avoid to use constraint name in 88pm860x regulator driverHaojian Zhuang
Avoid to use constraint name in regulator driver. So use regulator id is used instead in platform driver. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2011-05-26mfd: Remove checking on max8925 regulator[0]Haojian Zhuang
Since regulator[0] is always checking in mfd driver, it results in registration failure without regulator[0]. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
