path: root/drivers/mfd
2012-07-31Merge tag 'random_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random Pull random subsystem patches from Ted Ts'o: "This patch series contains a major revamp of how we collect entropy from interrupts for /dev/random and /dev/urandom. The goal is to addresses weaknesses discussed in the paper "Mining your Ps and Qs: Detection of Widespread Weak Keys in Network Devices", by Nadia Heninger, Zakir Durumeric, Eric Wustrow, J. Alex Halderman, which will be published in the Proceedings of the 21st Usenix Security Symposium, August 2012. (See https://factorable.net for more information and an extended version of the paper.)" Fix up trivial conflicts due to nearby changes in drivers/{mfd/ab3100-core.c, usb/gadget/omap_udc.c} * tag 'random_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/random: (33 commits) random: mix in architectural randomness in extract_buf() dmi: Feed DMI table to /dev/random driver random: Add comment to random_initialize() random: final removal of IRQF_SAMPLE_RANDOM um: remove IRQF_SAMPLE_RANDOM which is now a no-op sparc/ldc: remove IRQF_SAMPLE_RANDOM which is now a no-op [ARM] pxa: remove IRQF_SAMPLE_RANDOM which is now a no-op board-palmz71: remove IRQF_SAMPLE_RANDOM which is now a no-op isp1301_omap: remove IRQF_SAMPLE_RANDOM which is now a no-op pxa25x_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op omap_udc: remove IRQF_SAMPLE_RANDOM which is now a no-op goku_udc: remove IRQF_SAMPLE_RANDOM which was commented out uartlite: remove IRQF_SAMPLE_RANDOM which is now a no-op drivers: hv: remove IRQF_SAMPLE_RANDOM which is now a no-op xen-blkfront: remove IRQF_SAMPLE_RANDOM which is now a no-op n2_crypto: remove IRQF_SAMPLE_RANDOM which is now a no-op pda_power: remove IRQF_SAMPLE_RANDOM which is now a no-op i2c-pmcmsp: remove IRQF_SAMPLE_RANDOM which is now a no-op input/serio/hp_sdc.c: remove IRQF_SAMPLE_RANDOM which is now a no-op mfd: remove IRQF_SAMPLE_RANDOM which is now a no-op ...
2012-07-31Merge tag 'for-v3.6' of git://git.infradead.org/battery-2.6Linus Torvalds
Pull battery updates from Anton Vorontsov: "The tag contains just a few battery-related changes for v3.6. It's is all pretty straightforward, except one thing. One of our patches added thermal support for power supply class, but thermal/ subsystem changed under our feet. We (well, Stephen, that is) caught the issue and it was decided[1] that I'd just delay the battery pull request, and then will fix it up by merging upstream back into battery tree at the specific commit. That's not all though: another[2] small fixup for thermal subsystem was needed to get rid of a warning in power supply subsystem (the warning was not drivers/power's "fault", the thermal registration function just needed a proper const annotation, which is also done by a small commit on top of the merge. So, to sum this up: - The 'master' branch of the battery tree was in the -next tree for weeks, was never rebased, altered etc. It should be all OK; - Although, for-v3.6 tag contains the 'master' branch + merge + the warning fix. [1] http://lkml.org/lkml/2012/6/19/23 [2] http://lkml.org/lkml/2012/6/18/28" * tag 'for-v3.6' of git://git.infradead.org/battery-2.6: (23 commits) thermal: Constify 'type' argument for the registration routine olpc-battery: update CHARGE_FULL_DESIGN property for BYD LiFe batteries olpc-battery: Add VOLTAGE_MAX_DESIGN property charger-manager: Fix build break related to EXTCON lp8727_charger: Move header file into platform_data directory power_supply: Add min/max alert properties for CAPACITY, TEMP, TEMP_AMBIENT bq27x00_battery: Add support for BQ27425 chip charger-manager: Set current limit of regulator for over current protection charger-manager: Use EXTCON Subsystem to detect charger cables for charging test_power: Add VOLTAGE_NOW and BATTERY_TEMP properties test_power: Add support for USB AC source gpio-charger: Use cansleep version of gpio_set_value bq27x00_battery: Add support for power average and health properties sbs-battery: Don't trigger false supply_changed event twl4030_charger: Allow charger to control the regulator that feeds it twl4030_charger: Add backup-battery charging twl4030_charger: Fix some typos max17042_battery: Support CHARGE_COUNTER power supply attribute smb347-charger: Add constant charge and current properties power_supply: Add constant charge_current and charge_voltage properties ...
2012-07-31Merge with upstream to accommodate with thermal changesAnton Vorontsov
This merge is performed to take commit c56f5c0342dfee11a1 ("Thermal: Make Thermal trip points writeable") out of Linus' tree and then fixup power supply class. This is needed since thermal stuff added a new argument: CC drivers/power/power_supply_core.o drivers/power/power_supply_core.c: In function ‘psy_register_thermal’: drivers/power/power_supply_core.c:204:6: warning: passing argument 3 of ‘thermal_zone_device_register’ makes integer from pointer without a cast [enabled by default] include/linux/thermal.h:154:29: note: expected ‘int’ but argument is of type ‘struct power_supply *’ drivers/power/power_supply_core.c:204:6: error: too few arguments to function ‘thermal_zone_device_register’ include/linux/thermal.h:154:29: note: declared here make[1]: *** [drivers/power/power_supply_core.o] Error 1 make: *** [drivers/power/] Error 2 Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org>
2012-07-30Merge tag 'mfd-3.6-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 Pull MFD bits from Samuel Ortiz: "We have support for a few new drivers: - Samsung s2mps11 - Wolfson Microelectronics wm5102 and wm5110 - Marvell 88PM800 and 88PM805 - TI twl6041 We also have our regular driver improvements: - Device tree and IRQ domain support for STE AB8500 - Regmap and devm_* API conversion for TI tps6586x - Device tree support for Samsung max77686 - devm_* API conversion for STE AB3100 Besides that, quite a lot of fixing and cleanup for mc13xxx, tps65910, tps65090, da9052 and twl-core." Fix up mostly trivial conflicts, with the exception of drivers/usb/host/ehci-omap.c in particular, which had some re-organization of the reset sequence (commit 1a49e2ac9651: "EHCI: centralize controller initialization") that clashed with commit 2761a6394516 ("mfd: USB: Fix the omap-usb EHCI ULPI PHY reset fix issues"). In particular, commit 2761a6394516 moved the usb_add_hcd() to the *middle* of the reset sequence, which clashes fairly badly with the reset sequence re-organization (although it could have been done inside the new omap_ehci_init() function). I left that part of commit 2761a6394516 just undone. * tag 'mfd-3.6-1' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (110 commits) mfd: Ensure AB8500 platform data is passed through db8500-prcmu to MFD Core mfd: Arizone core should select MFD_CORE mfd: Fix arizona-irq.c build by selecting REGMAP_IRQ mfd: Add debug trace on entering and leaving arizone runtime suspend mfd: Correct tps65090 cell names mfd: Remove gpio support from tps6586x core driver ARM: tegra: defconfig: Enable tps6586x gpio gpio: tps6586x: Add gpio support through platform driver mfd: Cache tps6586x register through regmap mfd: Use regmap for tps6586x register access. mfd: Use devm managed resources for tps6586x input: Add onkey support for 88PM80X PMIC mfd: Add support for twl6041 mfd: Fix twl6040 revision information mfd: Matches should be NULL when populate anatop child devices input: ab8500-ponkey: Create AB8500 domain IRQ mapping mfd: Add missing out of memory check for pcf50633 Documentation: Describe the AB8500 Device Tree bindings mfd: Add tps65910 32-kHz-crystal-input init mfd: Drop modifying mc13xxx driver's id_table in probe ...
2012-07-30Merge branch 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwmLinus Torvalds
Pull PWM subsystem from Thierry Reding: "The new PWM subsystem aims at collecting all implementations of the legacy PWM API and to eventually replace it completely. The subsystem has been in development for over half a year now and many drivers have already been converted. It has been in linux-next for a couple of weeks and there have been no major issues so I think it is ready for inclusion in your tree." Arnd Bergmann <arnd@arndb.de>: "Very much Ack on the new subsystem. It uses the interface declarations as the previously separate pwm drivers, so nothing changes for now in the drivers using it, although it enables us to change those more easily in the future if we want to. This work is also one of the missing pieces that are required to eventually build ARM kernels for multiple platforms, which is currently prohibited (amongs other things) by the fact that you cannot have more than one driver exporting the pwm functions." Tested-and-acked-by: Alexandre Courbot <acourbot@nvidia.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Philip, Avinash <avinashphilip@ti.com> # TI's AM33xx platforms Acked-By: Alexandre Pereira da Silva <aletes.xgr@gmail.com> # LPC32XX Acked-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Sachin Kamat <sachin.kamat@linaro.org> Fix up trivial conflicts with other cleanups and DT updates. * 'for-3.6' of git://gitorious.org/linux-pwm/linux-pwm: (36 commits) pwm: pwm-tiehrpwm: PWM driver support for EHRPWM pwm: pwm-tiecap: PWM driver support for ECAP APWM pwm: fix used-uninitialized warning in pwm_get() pwm: add lpc32xx PWM support pwm_backlight: pass correct brightness to callback pwm: Use pr_* functions in pwm-samsung.c file pwm: Convert pwm-samsung to use devm_* APIs pwm: Convert pwm-tegra to use devm_clk_get() pwm: pwm-mxs: Return proper error if pwmchip_remove() fails pwm: pwm-bfin: Return proper error if pwmchip_remove() fails pwm: pxa: Propagate pwmchip_remove() error pwm: Convert pwm-pxa to use devm_* APIs pwm: Convert pwm-vt8500 to use devm_* APIs pwm: Convert pwm-imx to use devm_* APIs pwm: Conflict with legacy PWM API pwm: pwm-mxs: add pinctrl support pwm: pwm-mxs: use devm_* managed functions pwm: pwm-mxs: use global reset function stmp_reset_block pwm: pwm-mxs: encode soc name in compatible string pwm: Take over maintainership of the PWM subsystem ...
2012-07-28Merge branch 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linuxLinus Torvalds
Pull embedded i2c changes from Wolfram Sang: "Changes for the "embedded" part of the I2C subsystem: - lots of devicetree conversions of drivers (and preparations for that) - big cleanups for drivers for OMAP, Tegra, Nomadik, Blackfin - Rafael's struct dev_pm_ops conversion patches for I2C - usual driver cleanups and fixes All patches have been in linux-next for an apropriate time and all patches touching files outside of i2c-folders should have proper acks from the maintainers." * 'i2c-embedded/for-next' of git://git.pengutronix.de/git/wsa/linux: (60 commits) Revert "i2c: tegra: convert normal suspend/resume to *_noirq" I2C: MV64XYZ: Add Device Tree support i2c: stu300: use devm managed resources i2c: i2c-ocores: support for 16bit and 32bit IO V4L/DVB: mfd: use reg_shift instead of regstep i2c: i2c-ocores: Use reg-shift property i2c: i2c-ocores: DT bindings and minor fixes. i2c: mv64xxxx: remove EXPERIMENTAL tag i2c-s3c2410: Use plain pm_runtime_put() i2c: s3c2410: Fix pointer type passed to of_match_node() i2c: mxs: Set I2C timing registers for mxs-i2c i2c: i2c-bfin-twi: Move blackfin TWI register access Macro to head file. i2c: i2c-bfin-twi: Move TWI peripheral pin request array to platform data. i2c:i2c-bfin-twi: include twi head file i2c:i2c-bfin-twi: TWI fails to restart next transfer in high system load. i2c: i2c-bfin-twi: Tighten condition when failing I2C transfer if MEN bit is reset unexpectedly. i2c: i2c-bfin-twi: Break dead waiting loop if i2c device misbehaves. i2c: i2c-bfin-twi: Improve the patch for bug "Illegal i2c bus lock upon certain transfer scenarios". i2c: i2c-bfin-twi: Illegal i2c bus lock upon certain transfer scenarios. i2c-mv64xxxx: allow more than one driver instance ... Conflicts: drivers/i2c/busses/i2c-nomadik.c
2012-07-27mfd: Ensure AB8500 platform data is passed through db8500-prcmu to MFD CoreLee Jones
When booting via platform code the AB8500 platform data is now passed in though the DB8500. However, if pdata_size is not set it will not be subsequently passed onto subordinate devices. This patch correctly populates pdata_size. Signed-off-by: Lee Jones <lee.jones@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-27mfd: Arizone core should select MFD_CORESamuel Ortiz
Otherwise, with: CONFIG_MFD_ARIZONA=y CONFIG_MFD_ARIZONA_I2C=m CONFIG_MFD_CORE=m We get: drivers/built-in.o: In function `arizona_dev_init': (.devinit.text+0x3ab0): undefined reference to `mfd_add_devices' drivers/built-in.o: In function `arizona_dev_init': (.devinit.text+0x3fdc): undefined reference to `mfd_add_devices' drivers/built-in.o: In function `arizona_dev_init': (.devinit.text+0x3fff): undefined reference to `mfd_add_devices' drivers/built-in.o: In function `arizona_dev_init': (.devinit.text+0x4059): undefined reference to `mfd_remove_devices' drivers/built-in.o: In function `arizona_dev_exit': (.devexit.text+0x9): undefined reference to `mfd_remove_devices' Reported-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-25mfd: Fix arizona-irq.c build by selecting REGMAP_IRQRandy Dunlap
arizona-irq.c uses functions that are only available when CONFIG_REGMAP_IRQ is enabled, so select that symbol for arizona builds. Fixes these build errors: arizona-irq.c:(.text+0xb2d47): undefined reference to `regmap_irq_get_virq' (.text+0xb2fe3): undefined reference to `regmap_add_irq_chip' (.text+0xb3173): undefined reference to `regmap_del_irq_chip' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-25mfd: Add debug trace on entering and leaving arizone runtime suspendMark Brown
There doesn't appear to be any useful diagnostic information from the core. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-25mfd: Correct tps65090 cell namesVenu Byravarasu
mfd cell names are mistyped as TPS65910 instead of TPS65090. Signed-off-by: Venu Byravarasu <vbyravarasu@nvidia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-25mfd: Remove gpio support from tps6586x core driverLaxman Dewangan
The GPIO functionality of device tps6586x is added through platform gpio driver and it can be register as the mfd sub device and hence removing the duplicates code which register the gpio functionality from core driver. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-25mfd: Cache tps6586x register through regmapLaxman Dewangan
To cache the interrupt mask register, use the regmap RB_TREE cache-ing mechanism in place of implementing it locally. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-25mfd: Use regmap for tps6586x register access.Laxman Dewangan
Using regmap apis for accessing the device registers. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-25mfd: Use devm managed resources for tps6586xLaxman Dewangan
Allocate memory for device state using devm_kzalloc() to simplify accounting and letting the kernel do the garbage-collection. Signed-off-by: Laxman Dewangan <ldewangan@nvidia.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-25mfd: Add support for twl6041Peter Ujfalusi
The delta between twl6040 and twl6041 is small, the main difference is in the number of GPOs (3 on twl6040, 1 on twl6041). Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-23pwm: Conflict with legacy PWM APIThierry Reding
In order to avoid duplicate symbols with legacy PWM API implementations, the new PWM framework needs to conflict with any of the existing legacy implementations. This is done in two ways: for implementations provided by drivers, a conflict is added to the driver to ensure it will have to be ported to the PWM subsystem before it can coexist with other PWM providers. For architecture-specific code, the conflict is added to the PWM symbol to avoid confusion when a previously picked platform or machine can no longer be selected because of the PWM subsystem being included. Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de>
2012-07-19mfd: remove IRQF_SAMPLE_RANDOM which is now a no-opTheodore Ts'o
With the changes in the random tree, IRQF_SAMPLE_RANDOM is now a no-op; interrupt randomness is now collected unconditionally in a very low-overhead fashion; see commit 775f4b297b. The IRQF_SAMPLE_RANDOM flag was scheduled to be removed in 2009 on the feature-removal-schedule, so this patch is preparation for the final removal of this flag. Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: Samuel Ortiz <sameo@linux.intel.com>
2012-07-19random: remove rand_initialize_irq()Theodore Ts'o
With the new interrupt sampling system, we are no longer using the timer_rand_state structure in the irq descriptor, so we can stop initializing it now. [ Merged in fixes from Sedat to find some last missing references to rand_initialize_irq() ] Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Sedat Dilek <sedat.dilek@gmail.com>
2012-07-19mfd: wm831x: Feed the device UUID into device_add_randomness()Mark Brown
wm831x devices contain a unique ID value. Feed this into the newly added device_add_randomness() to add some per device seed data to the pool. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Cc: stable@vger.kernel.org
2012-07-17mfd: Matches should be NULL when populate anatop child devicesRichard Zhao
Signed-off-by: Richard Zhao <richard.zhao@freescale.com> Reviewed-by: Ying-Chun Liu (PaulLiu) <paulliu@debian.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Add missing out of memory check for pcf50633Alan Cox
Resolves-bug: https://bugzilla.kernel.org/show_bug.cgi?id=44561 Reported-by: <rucsoftsec@gmail.com> Cc: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Add tps65910 32-kHz-crystal-input initJohan Hovold
Replace tps65910_misc_init with a dedicated init function for the 32-kHz-crystal input, and make the code more readable. Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Drop modifying mc13xxx driver's id_table in probeUwe Kleine-König
This was introduced in commit 876989d (mfd: Add device tree probe support for mc13xxx) for spi and later while introducing support for i2c copied to the i2c driver. Modifying driver details is very strange, for example probing an mc13892 device (instantiated via dt) removes the driver's ability to handle (traditionally probed) mc13783 devices in this case. I'm not aware of any problems that make this hack necessary and if there were some, they'd have to be fixed in the spi/i2c core, not in a driver. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Remove unneeded io_mutex from struct twl6040Axel Lin
Current code has been converted to use regmap APIs, the io_mutex is not needed. Thus remove the io_mutex. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Remove __devexit annotation for pm80x_deinitAxel Lin
This fixes below section mismatch warning: LD drivers/mfd/built-in.o WARNING: drivers/mfd/built-in.o(.devinit.text+0x46c): Section mismatch in reference from the function pm800_probe() to the function .devexit.text:pm80x_deinit() The function __devinit pm800_probe() references a function __devexit pm80x_deinit(). This is often seen when error handling in the init function uses functionality in the exit path. The fix is often to remove the __devexit annotation of pm80x_deinit() so it may be used outside an exit section. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Fix checking return value of 88pm8xx regmap_read()Axel Lin
Check the return value of regmap_read() rather than the read value. Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Initial support for the WM5110Mark Brown
The WM5110 is a highly-integrated low-power audio system for smartphones, tablets and other portable audio devices. It combines an advanced DSP feature set with a flexible, high-performance audio hub CODEC. The support is based on the Arizona core driver. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Add data tables for the WM5110Mark Brown
The WM5110 is a highly integrated low power audio subsystem for smartphones, tablets and other portable audio devices. It combines an advanced DSP feature set with a flexible, high performance audio hub CODEC. This patch adds data tables for the WM5110. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Add s2mps11 irq driverSangbeom Kim
This patch support irq handling driver for s2mps11. As this patch use regmap_irq, s5m8767 and s5m8763 are modified with regmap_irq. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Add samsung s2mps11 mfd supportSangbeom Kim
This patch add Samsung S2MPS11 mfd driver. The S2MPS11 can support regulators and RTC. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Modify samsung mfd headerSangbeom Kim
As Prefix of Samsung pmic changed from s5m to s2m, To make common mfd driver for s2m and s5m series, This patch rename header of Samsung mfd and modify mfd driver. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Modify samsung mfd driver for common apiSangbeom Kim
Previous naming rule of samsung pmic start with s5m prefix. But It is changed by s2m. To cover various samsung s2m and s5m series, This patch modify function and variable name for common usage. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-16mfd: Rename s5m file and directories to samsungSangbeom Kim
Previously, Samsung PMIC naming rule start with prefix of s5m. But Naming rule is changed. From now on, Prefix will be changed to s2m. So, To support pmic series of s5m and s2m, change mfd file and directory name. Signed-off-by: Sangbeom Kim <sbkim73@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-15Merge tag 'v3.5-rc7' into regulator-driversMark Brown
Linux 3.5-rc7
2012-07-14random: make 'add_interrupt_randomness()' do something saneTheodore Ts'o
We've been moving away from add_interrupt_randomness() for various reasons: it's too expensive to do on every interrupt, and flooding the CPU with interrupts could theoretically cause bogus floods of entropy from a somewhat externally controllable source. This solves both problems by limiting the actual randomness addition to just once a second or after 64 interrupts, whicever comes first. During that time, the interrupt cycle data is buffered up in a per-cpu pool. Also, we make sure the the nonblocking pool used by urandom is initialized before we start feeding the normal input pool. This assures that /dev/urandom is returning unpredictable data as soon as possible. (Based on an original patch by Linus, but significantly modified by tytso.) Tested-by: Eric Wustrow <ewust@umich.edu> Reported-by: Eric Wustrow <ewust@umich.edu> Reported-by: Nadia Heninger <nadiah@cs.ucsd.edu> Reported-by: Zakir Durumeric <zakir@umich.edu> Reported-by: J. Alex Halderman <jhalderm@umich.edu>. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: stable@vger.kernel.org
2012-07-14V4L/DVB: mfd: use reg_shift instead of regstepJayachandran C
Update for change in i2c-ocores.h which uses reg_shift to specify the register offset shifts instead of regstep. Signed-off-by: Jayachandran C <jayachandranc@netlogicmicro.com> Acked-by: Richard Rojfors <richard.rojfors@pelagicore.com> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de>
2012-07-12regulator: tps65217: Add device tree supportAnilKumar Ch
This commit adds device tree support for tps65217 pmic. And usage details are added to device tree documentation. Driver is tested by using kernel module with regulator set and get APIs. Signed-off-by: AnilKumar Ch <anilkumar@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-07-10mfd: Add support for multiple arizona PDM speaker outputsMark Brown
The registers have stride 2 so we can write the loop properly now. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-10mfd: Export pm80x_regmap_configAxel Lin
This fixes below build error when CONFIG_MFD_88PM800=m. ERROR: "pm80x_regmap_config" [drivers/mfd/88pm800.ko] undefined! make[1]: *** [__modpost] Error 1 make: *** [modules] Error 2 Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-10mfd: Guard max77686_pmic_dt_match with CONFIG_OFAxel Lin
This fixes below build warning if CONFIG_OF is not set. CC drivers/mfd/max77686.o drivers/mfd/max77686.c:37:42: warning: 'max77686_pmic_dt_match' defined but not used [-Wunused-variable] Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-09mfd: Error out if initial arizona boot failsMark Brown
2012-07-09mfd: 88pm80[05] i2c device_id arrays should be NULL terminatedSamuel Ortiz
2012-07-09mfd: Add device tree support for max77686Yadwinder Singh Brar
This patch adds device tree support for mfd driver and adds Documentation/devicetree/bindings/mfd/max77686.txt. This patch also intialize max77686 pointer to NULL in max77686_i2c_probe to silent a compile time warning. Signed-off-by: Yadwinder Singh Brar <yadi.brar@samsung.com> Reviwed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-09mfd: Allow to specify max77686 interrupt through DT or platform file alsoYadwinder Singh Brar
Presently driver expects irq_gpio pin in platform data and maps it to irq itself. But we can also directly specify the interrupt in DT or platform file. Signed-off-by: Yadwinder Singh Brar <yadi.brar@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-09mfd: Apply irq_mask_cur before handling max77686 interruptsYadwinder Singh Brar
According to TRM, though we mask the interrupts in interrupt-mask register, interrupt source-register still provide the status of the masked interrupts. So we should apply irq_mask_cur to read interrupt source-register value before handling. Signed-off-by: Yadwinder Singh Brar <yadi.brar@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-09mfd: Use pmic regmap to read max77686 pmic interrupt registerYadwinder Singh Brar
PMIC's regmap should be used to read pmic interrupt registers. Signed-off-by: Yadwinder Singh Brar <yadi.brar@samsung.com> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-09mfd: Move twl-core device_init_wakeup to after platform_device_addNeilBrown
device_init_wakeup uses the dev_name() of the device to set the name of the wakeup_source which appears in /sys/kernel/debug/wakeup_sources. For a platform device, that name is not set until platform_device_add calls dev_set_name. So the call to device_init_wakeup() must be after the call to platform_device_add(). Making this change causes correct names to appear in the wakeup_sources file. Signed-off-by: NeilBrown <neilb@suse.de> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-09mfd: Add companion chip in 88pm80xQiao Zhou
in hw design, 800 is mainly for pmic control, while 805 for audio. but there are 3 registers which controls class D speaker property, and they are defined in 800 i2c client domain. so 805 codec driver needs to use 800 i2c client to access class D speaker reg for audio path management. so add this workaround for the purpose to let 805 access 800 i2c in some scenario. Signed-off-by: Qiao Zhou <zhouqiao@marvell.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2012-07-09mfd: Support 88pm80x in 80x driverQiao Zhou
88PM800 and 88PM805 are two discrete chips used for power management. Hardware designer can use them together or only one of them according to requirement. 88pm80x.c provides common i2c driver handling for both 800 and 805, such as i2c_driver init, regmap init, read/write api etc. 88pm800.c handles specifically for 800, such as chip init, irq init/handle, mfd device register, including rtc, onkey, regulator( to be add later) etc. besides that, 800 has three i2c device, one regular i2c client, two other i2c dummy for gpadc and power purpose. 88pm805.c handles specifically for 805, such as chip init, irq init/handle, mfd device register, including codec, headset/mic detect etc. the i2c operation of both 800 and 805 are via regmap, and 88pm80x-i2c exported a group of r/w bulk r/w and bits set API for facility. Signed-off-by: Qiao Zhou <zhouqiao@marvell.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
