path: root/drivers/mfd
2010-06-03i2c: Remove all i2c_set_clientdata(client, NULL) in driversWolfram Sang
I2C drivers can use the clientdata-pointer to point to private data. As I2C devices are not really unregistered, but merely detached from their driver, it used to be the drivers obligation to clear this pointer during remove() or a failed probe(). As a couple of drivers forgot to do this, it was agreed that it was cleaner if the i2c-core does this clearance when appropriate, as there is no guarantee for the lifetime of the clientdata-pointer after remove() anyhow. This feature was added to the core with commit e4a7b9b04de15f6b63da5ccdd373ffa3057a3681 to fix the faulty drivers. As there is no need anymore to clear the clientdata-pointer, remove all current occurrences in the drivers to simplify the code and prevent confusion. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Acked-by: Richard Purdie <rpurdie@linux.intel.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-05-28mfd: Rename twl5031 sih modulesIlkka Koskinen
Fix the names of twl5031 specific sih modules to match the documentation. Signed-off-by: Ilkka Koskinen <ilkka.koskinen@nokia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Storage class for timberdale should be before const qualifierTobias Klauser
The C99 specification states in section 6.11.5: The placement of a storage-class specifier other than at the beginning of the declaration specifiers in a declaration is an obsolescent feature. Signed-off-by: Tobias Klauser <tklauser@distanz.ch> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Remove unneeded and dangerous clearing of clientdataWolfram Sang
Unlike real i2c-devices which get detached from the driver, dummy-devices get truly unregistered. So, there has never been a need to clear the clientdata because the device will go away anyhow. For the occasions fixed here, clearing clientdata was even dangerous as the structure was freed already. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: New AB8500 driverRabin Vincent
Add a new driver to support the AB8500 Power Management chip, replacing the current AB4500. The new driver replaces the old one, instead of an incremental modification, because this is a substantial overhaul including: - Split of the driver into -core and -spi portions, to allow another interface layer to be added - Addition of interrupt support - Switch to MFD core API for handling subdevices - Simplification of the APIs to remove a redundant block parameter - Rename of the APIs and macros from ab4500_* to ab8500_* - Rename of the files from ab4500* to ab8500* - Change of the driver name from ab4500 to ab8500 Acked-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Srinidhi Kasagar <srinidhi.kasagar@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Change rdc321x resources flags to IORESOURCE_IOFlorian Fainelli
The rdc321x southbridge PCI device has no MEM PCI resources that we could pass to mfd_add_devices. Since 33254dd5, mfd_add_device checks for the mem_base argument that we set to NULL. Changing the resources passed to our MFD cells from IORESOURCE_MEM to IORESOURCE_IO fixes that. Since we use those resources as offsets to the PCI configuration space base address of the southbridge device this is also more adequate. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Move pcf50633 irq related functions to its own file.Lars-Peter Clausen
This reduces code clutter a bit and will ease an migration to genirq. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Use threaded irq for pcf50633Lars-Peter Clausen
Use threaded oneshot irq handler instead of normal irq handler and a workqueue. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: pcf50633-adc: Fix potential race in pcf50633_adc_sync_readLars-Peter Clausen
Currently it's not guaranteed that request struct is not already freed when reading from it. Fix this by moving synced request related fields from the pcf50633_adc_request struct to its own struct and store it on the functions stack. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Fix pcf50633 bitfield logic in interrupt handlerLars-Peter Clausen
Those constants are alreay bitfields. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Use menuconfig for quicker config editingRandy Dunlap
Change MFD 'menu' to 'menuconfig' to facilitate easy (one-click) disabling of all MFD drivers. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: AB3550 core driverMattias Wallin
This adds a core driver for the AB3550 mixed-signal circuit found in the ST-Ericsson U300 platforms. This driver is a singleton proxy for all access to the AB3550 sub functionality drivers which can be added on top of this one: RTC, regulators, battery and system power control, vibrator, LEDs and an ALSA codec. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: AB3100 register access change to abx500 APIMattias Wallin
The interface for the AB3100 is changed to make way for the ABX500 family of chips: AB3550, AB5500 and future ST-Ericsson Analog Baseband chips. The register access functions are moved out to a separate struct abx500_ops. In this way the interface is moved from the implementation and the sub functionality drivers can keep their interface intact when chip infrastructure and communication mechanisms changes. We also define the AB3550 device IDs and the AB3550 platform data struct and convert the catenated 32bit event to an array of 3 x 8bits. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Renamed ab3100.h to abx500.hLinus Walleij
The goal here is to make way for a more general interface for the analog baseband chips ab3100 ab3550 ab550 and future chips. This patch have been divided into two parts since both changing name and content of a file is not recommended in git. Signed-off-by: Mattias Wallin <mattias.wallin@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Add Toshiba's TC35892 MFD coreRabin Vincent
The TC35892 I/O Expander provides 24 GPIOs, a keypad controller, timers, and a rotator wheel interface. This patch adds the MFD core. Acked-by: Linus Walleij <linus.walleij@stericsson.com> Signed-off-by: Rabin Vincent <rabin.vincent@stericsson.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Delay to mask tsc irq in max8925Haojian Zhuang
There're two IRQ pins output from MAX8925. One is PMIC interrupt, the other is TSC interrupt. But they're sharing one irq chip. After initializing MAX8925 interrupts, unexpected TSC interrupt may occur and it can't be cleared if touch driver isn't loaded. Now move the operation of masking TSC interrupt behind requesting PMIC interrupt. If touch driver isn't loaded, this interrupt is always masked. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Remove incorrect wm8350 kfreeRabin Vincent
The i2c_client received in probe() should not be kfree()'d. Signed-off-by: Rabin Vincent <rabin@rab.in> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Fix error in wm8400 reg cache access checkPhil Carmody
Accessing num_reg elements in the interval [reg .. reg+num_regs) is permitted if (reg+numregs <= array size), so barf when that excluded upper bound is > array size. The prior -1 would give access to one too many elements. Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Ensure WM831x charger interrupts are acknowledged when suspendingMark Brown
The charger interrupts on the WM831x are unconditionally a wake source for the system. If the power driver is not able to monitor them (for example, due to the IRQ line not having been wired up on the system) then any charger interrupt will prevent the system suspending for any meaningful amount of time since nothing will ack them. Avoid this issue by manually acknowledging these interrupts when we suspend the WM831x core device if they are masked. If software is actually using the interrupts then they will be unmasked and this change will have no effect. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Initialise WM831x IRQ masks on chip even if interrupts not in useMark Brown
Ensure that the hardware has interrupts masked if we are not using the interrupt controller on the WM831x by initialising the masks before we check for the setup data required for the IRQ line. This avoids signalling an unused IRQ line and improves the robustness of checks that the IRQ is in use. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28input: Touchscreen driver for TPS6507xTodd Fischer
Add touch screen input driver for TPS6507x family of multi-function chips. Uses the TPS6507x MFD driver. No interrupt support due to testing limitations of current hardware. Signed-off-by: Todd Fischer <todd.fischer@ridgerun.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Add TPS6507x supportTodd Fischer
TPS6507x are multi function (PM, touchscreen) chipsets from TI. This commit also changes the corresponding regulator driver from being standalone to an MFD subdevice. Signed-off-by: Todd Fischer <todd.fischer@ridgerun.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Improve WM831x AUXADC completion handlingMark Brown
Currently completion of WM831x AUXADC conversions is monitored by checking for convertor enable. Due to the mechanism used to ensure data corruption is avoided when reading AUXADC data there may under heavy I/O be a window where this bit has cleared but the conversion results have not been updated. Data availability is only guaranteed after the AUXADC data interrupt has been asserted. Avoid this by always using the interrupt to detect completion. If the chip IRQ is not set up then we poll the IRQ status register for up to 5ms. If it is set up then we rely on the data done interrupt with a vastly increased timeout, failing the conversion if the interrupt is not generated. This also saves a register read when using interrupts. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Janz CMOD-IO PCI MODULbus Carrier Board supportIra W. Snyder
The Janz CMOD-IO PCI MODULbus carrier board is a PCI to MODULbus bridge, which may host many different types of MODULbus daughterboards, including CAN and GPIO controllers. Signed-off-by: Ira W. Snyder <iws@ovro.caltech.edu> Reviewed-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Proper pcf50633 irq checkDan Carpenter
"pcf->irq_handler" has PCF50633_NUM_IRQ elements. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Remove unused wm831x IRQ handler dataMark Brown
This was used by the old, pre-genirq IRQ implementation but is no longer required. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Add timb-dma to all configurations of timberdaleRichard Röjfors
Add platform data for timb-dma, and add it in to timb-dma in all configurations of timberdale. Also incremented the version number. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Section cleanup of 88pm860x driverHenrik Kretzschmar
This patch fixes three section mismatches. WARNING: drivers/mfd/88pm860x.o(.text+0x12): Section mismatch in reference from the function pm860x_device_exit() to the function .devexit.text:device_irq_exit() The function pm860x_device_exit() references a function in an exit section. Often the function device_irq_exit() has valid usage outside the exit section and the fix is to remove the __devexit annotation of device_irq_exit. WARNING: drivers/mfd/88pm860x.o(.text+0xb0): Section mismatch in reference from the function pm860x_device_init() to the function .devinit.text:device_8606_init() The function pm860x_device_init() references the function __devinit device_8606_init(). This is often because pm860x_device_init lacks a __devinit annotation or the annotation of device_8606_init is wrong. WARNING: drivers/mfd/88pm860x.o(.text+0xbe): Section mismatch in reference from the function pm860x_device_init() to the function .devinit.text:device_8607_init() The function pm860x_device_init() references the function __devinit device_8607_init(). This is often because pm860x_device_init lacks a __devinit annotation or the annotation of device_8607_init is wrong. Signed-off-by: Henrik Kretzschmar <henne@nachtwindheim.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Check for mem_base when building IORESOURCE_MEM resourcesSamuel Ortiz
If mem_base is NULL, then we fall back to the default case, just copying the original resource. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Off by one calculating size for timberdaleDan Carpenter
I'm pretty sure that it should be + 1 here. It's an off by one, because we start counting at zero. Signed-off-by: Dan Carpenter <error27@gmail.com> Acked-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Add support for the RDC321x southbridgeFlorian Fainelli
This patch adds a new MFD driver for the RDC321x southbridge. This southbridge is always present in the RDC321x System-on-a-Chip and provides access to some GPIOs as well as a watchdog. Access to these two functions is done using the southbridge PCI device configuration space. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Fix dangling pointersWolfram Sang
Fix I2C-drivers which missed setting clientdata to NULL before freeing the structure it points to. Also fix drivers which do this _after_ the structure was freed already. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Add in XIIC to some configurations of timberdaleRichard Röjfors
This patch adds in the Xilinx I2C bus driver to some of the configurations of the timberdale MFD. It provides the I2C devices to the XIIC via platform data in a similar way as done to the ocores driver. Signed-off-by: Richard Röjfors <richard.rojfors@pelagicore.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-28mfd: Check t7l66 platform_data pointerSamuel Ortiz
We should check for pdata being not NULL before dereferencing it. Reported-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-27Merge branch 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlightLinus Torvalds
* 'for-linus' of git://git.o-hand.com/linux-rpurdie-backlight: gta02: Use pcf50633 backlight driver instead of platform backlight driver. backlight: pcf50633: Register a pcf50633-backlight device in pcf50633 core driver. backlight: Add pcf50633 backlight driver backlight: 88pm860x_bl: fix error handling in pm860x_backlight_probe backlight: max8925_bl: Fix error handling path backlight: l4f00242t03: fix error handling in l4f00242t03_probe backlight: add S6E63M0 AMOLED LCD Panel driver backlight: adp8860: add support for ADP8861 & ADP8863 backlight: mbp_nvidia_bl - Fix DMI_SYS_VENDOR for MacBook1,1 backlight: Add Cirrus EP93xx backlight driver backlight: l4f00242t03: Fix regulators handling code in remove function backlight: fix adp8860_bl build errors backlight: new driver for the ADP8860 backlight parts backlight: 88pm860x_bl - potential memory leak backlight: mbp_nvidia_bl - add support for older MacBookPro and MacBook 6,1. backlight: Kconfig cleanup backlight: backlight_device_register() return ERR_PTR()
2010-05-26backlight: pcf50633: Register a pcf50633-backlight device in pcf50633 core ↵Lars-Peter Clausen
driver. Register a device newly added pcf50633-backlight driver as a child device in the pcf50633 core driver. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2010-05-26leds: Add mc13783 LED supportPhilippe Rétornaz
This add basic led support for Freescale MC13783 PMIC. Signed-off-by: Philippe Rétornaz <philippe.retornaz@epfl.ch> Signed-off-by: Richard Purdie <rpurdie@linux.intel.com>
2010-05-25regulator: use voltage number array in 88pm860xHaojian Zhuang
A lot of condition comparision statements are used in original driver. These statements are used to check the boundary of voltage numbers since voltage number isn't linear. Now use array of voltage numbers instead. Clean code with simpler way. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-25regulator: make 88pm860x sharing one driver structureHaojian Zhuang
Remove a lot of driver structures in 88pm860x driver. Make regulators share one driver structure. Signed-off-by: Haojian Zhuang <haojian.zhuang@marvell.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-05-22sh: allow platforms to specify SD-card supported voltagesGuennadi Liakhovetski
Boards can have different supplied voltages on different SD card slots. This information has to be passed down to the SD/MMC driver. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22mfd: pass platform flags down to the tmio_mmc driverGuennadi Liakhovetski
2010-05-22mmc: add DMA support to tmio_mmc driver, when used on SuperHGuennadi Liakhovetski
SDHI controllers on SuperH, served by the tmio_mmc driver, can use slave DMA for data transfer. This patch adds support for the dmaengine API to the tmio_mmc driver. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Ian Molton <ian@mnementh.co.uk> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-22sh: prepare the SDHI MFD driver to pass DMA configuration to tmio_mmc.cGuennadi Liakhovetski
Pass DMA slave IDs from platform down to the tmio_mmc driver, to be used for dmaengine configuration. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-05-20Merge branch 'topic/asoc' into for-linusTakashi Iwai
Conflicts: sound/soc/codecs/ad1938.c
2010-05-13mfd: Clean up after WM83xx AUXADC interrupt if it arrives lateMark Brown
In certain circumstances, especially under heavy load, the AUXADC completion interrupt may be detected after we've timed out waiting for it. That conversion would still succeed but the next conversion will see the completion that was signalled by the interrupt for the previous conversion and therefore not wait for the AUXADC conversion to run, causing it to report failure. Provide a simple, non-invasive cleanup by using try_wait_for_completion() to ensure that the completion is not signalled before we wait. Since the AUXADC is run within a mutex we know there can only have been at most one AUXADC interrupt outstanding. A more involved change should follow for the next merge window. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2010-05-10ASoC: Use more idiomatic driver name for WM8731Mark Brown
Make dev_() prints much prettier. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Liam Girdwood <lrg@slimlogic.co.uk>
2010-04-05mfd: Add WM8994 interrupt controller supportMark Brown
The WM8994 has an interrupt controller which supports interrupts for both CODEC and GPIO portions of the chip. Support this using genirq, while allowing for systems that do not have an interrupt hooked up. Wrapper functions are provided for the IRQ request and free to simplify the code in consumer drivers when handling cases where IRQs are not set up. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Samuel Ortiz <sameo@linux.intel.com>
2010-04-02mfd: update gfp/slab.h includesTejun Heo
Implicit slab.h inclusion via percpu.h is about to go away. Make sure gfp.h or slab.h is included as necessary. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-22Merge branch 'for-2.6.34' into for-2.6.35Mark Brown
